Python plugin: Bluetooth Beacon Presence Detection
EddyG
Re: Python plugin: Bluetooth Beacon Presence Detection
Post by EddyG »
I tried TCP/IP, but the same problem exists with the 127.0.0.1 address.
lamouette
Post by lamouette »
works like a charm, many thanks !
schulpr
Post by schulpr »
For some reason I can't get auto starting to work after a reboot of my pi (with stretch lite).
After a manual start it works flawless.
I hope that someone can help me further with this.
Kind regards, Rob
mrinner
Post by mrinner »
@schulpr
ble_scanner.sh added as service?
If yes, try to update locally this line in ble_scanner.py to 10+ attempts.
https://github.com/mrin/domoticz-bt-pre ... er.py#L177
By default ~ 25sec (5 attempts * 5sec sleep) for check hci is RUNNING.
schulpr
Post by schulpr »
@mrinner
I increased the setting to 25 but that doesn't help. I just followed the steps as described. I didn't add any lines to a script. Do I need to?
Thanks for your help!
Rob
mrinner
Post by mrinner »
Can you see which status when service not started:
sudo service ble_scanner status
Also then try to run "hciconfig" without "sudo" and check string "RUNNING" in output.
schulpr
Post by schulpr »
This is the output with "sudo service ble_scanner status":
Dec 10 14:47:08 raspberrypi sudo[389]: pam_unix(sudo:session): session closed for user root
Dec 10 14:47:09 raspberrypi sudo[412]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/local/bin/hciconfig hci0 up
Dec 10 14:47:09 raspberrypi sudo[412]: pam_unix(sudo:session): session opened for user root by (uid=0)
Dec 10 14:47:10 raspberrypi sudo[412]: pam_unix(sudo:session): session closed for user root
Dec 10 14:47:10 raspberrypi sudo[423]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/local/bin/hciconfig hci0 down
Dec 10 14:47:10 raspberrypi sudo[423]: pam_unix(sudo:session): session opened for user root by (uid=0)
Dec 10 14:47:10 raspberrypi sudo[423]: pam_unix(sudo:session): session closed for user root
Dec 10 14:47:11 raspberrypi sudo[481]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/local/bin/hciconfig hci0 up
Dec 10 14:47:11 raspberrypi sudo[481]: pam_unix(sudo:session): session opened for user root by (uid=0)
Dec 10 14:47:12 raspberrypi sudo[481]: pam_unix(sudo:session): session closed for user root
hciconfig gives:
hci0: Type: BR/EDR Bus: USB
BD Address: 00:15:83:EE:93:F0 ACL MTU: 310:10 SCO MTU: 64:8
UP RUNNING
RX bytes:3162 acl:0 sco:0 events:132 errors:0
TX bytes:1932 acl:0 sco:0 commands:99 errors:0
In the domoticz log I see a lot of lines with:
Calling message handler 'onHeartbeat'.
But the switches are staying off.
Does this info tell you something?
Regards, Rob
mrinner
Post by mrinner »
In logs I see several attempts to startup and seems like hci0 was not ready.
in Debug plugin mode this is ok. Plugin checks timeout expiration on each heartbeat.
I will add debug logging in file as option for ble_scanner, maybe on this week.
mrinner
Post by mrinner »
@schulpr
Logging in file added. Just git pull updates and uncomment lines in ble_scanner.sh
schulpr
Post by schulpr »
@ mrinner,
My knowledge is between noob and hard learning beginner. Can you please help me a bit further? Were do I add this command? In the folder were the plugin is it doesn't work.
Rob
mrinner
Post by mrinner »
Go to the plugin folder "bt-presence", then "git pull"
Then "nano ble_scanner.sh" and uncomment lines + check path to log file:
DAEMON_ARGS="$DAEMON_ARGS --log /home/pi/domoticz/plugins/bt-presence/ble_scanner.log"
DAEMON_ARGS="$DAEMON_ARGS --loglevel debug"
schulpr
Post by schulpr »
Hi again,
That was easy :-). I got an error in the update process because it refused to override my config file. I decided to delete the current version and start all over again. Something strange happened, it worked!
So I tried another reboot and it didn't worked anymore. In the log everything seems fine, the process is running correct.
What it doesn't do is switch the switch that is created. I renamed it but that should be the problem I think? This is the content of the log file:
2017-12-15 11:25:26 - INFO - Ok hci0 interface Up n running !
2017-12-15 11:25:28 - DEBUG - new bt socket
2017-12-15 11:25:28 - DEBUG - Connected to bluetooth device hci0
2017-12-15 11:25:35 - INFO - ed:6a:79:4d:7f:76 RSSI -74 - NUT1
2017-12-15 11:25:35 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:25:43 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:25:47 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:26:03 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:26:07 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:26:15 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:26:23 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:26:30 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:26:34 - INFO - ed:6a:79:4d:7f:76 RSSI -70 - NUT1
2017-12-15 11:26:38 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:26:42 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:26:46 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:26:50 - INFO - ed:6a:79:4d:7f:76 RSSI -79 - NUT1
2017-12-15 11:26:53 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:26:57 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
I doesn't grow any further than this.
