Page 2 of 7
Re: Python Plugin: MeteoAlarmEU
Posted: Friday 09 November 2018 21:50
by misko903
ycahome wrote: Thursday 08 November 2018 14:08
Then your problem is still feedparser that was not on your system.
If you have python 3.x try :
sudo apt-get install python3-feedparser
tried. still does not work.
2018-11-09 21:42:53.157 Error: (MeteoAlarmEU) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/MeteoAlarmEU/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-11-09 21:42:53.159 Error: (MeteoAlarm) Module Import failed, exception: 'ImportError'
2018-11-09 21:42:53.159 Error: (MeteoAlarm) Module Import failed: ' Name: feedparser'
2018-11-09 21:42:53.160 Error: (MeteoAlarm) Error Line details not available.
and later it repeats this:
2018-11-09 21:44:21.572 Error: MeteoAlarm hardware (16) thread seems to have ended unexpectedly
to give some info:
pi@raspberrypi:~ $ which python3
/usr/bin/python3
/usr/bin/python
pi@raspberrypi:~ $ python --version
Python 3.5.3
drwxr-xrwx 4 root root 4096 okt 18 22:00 MeteoAlarmEU
is the owner ok?
Posted: Friday 09 November 2018 23:33
by ycahome
Hello.
as I said, your problem is that feedparser is missing.
please post here the output of the following command
sudo apt list --installed|grep feed
Posted: Saturday 10 November 2018 7:13
by manutremo
I'm also installing the plugin into a Synology box. I managed to get it running adding the following line to plugin.py:
sys.path.append('/volume1/@appstore/py3k/usr/local/lib/python3.5/site-packages')
Now I have a different errors in my domoticz log:
2018-11-10 07:08:24.878 Error: (MeteoAlarm) 'onStart' failed 'KeyError'.
2018-11-10 07:08:24.878 Error: (MeteoAlarm) ----> Line 269 in '/usr/local/domoticz/var/plugins/MeteoAlarmEU/plugin.py', function onStart
2018-11-10 07:08:24.878 Error: (MeteoAlarm) ----> Line 96 in '/usr/local/domoticz/var/plugins/MeteoAlarmEU/plugin.py', function onStart
2018-11-10 07:08:35.110 Error: (MeteoAlarm) 'onHeartbeat' failed 'KeyError'.
2018-11-10 07:08:35.110 Error: (MeteoAlarm) ----> Line 281 in '/usr/local/domoticz/var/plugins/MeteoAlarmEU/plugin.py', function onHeartbeat
2018-11-10 07:08:35.110 Error: (MeteoAlarm) ----> Line 137 in '/usr/local/domoticz/var/plugins/MeteoAlarmEU/plugin.py', function onHeartbeat
Any idea?
Posted: Saturday 10 November 2018 9:38
by misko903
ycahome wrote: Friday 09 November 2018 23:33
Hello.
output:
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
python3-feedparser/stable,now 5.1.3-3 all [installed]
looks like installed. is it the righr version?
in directory
/usr/local/lib/python3.5/ i have only
dist-packages, no
site-packages
is it right?
EDIT:
changed the plugin.py paths like that:
sys.path
#sys.path.append('/usr/lib/python/dist-packages')
sys.path.append('/usr/lib/python3/dist-packages')
import feedparser
#sys.path.append('/usr/local/lib/python3.5/site-packages')
sys.path.append('/home/pi/.local/lib/python3.5/site-packages')
after that, 2 devices were created, but
syslog wrote this:
2018-11-10 11:24:17.179 Status: (MeteoAlarm) Entering work loop.
