[edit] using .active gives unexpected behaviour in V2.2 not an error, so better be carefull with this
light switch not off with SwitchOn().forMIN(2) [closed]
- rbisschops
- Domoticz version: 2.2563
Re: light switch not off with SwitchOn().forMIN(2)
dannybloe: isn't .active not part of V2.3? Like many, i'm running V2.2.
Last edited by rbisschops on Friday 05 January 2018 14:14, edited 2 times in total.
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
dannybloe
Ah, yeah, you can check for the state or use 'if (device.bState) then'
dannybloe
I'm a bit confused now. Which 'original' code are you referring to? The one on '04 Jan 2018, 17:34'?
You description of how checkFirst() is correct. It's just a check against the current state indeed.
- rbisschops
I understand your confusion. I was refering to the code i posted yesterday (17:34) the one you kindly corrected. The puzzling part for me is that the command is still send despite the checkfist() after the switchOn(). Afterall, as the switch is on, it should not be send at all imho.
dannybloe
I suppose you mean the outdoorlamp.switchOn().checkFirst().forMin(2) inside the nightime check. (that's the only lamp with a switchOn()).
So, have you really confirmed that the on command is indeed sent if the state is on? Have you set dzVents in debug mode and actually confirmed that a switch on command is placed in the commandArray? In debug mode the command array is dumped after each script. If it is sent it should show something like 'Buitenlam voor: On FOR 2 MINUTES'
- rbisschops
@dannybloe: Maybe a stuppid moment to conclude this, but wasn't checkFirst() also added in 2.3.0. I see this in the log:
I checked the DzVents changelog and see that it's noted as a 2.3.0 function ...
2018-01-06 13:54:30.386 Error: dzVents: Error: Presence actions: An error occured when calling event handler presence_V1-0-3
2018-01-06 13:54:30.386 Error: dzVents: Error: Presence actions: .../pi/domoticz/scripts/dzVents/scripts/presence_V1-0-3.lua:35: attempt to call field 'checkFirst' (a nil value)RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
dannybloe
Ah. Indeed. I lose track actually.
