Page 2 of 3
Re: Persistent data as a variable
Posted: Sunday 18 November 2018 21:26
by waaren
pvklink wrote: Sunday 18 November 2018 11:32 @waaren GREAT, Thanks!
I changed the script with 2 devices and one does work!, have two questions.
1) dz.data.sensors[name] is rizing even when the current usage huidwaarde is lower then watt (see the below log)
Is that no problem ?
2) the script only starts sensor buro
my sensor droger isnt reachable(to far away at the time) could that be the problem, because i dont see an error that it isnt reachable...
@pvklink, Hi Peter,
1) Should not be a problem if you use the device more then once a year :D . The counter is reset to 0 when the kwH rises above the usage fence.
2) If the second sensor is not reachable it will not trigger the script. Not a problem but not very useful either.
Posted: Sunday 18 November 2018 21:37
by pvklink
@waaren
Both work! THANKKKKKS
I also used SwitchTimeOutMinutes for the timeout period. i use the counter for this and i adjust the hard values =1, =2 and >2 for the counter
and i made the notificationsounds flexibel.
Peter
local USAGE_SENSORS = {
    ['buro_kwh'] = 'buro_kwh',                -- Adjust to your needs. Between every line you need to add a ",".
    ['wasmachine_kwh'] = 'wasmachine_kwh',                -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_SWITCHES = {
    ['buro_kwh'] = 'buro',                     -- Name of device that switch kw_1 On/ Off
    ['wasmachine_kwh'] = 'wasmachine',                     -- Name of device that switch kw_1 On/ Off
local USAGE_SwitchTimeOutMinutes = {
    ['buro_kwh'] = 4,                              -- Adjust to your needs. Between every line you need to add a ",".
    ['wasmachine_kwh'] = 4,                              -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_MaxWatt = {
    ['buro_kwh'] = 2,                    -- Adjust to your needs. Between every line you need to add a ",".
    ['wasmachine_kwh'] = 2,                    -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_SwitchOnOff = {
    ['buro_kwh'] = 'Yes',                -- Adjust to your needs. Between every line you need to add a ",".
    ['wasmachine_kwh'] = 'Yes',                -- Adjust to your needs. Between every line you need to add a ",".
local USAGE_Notify = {
local USAGE_Pushoverreceivers = {
    ['buro_kwh'] = '',
    ['wasmachine_kwh'] = '',
local USAGE_Pushoversound = {
    ['buro_kwh'] = 'bike',
    ['wasmachine_kwh'] = 'bike',
    on = { devices = USAGE_SENSORS },
    logging = { level   = domoticz.LOG_DEBUG ,                   -- Uncomment to override the dzVents global logging setting
                marker  = actOnIdleDevices
    data = { sensors              = { initial  = {} } },
    execute = function(dz, device)
        local name = device.name
        if dz.data.sensors[name] == nil then
            dz.data.sensors[name] = 0
        local switch        = dz.devices(USAGE_SWITCHES[name])
        local timeout       = USAGE_SwitchTimeOutMinutes[USAGE_SENSORS[name]]
        local watt          = USAGE_MaxWatt[USAGE_SENSORS[name]]
        local onoff         = USAGE_SwitchOnOff[USAGE_SENSORS[name]]
        local notify        = USAGE_Notify[USAGE_SENSORS[name]]
        local receivers     = USAGE_Pushoverreceivers[USAGE_SENSORS[name]]
        local sound         = USAGE_Pushoversound[USAGE_SENSORS[name]]
        local huidwaarde    = device.WhActual
        dz.log("00 Sensor device        = " .. name)
        dz.log("00 Sensor onoff         = " .. onoff)
        dz.log("00 Sensor notify        = " .. notify)
        dz.log("00 Sensor receivers     = " .. receivers)
        dz.log("00 Sensor sound         = " .. sound)
        dz.log("00 Sensor timeout       = " .. timeout)
        dz.log("00 Sensor watt          = " .. watt)
        dz.log("00 Sensor teller eronder= " .. tostring(dz.data.sensors[name]))
        dz.log("00 Sensor huidwaarde    = " .. tostring(huidwaarde))
        dz.log(dz.data.sensors[name],dz.LOG_DEBUG)
        dz.log("---------------------------------------")
        if  huidwaarde <= watt then
            dz.log("01 Sensor info         = Oude en huidige waarde zijn onder de norm")
            dz.data.sensors[name] = dz.data.sensors[name] + 1
            if dz.data.sensors[name] < timeout then
                dz.log("02 Sensor info         = Nu nog geen actie omdat de timeout limiet nog niet is bereikt")
            elseif dz.data.sensors[name] == timeout then
