Re: Python plugin: Daikin BRP069A42 WiFi adapter
Posted: Friday 22 December 2017 15:39
Anyone could help me?
Inviato dal mio HUAWEI CRR-L09 utilizzando Tapatalk
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
Seems some settings always revert back to some previous settings for example i set Airco to FAN but jumps back to cool after a minute.Prutsium wrote: Saturday 07 July 2018 10:38 Just installed it and works great. Added the first Aircon (1 of 3) and no issues with setup.
2018-07-18 10:39:22.576 (Airco - Living) Processing 'ReadEvent' message
2018-07-18 10:39:22.576 (Airco - Living) Received 84 bytes of data
2018-07-18 10:39:22.576 (Airco - Living) 48 54 54 50 2f 31 2e 30 20 32 30 30 20 4f 4b 0d 0a 43 6f 6e HTTP/1.0.200.OK..Con
2018-07-18 10:39:22.576 (Airco - Living) 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 31 39 0d 0a 43 6f 6e tent-Length:.19..Con
2018-07-18 10:39:22.576 (Airco - Living) 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 78 74 2f 70 6c 61 69 tent-Type:.text/plai
2018-07-18 10:39:22.576 (Airco - Living) 6e 0d 0a 0d 0a 72 65 74 3d 50 41 52 41 4d 20 4e 47 2c 61 64 n....ret=PARAM.NG,ad
2018-07-18 10:39:22.576 (Airco - Living) 76 3d 31 33 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. v=13
2018-07-18 10:39:22.576 (Airco - Living) Pushing 'onMessageCallback' on to queue
2018-07-18 10:39:22.576 (Airco - Living) Processing 'DisconnectedEvent' message
2018-07-18 10:39:22.576 (Airco - Living) Disconnect event received for '192.168.199.106:80'.
2018-07-18 10:39:22.577 (Airco - Living) Pushing 'onDisconnectCallback' on to queue
2018-07-18 10:39:22.577 (Airco - Living) Processing 'onMessageCallback' message
2018-07-18 10:39:22.577 (Airco - Living) Calling message handler 'onMessage'.
2018-07-18 10:39:22.577 (Airco - Living) onMessage called
2018-07-18 10:39:22.577 (Airco - Living) Received data from connection Set Control: ret=PARAM NG,adv=13
After digging in your Python script i found the whole FAN mode missing.Prutsium wrote: Wednesday 18 July 2018 9:44 Seems with the new firmware of the Wifi adapter some commands are not accepted anymore.
Below i try to switch to FAN mode got the following result:Code: Select all
2018-07-18 10:39:22.576 (Airco - Living) Processing 'ReadEvent' message 2018-07-18 10:39:22.576 (Airco - Living) Received 84 bytes of data 2018-07-18 10:39:22.576 (Airco - Living) 48 54 54 50 2f 31 2e 30 20 32 30 30 20 4f 4b 0d 0a 43 6f 6e HTTP/1.0.200.OK..Con 2018-07-18 10:39:22.576 (Airco - Living) 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 31 39 0d 0a 43 6f 6e tent-Length:.19..Con 2018-07-18 10:39:22.576 (Airco - Living) 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 78 74 2f 70 6c 61 69 tent-Type:.text/plai 2018-07-18 10:39:22.576 (Airco - Living) 6e 0d 0a 0d 0a 72 65 74 3d 50 41 52 41 4d 20 4e 47 2c 61 64 n....ret=PARAM.NG,ad 2018-07-18 10:39:22.576 (Airco - Living) 76 3d 31 33 .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. v=13 2018-07-18 10:39:22.576 (Airco - Living) Pushing 'onMessageCallback' on to queue 2018-07-18 10:39:22.576 (Airco - Living) Processing 'DisconnectedEvent' message 2018-07-18 10:39:22.576 (Airco - Living) Disconnect event received for '192.168.199.106:80'. 2018-07-18 10:39:22.577 (Airco - Living) Pushing 'onDisconnectCallback' on to queue 2018-07-18 10:39:22.577 (Airco - Living) Processing 'onMessageCallback' message 2018-07-18 10:39:22.577 (Airco - Living) Calling message handler 'onMessage'. 2018-07-18 10:39:22.577 (Airco - Living) onMessage called 2018-07-18 10:39:22.577 (Airco - Living) Received data from connection Set Control: ret=PARAM NG,adv=13
elif (mode == "6"):
sValueNew = "40" #Fan
elif (Devices[4].sValue == "40"):
requestUrl = requestUrl + "6"
# Basic Python Plugin Example
# Author: GizMoCuz
<plugin key="BRP069A42" name="Daikin Airconditioning (BRP069A42)" author="leejoow" version="1.1.0" externallink="https://www.daikin.nl/nl_nl/products/BRP069A42.html">
<params>
<param field="Address" label="IP Address" width="200px" required="true" default=""/>