This is the log when I start the process in terminal:
pi@raspberrypi:~/domoticz/plugins/bt-presence $ sudo ./ble_scanner.py
2017-12-15 11:37:05 - INFO - Ok hci0 interface Up n running !
2017-12-15 11:37:07 - DEBUG - new bt socket
2017-12-15 11:37:07 - DEBUG - Connected to bluetooth device hci0
2017-12-15 11:37:15 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:37:19 - INFO - ed:6a:79:4d:7f:76 RSSI -74 - NUT1
2017-12-15 11:37:27 - INFO - ed:6a:79:4d:7f:76 RSSI -74 - NUT1
2017-12-15 11:37:30 - INFO - ed:6a:79:4d:7f:76 RSSI -74 - NUT1
2017-12-15 11:37:38 - INFO - ed:6a:79:4d:7f:76 RSSI -80 - NUT1
2017-12-15 11:37:42 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:37:50 - INFO - ed:6a:79:4d:7f:76 RSSI -74 - NUT1
2017-12-15 11:37:54 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:37:57 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:38:01 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:38:05 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:38:09 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:38:13 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:38:17 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:38:21 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:38:24 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:38:28 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:38:32 - INFO - ed:6a:79:4d:7f:76 RSSI -79 - NUT1
2017-12-15 11:38:36 - INFO - ed:6a:79:4d:7f:76 RSSI -75 - NUT1
2017-12-15 11:38:40 - INFO - ed:6a:79:4d:7f:76 RSSI -69 - NUT1
2017-12-15 11:38:44 - INFO - ed:6a:79:4d:7f:76 RSSI -78 - NUT1
2017-12-15 11:38:48 - INFO - ed:6a:79:4d:7f:76 RSSI -74 - NUT1
2017-12-15 11:38:51 - INFO - ed:6a:79:4d:7f:76 RSSI -80 - NUT1
2017-12-15 11:38:55 - INFO - ed:6a:79:4d:7f:76 RSSI -80 - NUT1
2017-12-15 11:38:59 - INFO - ed:6a:79:4d:7f:76 RSSI -74 - NUT1
This turns my switch on and doesn't stop.
I hope this helps to find a solution.
Thanks once more!
Rob
deennoo
Post by deennoo »
Have you try to use a synology as a "scanner" ?
Thanks for this plug in, will try it on serval device (rooted android tv box)
http://domo-attitude.fr
mrinner
Post by mrinner »
@schulpr
You can rename created devices as you want, plugin does not relying on name.
First log was immediately after the reboot and log did not grow anymore and "sudo service ble_scanner status" is "active (running)"?
Check what you not run 2 services on the one machine, or some other process maybe use BT.. Discovering can be stopped when hci going down, or bt connecting to some device by other process...
EddyG
Post by EddyG »
At the battery check one of my Nut3 came back with only 2 chars.
I had to add/change:
        bin_value = gatt_output[gatt_output.find("value:") + 6:]
        if len(bin_value) == 2:
             bin_value = bin_value + "00"
        bin_value = bin_value.decode("hex")
chrispazz
Post by chrispazz »
Which is the correct configuration for having correct battery charge reporting with a NUT2?
chrispazz
Post by chrispazz »
With latest domoticz beta BLE device are no more updating from BLE Scanner....
chrispazz
Post by chrispazz »
I am the only using this plugin with latest beta?
mrinner
Post by mrinner »
@chrispazz
I'm on 3.8805 - my setup works perfect.
Many people have problems with the python plugin system on latest beta...
chrispazz
Post by chrispazz »
@mrinner
thank you for answering me :)
I am on 3.8850 and plugin is running ok looking at logs.
It only seems not to update the devices....
2018-01-26 22:32:00.995 (BLE Presence) Update NUT Green: nValue 1 - sValue 100 - BatteryLevel 255
2018-01-26 22:32:01.598 (BLE Presence) Update NUT White: nValue 1 - sValue 100 - BatteryLevel 255
2018-01-26 22:32:04.855 (BLE Presence) Update NUT Green: nValue 1 - sValue 100 - BatteryLevel 255
2018-01-26 22:32:05.459 (BLE Presence) Update NUT White: nValue 1 - sValue 100 - BatteryLevel 255
2018-01-26 22:32:08.717 (BLE Presence) Update NUT Green: nValue 1 - sValue 100 - BatteryLevel 255
2018-01-26 22:32:09.371 (BLE Presence) Update NUT White: nValue 1 - sValue 100 - BatteryLevel 255