                dz.log("03 Sensor info         = Oude en huidige waarde zijn onder norm en gelijk aan de timeout dus actie")
                if onoff == 'Yes' then
                    dz.log("03a Sensor info         = Oude en huidige waarde zijn onder norm en gelijk aan de timeout, device wordt uitgezet")
                    switch.switchOff().checkFirst().silent()
                if notify == 'Yes' then
                    dz.log("03b Sensor info         = Oude en huidige waarde zijn onder norm en gelijk aan de timeout, er wordt een notificatie gestuurd")
                        dz.notify(    'dz: ' .. name .. ' is gereed',
                                            name,
                                            PRIORITY_NORMAL,
                                            sound,
                                            receivers,
                                            dz.NSS_PUSHOVER
            elseif dz.data.sensors[name] > timeout then
                dz.log("04 Sensor info         = Oude en huidige waarde zijn onder norm maar acties zijn al gedaan dus niets meer doen")
            dz.log("05 Sensor info         = Huidig waarde boven norm dus reset van idlecounter")
Posted: Sunday 18 November 2018 21:54
by waaren
pvklink wrote: Sunday 18 November 2018 11:32 I changed the variables in the script with 2 devices and both work! THANKKKKKS
Is it ok that USAGE_SENSORS uses the same values on the left and right side of the comparison?
I don't see any line where you compare USAGE_SENSORS against USAGE_SENSORS. Can you elaborate which line you have in mind when asking this ?
and
Can you have a quick look if this makes sense ?
Looks OK to me
Only thing i cant get to work is that when my wasmachine_kwh is ready wasmachine is used as text for notify instead of wasmachine_kwh (or other device_kwh names)
Should work if you add
name = USAGE_SWITCHES[name]
direct after the line
Posted: Sunday 18 November 2018 22:34
by pvklink
This was the line where left is right comparison, looks kind a strange... but works great
Rest is working GREAT
Posted: Sunday 18 November 2018 23:12
by waaren
pvklink wrote: Sunday 18 November 2018 22:34 This was the line where left is right comparison, looks kind a strange... but works great
OK understand your confusion now.
The line
is actually not a comparison but an assignment where you assign the value "buro_kwh" to the key "buro_kwh" in the table USAGE_SENSORS
from Programming in Lua "The table type ... can be indexed not only with numbers, but also with strings or any other value of Lua, except nil"
Posted: Monday 19 November 2018 13:39
by pvklink
@waaren
Everything works perfect :D
Here is the finanal usage_script based(99,9999%) on the script from @waaren.
Thanks for your help!
Peter
    ['buro_kwh'] = '',
        local name2 = USAGE_SWITCHES[name]
                        dz.notify(    'dz: ' .. name2 .. ' is gereed',
                                            name,
                                            PRIORITY_NORMAL,
                                            sound,
                                            receivers,
                                            dz.NSS_PUSHOVER
Posted: Saturday 08 December 2018 13:11
by pvklink
I made a script for an electric heater, sort of antifrostdevice.
It has a thermostatic powermechanisme. When it uses 13 watt is is working. when it uses 1 watt it is problably in thermo-mode.
I stick the thermo in a zwave switch with powermeasuring.
I check every hour when the zwaveswitch is on (another scripts that puts the switch on when temp is below 3 gr, this part works!)
if this devices consumes power when it does it is ok, nothing broken, when it dont, it is broken or in thermostate...
Problems
018-12-08 14:09:03.300 Status: dzVents: Info: ------ Start internal script: testxxx: Device: "buro_kwh (zwavepluspvk)", Index: 458
2018-12-08 14:09:03.301 Status: dzVents: Error (2.4.9): An error occured when calling event handler testxxx
2018-12-08 14:09:03.301 Status: dzVents: Error (2.4.9): /home/pi/domoticz/dzVents/runtime/Domoticz.lua:165: attempt to perform arithmetic on local 'x' (a nil value)
2018-12-08 14:09:03.301 Status: dzVents: Info: ------ Finished testxxx
-- test met stroomlint
-- boven maxwatt dan werkt t lint
-- onder maxwatt en geijk aan switchoutminutes dan is het lint mogelijk kapot of is toch de thermostaat aan. dan is maxwatt niet juist gekozen
local USAGE_DEVICES = {
    ['buro_kwh'] = 88,                    -- Adjust to your needs. Between every line you need to add a ",".