<param field="Port" label="Port" width="30px" required="true" default="80"/>
<param field="Mode1" label="Update every x seconds" width="75px">
<options>
<option label="30" value="3" />
<option label="60" value="6" default="true" />
<option label="90" value="9" />
<option label="120" value="12" />
<option label="150" value="15" />
<option label="180" value="18" />
<option label="210" value="21" />
<option label="240" value="24" />
</options>
</param>
<param field="Mode2" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
from datetime import datetime
class BasePlugin:
enabled = True
powerOn = 0
runCounter = 0
httpConnSensorInfo = None
httpConnControlInfo = None
httpConnSetControl = None
def __init__(self):
#self.var = 123
return
def onStart(self):
Domoticz.Log("onStart called")
if Parameters["Mode2"] == "Debug":
Domoticz.Debugging(1)
if (len(Devices) == 0):
Domoticz.Device(Name="Power", Unit=1, Image=16, TypeName="Switch", Used=1).Create()
Domoticz.Device(Name="Temp IN", Unit=2, TypeName="Temperature", Used=1).Create()
Domoticz.Device(Name="Temp OUT", Unit=3, TypeName="Temperature",Used=1).Create()
Options = {"LevelActions" : "|||||",
"LevelNames" : "|Auto|Cool|Heat|Fan|Dry",
"LevelOffHidden" : "true",
"SelectorStyle" : "1"}
Domoticz.Device(Name="Mode", Unit=4, TypeName="Selector Switch", Image=16, Options=Options, Used=1).Create()
Options = {"LevelActions" : "|||||||",
"LevelNames" : "|Auto|Silent|L1|L2|L3|L4|L5",
Domoticz.Device(Name="Fan Rate", Unit=5, TypeName="Selector Switch", Image=7, Options=Options, Used=1).Create()
Domoticz.Device(Name="Temp TARGET", Unit=6, Type=242, Subtype=1, Image=16, Used=1).Create()
Domoticz.Log("Device created.")
DumpConfigToLog()
Domoticz.Heartbeat(10)
self.httpConnSensorInfo = Domoticz.Connection(Name="Sensor Info", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"])
self.httpConnSensorInfo.Connect()
self.httpConnControlInfo = Domoticz.Connection(Name="Control Info", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"])
self.httpConnControlInfo.Connect()
self.httpConnSetControl = Domoticz.Connection(Name="Set Control", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"])
self.runCounter = int(Parameters["Mode1"])
def onStop(self):
Domoticz.Log("onStop called")
def onConnect(self, Connection, Status, Description):
if (Status == 0):
Domoticz.Debug("Connection successful")
data = ''
headers = { 'Content-Type': 'text/xml; charset=utf-8', \
'Connection': 'keep-alive', \
'Accept': 'Content-Type: text/html; charset=UTF-8', \
'Host': Parameters["Address"]+":"+Parameters["Port"], \
'User-Agent':'Domoticz/1.0', \
'Content-Length' : "%d"%(len(data)) }
if (Connection == self.httpConnSensorInfo):
Domoticz.Debug("Sensor connection created")
requestUrl = "/aircon/get_sensor_info"
elif (Connection == self.httpConnControlInfo):
Domoticz.Debug("Control connection created")
requestUrl = "/aircon/get_control_info"
elif (Connection == self.httpConnSetControl):
Domoticz.Debug("Set connection created")
requestUrl = self.buildCommandString()
Connection.Send({"Verb":"GET", "URL":requestUrl, "Headers": headers})
else:
Domoticz.Debug("Connection failed")
def onMessage(self, Connection, Data):
Domoticz.Log("onMessage called")
dataDecoded = Data["Data"].decode("utf-8", "ignore")
Domoticz.Debug("Received data from connection " + Connection.Name + ": " + dataDecoded)
position = dataDecoded.find("pow=")
power = dataDecoded[position + 4 : position + 5]
position = dataDecoded.find("mode=")
mode = dataDecoded[position + 5 : position + 6]
position = dataDecoded.find("f_rate=")
f_rate = dataDecoded[position + 7 : position + 8]
position = dataDecoded.find("stemp=")
stemp = dataDecoded[position + 6 : position + 8]
Domoticz.Debug("Power: " + power + "; Mode: " + mode + "; FanRate: " + f_rate + "; Target temperature: " + stemp)
self.powerOn = int(power)
# Power
if (power == "0"):
if (Devices[1].nValue != 0):
Devices[1].Update(nValue = 0, sValue ="0")
else:
if (Devices[1].nValue != 1):
Devices[1].Update(nValue = 1, sValue ="100")
# Mode
if (mode == "0"):
sValueNew = "10" #Auto
elif (mode == "2"):
sValueNew = "50" #Dry
elif (mode == "3"):
