[Problem] Event with time won't trigger
cantarevolare
Re: [Problem] Event with time won't trigger
Post by cantarevolare »
Yes, I checked and there is only one device that's named like that.
I tried with another device that's named differently, and there is still this return :
2017-12-19 19:14:58.226 dzVents: curtemp:
I just thought of something and that's my bad of not telling you earlier, but this is a device that gives the temperature and the humidity. Maybe there is a sub function of the device or something like that to call in order to obtair the temperature only ?
I think I found the solution thanks to the wiki and you:
sTemperature, sWeatherHumidity = otherdevices_svalues['Chambre temp']:match("([^;]+);([^;]+)")
curtemp = tonumber(sTemperature);
print("curtemp : " .. curtemp .. " ");
The result : 2017-12-19 19:31:53.247 dzVents: curtemp: 16.9
Let see if it matches exactly what I need.
Thank you very much for your help.
jvdz
Domoticz version: 4.107
Post by jvdz »
That explains it.You could also do it this way:
curtemp = tonumber(otherdevices_temperature['Chambre temp']);
Jos