    ['buro_kwh'] = '',
    ['buro_kwh'] = 'siren',
    on = {devices = USAGE_DEVICES,
    data    =   {
                    prevhistwaarde  = { history = true, maxItems = 10 },
                    sensors         = { initial  = {} },
        if dz.data.prevhistwaarde.getOldest() == nil then  -- Check if history is already filled (initial does not work with history persistent data
          dz.data.prevhistwaarde.add(100)
        local huidwaarde    = dz.utils.round(device.temperature,1)
        local prevwaarde    = dz.utils.round(dz.data.prevhistwaarde.getLatest().data,1)
        local timeout       = USAGE_SwitchTimeOutMinutes[USAGE_DEVICES[name]]
        local watt          = USAGE_MaxWatt[USAGE_DEVICES[name]]
        local notify        = USAGE_Notify[USAGE_DEVICES[name]]
        local receivers     = USAGE_Pushoverreceivers[USAGE_DEVICES[name]]
        local sound         = USAGE_Pushoversound[USAGE_DEVICES[name]]
        dz.log("00 Sensor vorige waarde = " .. prevwaarde)
        dz.log("00 Sensor huidwaarde    = " .. huidwaarde)
       for i = dz.data.prevhistwaarde.size,1,-1 do
            item = dz.data.prevhistwaarde.get(i)
            dz.log("00 History data van " .. item.time.rawDate .. " " .. item.time.rawTime ..
                                    " = " .. item.data .. " graden")
         if dz.devices("buro").state == 'On' then
                dz.log("01 Sensor info         = Huidige waarde is onder de norm, dus lint werkt niet of thermostaat staat aan")
                        dz.log("03b Sensor info         = Huidige waarde is onder de norm en gelijk aan de timeout, er wordt een notificatie gestuurd")
                                            name,
                                            PRIORITY_NORMAL,
                                            sound,
                                            receivers,
                                            dz.NSS_PUSHOVER
                dz.log("05 Sensor info         = Huidig waarde boven norm, lint gebruikt stroom dus reset van idlecounter")
Posted: Saturday 08 December 2018 14:36
by waaren
pvklink wrote: Saturday 08 December 2018 13:11 Problems
What I think goes wrong here is that the script calls the function dz.utils.round with a nil value. the device is a kwh device but the call to the round function is with the temperature which likely is nil here.
Try replacing the line l
with
dz.log("00 Sensor temperature   = " .. tostring(device.temperature))
dz.log("00 Sensor usage         = " .. tostring(device.usage))
local huidwaarde    = dz.utils.round(device.usage,1)
Posted: Saturday 08 December 2018 15:10
by pvklink
you were wright(again). Script is running!
Posted: Monday 10 December 2018 18:36
by pvklink
Script is running fine!
There is one thing i like to uptimize, but to difficult for me.
I use dz.data.sensors[name] as a counter and when it reaches USAGE_DurTimer then a notification could be send.
The number of USAGE_DurTimer is a value that represense time. Is it possible to use actuel time?
Example:
When the first value of dz.data.sensors[name] is created, it also has a timestamp X.
