Re: Logitech Media Server (LMS) dzVents adapter
Posted: Saturday 16 March 2019 15:23
I do not own an LMS so can you please test this updated device adapter (see below) and report back ?stephanvdplas wrote: Saturday 16 March 2019 12:04 Hello, I use the LMS DZVents adapter with much pleasure. I've only got a small feature request.
Is it possible to expand this function with VolumeUp and VolumeDown?
To do this:
from your domoticz dir
cp dzVents\runtime\device-adapters\logitech_media_server_device.lua dzVents\runtime\device-adapters\logitech_media_server_device.bak
test the commands
domoticz.devices(<name>).volumeUp()
domoticz.devices(<name>).volumeDown()
local TimedCommand = require('TimedCommand')
baseType = 'device',
name = 'Logitech Media Server device',
matches = function (device, adapterManager)
local res = (device.hardwareType == 'Logitech Media Server')
if (not res) then
adapterManager.addDummyMethod(device, 'switchOff')
adapterManager.addDummyMethod(device, 'stop')
adapterManager.addDummyMethod(device, 'play')
adapterManager.addDummyMethod(device, 'pause')
adapterManager.addDummyMethod(device, 'setVolume')
adapterManager.addDummyMethod(device, 'startPlaylist')
adapterManager.addDummyMethod(device, 'playFavorites')
adapterManager.addDummyMethod(device, 'volumeUp')
adapterManager.addDummyMethod(device, 'volumeDown')
return res
end,
process = function (device, data, domoticz, utils, adapterManager)
device.playlistID = data.data.levelVal
function device.switchOff()
return TimedCommand(domoticz, device.name, 'Off', 'device', device.state)
function device.stop()
return TimedCommand(domoticz, device.name, 'Stop', 'device', device.state)
function device.play()
return TimedCommand(domoticz, device.name, 'Play', 'device', device.state)
function device.pause()
return TimedCommand(domoticz, device.name, 'Pause', 'device', device.state)
function device.setVolume(value)
value = tonumber(value)
if (value < 0 or value > 100) then
utils.log('Volume must be between 0 and 100. Value = ' .. tostring(value), utils.LOG_ERROR)
return TimedCommand(domoticz, device.name, 'Set Volume ' .. tostring(value), 'device', device.state)
function device.startPlaylist(name)
return TimedCommand(domoticz, device.name, 'Play Playlist ' .. tostring(name), 'updatedevice', device.state)
function device.playFavorites(position)
position = tonumber(position)
if (position == nil) then
position = 0
return TimedCommand(domoticz, device.name, 'Play Favorites ' .. tostring(position), 'updatedevice', device.state)
function device.volumeDown()
local url = domoticz.settings['Domoticz url'] .. "/json.htm?type=command¶m=lmsmediacommand&action=VolumeDown" ..
'&idx=' .. device.id
return domoticz.openURL(url)
function device.volumeUp()
local url = domoticz.settings['Domoticz url'] .. "/json.htm?type=command¶m=lmsmediacommand&action=VolumeUp" ..