2018-11-10 11:24:17.179 Status: (MeteoAlarm) Initialized version 1.0.2, author 'ycahome'
2018-11-10 11:24:17.265 Status: dzVents: Error (2.4.7): Discarding device. No last update info found: {["id"]=101, ["signalLevel"]=0, ["baseType"]="device", ["switchTypeValue"]=0, ["data"]={["_state"]="No Data", ["icon"]="Alert", ["_nValue"]=0, ["hardwareType"]="Meteo Alarm EU RSS Reader", ["protected"]=false, ["unit"]=1, ["hardwareTypeValue"]=94, ["hardwareName"]="MeteoAlarm", ["hardwareID"]=16}, ["changed"]=true, ["switchType"]="On/Off", ["lastLevel"]=255, ["rawData"]={"No Data"}, ["timedOut"]=true, ["description"]="", ["batteryLevel"]=0, ["deviceID"]="", ["subType"]="Alert", ["lastUpdate"]="", ["deviceType"]="General", ["name"]="MeteoAlarm - Today"}
2018-11-10 11:24:17.465 Status: dzVents: Error (2.4.7): Discarding device. No last update info found: {["id"]=102, ["signalLevel"]=0, ["baseType"]="device", ["switchTypeValue"]=0, ["data"]={["_state"]="No Data", ["icon"]="Alert", ["_nValue"]=0, ["hardwareType"]="Meteo Alarm EU RSS Reader", ["protected"]=false, ["unit"]=2, ["hardwareTypeValue"]=94, ["hardwareName"]="MeteoAlarm", ["hardwareID"]=16}, ["changed"]=true, ["switchType"]="On/Off", ["lastLevel"]=255, ["rawData"]={"No Data"}, ["timedOut"]=false, ["description"]="", ["batteryLevel"]=0, ["deviceID"]="", ["subType"]="Alert", ["lastUpdate"]="", ["deviceType"]="General", ["name"]="MeteoAlarm - Tomorrow"}
2018-11-10 11:24:25.061 (Xiaomi Gateway) Light/Switch (Obývačka Pohyb)
2018-11-10 11:24:27.181 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:24:27.182 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:24:27.184 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:24:27.463 (MeteoAlarm) Gathering Data for:Attiki
2018-11-10 11:24:27.463 (MeteoAlarm) Alarm(s) for Today: No special awareness required.
2018-11-10 11:24:27.464 (MeteoAlarm) Type Of Warning:-1
2018-11-10 11:24:27.464 (MeteoAlarm) Data:-tr>TODAY -/th>-/tr>-tr>-td width="28">-img alt="awt:3 level:1" border="1" src="https://www.meteoalarm.eu/documents/rss/wflag-l1-t3.jpg" />-/td>-/tr>-tr>-td width="28">-/td>-td>No special awareness required-/td>-/tr>-tr>-th align="left" colspan="3">-br />
2018-11-10 11:24:27.464 (MeteoAlarm) Current Awareness Status:No Data with Level 0
2018-11-10 11:24:27.464 (MeteoAlarm) Awareness for Today Updated to:No special awareness required
2018-11-10 11:24:27.464 (MeteoAlarm - Today) Updating device from 0:'No Data' to have values 1:'No special awareness required'.
2018-11-10 11:24:27.470 (MeteoAlarm) Alarm(s) for Tomorrow: No special awareness required
2018-11-10 11:24:27.470 (MeteoAlarm) Type Of Warning:-1
2018-11-10 11:24:27.470 (MeteoAlarm) Current Awareness Status:No Data with Level 0
2018-11-10 11:24:27.470 (MeteoAlarm) Awareness for Tomorrow Updated to:No special awareness required
2018-11-10 11:24:27.470 (MeteoAlarm - Tomorrow) Updating device from 0:'No Data' to have values 1:'No special awareness required'.
2018-11-10 11:24:37.183 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:24:37.211 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:24:37.211 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:24:44.030 Error: Python Plugins hardware (15) thread seems to have ended unexpectedly
2018-11-10 11:24:44.031 Error: Python Plugins hardware (18) thread seems to have ended unexpectedly
2018-11-10 11:24:47.185 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:24:47.230 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:24:47.230 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:24:57.187 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:24:57.199 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:24:57.199 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:25:00.515 Status: LUA: Domoticz alive !
2018-11-10 11:25:07.189 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:25:07.222 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:25:07.222 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:25:17.192 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:25:17.241 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:25:17.241 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:25:27.194 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:25:27.209 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:25:27.209 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:25:37.196 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:25:37.227 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:25:37.227 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:25:47.198 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:25:47.246 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:25:47.246 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:25:57.200 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:25:57.214 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:25:57.214 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:26:00.466 Status: LUA: Domoticz alive !
2018-11-10 11:26:07.202 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:26:07.241 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:26:07.241 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:26:17.204 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:26:17.209 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:26:17.209 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:26:24.767 (Xiaomi Gateway) Light/Switch (Obývačka Pohyb)
2018-11-10 11:26:27.206 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:26:27.227 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:26:27.227 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:26:37.207 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:26:37.246 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:26:37.246 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:26:47.209 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:26:47.214 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:26:47.215 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2018-11-10 11:26:57.211 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2018-11-10 11:26:57.233 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2018-11-10 11:26:57.233 (MeteoAlarm) Calling message handler 'onHeartbeat'.
looks like it works now, but every second calling is maybe too often?
