Page 2 of 4
Re: Dashticz - [BETA] - Function - Do something at a specific value
Posted: Tuesday 23 May 2017 15:38
by mikeoo
robgeerts wrote:It's not the same for all devices.
You can search the output (http://DOMOTICZ_URL:8080/json.htm?type=devices&filter=all&used=true&order=Name) for attributes you could use.
For example, you could use for switch:
function getStatus_145(idx,value,device){
if(device['Data']=="On"){
$('div.block_145').addClass('warning');
else {
$('div.block_145').removeClass('warning');
Thanks again for the quick response
Posted: Tuesday 23 May 2017 19:15
by mvveelen
I'm using:
.transbg.col-xs-1, .transbg.col-xs-2, .transbg.col-xs-3, .transbg.col-xs-4, .transbg.col-xs-5, .transbg.col-xs-6, .transbg.col-xs-7, .transbg.col-xs-8, .transbg.col-xs-9, .transbg.col-xs-10, .transbg.col-xs-11, .transbg.col-xs-12 {
padding-top: 15px;
padding-bottom: 15px;
border: 2px solid rgba(255,255,255,0);
background: rgba(0,0,0,0.2);
background-clip: padding-box;
border-radius: 9px;
for the size and rounded corners of the buttons. How can I use (for instance) the orange style code to get the same sized button? Tried a few things, but it still has another size. See attachment.
Posted: Tuesday 23 May 2017 21:30
by htilburgs
If you use this code, I think it should be the same....
.warning {
background: rgba(204,129,44,0.30) !important;
border: 7px solid rgba(255,255,255,0);
Posted: Tuesday 23 May 2017 22:14
by htilburgs
Is it also possible to get multiple devices / IDX in 1 function?
Now I've to add the same function 2, 3 or more times with a different IDX. Is it possible to create a kind of array?
Posted: Tuesday 23 May 2017 22:52
by robgeerts
Not yet but you can do this to by pass this:
if(parseFloat(device['Data'])>24){
else {
function getStatus_5(idx,value,device){
getStatus_145(idx,value,device);
Posted: Wednesday 24 May 2017 17:42
by repoman
htilburgs wrote:If you use this code, I think it should be the same....
.warning {
Hi. I've tried adding the line "border: 7px solid rgba(255,255,255,0);" but nothing seems to change.
The warning block is still bigger...
Is this by design? How can I make them the same size as the others?
Thanks,
Pascal
Posted: Thursday 25 May 2017 12:04
by mvveelen
.warning {
Unfortunately it isn't:
Posted: Thursday 25 May 2017 13:28
by HansieNL
mvveelen wrote:htilburgs wrote:If you use this code, I think it should be the same....
.warning {
Don't know for sure, but what if removing the border code?
Posted: Thursday 25 May 2017 18:46
by mvveelen
I get the same result when I delete that line.
Posted: Thursday 25 May 2017 20:56
by HansieNL
mvveelen wrote:I get the same result when I delete that line.
Does this work?
.warning .transbg.col-xs-1,
.warning. transbg.col-xs-2,
.warning .transbg.col-xs-3,
.warning .transbg.col-xs-4,
.warning .transbg.col-xs-5,
.warning .transbg.col-xs-6,
.warning .transbg.col-xs-7,
.warning .transbg.col-xs-8,
.warning .transbg.col-xs-9,
.warning .transbg.col-xs-10,
.warning .transbg.col-xs-11,
.warning .transbg.col-xs-12 {
padding-top: 15px;
border-radius: 9px;
Posted: Thursday 25 May 2017 21:26
by htilburgs
Maybe you overrule the setting in your custom.css. Is it possible for you to post your custom.css
I've tested the css and for me it's working great.