USAGE_DurTimer could be something like '04:00:00' (4 hours) and notification is send when currentime >timestamp X + '04:00:00'
-- evt kijken naar tijdstip van teller =1 en dan waarde in uren
-- ipv huidwaarde en prevwaarde de laatste 5 waarde nemen om pieken te voorkomen, historie op 5 zetten en die nemen
-- https://github.com/dannybloe/dzVents
local USAGE_Watt = {
    ['buro_kwh'] = 110,                    -- There is powerconsumption
local USAGE_DurTimer = {
    ['buro_kwh'] = 20,                   -- There is powerconsumption
    ['buro_kwh'] = 'galaxya52017',
    data    =   {
                    prevhistwaarde  = { history = true, maxHours = 4 },     --Deze tijdspanne moet je juist kiezen zodat het lint ook de kans krijgt om aan te gaan en boven t gemiddelde te komen
                    sendnotification = {initial = {}},
          dz.data.prevhistwaarde.add(0)  -- eerste waarde op 0 gezet
            dz.data.sensors[name] = 0       -- eerste waarde teller op 0 gezet  -- geen notify gedaan
        if dz.data.sendnotification[name] == nil then
            dz.data.sendnotification[name] = false       -- eerste waarde teller op false gezet  -- geen notify gedaan
        local prevwaarde    = dz.utils.round(dz.data.prevhistwaarde.getLatest().data,1)             --local prevwaarde5   = dz.utils.round(dz.data.prevhistwaarde.get(5).data,1)
        local gemwaarden    = dz.utils.round(dz.data.prevhistwaarde.avgSince('00:05:00'),1)
        local avgwaarde     = dz.utils.round(dz.data.prevhistwaarde.avg(),1)
        local watt          = USAGE_Watt[USAGE_DEVICES[name]]
        local DurTimer      = USAGE_DurTimer[USAGE_DEVICES[name]]
        local minwaarde     = dz.utils.round(dz.data.prevhistwaarde.min(),1)
        local maxwaarde     = dz.utils.round(dz.data.prevhistwaarde.max(),1)
            dz.log("00 History data van " .. item.time.rawDate .. " " .. item.time.rawTime .. " = " .. item.data .. " watt")
        dz.log("00 Sensor kwh device    = " .. name)
        dz.log("00 Sensor switch device = " .. name2)
        dz.log("-------------------------------------------------")
        dz.log("00 Sensor watt norm     = " .. watt)
        dz.log("00 Sensor notif. norm   = " .. DurTimer)
        dz.log("00 Sensor notif. teller = " .. tostring(dz.data.sensors[name]))
        dz.log("00 Sensor huidige waarde= " .. huidwaarde)
        dz.log("00 Sensor gemid. 5min   = " .. gemwaarden)
        dz.log("00 Sensor gemid. hist   = " .. avgwaarde)
        dz.log("00 Sensor minimum waarde= " .. minwaarde)
        dz.log("00 Sensor maximum waarde= " .. maxwaarde)
        dz.log("00 Status notificatie   = " .. tostring(dz.data.sendnotification[name]))
        dz.data.prevhistwaarde.add(huidwaarde)
         if dz.devices(name2).state == 'On' then
            if  gemwaarden <= watt then
                dz.log("01 Sensor info         = Huidig gem waarde(".. gemwaarden ..") is onder de norm(".. watt .. "), device: " .. name ..  "")
                if dz.data.sensors[name] < DurTimer  then
                    dz.log("04 Sensor info         = Timerperiode(".. tostring(DurTimer) .. ") is nog niet verstreken, huidige timer is: (" .. dz.data.sensors[name] .. ")")
                elseif dz.data.sensors[name] == DurTimer then
                    dz.log("03 Sensor info         = Verbruik van device: " .. name ..  " is lange tijd onder de norm, mogelijk is deze kapot!")
                    if (notify == 'Yes') and (dz.data.sendnotification[name] == false) then
                        dz.notify('03 Sensor info         = Gemiddeld verbruik('.. gemwaarden .. ') van device:' .. name2 .. ' is lange tijd('.. tostring(DurTimer) .. '), onder de norm('.. watt .. '), mogelijk is deze kapot!',
                        name,PRIORITY_NORMAL,sound,receivers,dz.NSS_PUSHOVER)
                        dz.data.sendnotification[name] = true       -- eerste waarde teller op 0 gezet  -- registreren dat notificatie is gedaan
                    dz.log("04 Sensor info         = Timerperiode(".. tostring(DurTimer) .. ") is al voorbij(" .. dz.data.sensors[name] .. "), Gemmideld verbruik(" .. gemwaarden .. ") van device: " .. name ..  " is  lange tijd onder de norm(".. watt .. "), mogelijk is deze kapot!")
            elseif gemwaarden > watt then
                --dz.data.prevhistwaarde.reset()
                dz.log("05 Sensor info         = Gemiddeld verbruik van device: " .. name ..  " met huidig waarde(".. gemwaarden ..") is boven de norm(".. watt .. "), device: " .. name ..  " gebruikt stroom")
Posted: Tuesday 11 December 2018 2:58
by waaren
pvklink wrote: Monday 10 December 2018 18:36 There is one thing i like to optimize. I use dz.data.sensors[name] as a counter and when it reaches USAGE_DurTimer then a notification could be send.The number of USAGE_DurTimer is a value that represense time. Is it possible to use actuel time?
Could be something like the code below ** Untested so keep current script in a safe place.
