Dashticz - Install picoreplayer
madpatrick
Domoticz version: 2026.1
Re: Dashticz - Install picoreplayer
Post by madpatrick »
capman wrote: Tuesday 15 August 2017 22:32 Okayyy , getting something here 8-) Have made a selector switch with two url's to my playlist with each a radio station.
http://192.168.178.29:9002/status.html?p0=playlist&p1=play&p2=RadioFG&p3=b8:27:eb:29:3c:50
and
http://192.168.178.29:9002/status.html?p0=playlist&p1=play&p2=StuBru&p3=b8:27:eb:29:3c:50
Just like freakshock say. Thanks freakshock!
Now I just have 2 make a selector switch in dashticz and we have control about my player (stop , play). And a selector with some favorites in.
Next thing to do , volume control :D .
Thanks 2 everybody 4 all help so far !
Great !! I’ve LMSworking in Dashticz.
Is it possible to make the buttons bigger and add the on/off switch ?
capman
Post by capman »
In 'custom.css' paste this code and edit the px (40) parameter.
/* PLayer buttons */
.fa.fa-arrow-circle-left.fa-small {
    font-size: 40px !important;
.fa.fa-stop-circle.fa-small {
.fa.fa-play-circle.fa-small {
.fa.fa-arrow-circle-right.fa-small {
.fa.fa-pause-circle.fa-small {
I just don't know how to get the buttons higher or lower on the screen. But it's a start ;)
madpatrick
capman wrote: Thursday 24 August 2017 19:14 In 'custom.css' paste this code and edit the px (40) parameter.
Working !! thanks
pvm
Domoticz version: 4.10538
Post by pvm »
Volume control:
Volume parameter P2 can be absolute like 30% of relative as shown below:
http://[IP_LMS]:9002/status.html?p0=mixer&p1=volume&p2=-2&player=[mac_address, replace : with %3A] // decrease volume with 2
http://[IP_LMS]:9002/status.html?p0=mixer&p1=volume&p2=%2B2&player=[mac_address, replace : with %3A] // increase volume with 2
capman
Post by capman »
For who has interresting in how to have the artwork showing for what's playing from LMS server.
In custom/config.js make a line. Where you set the values for ip:port and player mac to your values.
The player mac adress , you find this in the settings from LMS server.
frames.artwork = {width:12, isimage:true, refresh:2000, image: 'http://IP LMS:PORT LMS/music/current/cover.jpg?player=PLAYER MAC ADRESS'}
Then put the frames.artwork where you want you to showup in your collums.
Example
columns[3] = {}
columns[3]['blocks'] = [buttons.buienradar,'blocktitle_7',92,86,'blocktitle_4',frames.artwork]
columns[3]['width'] = 2;
EdwinK
Post by EdwinK »
Looks great. :)
Had tried several players, but this one is mostly self explaining. It even found my LMS without problems. Volumio couldn't
pvm
Post by pvm »
Nice, thanks. I've added this for my players.
To get the graphics optimized I want to decrease the height of the cover image, do you happen to know how to do this?
EdwinK
Post by EdwinK »
When you change the width of the image from width:12 to something lower, the height will change as well. I've mine at 4 I think, and the image is much smaller.
Screen Shot 2018-08-17 at 17.40.48.png (168.83 KiB) Viewed 1820 times
pvm
Post by pvm »
This is my current layout:
To get this aligned correctly i've added padding/border (in css) to the selector showing radio selection. I would prefer to have the image just a little smaller (50px will do). Changing width from 2 (current value) to 1 decreases size too much.
I did inspection in chrome but I do not see a CSS identifier I can use... Guess it is just not possible.
If the frame identifier was used in CSS I/we would have much more options like giving it rounded corners etc.
EdwinK
Post by EdwinK »
O.. No clue about that, sorry. Maybe user capman can help you with that.
stephanvdplas
Domoticz version: 2023.1
Post by stephanvdplas »
capman wrote: Wednesday 01 August 2018 18:10 For who has interresting in how to have the artwork showing for what's playing from LMS server.
Example
columns[3] = {}
I'm trying to use this, but can't get it to work.
I have implemented it exactly like capman did, but see no image. The image address as show in the browser is; http://<IP address Dashticz webserver>:8082/img/http://<IP address LMS server>:9000/music/current/cover.jpg?player=<Player MAC address>
What is going wrong?
What actually does work is this:
frames.artwork = {height:600, scrollbars:false, isimage:true, refresh:2000, forcerefresh:1, frameurl: 'http://<IP address LMS server>:9000/music/current/cover.jpg?player=<Player MAC address>'}
But this is way too large and when I choose a smaller value for height, the image doesn't fit and is shown partly.
Regards,
Stephan
Last edited by stephanvdplas on Tuesday 09 February 2021 17:47, edited 1 time in total.
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
madpatrick
Maybe an other option is to use the LMS Material Skin and a seperate screen with Dashticz.
I've made a button on my homescreen which goes to Screen2 and then i've the fullscreen of LMS
blocks['Slide_2'] = {type: 'dial', color: '#ffff00', width: 2, last_update: false, title:' ',slide:2, iconSwitch: 'fas fa-volume-up'}
frames.slide2 = {frameurl:"http://192.168.1.1:9000/",  height: '540',scrollbars : false,  width:12}
stephanvdplas
Thanks for your swift reply! Material skin directly as a frame in dashticz: that's is a good option, I'm already using that skin and it integrates perfectly in Dashticz I see.
One more question How can a make it full screen? It is now shown as 540 pixels high. Not a problem, but as you state you have a full-screen LMS window. What do I need to change to make it full-screen?
Regards,
Stephan
madpatrick
I'm using a tablet with a resolution height of 800px and have a button under the LMS screen, so for me 540px is enough.
You can atry to remove the option.
I think it will then fill the screen.