Posted: Saturday 10 November 2018 18:04
by ycahome
Glad to hear that this plugin worked for your.
As forthe Log Messages, are you sure that you don't have "Debug=True"?
Posted: Saturday 10 November 2018 19:39
by misko903
ycahome wrote: Saturday 10 November 2018 18:04
You are right, it was turned on. Thanks for help and for the plugin
Looking forward to first alert
Posted: Sunday 11 November 2018 0:39
by ycahome
Make sure that you have set your country's/city RSS Feed,otherwise it will report Athens's alerts.
Posted: Sunday 11 November 2018 18:39
by EdwinK
ycahome wrote: Sunday 11 November 2018 0:39
Yes... Well... I forgot that, and I was wondering about the things it showed, later I realized you needed to add the right RSS in it
Posted: Tuesday 13 November 2018 9:57
by misko903
Posted: Tuesday 13 November 2018 10:37
by misko903
Idea for upgrade:
- show icons of warnings
- after click - display the meteoalarm webpage, for example:
https://www.meteoalarm.eu/sl_SK/0/0/SK309.html
Posted: Friday 16 November 2018 9:48
by manutremo
Hi, today I noticed that the plug-in was reporting no alerts even though we actually have a rain alert in my area. I checked the log and found the following:
2018-11-16 09:43:42.622 (MeteoAlarm) Gathering Data for:Barcelona
2018-11-16 09:43:42.622 (MeteoAlarm) Awareness for Today Updated to:Rain(2>-/td>-td>-b>From: -/b>-i>16.11.2018 00:00 CET-/i>-b> Until: -/b>-i>16.11.2018 09:59 CET-/i>-/td>-/tr>-tr>-td width=28>-/td>-td>-/td>-/tr>-tr>-th colspan=3 align=left>-br />)
2018-11-16 09:43:42.622 Error: (MeteoAlarm) 'onHeartbeat' failed 'ValueError':'invalid literal for int() with base 10: '2>-/td>-td>-b>From: -/b>-i>16.11.2018 00:00 CET-/i>-b> Until: -/b>-i>16.11.2018 09:59 CET-/i>-/td>-/tr>-tr>-td width=28>-/td>-td>-/td>-/tr>-tr>-th colspan=3 align=left>-br />''.
2018-11-16 09:43:42.623 Error: (MeteoAlarm) ----> Line 281 in '/usr/local/domoticz/var/plugins/MeteoAlarmEU/plugin.py', function onHeartbeat
2018-11-16 09:43:42.623 Error: (MeteoAlarm) ----> Line 190 in '/usr/local/domoticz/var/plugins/MeteoAlarmEU/plugin.py', function onHeartbeat
Do I need to check something?
Posted: Friday 16 November 2018 10:18
by ycahome
Checked on my test server with the following RSS feed:
http://www.meteoalarm.eu/documents/rss/es/ES001.rss
and everything seems ok:
2018-11-16 11:15:24.846 (MeteoAlarmEU) Gathering Data for:Barcelona
2018-11-16 11:15:24.846 (MeteoAlarmEU) Awareness for Today Updated to:Rain(2)
2018-11-16 11:15:24.847 (MeteoAlarmEU) Awareness for Tomorrow Updated to:No special awareness required
Posted: Friday 16 November 2018 10:33
by manutremo
Thanks for checking in your own server. Any idea of what be the issue in mine from the error log?
Posted: Friday 16 November 2018 10:41
by ycahome
manutremo wrote: Friday 16 November 2018 10:33
I don't have a clue.
So, in order to have chance to help you, should be aware of your environment's details (python, domoticz, plugin version etc)
Posted: Sunday 18 November 2018 12:13
by manutremo
Looking at the error I posted it is clear that the int() function is expecting a "2" string and not the long string shown in the error. Therefore something is not right in the logic that partitions the strings from the feed. I'm not familiar with python at all but have tried to trace back the code.