    ['buro_kwh'] = 1800,                -- Timer in seconds
    data    =   {
		local rawTime       = dz.data.sensors[name .. "_rawTime"] or ""
				local now = os.time(os.date('*t'))
				if dz.data.sensors[name] == 0 then
					dz.data.sensors[name] = now
					dz.data.sensors[name .. "_rawTime"] = dz.time.rawTime
					rawTime = dz.time.rawTime
                if dz.data.sensors[name] > ( now - DurTimer ) then
                    dz.log("04 Sensor info         = Timerperiode(".. tostring(DurTimer) .. ") is nog niet verstreken, huidige timer is set at: (" .. rawTime .. ")")
                elseif dz.data.sensors[name] < ( now - DurTimer) then
                        dz.notify('03 Sensor info         = Gemiddeld verbruik('.. gemwaarden .. ') van device:' .. name2 .. ' is lange tijd('.. tostring(DurTimer) .. ' seconden), onder de norm('.. watt .. '), mogelijk is deze kapot!',
				dz.data.sensors[name].rawTime = nil
Posted: Tuesday 11 December 2018 8:25
by pvklink
Hi, Thanks!
I just tested it, got some errors and used your tricks to rewrite it a bit with a new variable in the data section for timer functions
data = {pvktimer = {initial = {}},
Everything seems to work great, many thanks to yoy @Waaren on behalve of my father in law, his waterpipes wont freeze this winter!
Last thing to do, is to publish time of the lines below not as a number but als actual time, is that possible?
My experience is dat dat/time conversion are terrible
dz.log("00 Notificatie.huidige tijd..............= " .. tostring(now))
dz.log("00 Notificatie.timer.....................= " .. tostring(dz.data.pvktimer[name]))
Can you take a final look at the code, if this is a decent workout?
Again, many thanks for your help, i am not a programmer, but with a little help i can make some spagetti-code :D
I am almost ready to convert all of my old lua-scripts in dzventz!
    --['Verbruikwarmtelint'] = 'Verbruikwarmtelint',                -- Adjust to your needs. Between every line you need to add a ",".
    --['Verbruikwarmtelint'] = 'stroomlint',          -- Name of device that switch kw_1 On/ Off
    --['Verbruikwarmtelint'] = 1,                    -- There is powerconsumption
    ['buro_kwh'] = 300,                   --in seconden, tijd dat gemiddeld gebruik onder de norm zit, na deze periode evt n notificatie
    --['Verbruikwarmtelint'] = 200,
   -- ['Verbruikwarmtelint'] = 'Yes',
    --['Verbruikwarmtelint'] = 'galaxya52017',
    --['Verbruikwarmtelint'] = 'siren',
    on = {devices = USAGE_SENSORS,
    data    =   {
                    prevhistwaarde  = { history = true, maxHours = 1 },     --
        local watt          = USAGE_Watt[USAGE_SENSORS[name]]
        local DurTimer      = USAGE_DurTimer[USAGE_SENSORS[name]]
        if dz.data.pvktimer[name] == nil then
            dz.data.pvktimer[name] = '0'       --eerste waarde op 0 gezet
        dz.log("Deviceinfo-----------------------------------------")
        dz.log("00 Kwh-device............................= " .. name)
        dz.log("00 Switch-device.........................= " .. name2)
        dz.log("Verbruikinfo---------------------------------------")
        dz.log("00 Verbruik.norm.........................= " .. watt)
        dz.log("00 Verbruik.gemid. 5min..................= " .. gemwaarden)
        dz.log("00 Verbruik.vorige waarde................= " .. prevwaarde)
        dz.log("00 Verbruik.gemid. hist..................= " .. avgwaarde)
        dz.log("00 Verbruik.minimumwaarde................= " .. minwaarde)
        dz.log("00 Verbruik.maximumwaarde................= " .. maxwaarde)
        dz.log("Notificatie-----------------------------------------")
        dz.log("00 Notificatie.norm(in.min)..............= " .. DurTimer/60)
        if now <= tonumber(dz.data.pvktimer[name]) then
            dz.log("00 Notificatie.timer resterend (in.sec)..= " .. tostring(dz.utils.round(tonumber(dz.data.pvktimer[name]) - now,1)))
            dz.log("00 Notificatie.timer resterend (in.sec)..= " .. '0')
        dz.log("00 Notificatie.verzonden.................= " .. tostring(dz.data.sendnotification[name]))
        dz.log("00 Notificatie.teller....................= " .. tostring(dz.data.sensors[name]))
        dz.log("00 Notificatie.aan.......................= " .. notify)
        dz.log("00 Notificatie.receivers.................= " .. receivers)
        dz.log("00 Notificatie.sound.....................= " .. sound)
        dz.log("---------------------------------------------------")
                dz.log("01 Sensor info         = Gemiddeld verbruik van device: " .. name ..  " met huidig gemiddeld verbruik: (".. gemwaarden ..") is onder de norm(".. watt .. ")")
	                dz.data.pvktimer[name] = tostring(now+DurTimer)
                if tonumber(now)  < ( tonumber(dz.data.pvktimer[name])) then
                    dz.log("02 Sensor info         = Timerperiode(".. tostring(DurTimer/60) .. "Min) is nog niet verstreken, huidige timer is set at: (" .. dz.data.pvktimer[name] .. ")")           --TOEVOEGING
                    if (dz.data.sendnotification[name] == false) then
                        dz.log("03 Sensor info         = Gemiddeld verbruik van device: " .. name ..  " is lange tijd onder de norm, deze is defect!")
