Dashticz - Module - Settings
robgeerts
Domoticz version: 3.7067
Re: Dashticz - [BETA]Module - Settings - VERSION 2
Post by robgeerts »
It's working now @mozart, @benbammens could you try latest beta?
If it is still not working, it might be another bug. Please send me your Teamviewer ID and PASS via PM.
Mozart
Post by Mozart »
robgeerts wrote:It's working now @mozart, @benbammens could you try latest beta?
Indeed, it's working again.
Thanks Rob
Raspberry 3
Aeon Labs Z-Wave Stick Series 2 - RFLink USB Gateway
Z-Wave switches
433 MHz Temperature + Humidity sensors
Philips Hue Lights
Mi-Light WiFi Bridge + RGBW Controllers
benbammens
Post by benbammens »
Still nothing. I've sent PM
vgr2
Post by vgr2 »
Hi Rob, did update to last beta without notification from Setting Module. Now I have black screen. How can I get back to config.js?
robgeerts
Post by robgeerts »
Could yoimu send me your Teamviewer details via PM?
vgr2
Post by vgr2 »
Thanks Rob, now it's working
benbammens
En na een kleine ingreep van Rob werkt het nu ook bij mij. Bedankt!
robgeerts
Post by robgeerts »
Yes, and fixed the thing that caused the problem in latest beta!
Derik
Post by Derik »
mm mine is flashing the [new ] setting screen...
Cannot get the screen.
capman
Post by capman »
Also black screen here with the last beta :( . Some solution 4 this ? I have used firefox and chrome .
robgeerts
Post by robgeerts »
What if you manually add configuration in config.js? ( in de topicstart you can find this code)
capman
Post by capman »
Okee , I found it why my screen goes black. As soon when I have multiple screens ,3 or more, it goes wrong. With 2 screens it's working.
Working code (All the way 2 the end)
var config = {}
config['domoticz_ip'] = 'http://xxxxxxxxxxxxx';
config['default_news_url'] = 'http://www.standaard.be/rss/section/1f2 ... 8784c7ea7c';
config['news_scroll_after'] = '15';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['language'] = 'nl_NL';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dddd DD MMMM YYYY HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 'https://xxxxxxxxxxxx/basic.ics';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'xxxxxxxxxxxx';
config['gm_zoomlevel'] = '13';
config['gm_latitude'] = xxxxxxxxxxx';
config['gm_longitude'] = 'xxxxxxxxxx';
config['wu_api'] = 'xxxxxxxxxxxx';
config['wu_city'] = 'xxxxxxxxxx';
config['wu_name'] = 0;
config['wu_country'] = 'BE';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 'xxxxxxxxxxxxxx';
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 0;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 0;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
//TV Gids
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:12, channels: [5,6,60,49], maxitems: 6 }
//var _STANDBY_CALL_URL = 'http://192.168.178.42/cgi-bin/screen_br ... ghtness=20'; //adjust brightness raspberry touchscreen, leave empty if not used
//var _END_STANDBY_CALL_URL = 'http://192.168.178.42/cgi-bin/screen_br ... htness=250'; //adjust brightness raspberry touchscreen, leave empty if not used
//predefined colors, when you have RGB-lamps
//var _SAVED_COLORS = ['black', 'white', 'blanchedalmond','rgb(255, 128, 0);', 'hsv 100 70 50', 'lightyellow'];
// Online Radio Stream Plugin, Note: you must enable plugin in column section 'streamplayer', see columns[3]['blocks'] example below.
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Music FM","file":"http://stream.musicfm.hu:8000/musicfm.mp3"},
{"track":2,"name":"Radio 1","file":"http://213.181.210.106:8000/high.mp3"},
{"track":3,"name":"Test FM","file":"http://213.181.210.106:8000/high.mp3"},
// iCalendar Plugin, supports all .ics calendar types like Google Calendar, Apple Calendar
//var _ICALENDAR_URL = 'https://calendar.google.com/calendar/ic ... /basic.ics'; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
//var _ICALENDAR_DATEFORMAT = 'dddd DD MMMM YYYY HH:mm'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm','dddd DD MMMM YYYY HH:mm'
//var _ICALENDAR_LOCALE = 'nl_NL'; //en,hu, etc.