As of now, the feed I use is:
<?xml version="1.0" encoding="utf-8" ?>
<rss version="2.0" xmlns:atom="http://www.w3.org/2005/Atom">
<channel>
<atom:link href="http://meteoalarm.eu/documents/rss/es/ES001.rss" rel="self" type="application/rss+xml"/>
<title>Meteoalarm Spain, Barcelona</title>
<link>https://www.meteoalarm.eu/es_ES/0/0/ES001.html</link>
<description>Metoalarm actual warnings from Spain, Barcelona</description>
<ttl>10</ttl>
<language>eng</language>
<item>
<title>Barcelona</title>
<description><![CDATA[<table border="0" cellspacing="0" cellpadding="3"><tr><th colspan="3" align="left">Today</th></tr><tr><td width="28"><img border="1" src="https://www.meteoalarm.eu/documents/rss/wflag-l2-t10.jpg" alt="awt:10 level:2"></td><td><b>From: </b><i>18.11.2018 09:00 CET</i><b> Until: </b><i>18.11.2018 20:59 CET</i></td></tr><tr><td width="28"></td><td></td></tr><tr><th colspan="3" align="left"><br />Tomorrow</th></tr><tr><td width="28"><img border="1" src="https://www.meteoalarm.eu/documents/rss/wflag-l1-t4.jpg" alt="awt:4 level:1"></td></tr><tr><td width="28"></td><td>No special awareness required</td></tr></table>]]></description>
<pubDate>Sun, 18 Nov 2018 08:59:12 +0100</pubDate>
<guid isPermaLink="false">d31bb52bb3b94d8322370ae3b3f15c2c</guid>
</item>
</channel>
</rss>
Looking through the code I found that that string is LEVELValue, which is partitioned in lines 156-160.
In line 158, the string AWTPossitions[1] is:
10 level:2">-/td>-td>-b>From: -/b>-i>18.11.2018 09:00 CET-/i>-b> Until: -/b>-i>18.11.2018 20:59 CET-/i>-/td>-/tr>-tr>-td width="28">-/td>-td>-/td>-/tr>-tr>-th colspan="3" align="left">-br />
This line correctly extracts value 10 for AWTvalue.
However line 160:
LEVELvalue = AWTPossitions[AWTPos].split('level:')[1].split('border')[0].replace('"','').strip()
tries to split the string using "border", which is not present, therefore it delivers a wrong result for LEVELvalue.
In turn, the list AWTPossitions comes from FeedValueFTd, which is:
<tr>TODAY </th></tr><tr><td width="28"><img border="1" src="https://www.meteoalarm.eu/documents/rss/wflag-l2-t10.jpg" alt="awt:10 level:2"></td><td><b>From: </b><i>18.11.2018 11:00 CET</i><b> Until: </b><i>18.11.2018 20:59 CET</i></td></tr><tr><td width="28"></td><td></td></tr><tr><th colspan="3" align="left"><br />
In line 152 this is split using string "awt:" and "<" are replaced by "-", so:
AWTpossitions[0] = -tr>TODAY -/th>-/tr>-tr>-td width="28">-img border="1" src="https://www.meteoalarm.eu/documents/rss/wflag-l2-t10.jpg" alt="
AWTPossitions[1] = 10 level:2">-/td>-td>-b>From: -/b>-i>18.11.2018 11:00 CET-/i>-b> Until: -/b>-i>18.11.2018 20:59 CET-/i>-/td>-/tr>-tr>-td width="28">-/td>-td>-/td>-/tr>-tr>-th colspan="3" align="left">-br />
Unless I have missed something, at this points it seems pretty obvious that the code is expecting a different format to that the feed is using. I checked other feeds containing alerts and they seem to use that "border" tag as the code expects, but apparently some do not; it looks like it depends on there actually being an alert or not, or maybe on there being one or more. You may want to give it a quick review. I hope this helps.
Posted: Monday 19 November 2018 17:08
by ycahome
manutremo wrote: Sunday 18 November 2018 12:13
Looking at the error .................. I hope this helps.
Nice analysis.All those you mention seem correct.
What you don;t explain is why works on my system and not to yours.
Do you have version 1.0.2 of this plugin?
Can you enable "Debig Mode", flter by "meteoalarm" and compare with my output bellow:
2018-11-19 17:52:05.322 (MeteoAlarmEU) Started.
2018-11-19 17:52:05.639 (MeteoAlarmEU) Entering work loop.
