Aurora theme
piokuc
Re: Aurora theme
Post by piokuc »
And when i copy directory aurora to /www/style this theme not working. I must under directory aurora\aurora4-mobile copy file to to directory aurora and theme start working
In backup page button do backup and restore has other style:
fkok
Re: Aurora theme
Post by fkok »
madpatrick wrote: Monday 18 December 2017 6:11 I'm having the same issue.
Tried to clear cache on several ways, restarted the server,....
I see no errors in Chrome
gijsje wrote: Sunday 17 December 2017 22:17 I have the issue that it does not show corect but i have it with all the themes.
I did delete the cache and did try ctrl F5
Any ideas?
Same problem here!! In Safari, Chrome and FireFox....
Phantom
Domoticz version: 4.11652
Re: Aurora theme
Post by Phantom »
The download link is still not working here
Maybe an idea to put it in github?
gajotnt
Domoticz version: V4.9700
Re: Aurora theme
Post by gajotnt »
Amazing Work :O :D
basmaaks
Re: Aurora theme
Post by basmaaks »
can't get it work
copied the files and subdirs to //domoticz/www/styles/aurora, //domoticz/www/styles/aurora/aurora4-mobile, //domoticz/www/styles/aurora4-mobile
don't know wich one is right ?
DarkAllMan
Re: Aurora theme
Post by DarkAllMan »
Same for me
piokuc
Re: Aurora theme
Post by piokuc »
Suggestion
Sub menu Cameras, Users etc should be show when we set poin mouse on MORE OPTION...Like as in sidebar menu. Now is show when we open SETUP menu. This is no good.
Skippiemanz
Domoticz version: 4.10233
Re: Aurora theme
Post by Skippiemanz »
fkok wrote: Monday 18 December 2017 11:34
Any ideas?
It was not working for me to.. But then i checked the zipped folder. in this folder there is a subfolder autora witch contains the actual images etc. This folder needs to be placed in www/styles/ Then it should work
Skippiemanz
Re: Aurora theme
Any ideas?
gajotnt
Re: Aurora theme
Post by gajotnt »
The zip file contains this
_MACOSX
aurora4-mobile
Looking at the other themes, this (aurora4-mobile) must be placed in
\Domoticz\www\styles\aurora4-mobile
but it doenst work correctly (Internet explorer, Edge, Chrome, Firefox) :(
DarkAllMan
Re: Aurora theme
When I download the ZIP it only contains a folder aurora4-mobile and a mac-os folder...
gijsje
Domoticz version: Stable
Re: Aurora theme
Post by gijsje »
If i edit the custom.css and add this it works a bit better but still not as it should be i think.
/* These are the minimal required CSS files for the theme. The rest is loaded via javascript. */
@import url("aurora.css");  /* Don't remove this line! */
@import url("base.css"); /* Don't remove this line! */
@import url("center_popups.css");  /* Don't remove this line! */
@import url("dashboard_camera_previews.css");  /* Don't remove this line! */
@import url("dashboard_highlighted.css");  /* Don't remove this line! */
@import url("dashboard_highlights_see-through.css");  /* Don't remove this line! */
@import url("dashboard_merge_items_with_same_name.css");  /* Don't remove this line! */
@import url("dashboard_move_sun.css");  /* Don't remove this line! */
@import url("dashboard_show_data_visualizations.css");  /* Don't remove this line! */
@import url("dashboard_show_last_update.css");  /* Don't remove this line! */
@import url("dashboard_vertical_columns.css");  /* Don't remove this line! */
@import url("extras_and_animations.css");  /* Don't remove this line! */
@import url("navigation_main_sidebar.css");  /* Don't remove this line! */
@import url("navigation_settings_fixed_tabs.css");  /* Don't remove this line! */
@import url("navigation_settings_sidemenu.css");  /* Don't remove this line! */
@import url("oldbrowser.css");  /* Don't remove this line! */
@import url("show_version_number.css");  /* Don't remove this line! */
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
gajotnt
Re: Aurora theme
Post by gajotnt »
gijsje wrote: Monday 18 December 2017 15:46 If i edit the custom.css and add this it works a bit better but still not as it should be i think.
Looking more like it should, but still alot is missing
gajotnt
Re: Aurora theme
Post by gajotnt »
Had to install Domoticz Beta btw
had to copy images do domoticz\www\images\
zak45
Domoticz version: V2024.4
Re: Aurora theme
Post by zak45 »
Not able to save the settings for the theme, every time I made modification and save, when come back to settings, retreive old (original)values:
niki_lauda
Re: Aurora theme
Post by niki_lauda »
blauwebuis wrote: Sunday 17 December 2017 22:53 Link has been fixed.
@niki_lauda: I made some adjustments, you could try to redownload the theme. I don't have KODI to test it with, so I had to wing it a bit..
@febalci: The theme has been tested on mobile. I recommend choosing 'desktop' mode, and letting the theme create the mobile view.
@gijsje: it looks like a javascript problem. Are you using a javascript blocker? Try: right mouse button -> inspect element -> console and see if you can spot some errors there.
Much better
gajotnt
Re: Aurora theme
Post by gajotnt »
Getting this warning on the chrome console
jquery-1.12.0.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery-1.12.0.min.js:4
niki_lauda
Re: Aurora theme
Very small bug.
If I click the add or remove from dashboard star in the utility tab. the values are shown in the block.
blauwebuis
Domoticz version: current
Re: Aurora theme
Post by blauwebuis »
I have uploaded a new version of the theme. This version is faster (simplifications), and has a better mobile display, which can also be used for the desktop:
@Skippiemanz, @madpatrick, @gijsje: this indicates a javascript problem. Check the console and report any errors. Also, try the new version of the theme. Also, you should probably be on the beta version of domoticz.
@Phantom I tested the download link, it should work.
@piokuc thank you for your help!
- I've made it so that long words are not broken into multiple lines.
- I could style the buttons for backup and restore. hmm.
@zak45 settings are stored both inside domoticz and in the 'local storage' of the browser.
- If you can change colors, and these changes are still there when you reload the page, then local storage is working.
- Check if you have a "theme-aurora" variable under your User Variables. This stores all the features' ID's. For example, here's mine:
[2,4,5,6,7,8,9,10,11,12,13,14,16,17]
The numbers correspond to the feature ID"s which you can find inside theme.json.
@niki_lauda
- Glad to hear the remote works now. Is it just better, or actually working ok?
- I've made the theme respond quicker to making an item a favourite. Thanks!
bing69
Re: Aurora theme
Post by bing69 »
What ever i try i get this in chrome, safari , IE; I dont now what to do??
Clear cache etc.
