Page 2 of 2
Re: dzVents 2.0 getting started video
Posted: Sunday 04 March 2018 18:56
by Sarcas
Well done. Looking forward to volume 2!
Posted: Thursday 14 June 2018 22:25
by kamercer
This video was really useful to me, once I found it! How about a link in the wiki? Anyway, I've made a basic index on the topics covered:
1:40 index in Wiki
2:19 open Domoticz example
3:00 adjust Settings
5:21 open blank dzVents
7:50 living room script -> switches kitchen on
10:44 running the living room switch
11:40 explain devices
12:10 explain device object
14:50 print living.state
17:00 if statement
19:40 dimto(25)
21:15 hallway script, using a timer as a trigger
23:30 hallway flash light every minute
25:55 other timer possibilities
28:50 devices plus timer in on section
31:17 the domoticz object
34:45 the domoticz methods
35:00 using print
35:20 execute URL
35:50 make sound
36:10 device object
36:58 text object with two strings combined
39:20 use device ID instead of name
Posted: Sunday 08 December 2019 22:21
by Peterus
I love the video!
I have now finally converted all my Blockly scripts to Dzvents!
Posted: Saturday 29 February 2020 16:36
by alarm_guy1
Hi, is there a very very basic tutorial for someone that has no none nada programming experience, like a hand held walkthrough.
I would love to learn, but kicking around the 50+ mark and starting to find learning new stuff difficult.
Cheers
Posted: Saturday 29 February 2020 17:24
by waaren
alarm_guy1 wrote: Saturday 29 February 2020 16:36
dzVents is almost completely Lua so I suggest you begin with a Lua tutorial.
this tutorial could be a good start.
Posted: Saturday 29 February 2020 17:25
by alarm_guy1
Cheers I will take a look...
Posted: Sunday 12 July 2020 11:51
by mojojojo490
Thanks for the video. For starters it is really great!
Posted: Wednesday 29 June 2022 11:07
by Thuis
I thought id finaly go and try dzvents, so this could be a good starting point.
Great video, what drives me crazy after hours of trying different combinations, i get stuck at 10:42. I think i did the same as in the video.
I can see it writes the file. I can see i initiated a switch command (1379/Living/On), but there is no log showing.
I do this:
return{
active = true,
devices = {
'Living'
domoticz.log('Living lights are switched')
If i add before end: " print('test test') " is see the "test test" in the log.
What am i doing wrong?
Version: 2022.1 (build 14352)
dzVents Version: 3.1.8
Python Version: 3.8.10 (default, Mar 15 2022, 12:22:08) [GCC 9.4.0]
Posted: Wednesday 29 June 2022 11:17
by boum
I would say you need to check your log level.
Either change it in the settings, on the script return array, or locally in the domoticz.log second parameter:
https://www.domoticz.com/wiki/DzVents:_ ... ptional.29
Posted: Wednesday 29 June 2022 11:58
by Thuis
like this ? probably wrong, still nothing.
return{
active = true,
devices = {
'Living'
logging = {
level = domoticz.LOG_DEBUG
print('test test')
Posted: Wednesday 29 June 2022 12:11
by Thuis
Thanks for the help, i give up, ive been trying for a few hours now, and stuck at some stupid logging thing, let alone the rest of the dzvents stuff.
Thanks for the pointer and help. If i have new energy i will try again.
Posted: Wednesday 29 June 2022 12:21
by Thuis
I want structured text implemented in domoticz
VAR
activate: BOOL;
living: BOOL;
light: BOOL;
END_VAR
IF activate AND living THEN
light:=TRUE;
END_IF
Posted: Wednesday 29 June 2022 15:01
by azonneveld
Thuis wrote: Wednesday 29 June 2022 12:21
The language is not much of importance, it is the library that comes with it.
For your STX wish, LUA looks a lot like it, if you mean STX from IEC 61131-3
Posted: Wednesday 29 June 2022 23:19
by plugge
Thuis wrote: Wednesday 29 June 2022 12:11
Change:
Into:
level = domoticz.LOG_INFO
marker = 'living script' -- to easily identify it in the log.
Posted: Monday 22 December 2025 19:50
by TiXav
Very quick to learn, scripts responses very fast, what else ?
Asynchronous http and shell, cancelQueuedCommands and other methods of the library : whaoo !
Thank you a lot !
I just add these 2 lignes and made a PR for selector
Without this, domotice.devices("MySelector").active is always false and .inActive always true and it cannot be tested in the same way as boolean 'on/off' switches althought it can. Tested during 3 days without issue
https://github.com/domoticz/domoticz/pull/6481/commits
- selector active.jpg (99.33 KiB) Viewed 8236 times