                        if (notify == 'Yes') then
                            dz.notify('03 Sensor info         = Gemiddeld verbruik('.. gemwaarden .. ') van device:' .. name2 .. ' is lange tijd('.. tostring(DurTimer/60) .. 'min), onder de norm('.. watt .. '), deze is defect!',
                        dz.log("04 Sensor info         = Gemiddeld verbruik(".. gemwaarden .. ") van device:" .. name2 .. " is lange tijd(".. tostring(DurTimer/60) .. "min), onder de norm(".. watt .. "), deze is defect! melding is reeds verzonden")
                dz.log("05 Sensor info         = Gemiddeld verbruik van device: " .. name ..  " met huidig gemiddeld verbruik: (".. gemwaarden ..") is boven de norm(".. watt .. "), en werkt dus correct")
Posted: Tuesday 11 December 2018 22:31
by waaren
pvklink wrote: Tuesday 11 December 2018 8:25 Last thing to do, is to publish time of the lines below not as a number but als actual time, is that possible?
To get a time string you can change this to
        dz.log("00 Notificatie.huidige tijd..............= " .. os.date("%X", now))
        dz.log("00 Notificatie.timer.....................= " ..os.date("%X",dz.data.pvktimer[name]))
Posted: Tuesday 11 December 2018 23:30
by pvklink
Ok, this is much more easier then expected! THANKS agaian!
Almost ready with converting all my LUA scripts
Never asked the question if dzventz is a beter scripting language, but it looks more powerful...
Posted: Wednesday 12 December 2018 0:49
by waaren
pvklink wrote:Ok, this is much more easier then expected! THANKS agaian!
dzVents is 100% Lua
Posted: Wednesday 12 December 2018 10:59
by pvklink
Got it almost working, one strange thing, see output:
us: dzVents: Info: Notificatie-----------------------------------------
2018-12-12 10:55:27.646 Status: dzVents: Info: 00 Notificatie.norm(in.min)............= 5
2018-12-12 10:55:27.647 Status: dzVents: Info: 00 Notificatie.huidige tijd..............= 10:55:27
2018-12-12 10:55:27.647 Status: dzVents: Info: 00 Notificatie.eind tijd.................= 10:55:57
2018-12-12 10:55:27.647 Status: dzVents: Info: 00 Notificatie.resterende tijd.........= 01:00:30
2018-12-12 10:55:27.647 Status: dzVents: Info: 00 Notificatie.verzonden..............= false
2018-12-12 10:55:27.647 Status: dzVents: Info: 00 Notificatie.teller.....................= 77
The difference between curent time and timer was at this moment 30 seconds
At line 4 you see: 01:00:30, an hour and 30 seconds!
It works great, it does give a notification at 10:55:57, so it must be the presentation of the variable
I have all my LUA scripts rewritten, i am finished! Thanks @Waaren, no more LUA for me...
ANd they work with my raspberry pi google home assistent!
