dzVents 2.0 just got integrated into Domoticz (beta v3.8023)
McFranky
Re: dzVents 2.0 just got integrated into Domoticz (beta v3.7968)
I'm running beta 3.7969 and dzVents is not integrated in my system (raspberry 3). The path structure is existing, but in the domoticz settings/others there is no dzVents...
In the events-section there is also no LUA-dzVents...
Greetings from Berlin...
dannybloe
randytsuch
Sh*t happens
Must be really hard to account/test for all the different domoticz environments.
Patiently waiting for 2.0, while continuing to figure stuff out on 1.1.
Thanks for all your efforts, really like dzVents.
Randy
Randy
dannybloe
A new pull-requet is waiting to be merged. This time it runs properly (linux, mac, windows). Stay tuned....
Derik
- Domoticz version: BETA
will try to make some scripts...
Can i use the examples in the dzvents map?
Or better wait??
Or better wait??
Derik
I did try the simple start script genric.lua
Did change the config ip and rename it.
Set the generic into the scripts foldet in the Dzvent folder.
Set a switch [ copy/paste ]
Only i see no: hey .... in my log.
So where do i go wrong?
randytsuch
In Version: 3.8000 there seems to be a permission problem.
I can't make any changes to any files in the scripts/dzVents directory
I tried to edit a file, wont save changes. Also can't rename, delete or create a file.
I can make changes fine in scripts/lua/scripts or scripts/lua/dzVents
I am using cyberduck on a mac, but it has been working fine for me.
Randy
Randy
Doler
Any idea when the pull request is going to be honoured? Looks like its being hold for several commits now.dannybloe wrote:A new pull-requet is waiting to be merged. This time it runs properly (linux, mac, windows). Stay tuned....
Mark
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
Derik
summertime???? really clam here on this peace of forum...
Hope there is some support...
Will try this scripts.. my blockley's canot handle the option i need.
When my solar panels deliver back between x and y and switch A is off.
Turn switch A on.
Els if switch A off
And other type of scripts is higher math..
So i set all my money on dzvents...
Turn switch A on.
Els if switch A off
dannybloe
Still waiting for Gizmocus to merge the pull request. Maybe you guys can vote for the PR
Derik
But are the scripts now not working? [ not by me ]dannybloe wrote:Still waiting for Gizmocus to merge the pull request. Maybe you guys can vote for the PR
I was thinking the out of the box integration with Domoticz was not working.?
Or is it now not possible to run any dzVents script??
dannybloe
You can run dzvents but you need to use the github version. Not the one included woth domoticz. That one doesnt work. Yet.
And the github version is 1.1. But hopefylly giz pulls my request soon.
Derik
dannybloe wrote:You can run dzvents but you need to use the github version. Not the one included woth domoticz. That one doesnt work. Yet.
A link to the pull request? I do not not how this work..
randytsuch
The instructions to install 1.1 is here
https://github.com/dannybloe/dzVents
The harder part with this is you need something to transfer the files from your PC to whatever runs domoicz. Winscp will work to transfer from a PC to a Pi.
Danny
How do we vote for dzvents?
Danny
dannybloe
https://github.com/domoticz/domoticz/pull/1639Derik wrote:A link to the pull request? I do not not how this work..dannybloe wrote:You can run dzvents but you need to use the github version. Not the one included woth domoticz. That one doesnt work. Yet.
It's possible you need a (free) github account to be able to vote. But I'm not sure.
randytsuch
I gave it a thumbs up. Hope that helps get this done.dannybloe wrote: It's possible you need a (free) github account to be able to vote. But I'm not sure.
I did have to make an account there, but it was easy. Just need to verify email on new account before you can vote.
Randy
dannybloe
Glad to inform ye all that as of v3.8023+ dzVents 2.0 has now successfully been integrated.
Again, please check the release notes and the migration instructions for previous version-users as there are a couple of minor changes that may break.
I'm running this integration in production for a while and must say that it works like a charm. Using Domoticz' internal web-editor is quite simple now. Simply switch to dzVents mode and you're good to go.
I'm planning to make a couple of screen recordings in the coming days to help you all get started if reading the (quite extensive) documentation is too much of a hassle. The docs are quite extensive but don't let that scare you off. I've tried to make it easy to read with plenty examples.
Doler
Re: dzVents 2.0 just got integrated into Domoticz (beta v3.8023)
I'm not seeing v3.8023 for Raspberry so guess I have to wait a little bit longer
dannybloe
v3.8023+ means everything higher or equal to 3.8023
. So, just grab 3.8024. But tomorrow it may be 3.8025
Doler
Yeah got that but Raspberry is still on 3.8015, nothing higher so...waiting!!!