2018-11-19 17:52:05.639 (MeteoAlarmEU) Initialized version 1.0.2, author 'ycahome'
2018-11-19 17:52:05.640 (MeteoAlarmEU) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'Version':'1.0.2'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'Mode1':'http://www.meteoalarm.eu/documents/rss/es/ES001.rss'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'Name':'MeteoAlarmEU'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'Author':'ycahome'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'DomoticzHash':'bc239243'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'HardwareID':'16'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'Mode4':'Debug'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'DomoticzVersion':'3.9443'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'Mode3':'60'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'HomeFolder':'/home/yiannis/domoticz/plugins/MeteoAlarmEU/'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'Port':'0'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'DomoticzBuildTime':'2018-05-16 09:28:53'
2018-11-19 17:52:05.640 (MeteoAlarmEU) 'Key':'MeteoAlarmEU'
2018-11-19 17:52:05.640 (MeteoAlarmEU) Device count: 2
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device: 1 - ID: 64, Name: 'MeteoAlarmEU - Today', nValue: 1, sValue: 'No special awareness required'
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device ID: '64'
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device Name: 'MeteoAlarmEU - Today'
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device nValue: 1
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device sValue: 'No special awareness required'
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device LastLevel: 0
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device: 2 - ID: 65, Name: 'MeteoAlarmEU - Tomorrow', nValue: 1, sValue: 'No special awareness required'
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device ID: '65'
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device Name: 'MeteoAlarmEU - Tomorrow'
2018-11-19 17:52:05.724 (MeteoAlarmEU) onStart called
2018-11-19 17:52:05.724 (MeteoAlarmEU) Using polling interval of 3600 seconds
2018-11-19 17:52:05.724 (MeteoAlarmEU) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'Version':'1.0.2'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'Mode1':'http://www.meteoalarm.eu/documents/rss/es/ES001.rss'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'Name':'MeteoAlarmEU'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'Author':'ycahome'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'DomoticzHash':'bc239243'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'HardwareID':'16'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'Mode4':'Debug'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'DomoticzVersion':'3.9443'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'Mode3':'60'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'HomeFolder':'/home/yiannis/domoticz/plugins/MeteoAlarmEU/'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'Port':'0'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'DomoticzBuildTime':'2018-05-16 09:28:53'
2018-11-19 17:52:05.724 (MeteoAlarmEU) 'Key':'MeteoAlarmEU'
2018-11-19 17:52:05.724 (MeteoAlarmEU) Device count: 2
2018-11-19 17:52:05.724 (MeteoAlarmEU - Today) Updating device from 1:'No special awareness required' to have values 0:'No Data'.
2018-11-19 17:52:05.726 (MeteoAlarmEU - Tomorrow) Updating device from 1:'No special awareness required' to have values 0:'No Data'.
2018-11-19 17:52:15.141 (MeteoAlarmEU) Pushing 'onHeartbeatCallback' on to queue
2018-11-19 17:52:15.152 (MeteoAlarmEU) Processing 'onHeartbeatCallback' message
2018-11-19 17:52:15.152 (MeteoAlarmEU) Calling message handler 'onHeartbeat'.
2018-11-19 17:52:15.915 (MeteoAlarmEU) Gathering Data for:Barcelona
2018-11-19 17:52:15.915 (MeteoAlarmEU) Alarm(s) for Today: No special awareness required.
2018-11-19 17:52:15.915 (MeteoAlarmEU) Type Of Warning:-1
2018-11-19 17:52:15.915 (MeteoAlarmEU) Data:-tr>TODAY -/th>-/tr>-tr>-td width="28">-img alt="awt:4 level:1" border="1" src="https://www.meteoalarm.eu/documents/rss/wflag-l1-t4.jpg" />-/td>-/tr>-tr>-td width="28">-/td>-td>No special awareness required-/td>-/tr>-tr>-th align="left" colspan="3">-br />
2018-11-19 17:52:15.915 (MeteoAlarmEU) Current Awareness Status:No Data with Level 0
2018-11-19 17:52:15.915 (MeteoAlarmEU) Awareness for Today Updated to:No special awareness required
2018-11-19 17:52:15.915 (MeteoAlarmEU - Today) Updating device from 0:'No Data' to have values 1:'No special awareness required'.
2018-11-19 17:52:15.917 (MeteoAlarmEU) Alarm(s) for Tomorrow: No special awareness required
2018-11-19 17:52:15.917 (MeteoAlarmEU) Type Of Warning:-1
2018-11-19 17:52:15.917 (MeteoAlarmEU) Current Awareness Status:No Data with Level 0
2018-11-19 17:52:15.917 (MeteoAlarmEU) Awareness for Tomorrow Updated to:No special awareness required
2018-11-19 17:52:15.917 (MeteoAlarmEU - Tomorrow) Updating device from 0:'No Data' to have values 1:'No special awareness required'.