var calendars = {}
calendars.business = {width:12, maxitems: 3,icon: 'fa-calendar ', url: 'https://calendar.google.com/calendar/em ... e/Brussels', icalurl: 'https://calendar.google.com/calendar/ic ... /basic.ics' }
calendars.private = {maxitems: 3,icon: 'fa-calendar ',icalurl: 'https://calendar.google.com/calendar/ic ... /basic.ics' }
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667'}
buttons.camvoordeur = {width:12, isimage:true, refresh:2000, image: 'http://xxxxxxxxxxxxxxx
buttons.radio = {width:12, image: 'img/radio_on.png', title: 'Radio', url: 'http://192.168.178.29:9002'}
buttons.nzbget = {width:4, icon: 'fa-download', title: 'NZBget', url: 'http://192.168.178.29:6789'}
buttons.calendar = {width:4, icon: 'fa-calendar', title: 'Kalender', url: 'https://calendar.google.com/calendar'}
buttons.moon = {width:12, isimage:true, refreshimage:60000, image: 'moon'}
buttons.domoticz = {width:12, icon:'fa-microchip', title: 'Domoticz Log', url: 'http://192.168.178.29:8084/json.htm?typ ... loglevel=2'}
// Afvalwijzer
var trashcan = {}
trashcan.afvalapp = {key:'afvalapp',maxitems: 2,trashapp: 'ophaalkalender', width:4,street:'xxxxxxxxxxxxxxxx', country:'BE' }
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Restafval'] = 'Rest'
trashnames['Pmd'] = 'PMD'
trashnames['P-k'] = 'Papier'
trashnames['Glas'] = 'Glas'
trashnames['Snoeiafval'] = 'Snoeiafval'
var trashcolors = {}
trashcolors['Gft'] = 'green';
//trashcolors['P-k'] = 'brown';
trashcolors['Restafval'] = 'Darkgrey'
trashcolors['Pmd'] = 'deepskyBlue'
trashcolors['Glas'] = 'yellow'
trashcolors['Snoeiafval'] = 'lightgreen'
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'SCHAKELAARS';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'INFO';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Verkeersinfo';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'MUZIEK';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'ROLLUIKEN';
blocks['blocktitle_5']['width'] = 5;
blocks['blocktitle_6'] = {}
blocks['blocktitle_6']['type'] = 'blocktitle';
blocks['blocktitle_6']['title'] = 'CAMERA';
blocks['blocktitle_7'] = {}
blocks['blocktitle_7']['type'] = 'blocktitle';
blocks['blocktitle_7']['title'] = 'SPEEDTEST.NET';
blocks['blocktitle_7']['width'] = 4;
blocks['blocktitle_8'] = {}
blocks['blocktitle_8']['type'] = 'blocktitle';
blocks['blocktitle_8']['title'] = 'LICHAAM';
blocks['blocktitle_8']['width'] = 4;
//NIEUWS
blocks['news_1'] = {}
blocks['news_1']['feed'] = 'https://crossorigin.me/http://www.stand ... 8784c7ea7c';
blocks['news_1']['width'] = 12;
//SCHAKELAARS
blocks[276] = {}
//blocks[276]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[276]['title'] = 'Thermostaat' //if you want change the name of switch different then domoticz
blocks[276]['icon'] = ' fa-lightbulb-o'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
//blocks[276]['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks[215] = {}
blocks[215]['width'] = 4;
blocks[215]['title'] = 'Handmatig'
blocks[215]['icon'] = 'fa-hand-paper-o';
blocks[211] = {}
blocks[211]['width'] = 4;
blocks[211]['title'] = 'Slaapwel'
blocks[211]['image'] = 'sleep.png';
blocks[227] = {}
blocks[227]['width'] = 12;
blocks[227]['title'] = 'Lampje tablet'
blocks[30] = {}
blocks[30]['width'] = 12;
blocks[30]['title'] = 'Inkom'
blocks[29] = {}
blocks[29]['width'] = 12;
blocks[29]['title'] = 'Haard'
blocks[24] = {}
blocks[24]['width'] = 12;
blocks[24]['title'] = 'Lamp TV'
blocks[46] = {}
blocks[46]['width'] = 12;
blocks[46]['title'] = 'Rond tafeltje'
blocks[26] = {}
blocks[26]['width'] = 12;
blocks[26]['title'] = 'Leeslicht'
blocks[25] = {}
blocks[25]['width'] = 12;
blocks[25]['title'] = 'Leeslicht'
//ROLLUIKEN
blocks[18] = {}
blocks[18]['width'] = 6;
blocks[18]['title'] = 'Keuken'
blocks[18]['hide_stop'] = true;
blocks[17] = {}
blocks[17]['width'] = 6;
blocks[17]['title'] = 'Terras'
blocks[17]['hide_stop'] = true;
blocks[15] = {}
blocks[15]['width'] = 6;
blocks[15]['title'] = 'Eetkamer'