Posted: Thursday 25 May 2017 22:38
by mvveelen
htilburgs wrote:Maybe you overrule the setting in your custom.css. Is it possible for you to post your custom.css
- Spoiler: show
CUSTOM CSS FILE
.h4.h4 {
font-size: 14px;
.trashcan {
height 36px;
width: 36px;
.warning {
/* Calendar font modifications with icon active */
/*.col-xs-10.items {
/* font-size: 12px;
/* Calendar font modifications with NO icon active */
/*.col-xs-12.items {
/* font-size: 12px;
.trash .state div.trashrow {
font-size: 12px;
.trash .state div.trashtoday {
font-size: 16px;
font-weight: bold;
.trash .state div.trashtomorrow {
font-size: 14px;
font-weight: bold;
/* Transparent background for buttons Thermostat */
.input-groupBtn .btn-number {
opacity: 0.5;
color: white;
background-color: rgb(34, 34, 34);
border-radius: 0px;
padding: 6px 10px 6px 10px;
line-height: 20px;
background-color: transparent;
.swiper-pagination-bullet {
width: 30px !important;
height: 30px !important;
/* Height of the blocktitles and center text in new height */
div.mh.titlegroups {
height: 60px !important;
padding-top: 3px !important;
padding-top: 15px;
border-radius: 9px;
.transbg.col-xs-1.hover:hover,
.transbg.col-xs-2.hover:hover,
.transbg.col-xs-3.hover:hover,
.transbg.col-xs-4.hover:hover,
.transbg.col-xs-5.hover:hover,
.transbg.col-xs-6.hover:hover,
.transbg.col-xs-7.hover:hover,
.transbg.col-xs-8.hover:hover,
.transbg.col-xs-9.hover:hover,
.transbg.col-xs-10.hover:hover,
.transbg.col-xs-11.hover:hover,
.transbg.col-xs-12.hover:hover {padding-top:15px; padding-bottom:15px; border: 2px solid rgba(0,0,0,0); background: rgba(100,100,100,0.8); background-clip: padding-box; border-radius: 9px; }
#newsTicker li {
min-height: 72px;
overflow: hidden;
text-overflow: ellipsis;
text-align: left;
font-size: 14px;
color: #fff;
max-height: 250px; */ Set the maxim height of the news-ticker */
Posted: Friday 26 May 2017 9:38
by htilburgs
Ok, quite a puzzle (but a nice one...
Put this in your custom.css for the .warning part and it should work:
.warning {
padding-top: 15px !important;
padding-bottom: 15px !important;
border-radius: 9px !important;
background-color: rgba(199, 44, 43, 0.3) !important;
border: 2px solid rgba(255,255,255,0) !important;
background-image: initial !important;
background-position-x: initial !important;
background-position-y: initial !important;
background-size: initial !important;
background-repeat-x: initial !important;
background-repeat-y: initial !important;
background-attachment: initial !important;
background-origin: initial !important;
background-clip: padding-box !important;
Let me know, if its OK now.
And I see one minor error in your custom.css.
In the
#newsTicker li part the
*/ Set the maxim height of the news-ticker */ shoud be
/* Set the maxim height of the news-ticker */
For now it's not causing an issue, but you never now what it causes in the future....
Posted: Friday 26 May 2017 11:47
by repoman
htilburgs wrote:Ok, quite a puzzle (but a nice one...
.warning {
Tried this code and I get the rounded corners but the warning blocks are still bigger...
(it's the only code in my custom.css)
Posted: Friday 26 May 2017 11:59
by htilburgs
This was specific for @mveelen, based on his css.
I'll will look into it later on, now busy with my regular job....
Posted: Friday 26 May 2017 12:10
by htilburgs
Try this one:
.warning {
background: rgba(199,44,44,0.7) !important;
Posted: Friday 26 May 2017 12:16
by repoman
Yep, that did the trick!
Posted: Friday 26 May 2017 15:26
by freakshock
robgeerts wrote:I did this to have different colors, depending on the temperature of my living room:
if(parseFloat(device['Data'])>23){
$('div.block_145').removeClass('warning').addClass('warningorange');
else if(parseFloat(device['Data'])>25){
$('div.block_145').removeClass('warningorange').addClass('warning');
else {
$('div.block_145').removeClass('warning').removeClass('warningorange');
Hi Rob,
I think you need to switch the higher value with the lower value.
Your code did not work for me, the blocks remained orange even though the value exceeded 25.
My code:
//kleurtje op knop temp huiskamer wanneer het warmer is dan bepaalde temperatuur (oranje of rood)
function getStatus_90(idx,value,device){
if(parseFloat(device['Temp'])>25){
$('div.block_90').removeClass('warningoranje').addClass('warning');
else if(parseFloat(device['Temp'])>23){
$('div.block_90').removeClass('warning').addClass('warningoranje');
else {
$('div.block_90').removeClass('warning').removeClass('warningoranje');
Posted: Friday 26 May 2017 19:32
by mvveelen
- Spoiler: show
.warning {
In the
Yesssss, that's it !! Thanks !
Also changed the newsTicker-part
Posted: Friday 26 May 2017 19:37
by htilburgs
mvveelen wrote:htilburgs wrote:Ok, quite a puzzle (but a nice one...
- Spoiler: show
.warning {
In the
I also noticed a minor in .trashcan. After height the : is missing. (I know, I'm a nitpicker