2018-11-19 17:52:25.144 (MeteoAlarmEU) Pushing 'onHeartbeatCallback' on to queue
2018-11-19 17:52:25.193 (MeteoAlarmEU) Processing 'onHeartbeatCallback' message
2018-11-19 17:52:25.193 (MeteoAlarmEU) Calling message handler 'onHeartbeat'.
2018-11-19 17:52:35.146 (MeteoAlarmEU) Pushing 'onHeartbeatCallback' on to queue
2018-11-19 17:52:35.168 (MeteoAlarmEU) Processing 'onHeartbeatCallback' message
2018-11-19 17:52:35.168 (MeteoAlarmEU) Calling message handler 'onHeartbeat'.
2018-11-19 17:52:45.148 (MeteoAlarmEU) Pushing 'onHeartbeatCallback' on to queue
2018-11-19 17:52:45.156 (MeteoAlarmEU) Processing 'onHeartbeatCallback' message
2018-11-19 17:52:45.156 (MeteoAlarmEU) Calling message handler 'onHeartbeat'.
2018-11-19 17:52:55.151 (MeteoAlarmEU) Pushing 'onHeartbeatCallback' on to queue
2018-11-19 17:52:55.190 (MeteoAlarmEU) Processing 'onHeartbeatCallback' message
2018-11-19 17:52:55.190 (MeteoAlarmEU) Calling message handler 'onHeartbeat'.
Posted: Saturday 15 December 2018 13:19
by mozo78
Hi, now works well for me too. Thank you for your work.
Hint: only works well if you exactly choose your area. In may case:
1. Not working, it is the rss for the whole country:
https://www.meteoalarm.eu/documents/rss/hu.rss
When I used this I got the same error as above declared.
2.Working, only the central area of the country:
https://www.meteoalarm.eu/documents/rss/hu/HU006.rss
Next step: try to find informative icons for dashticz.
Posted: Friday 21 December 2018 14:22
by EdwinK
Now seeing this all the time in the error-log:
2018-12-21 11:07:45.532 Error: (MeteoAlarm) 'onHeartbeat' failed 'IndexError':'list index out of range'.
2018-12-21 11:07:45.532 Error: (MeteoAlarm) ----> Line 280 in '/home/pi/domoticz/plugins/MeteoAlarmEU/plugin.py', function onHeartbeat
2018-12-21 11:07:45.532 Error: (MeteoAlarm) ----> Line 147 in '/home/pi/domoticz/plugins/MeteoAlarmEU/plugin.py', function onHeartbeat
2018-12-21 12:07:46.507 Error: (MeteoAlarm) 'onHeartbeat' failed 'IndexError':'list index out of range'.
Posted: Friday 04 January 2019 8:47
by EdwinK
2019-01-04 08:44:07.651 (MeteoAlarm) 'HardwareID':'14'
2019-01-04 08:44:07.651 (MeteoAlarm) 'Port':'0'
2019-01-04 08:44:07.651 (MeteoAlarm) 'Key':'MeteoAlarmEU'
2019-01-04 08:44:07.651 (MeteoAlarm) 'DomoticzVersion':'4.10311'
2019-01-04 08:44:07.651 (MeteoAlarm) 'DomoticzHash':'e588266e'
2019-01-04 08:44:07.651 (MeteoAlarm) 'Name':'MeteoAlarm'
2019-01-04 08:44:07.651 (MeteoAlarm) 'HomeFolder':'/home/pi/domoticz/plugins/MeteoAlarmEU/'
2019-01-04 08:44:07.651 (MeteoAlarm) 'Mode4':'Debug'
2019-01-04 08:44:07.651 (MeteoAlarm) Device count: 2
2019-01-04 08:44:07.652 (MeteoAlarm) Device: 1 - ID: 137, Name: 'MeteoAlarm - Today', nValue: 0, sValue: 'No Data'
2019-01-04 08:44:07.652 (MeteoAlarm) Device ID: '137'
2019-01-04 08:44:07.652 (MeteoAlarm) Device Name: 'MeteoAlarm - Today'
2019-01-04 08:44:07.652 (MeteoAlarm) Device nValue: 0
2019-01-04 08:44:07.652 (MeteoAlarm) Device sValue: 'No Data'
2019-01-04 08:44:07.652 (MeteoAlarm) Device LastLevel: 0
2019-01-04 08:44:07.652 (MeteoAlarm) Device: 2 - ID: 138, Name: 'MeteoAlarm - Tomorrow', nValue: 0, sValue: 'No Data'
2019-01-04 08:44:07.652 (MeteoAlarm) Device ID: '138'
2019-01-04 08:44:07.652 (MeteoAlarm) Device Name: 'MeteoAlarm - Tomorrow'
2019-01-04 08:44:07.652 (MeteoAlarm - Today) Updating device from 0:'No Data' to have values 0:'No Data'.
