Dashticz - Function - Trigger action on specific value
mikeoo
Re: Dashticz - [BETA] - Function - Do something at a specific value
Post by mikeoo »
robgeerts wrote:It's not the same for all devices.
You can search the output (http://DOMOTICZ_URL:8080/json.htm?type=devices&filter=all&used=true&order=Name) for attributes you could use.
For example, you could use for switch:
function getStatus_145(idx,value,device){
   if(device['Data']=="On"){
      $('div.block_145').addClass('warning');
   else {
      $('div.block_145').removeClass('warning');
Thanks again for the quick response
mvveelen
Post by mvveelen »
I'm using:
.transbg.col-xs-1, .transbg.col-xs-2, .transbg.col-xs-3, .transbg.col-xs-4, .transbg.col-xs-5, .transbg.col-xs-6, .transbg.col-xs-7, .transbg.col-xs-8, .transbg.col-xs-9, .transbg.col-xs-10, .transbg.col-xs-11, .transbg.col-xs-12 {
    padding-top: 15px;
    padding-bottom: 15px;
    border: 2px solid rgba(255,255,255,0);
  background: rgba(0,0,0,0.2);
  background-clip: padding-box;
border-radius: 9px;
for the size and rounded corners of the buttons. How can I use (for instance) the orange style code to get the same sized button? Tried a few things, but it still has another size. See attachment.
Schermafbeelding 2017-05-23 om 19.18.20.png (266.8 KiB) Viewed 4576 times
htilburgs
Post by htilburgs »
If you use this code, I think it should be the same....
.warning {
   background: rgba(204,129,44,0.30) !important;
   border: 7px solid rgba(255,255,255,0);
Hardware:
htilburgs
Post by htilburgs »
Is it also possible to get multiple devices / IDX in 1 function?
Now I've to add the same function 2, 3 or more times with a different IDX. Is it possible to create a kind of array?
Hardware:
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Not yet but you can do this to by pass this:
	if(parseFloat(device['Data'])>24){
	else {
function getStatus_5(idx,value,device){
         getStatus_145(idx,value,device);
repoman
Post by repoman »
htilburgs wrote:If you use this code, I think it should be the same....
.warning {
Hi. I've tried adding the line "border: 7px solid rgba(255,255,255,0);" but nothing seems to change.
The warning block is still bigger...
Is this by design? How can I make them the same size as the others?
Thanks,
Pascal
mvveelen
Post by mvveelen »
.warning {
Unfortunately it isn't:
Schermafbeelding 2017-05-25 om 12.07.02.png (290.53 KiB) Viewed 4508 times
HansieNL
Post by HansieNL »
.warning {
Don't know for sure, but what if removing the border code?
Blah blah blah
mvveelen
Post by mvveelen »
I get the same result when I delete that line.
HansieNL
Post by HansieNL »
mvveelen wrote:I get the same result when I delete that line.
Does this work?
.warning .transbg.col-xs-1,
.warning. transbg.col-xs-2,
.warning .transbg.col-xs-3,
.warning .transbg.col-xs-4,
.warning .transbg.col-xs-5,
.warning .transbg.col-xs-6,
.warning .transbg.col-xs-7,
.warning .transbg.col-xs-8,
.warning .transbg.col-xs-9,
.warning .transbg.col-xs-10,
.warning .transbg.col-xs-11,
.warning .transbg.col-xs-12 {
    padding-top: 15px;
border-radius: 9px;
Blah blah blah
htilburgs
Post by htilburgs »
Maybe you overrule the setting in your custom.css. Is it possible for you to post your custom.css
I've tested the css and for me it's working great.