sValueNew = "20" #Cool
elif (mode == "4"):
sValueNew = "30" #Warm
elif (mode == "6"):
if (Devices[4].nValue != self.powerOn or Devices[4].sValue != sValueNew):
Devices[4].Update(nValue = self.powerOn, sValue = sValueNew)
# Fan rate
if (f_rate == "A"):
sValueNew = "10" # Auto
elif (f_rate == "B"):
sValueNew = "20" # Silent
#Manual f_rate
elif (f_rate == "3"):
sValueNew = "30" # L1
elif (f_rate == "4"):
sValueNew = "40" # L2
elif (f_rate == "5"):
sValueNew = "50" # L3
elif (f_rate == "6"):
sValueNew = "60" # L4
elif (f_rate == "7"):
sValueNew = "70" # L5
# else:
# sValueNew = str(int(f_rate) * 10)
if (Devices[5].nValue != self.powerOn or Devices[5].sValue != sValueNew):
Devices[5].Update(nValue = self.powerOn, sValue = sValueNew)
#lastUpdate = datetime.strptime(Devices[6].LastUpdate, "%Y-%m-%d %H:%M:%S")
#delta = datetime.now() - lastUpdate
# Setpoint temperature, update once per 30 minutes if no changes
#if (Devices[6].nValue != self.powerOn or Devices[6].sValue != stemp or delta.total_seconds() > 1800):
# Devices[6].Update(nValue = self.powerOn, sValue = stemp)
elif (Connection == self.httpConnSensorInfo):
position = dataDecoded.find("htemp=")
htemp = dataDecoded[position + 6 : position + 10]
position = dataDecoded.find("otemp=")
otemp = dataDecoded[position + 6 : position + 10]
Domoticz.Debug("Internal temperature: " + htemp + "; Outside temperature: " + otemp)
Devices[2].Update(nValue = 0, sValue = htemp)
Devices[3].Update(nValue = 0, sValue = otemp)
#Force disconnect, in case the Daikin unit doesn't disconnect
if (Connection.Connected()):
Domoticz.Debug("Close connection")
Connection.Disconnect()
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Debug("Command received U="+str(Unit)+" C="+str(Command)+" L= "+str(Level)+" H= "+str(Hue))
if (Unit == 1):
if(Command == "On"):
self.powerOn = 1
else:
self.powerOn = 0
#Update state of all other devices
Devices[4].Update(nValue = self.powerOn, sValue = Devices[4].sValue)
Devices[5].Update(nValue = self.powerOn, sValue = Devices[5].sValue)
Devices[6].Update(nValue = self.powerOn, sValue = Devices[6].sValue)
if (Unit == 4):
Devices[4].Update(nValue = self.powerOn, sValue = str(Level))
if (Unit == 5):
Devices[5].Update(nValue = self.powerOn, sValue = str(Level))
if (Unit == 6):
Devices[6].Update(nValue = self.powerOn, sValue = str(Level))
self.httpConnSetControl.Connect()
def onNotification(self, Name, Subject, Text, Status, Priority, Sound, ImageFile):
Domoticz.Log("Notification: " + Name + "," + Subject + "," + Text + "," + Status + "," + str(Priority) + "," + Sound + "," + ImageFile)
def onDisconnect(self, Connection):
Domoticz.Debug("Connection " + Connection.Name + " closed.")
def onHeartbeat(self):
self.runCounter = self.runCounter - 1
if self.runCounter <= 0:
Domoticz.Debug("Poll unit")
if (self.httpConnSensorInfo.Connected() == False):
if (self.httpConnControlInfo.Connected() == False):
else:
Domoticz.Debug("Polling unit in " + str(self.runCounter) + " heartbeats.")
def buildCommandString(self):
#Minimal string: pow=1&mode=1&stemp=26&shum=0&f_rate=B&f_dir=3
requestUrl = "/aircon/set_control_info?shum=0&f_dir=3&pow="
if (self.powerOn):
requestUrl = requestUrl + "1"
else:
requestUrl = requestUrl + "0"
requestUrl = requestUrl + "&mode="
if (Devices[4].sValue == "10"):
elif (Devices[4].sValue == "20"):
requestUrl = requestUrl + "3"
elif (Devices[4].sValue == "30"):
requestUrl = requestUrl + "4"
elif (Devices[4].sValue == "50"):
requestUrl = requestUrl + "2"
requestUrl = requestUrl + "&f_rate="
if (Devices[5].sValue == "10"):
requestUrl = requestUrl + "A"
elif (Devices[5].sValue == "20"):
requestUrl = requestUrl + "B"
elif (Devices[5].sValue == "30"):
elif (Devices[5].sValue == "40"):
elif (Devices[5].sValue == "50"):
requestUrl = requestUrl + "5"
elif (Devices[5].sValue == "60"):
elif (Devices[5].sValue == "70"):
requestUrl = requestUrl + "7"
# else:
# requestUrl = requestUrl + str(int(int(Devices[5].sValue) / 10))
requestUrl = requestUrl + "&stemp=" + Devices[6].sValue
return requestUrl
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
