React on RSS feed
EdwinK
Re: React on RSS feed
Post by EdwinK »
Okay, hadn't tried that yet :)
Seems the feed is a few days off.
I normally use https://alarmeringen.nl/ which does seem to have a RSS feed based on the place, but I can't figure out how to use it.
https://alarmeringen.nl/feeds/city/rhoon.rss
and even personalised feeds
elmortero
Domoticz version: 3.9639
Post by elmortero »
Hi EdwinK,
Sent you a PM
EdwinK
Post by EdwinK »
Noticed :)
elmortero
Post by elmortero »
Came up with this.
It is a PYthon script (NOT domoticz plugin)
Store it in an accessible location and run it using cron (via the crontab editor) in order to run it every x minutes.
The text sensor will be updated with the newest message in the rss feed only if it is a different message.
I use a temporal storage - much like dzVent's persistent data where I store the message combined with the timestamp of publication (as a same message can be sent at different times for different intervention).
You can then create a domoticz device triggered event based on your text sensor. My script below only updates the text sensor, it does not perform any other actions.
What you need to change in the script:
- the name you want to give to the log file (where the latest 30 messages from the rss feed will be stored (line 31)
- this name will also be used for the persistent variable (NAME.stor)
- change the ID of your text sensor to the one you use (line 32)
- change the IP address to the one of your Domoticz machine, or to http://127.0.0.1:8080 if you run script on your Domoticz machine (line 33)
- change the url at line 34 for use with other feed (should work with any alarmeringen.nl rss feed, but I haven't tried)
Update: just had a quick look at the alarmeringdroid.nl feeds, and those should also work (same structure). Haven't had time to check yet.
There is some comments in the script for the above changes, hope they are clear enough.
I have built in some checks at the start of the script to check if you have all python modules that this script needs installed.
If one is missing you should get some hints on what and how to install.
Give it a try when you can.
import urllib.parse
import csv, os, json
import json
import urllib.parse
import requests
try:
    from bs4 import BeautifulSoup
except ImportError:
    print(
        "You don't have BeautifulSoup installed.\nIt is required for this script.\n\nPlease run ' pip install beautifulsoup4 ' and try again\n"
    quit()
try:
    import lxml
except ImportError:
    print(
        "You don't have lxml installed.\nIt is required for this script.\n\nPlease run ' sudo apt-get install python-lxml ' if you are on python 2.x or  'sudo apt-get install python3-lxml ' if you are on python3.x and try again\n"
    quit()
try:
    from urllib.parse import urlparse, urlencode
    from urllib.request import urlopen, Request
    from urllib.error import HTTPError
except ImportError:
    from urlparse import urlparse
    from urllib import urlencode
    from urllib2 import urlopen, Request, HTTPError
log_name = "p2000_rhoorn"
text_idx = '1412'  # change into idx of your text sensor
domoticz_url = "http://192.168.1.6:8080"
NEWS_URL = "https://alarmeringen.nl/feeds/city/rhoon.rss"  #the alarmering feed to be fetched
### change this to the url for your domoticz IP or to http://127.0.0.1 if you run the script on your domoticz machine
if os.path.exists(log_name +
                  '.stor'):  ##check if a file with prevous message exists
    with open(log_name + '.stor',
              'r') as file:  ##if it exists, get the message(+timestamp)
        prev_msg = str(file.read())  ##write the content to variable prev_msg
else:
    prev_msg = 'nil'  ##if file does not exist, assign 'nil' to variable prev_msg
# for tests you can delete the .stor file. Then any message fetched from the feed will be considered new and sensor will update
def domo_post(idx, value):
    enc_value = urllib.parse.quote(value)
    url = (domoticz_url + '/json.htm?type=command&param=udevice&idx=' + idx +
           '&nvalue=0&svalue=' + enc_value)
    try:
        response = requests.get(url)
        resp_code = ('Sensor update OK')
    except:
        resp_code = ('Sensor update failed!!')
        return resp_code
def news(xml_news_url):
    url = xml_news_url
    headers = {'User-Agent': 'Mozilla/5.0'}
    request = Request(xml_news_url, headers=headers)
    xml_page = urlopen(request).read()
    soup_page = BeautifulSoup(xml_page, "lxml", from_encoding="ascii")
    news_list = soup_page.findAll("item")
    msg = (news_list[0].description.text)  #get newest entry from feed
    print("\nNewest message\n", msg)
    pub_date = (news_list[0].pubdate.text
                )  #get the timestamp to compare messages
    pick_check = (
        msg + pub_date
    )  #make a variable from fetched message and it's published date/time
    if pick_check != prev_msg:  #if stored value is different from current message with time stamp
        with open(log_name + '.stor', 'w') as file:  #write value to storage
            file.write(pick_check)
        post = domo_post(text_idx, msg)  #and update the text sensor
        print('New message received, updating P2000 text sensor')
    else:  #if message and timestamp are same --> no new message in rss feed
        print(
            '\nMessage was same as previous one'
        )  #print message and DONT update text sensor (so no new domoticz event)
    i = 0
    feedy = ''
    #here we loop through the rss feed (only for log file. You can see the latest 30 messages from feed
    while i < 30:
        title = (news_list[i].title.text)
        inhoud = (news_list[i].description.text)
        tijd = (news_list[i].pubdate.text)[:-6][5:]
        combi = tijd + ';' + inhoud
        i = i + 1
        feedy = feedy + combi + '\n'
        with open(log_name + '.log',
                  'w') as csvfile:  #write latest 30 messages to log file
            csvfile.write(feedy)
    return feedy
stream = news(NEWS_URL)
EdwinK
Post by EdwinK »
Seems to work alright, although I had to do a pip3 install beautifulsoup4 but that was quickly discovered :)