blocks[15]['hide_stop'] = true;
blocks[16] = {}
blocks[16]['width'] = 6;
blocks[16]['title'] = 'Woonkamer'
blocks[16]['hide_stop'] = true;
blocks[14] = {}
blocks[14]['width'] = 6;
blocks[14]['title'] = 'Buro'
blocks[14]['hide_stop'] = true;
blocks[20] = {}
blocks[20]['width'] = 6;
blocks[20]['title'] = 'Slaapkamer Groot'
blocks[20]['hide_stop'] = true;
blocks[65] = {}
blocks[65]['width'] = 6;
blocks[65]['title'] = 'Slaapkamer Klein'
blocks[65]['hide_stop'] = true;
blocks[21] = {}
blocks[21]['width'] = 6;
blocks[21]['title'] = 'Slaapkamer 2'
blocks[21]['hide_stop'] = true;
blocks[22] = {}
blocks[22]['width'] = 6;
blocks[22]['title'] = 'Slaapkamer 3'
blocks[22]['hide_stop'] = true;
blocks[23] = {}
blocks[23]['width'] = 6;
blocks[23]['title'] = 'Badkamer'
blocks[23]['hide_stop'] = true;
//REGEN VERWACHT
blocks[354] = {}
blocks[354]['width'] = 4;
blocks[354]['title'] = ''
blocks[354]['icon'] = 'fa-tint';
//VERWARMING
blocks[276] = {}
blocks[276]['title'] = 'Verwarming'
//blocks[276]['icon'] = 'fa-tint';
//GEWICHT
blocks[375] = {}
blocks[375]['width'] = 4;
blocks[375]['title'] = 'Sabine'
blocks[375]['icon'] = 'fa-balance-scale';
blocks[375]['gotoslide'] = 3;
blocks[375]['gotoslide']['auto_close'] = 30; //seconds
blocks[376] = {}
blocks[376]['width'] = 12;
blocks[376]['title'] = 'Kris'
blocks[376]['icon'] = 'fa-balance-scale';
blocks[376]['gotoslide'] = 3;
blocks[376]['gotoslide']['auto_close'] = 30; //seconds
blocks[377] = {}
blocks[377]['width'] = 12;
blocks[377]['title'] = 'Milan'
blocks[377]['icon'] = 'fa-balance-scale';
blocks[377]['gotoslide'] = 3;
blocks[377]['gotoslide']['auto_close'] = 30; //seconds
blocks[378] = {}
blocks[378]['width'] = 4;
blocks[378]['title'] = 'Robin'
blocks[378]['icon'] = 'fa-balance-scale';
blocks[378]['gotoslide'] = 3;
blocks[378]['gotoslide']['auto_close'] = 30; //seconds
//Temperatuur
blocks[4] = {}
//blocks[4]['width'] = 4;
blocks[4]['title'] = 'Slaapkamer 1'
//blocks[4]['icon'] = 'fa-tint';
blocks[4]['switch'] = true; //if you want to switch the title and data
//Internet speed
blocks[356] = {}
blocks[356]['width'] = 4;
//blocks[356]['title'] = 'Ping'
blocks[356]['icon'] = 'fa-globe';
blocks[357] = {}
blocks[357]['width'] = 4;
//blocks[357]['title'] = 'Mbit/s'
blocks[357]['icon'] = 'fa-download';
blocks[358] = {}
blocks[358]['width'] = 4;
//blocks[358]['title'] = 'Upload'
blocks[358]['icon'] = 'fa-upload';
//Popup Camera Deurbel
blocks[366] = {}
blocks[366]['width'] = 2;
blocks[366]['openpopup'] = {}
blocks[366]['openpopup']['url'] = 'http://xxxxxxxx';
blocks[366]['openpopup']['auto_close'] = 15; //seconds
//Muziek
blocks[338] = {}
blocks[338]['width'] = 4;
//blocks[356]['icon'] = 'fa-globe';
//MAPS
//var maps = {}
//maps.beveren = { width:12, latitude: xxxxxx, longitude: xxxxxxxx, zoom:13 }
//KOLOMMEN
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',211,215,276,'blocktitle_2','traffic',trashcan.afvalapp,354,320,calendars.business,calendars.private,'news_1']
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',4,2,250,256,318,277,174,'blocktitle_4','spotify']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['sunrise',buttons.buienradar,buttons.camvoordeur,'blocktitle_8',376,377]
columns[3]['width'] = 2;
columns[4] = {}
columns[4]['blocks'] = ['clock']
columns[4]['width'] = 12;
columns[5] = {}
columns[5]['blocks'] = ['blocktitle_8',375,376,377,378]
columns[5]['width'] = 5;
columns[6] = {}
columns[6]['blocks'] = [buttons.domoticz]
columns[6]['width'] = 5;
columns[7] = {}
columns[7]['blocks'] = ['blocktitle_5',18,17,15,16,14,20,65,21,22,23]
columns[7]['width'] = 5;
columns[8] = {}
columns[8]['blocks'] = ['clock']
columns[8]['width'] = 12;
columns[9] = {}
columns[9]['blocks'] = [buttons.camvoordeur,366]
columns[9]['width'] = 12;
columns[10] = {}
columns[10]['blocks'] = ['blocktitle_1',227,30,29,24,46,26,25]
columns[10]['width'] = 12;
//STANBY SCHERM
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg10.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
