Page 2 of 2
Re: Stability with Python Plugins
Posted: Sunday 24 December 2017 10:23
by micha_pr
2017-12-24 10:03:06.094 Error: Domoticz received fatal signal 11 !...
2017-12-24 10:03:06.094 Error: Domoticz received fatal signal 11 while backtracing !...
2017-12-24 10:03:06.099 Error: /home/pi/domoticz/domoticz() [0x236be4]
2017-12-24 10:03:06.099 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x236c9c]
2017-12-24 10:03:06.099 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76c04180]
2017-12-24 10:20:58.128 Error: Domoticz received fatal signal 6 !...
2017-12-24 10:20:58.131 Error: /home/pi/domoticz/domoticz() [0x236be4]
2017-12-24 10:20:58.131 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x236c9c]
2017-12-24 10:20:58.131 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76cd0180]
2017-12-24 10:20:58.131 Error: /lib/arm-linux-gnueabihf/libc.so.6(gsignal+0x38) [0x76ccef70]
But without the "CConnection" line in this time...
(version 3.8796)
Posted: Monday 25 December 2017 15:50
by micha_pr
Not sure why,... but I made a second installation now with Stretch and new Python version - now all is stable since more than two hours.
It was not possible before.
At other installation nothing else was installed - it was also a minimal system with Z-Wave-stick only for plugin testing, but Jessie with Python version 3.4.2.
Using Beta 3.8796.
Posted: Tuesday 26 December 2017 0:02
by Noudje
I also have less problems with a complete new install on Stretch. All plugins work great!!! Also the Kodi plugin is better then the standard interface
I only have sometimes problems with Connections. Last I did 'import urllib.request' and the plugin didn't work. I commented out this line and the plugin was working again. I have to investigate this again, also because something is changed during the last update.
Posted: Wednesday 27 December 2017 16:28
by micha_pr
I have seen that any enabled Python Event (the integrated one in Event system with Lua, Blockly...) will cause this error.
Even if enable the sample code the signal 11 error will come up.
It's not easy to go back - because system hang very fast...
Enable sample event:
2017-12-27 16:21:38.559 EventSystem: reset all events...
2017-12-27 16:21:39.249 Error: Domoticz received fatal signal 11 !...
2017-12-27 16:21:39.251 Error: /home/pi/domoticz/domoticz() [0x236be4]
2017-12-27 16:21:39.251 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x236c9c]
2017-12-27 16:21:39.251 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76be06b0]
restarting Domoticz - all is ok, while not python event will be fired:
2017-12-27 16:23:35.646 RxQueue: queue worker started...
2017-12-27 16:23:35.757 Incoming connection from: 192.168.178.185
2017-12-27 16:23:37.646 Hardware Monitor: Started
2017-12-27 16:23:37.662 EventSystem: reset all events...
2017-12-27 16:23:37.663 EventSystem: reset all device statuses...
2017-12-27 16:23:37.801 Python EventSystem: Initalizing event module.
2017-12-27 16:23:37.802 EventSystem: Queue thread started...
2017-12-27 16:23:37.802 EventSystem: Started
2017-12-27 16:23:38.039 PluginSystem: Entering work loop.
2017-12-27 16:24:00.433 Error: Domoticz received fatal signal 11 !...
2017-12-27 16:24:00.435 Error: /home/pi/domoticz/domoticz() [0x236be4]
2017-12-27 16:24:00.435 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x236c9c]
2017-12-27 16:24:00.435 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c4f6b0]
-> Disable python event, all is ok again...
Posted: Friday 29 December 2017 9:00
by Dnpwwo
@micha_pr ,
Can you post the event source that used and if you stored it in a file or the database.
I will try and reproduce it if you do.
Posted: Friday 29 December 2017 10:15
by micha_pr
Dnpwwo wrote: Friday 29 December 2017 9:00
@micha_pr ,
I have used for testing the sample code (with setting "All") only-
Posted: Saturday 30 December 2017 6:51
by Dnpwwo
@micha_pr,
Thanks. I used the sample as you suggested and could easily get Domoticz to crash quite reliably which was great (kind of
Anyway I found an issue in the event system where it was potentially clashing with the Plugin Framework and resolved it. I also found some places where the Plugin Framework was not locking properly either.
I've pushed an update so it will be in the next beta, fingers crossed
Posted: Tuesday 02 January 2018 11:55
by micha_pr
@Dnpwwo:
In 3.8798 I have still same problem - not sure, your patch is inside?
Posted: Friday 05 January 2018 6:10
by Dnpwwo
@micha_pr,
I assume so but I don't run betas (I build from source).
That said, there are 21 outstanding pull requests so may gizmocuz has taken an Xmas holiday.
Posted: Saturday 06 January 2018 16:49
by micha_pr
Just updated to 3.8799 - at Stretch with Python 3.5.3
Removed the running Python plugin - and created a new integrated Python event - have taken the sample event - not with "All" but in this time with "Device"
Changed a dummy device level - and got again this:
2018-01-06 16:37:40.461 EventSystem: reset all events...
2018-01-06 16:37:58.759 User: Admin initiated a switch command (33/test-selector/Set Level)
2018-01-06 16:37:58.780 (dummy) Light/Switch (test-selector)
2018-01-06 16:37:58.892 Error: Domoticz received fatal signal 11 !...
2018-01-06 16:37:58.894 Error: /home/pi/domoticz/domoticz() [0x237154]
2018-01-06 16:37:58.895 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x23720c]
2018-01-06 16:37:58.895 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c786b0]
What is your pull request (can not find it in list)?
Maybe your source is different from build - any other/additional files?
