Dashticz - Module - Spotify (new version!)
EdwinK
Re: Dashticz - Module - Spotify
Post by EdwinK »
Btw.. Nice it doesn't require a premium account
jmvdijk
Post by jmvdijk »
vgr2 wrote:I mean, empty playlist
I have the same problem. Is there a solution for this problem?
barbaar
Re: Dashticz - [BETA]Module - Spotify
Post by barbaar »
I got around this by opening Spotify itself once on the same machine..
But later I found I cannot get this to work in my Tablet using Fully Kiosk Browser. I keep seeing the "INVALID_CLIENT: Invalid redirect URL" error, even after I logged in op developer.spotify.com.
It would be very cool if we got this module to work, and extend a little (play music on other device!)
vgr2
Post by vgr2 »
barbaar wrote:I got around this by opening Spotify itself once on the same machine..
would be nice also for me......
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
I assume you're using the same url on windows and tablet?
For example, some people are using http://localhost/dashticz on windows and http://192.168.1.3/dashticz on another device.
vgr2
Post by vgr2 »
Maybe there is a missunderstanding on my side. At the moment I have to open / or the spotify web api opens Spotify in parallel. Means I have to install on all of the tablets spotify also. My understanding from spotify web api is that should be normaly not needed.
robgeerts
Post by robgeerts »
Indeed, it opens Spotify, but I agree it should play in webbrowser...
Let me get into this!
Derik
Post by Derik »
mmm looks very great...
Only on what speakers do you play this music??
On the tablet very bad...
Other options?
xxx
robgeerts
Post by robgeerts »
Well, it should open Spotify-app (at least on windows, didnt test on tablet yet).
Playing via browser is not supported by the Spotify API...
pollefinario
Post by pollefinario »
Rob, pointed me to this thread. I will check it tonight. Also using Fully Kiosk Browser, did you check any (advanced) settings also?
konix
Post by konix »
vgr2 wrote:Rob, now I have to loging to Spotify parallel, otherwise it will not work.
Hi vgr2,
How did you do to see your playlist finally? I have the button "show playlist" but no popup that opens anything?
Raspberry PI 2 whith Domoticz (Master)
Raspberry PI B+ whith Domoticz (Slave)
Raspberry PI B+ whith OSMC
RFLINK - ZWAVE - TELEINFO - 1 WIRE
vgr2
Post by vgr2 »
Have you installed last beta?
konix
Post by konix »
vgr2 wrote:Have you installed last beta?
Hi vgr2,
I try again and now it's works ..... :roll:
D'rMorris
Post by D'rMorris »
Just so that it might help others: if you only created a Spotify account so that you could test this plugin (like I did), please be aware that you indeed first have to actually play something. I created an account, enabled the developer API, created 2 playlists, got the Spotify login page when refresjng Dashticz, but nothing showed when I clicked playlists. Then I installed the Spotify app on my Android tablet (from which I'm now accessing Dashticz), played a song and all of a sudden the plugin appeared in Dashticz!
ArieKanarie
Post by ArieKanarie »
Is it still necessary to install spotify on the domoticz device?
Because as far as i know spotify cannot be installed on raspberry.. :|
robgeerts
Post by robgeerts »
Yes, i'm sorry, it is.
freakshock
Post by freakshock »
A possible alternative is using Logitech media server with a Spotify plugin (I use Spotty).
This way you can use a standard mediaplayer block in Dashticz. That way you can use back, stop, play/pause and next buttons.
I also made a selector switch that can choose playlist within Spotty (all manual config unfortunately).
Of course you would need a server to run LMS.
nvb1989
Post by nvb1989 »
Amazing plugin!
Is it possible to have the following features:
- If you click on "Select Playlists", also show the playlist label (name). Now there is only a album picture showing.
- Is it possible to show the available songs within a playlist? So you can navigate directly to the correct song?
- Is it possible to have a search field to use the search library within Spotify? So we can play songs outside our playlists?
Very pleased to have spotify now within Domoticz, thanks!!
robgeerts
Post by robgeerts »
First 2 suggestions are new in latest version, check it out!! :)
nvb1989
Post by nvb1989 »
robgeerts wrote: Wednesday 09 August 2017 16:30 First 2 suggestions are new in latest version, check it out!! :)
Great!! It is working. :)