2019-01-04 08:44:07.657 (MeteoAlarm - Tomorrow) Updating device from 0:'No Data' to have values 0:'No Data'.
2019-01-04 08:44:07.047 Status: (MeteoAlarm) Stopping threads.
2019-01-04 08:44:07.047 Status: (MeteoAlarm) Stopped.
2019-01-04 08:44:07.047 Status: (MeteoAlarm) Started.
2019-01-04 08:44:07.646 Status: (MeteoAlarm) Entering work loop.
2019-01-04 08:44:07.646 Status: (MeteoAlarm) Initialized version 1.0.2, author 'ycahome'
2019-01-04 08:44:17.648 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:44:17.694 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:44:17.694 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:44:18.226 (MeteoAlarm) Gathering Data for:Netherlands
2019-01-04 08:44:18.226 (MeteoAlarm) ------FEEDPARSER OUTPUT for TODAY:------------------
2019-01-04 08:44:18.226 Error: (MeteoAlarm) 'onHeartbeat' failed 'IndexError':'list index out of range'.
2019-01-04 08:44:18.226 Error: (MeteoAlarm) ----> Line 280 in '/home/pi/domoticz/plugins/MeteoAlarmEU/plugin.py', function onHeartbeat
2019-01-04 08:44:18.226 Error: (MeteoAlarm) ----> Line 147 in '/home/pi/domoticz/plugins/MeteoAlarmEU/plugin.py', function onHeartbeat
2019-01-04 08:44:27.728 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:44:27.760 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:44:27.760 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:44:37.730 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:44:37.782 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:44:37.782 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:44:47.734 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:44:47.760 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:44:47.763 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:44:57.735 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:44:57.739 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:44:57.739 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:45:07.737 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:45:07.762 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:45:07.762 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:45:17.739 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:45:17.744 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:45:17.746 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:45:27.743 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:45:27.765 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:45:27.765 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:45:37.745 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:45:37.749 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:45:37.751 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:45:47.752 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:45:47.783 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:45:47.783 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:45:57.754 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:45:57.807 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:45:57.807 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:46:07.758 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:46:07.803 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:46:07.804 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:46:17.761 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:46:17.777 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:46:17.779 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:46:27.763 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:46:27.771 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:46:27.771 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:46:37.765 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:46:37.798 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:46:37.798 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:46:47.767 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:46:47.783 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:46:47.783 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:46:57.769 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:46:57.805 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:46:57.805 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:47:07.775 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:47:07.799 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:47:07.799 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:47:17.779 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:47:17.787 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:47:17.787 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:47:27.789 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:47:27.814 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:47:27.814 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:47:37.794 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:47:37.798 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:47:37.798 (MeteoAlarm) Calling message handler 'onHeartbeat'.
2019-01-04 08:47:47.798 (MeteoAlarm) Pushing 'onHeartbeatCallback' on to queue
2019-01-04 08:47:47.818 (MeteoAlarm) Processing 'onHeartbeatCallback' message
2019-01-04 08:47:47.819 (MeteoAlarm) Calling message handler 'onHeartbeat'.
© 2012-2019 Domoticz | WWW: Domoticz.com
MY debug log
Posted: Friday 04 January 2019 9:50
by ycahome
EdwinK wrote: Friday 04 January 2019 8:47
MY debug log
I can't see which RSS feed you are using but from "2019-01-04 08:44:18.226 (MeteoAlarm) Gathering Data for:Netherlands"
i suppose that you use the one of the country (Netherlands) instead of your county (Specific region of Netherlands).
Based on your profile location i propose to use "Zuid-Holland" RSS feed instead which is
https://www.meteoalarm.eu/documents/rss/nl/NL009.rss
Let me now if this worked for you.