-- boven norm dan werkt t lint
-- onder norm en geijk aan switchoutminutes dan is het lint mogelijk kapot of is toch de thermostaat aan. dan is norm niet juist gekozen
local USAGE_Norm = {
    ['buro_kwh'] = 300,                   --in seconden, tijd dat gemiddeld gebruik onder de norm zit, na deze periode evt n notificatie, 300 is 5 minuten
    on = {devices = USAGE_SENSORS,},
    logging = { level   = domoticz.LOG_DEBUG ,marker  = actOnIdleDevices },
    data    =   {
        local norm          = USAGE_Norm[USAGE_SENSORS[name]]
            dz.log("00 History data van " .. item.time.rawDate .. " " .. item.time.rawTime .. " = " .. item.data .. " norm")
        dz.log("00 Verbruik.norm.........................= " .. norm)
        dz.log("00 Verbruik.huidige waarde...............= " .. huidwaarde)
        if tonumber(dz.data.pvktimer[name]) == 0 then
            dz.log("00 Notificatie.eind tijd.................= " .. 'n.v.t.')
            dz.log("00 Notificatie.eind tijd.................= " .. os.date("%X",dz.data.pvktimer[name]))
            dz.log("00 Notificatie.resterende tijd...........= " .. os.date("%X",dz.data.pvktimer[name] - now))
            dz.log("00 Notificatie.resterende tijd...........= " .. 'n.v.t.')
        --dz.data.prevhistwaarde.add(huidwaarde)
            if  gemwaarden <= norm then
                dz.log("01 Sensor info         = Gemiddeld verbruik van device: " .. name ..  " met huidig gemiddeld verbruik: (".. gemwaarden ..") is onder de norm(".. norm .. ")")
                            dz.notify('03 Sensor info         = Gemiddeld verbruik('.. gemwaarden .. ') van device:' .. name2 .. ' is lange tijd('.. tostring(DurTimer/60) .. 'min), onder de norm('.. norm .. '), deze is defect!',
                        dz.log("04 Sensor info         = Gemiddeld verbruik(".. gemwaarden .. ") van device:" .. name2 .. " is lange tijd(".. tostring(DurTimer/60) .. "min), onder de norm(".. norm .. "), deze is defect! melding is reeds verzonden")
            elseif gemwaarden > norm then
                dz.log("05 Sensor info         = Gemiddeld verbruik van device: " .. name ..  " met huidig gemiddeld verbruik: (".. gemwaarden ..") is boven de norm(".. norm .. "), en werkt dus correct")
Posted: Wednesday 12 December 2018 21:50
by waaren
pvklink wrote: Wednesday 12 December 2018 10:59 Got it almost working, one strange thing, see output:
This is not how to use the os.date function. Here you ask this function to show the timeString 30 seconds after epoch (Google for epoch linux and for os.date Lua)
What you probably want is in the code below. Please note that I added a function to convert the seconds to a timeString
    data    =   {
        local function secondsToClock(sec)
          local seconds = tonumber(sec)
          if seconds <= 0 then
            return "00:00:00"
            hours = string.format("%02.f", math.floor(seconds/3600))
            mins = string.format("%02.f", math.floor(seconds/60 - (hours*60)))
            secs = string.format("%02.f", math.floor(seconds - hours*3600 - mins *60))
            return hours..":"..mins..":"..secs
            -- dz.log("00 Notificatie.resterende tijd...........= " .. os.date("%X",dz.data.pvktimer[name] - now))
            dz.log("00 Notificatie.resterende tijd...........= " .. secondsToClock(dz.data.pvktimer[name] - now))
Posted: Wednesday 12 December 2018 22:57
by pvklink
Unbelievable how you know this so quickly....
I am going to update and look!
Posted: Wednesday 12 December 2018 23:09
by pvklink
t werkt......HELEMAAL PERFECT!
sorry, it Works PERFECT!
All my LUA's are gone now, Everybody thanks, specially @Waaren who did the most work !
My next job is to let my self made google speaker(raspberry with SDK) speak by a domoticz command...
I posted this in a new thread, first try is with the chromecast plugin....
Posted: Thursday 13 December 2018 10:14
by pvklink
I Copied my scripts to the environment of my father in law. Main target is to protect is waterpipes against frost.
So two dzventz script
a) temperature measurement to activate the switch below 4c
b) switch usage to measure if the heating works
I installed them both. The temperature was working direct!
I get errors with the second script with a nil value. No variable is mentioned in the logging and there was a line mentioned but my script does not have so much lines.
After lot of searching i saw that my script uses
and the device with my father in law says Usage electric so i think thats:
local huidwaarde = dz.utils.round(device.WhActual,1)
Does it makes any different qua functionality ?