screens[2] = {}
screens[2]['background'] = 'bg10.jpg';
screens[2]['columns'] = [10]
screens[3] = {}
screens[3]['background'] = 'bg10.jpg';
screens[3]['columns'] = [4,5,6,7]
screens[4] = {}
screens[4]['background'] = 'bg10.jpg';
screens[4]['columns'] = [8,9]
NOT Working code (also @the end ;) )
var config = {}
//TV Gids
var tvguide = {}
var calendars = {}
var buttons = {}
// Afvalwijzer
var trashcan = {}
var trashnames = {}
var blocks = {}
//NIEUWS
//SCHAKELAARS
blocks[276] = {}
blocks[215] = {}
blocks[211] = {}
blocks[227] = {}
blocks[30] = {}
blocks[29] = {}
blocks[24] = {}
blocks[46] = {}
blocks[26] = {}
blocks[25] = {}
//ROLLUIKEN
blocks[18] = {}
blocks[17] = {}
blocks[15] = {}
blocks[16] = {}
blocks[14] = {}
blocks[20] = {}
blocks[65] = {}
blocks[21] = {}
blocks[22] = {}
blocks[23] = {}
//REGEN VERWACHT
blocks[354] = {}
//VERWARMING
blocks[276] = {}
//GEWICHT
blocks[375] = {}
blocks[376] = {}
blocks[377] = {}
blocks[378] = {}
//Temperatuur
blocks[4] = {}
//Internet speed
blocks[356] = {}
blocks[357] = {}
blocks[358] = {}
blocks[366] = {}
//Muziek
blocks[338] = {}
//MAPS
//var maps = {}
//KOLOMMEN
var columns = {}
columns[1] = {}
columns[2] = {}
columns[3] = {}
columns[4] = {}
columns[5] = {}
columns[6] = {}
columns[7] = {}
columns[8] = {}
columns[9] = {}
columns[10] = {}
//STANBY SCHERM
var screens = {}
screens[1] = {}
screens[2] = {}
screens[3] = {}
screens[4] = {}
In the code is some 'xxxx' 4 hiding some personal data 8-)
robgeerts
Post by robgeerts »
This is working for me...
var screens = {}
screens['default'] = {}
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {}
screens['default'][1]['background'] = 'bg9.jpg';
screens['default'][1]['columns'] = [1,2,4]
screens['default'][2] = {}
screens['default'][2]['background'] = 'bg9.jpg';
screens['default'][2]['columns'] = [5,6,7]
screens['default'][3] = {}
screens['default'][3]['background'] = 'bg9.jpg';
screens['default'][3]['columns'] = [5,6,7]
screens['default'][4] = {}
screens['default'][4]['background'] = 'bg9.jpg';
screens['default'][4]['columns'] = [5,6,7]
screens['tablet'] = {}
screens['tablet']['maxwidth'] = 1024;
screens['tablet']['maxheight'] = 768;
screens['tablet'][1] = {}
screens['tablet'][1]['background'] = 'bg9.jpg';
screens['tablet'][1]['columns'] = [1]
screens['tablet'][2] = {}
screens['tablet'][2]['background'] = 'bg9.jpg';
screens['tablet'][2]['columns'] = [2]
capman
Post by capman »
Working 4 me also now, with the latest beta.
gielie
Domoticz version: latest β
Post by gielie »
I tried the latest beta but I also get a black screen. I tried to reduce the screens to 2 as stated above but still no luck.
Someone have an idea that might work?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
Blueone
Post by Blueone »
add "var config = {}" to the top of the config file, that resolved it for me (Was using the latest beta but also a black screen).
And another question :D , is it possible to set the sunrise on the place of the logo in the title bar (maybe an option in the menu)?
robgeerts
Post by robgeerts »
In latest beta, use:
columns['bar'] = {}
columns['bar']['blocks'] = ['sunrise','miniclock','settings']
Blueone
Post by Blueone »
PeJeWe
Domoticz version: Latest
Re: Dashticz - Module - Settings
Post by PeJeWe »
The function "edit mode" dus not work.
i have tried to reinstall it several times.
I have used git pull.
It won't save changes. i use Chrome
when i push save and i refresh nothing happens.
F12 shows me:
Uncaught TypeError: Cannot read property 'width' of undefined
at HTMLDivElement.eval (eval at globalEval (jquery.min.js:2), <anonymous>:72:47)
at Function.each (jquery.min.js:2)
at n.fn.init.each (jquery.min.js:2)
at saveBlocks (eval at globalEval (jquery.min.js:2), <anonymous>:43:20)
at HTMLAnchorElement.onclick ((index):1)
I cant add plugins.
robgeerts
Post by robgeerts »
Could you test latest beta?
Remember, this function is heavily in beta ;)
Later I want to add a menu for new blocks to add.