Hardware:
mvveelen
Post by mvveelen »
htilburgs wrote:Maybe you overrule the setting in your custom.css. Is it possible for you to post your custom.css
CUSTOM CSS FILE
.h4.h4 {
    font-size: 14px;
.trashcan {
    height 36px;
    width: 36px;
.warning {
/* Calendar font modifications with icon active */
/*.col-xs-10.items {
/*   font-size: 12px;
/* Calendar font modifications with NO icon active */
/*.col-xs-12.items {
/*   font-size: 12px;
.trash .state div.trashrow {
    font-size: 12px;
.trash .state div.trashtoday {
    font-size: 16px;
    font-weight: bold;
.trash .state div.trashtomorrow {
    font-size: 14px;
    font-weight: bold;
/* Transparent background for buttons Thermostat */
.input-groupBtn .btn-number {
    opacity: 0.5;
    color: white;
    background-color: rgb(34, 34, 34);
    border-radius: 0px;
    padding: 6px 10px 6px 10px;
    line-height: 20px;
    background-color: transparent;
.swiper-pagination-bullet {
    width: 30px !important;
    height: 30px !important;
/* Height of the blocktitles and center text in new height */
div.mh.titlegroups {
    height: 60px !important;
    padding-top: 3px !important;
    padding-top: 15px;
border-radius: 9px;
.transbg.col-xs-1.hover:hover,
.transbg.col-xs-2.hover:hover,
.transbg.col-xs-3.hover:hover,
.transbg.col-xs-4.hover:hover,
.transbg.col-xs-5.hover:hover,
.transbg.col-xs-6.hover:hover,
.transbg.col-xs-7.hover:hover,
.transbg.col-xs-8.hover:hover,
.transbg.col-xs-9.hover:hover,
.transbg.col-xs-10.hover:hover,
.transbg.col-xs-11.hover:hover,
.transbg.col-xs-12.hover:hover {padding-top:15px; padding-bottom:15px; border: 2px solid rgba(0,0,0,0); background: rgba(100,100,100,0.8); background-clip: padding-box; border-radius: 9px; }
#newsTicker li {
    min-height: 72px;
    overflow: hidden;
    text-overflow: ellipsis;
    text-align: left;
    font-size: 14px;
    color: #fff;
    max-height: 250px;    */ Set the maxim height of the news-ticker */
htilburgs
Post by htilburgs »
Ok, quite a puzzle (but a nice one...;-)).
Put this in your custom.css for the .warning part and it should work:
.warning {
	padding-top: 15px !important;
	padding-bottom: 15px !important;
	border-radius: 9px !important;
	background-color: rgba(199, 44, 43, 0.3) !important;
	border: 2px solid rgba(255,255,255,0) !important;
	background-image: initial !important;
	background-position-x: initial !important;
	background-position-y: initial !important;
	background-size: initial !important;
	background-repeat-x: initial !important;
	background-repeat-y: initial !important;
	background-attachment: initial !important;
	background-origin: initial !important;
	background-clip: padding-box !important;
Let me know, if its OK now.
And I see one minor error in your custom.css.
In the #newsTicker li part the */ Set the maxim height of the news-ticker */ shoud be /* Set the maxim height of the news-ticker */
For now it's not causing an issue, but you never now what it causes in the future....;-)
Hardware:
repoman
Post by repoman »
htilburgs wrote:Ok, quite a puzzle (but a nice one...;-)).
.warning {
Tried this code and I get the rounded corners but the warning blocks are still bigger...
(it's the only code in my custom.css)
htilburgs
Post by htilburgs »
This was specific for @mveelen, based on his css.
I'll will look into it later on, now busy with my regular job....;-)
Hardware:
htilburgs
Post by htilburgs »
repoman wrote: Tried this code and I get the rounded corners but the warning blocks are still bigger...
Try this one:
.warning {
	background: rgba(199,44,44,0.7) !important;
Hardware:
repoman
Post by repoman »
Yep, that did the trick!
freakshock
Post by freakshock »
robgeerts wrote:I did this to have different colors, depending on the temperature of my living room:
	if(parseFloat(device['Data'])>23){
		$('div.block_145').removeClass('warning').addClass('warningorange');
	else if(parseFloat(device['Data'])>25){
		$('div.block_145').removeClass('warningorange').addClass('warning');
	else {
		$('div.block_145').removeClass('warning').removeClass('warningorange');
Hi Rob,
I think you need to switch the higher value with the lower value.
Your code did not work for me, the blocks remained orange even though the value exceeded 25.
My code:
//kleurtje op knop temp huiskamer wanneer het warmer is dan bepaalde temperatuur (oranje of rood)
function getStatus_90(idx,value,device){
   if(parseFloat(device['Temp'])>25){
      $('div.block_90').removeClass('warningoranje').addClass('warning');
   else if(parseFloat(device['Temp'])>23){
      $('div.block_90').removeClass('warning').addClass('warningoranje');
   else {
      $('div.block_90').removeClass('warning').removeClass('warningoranje');
mvveelen
Post by mvveelen »
.warning {
Yesssss, that's it !! Thanks !
Also changed the newsTicker-part :)
htilburgs
Post by htilburgs »
.warning {
I also noticed a minor in .trashcan. After height the : is missing. (I know, I'm a nitpicker ;-))
Hardware:
