Page 2 of 2
Re: How can I remove a non-existing Z-wave Node/Device (Success)
Posted: Friday 06 November 2020 9:55
by mcwieger
Try this tool. Very basic, but it always does the trick.
https://aeotec.freshdesk.com/helpdesk/a ... 6091420613
Posted: Tuesday 10 November 2020 22:44
by Plantje
Janco wrote: Saturday 17 October 2020 15:48
Thanks! You saved my day. I had the same problem after trying to delete and re-include a faulty device.
Thank you for getting back to me and pointing me in the right direction! (I am not being sarcastic here, Janco did so in a private message)
And this was the best link to the software as this IS the Zensys tool that people are referring to. Thanks! did the trick!
This time, I was happy running Domoticz on a Windows machine. This way, I can easily just install the software and control my Z-Wave stick. I made a backup and removed the node that kept on popping up! Perhaps this tooling helps me controlling the Z-Wave network and devices better.
Posted: Monday 23 November 2020 9:50
by Yann
No it is not the correct address, the tool is from silicon labs.
Here is one link (you will find many on the web)
https://aeotec.freshdesk.com/support/so ... -download-
I am using the older version but principles should remain the same
Posted: Monday 23 November 2020 9:57
by Plantje
Euh.... I was trying to do that as well. And you need to go through that "simplicity studio" stuff to get PC controller 5. Do you see any advantages of PC Controller 5 over 4.78?
Posted: Wednesday 25 November 2020 11:48
by Yann
I don't know I am not using 5, only using 4.78 and it works very well.
Posted: Wednesday 25 November 2020 12:55
by Plantje
Yeah, it seems to the trick just fine. I finally got to delete a node that has been there for months! Makes you think about the other Z-wave stuff that doesn't go too well
Posted: Wednesday 16 December 2020 18:45
by DosN
i have also a node which is not present anymore, using fibaro sensors
i can also not reset de z-wave.me stick of delete the node which is not present anymore
i have the latest beta version of Domoticz
How can i remove the unused node ?
Posted: Wednesday 16 December 2020 18:53
by DosN
i installed ZWaveController.exe but i see no connection
Posted: Wednesday 16 December 2020 18:56
by Plantje
Make sure you stop the Domoticz service before starting the tool. Otherwise it looks like there is no Z-Wave stick
Posted: Wednesday 16 December 2020 21:24
by DosN
I did stop Domoticz , but the tool does not see anything
I start the tool on my win10 system , and the stick is in a pi3.
Posted: Wednesday 16 December 2020 21:38
by madpatrick
You must use the tool and stick on the same system, so in this case both on the same pc with Win10
Posted: Wednesday 16 December 2020 22:08
by Plantje
Ah, yes, like that. It looks for a local stick indeed. In case of the Aeotec stick the configuration is stored on the stick itself, so it should be fairly simple to connect it to the Windows machine running the tool
Posted: Wednesday 16 December 2020 22:17
by DosN
ok yes i see.
i put zwave stick in win pc and start programm
when i want to remove it(press remove icon), i get a pop-up
controller is waiting for teh node info
pres shorty the pushbutton on the node to be excluded from the netwok.
but i haven't the node anymore , so i cannot press the button
Posted: Thursday 17 December 2020 13:59
by madpatrick
It is to long ago for me.
I thought you must delete the device and not remove
I'd the same issue and did succeed in removing an old device which i don have anymore
Posted: Thursday 17 December 2020 14:44
by DosN
Posted: Thursday 17 December 2020 14:46
by DosN
this is what i see
Posted: Thursday 17 December 2020 22:28
by Plantje
So, you selected a node, ticked query override, clicked "send NOP", clicked "Node isfailed" and clicked "Remove failed node"?
Or are you unable to get that far?
Posted: Friday 18 December 2020 6:36
by DosN
Hi Plantje
yes it worked , thx . that sequence and the right buttons will removed the node .
Posted: Friday 18 December 2020 7:26
by Plantje
Good to hear!
I have used it quite often the past few days as I am troubleshooting Z-Wave in Domoticz in general.
What it comes down to is basically this: after adding a node, the node and its devices are added and work just fine. But over the coarse of a few days, weeks or months weird things start happening.
I will open a separate topic on this
Posted: Friday 18 December 2020 12:20
by DosN
Yes strange things happoning at open zwave
i have two old fibaro sesnors they work fine, i bough a new one but this one is not working will
i even clammed a new one at the store and same think . some reading are not correct
i checked a open zwave controller (at domoticz) and some sensor values are not correct .
Also some sensor inputs are overright eachother . very strange
