EDIT: Fixed
Dashticz - Bug report
- HansieNL
Re: Dashticz - Bug report
Just updated to latest beta and all the trash info is gone. I have only the icon left. Anyone else has same problem?
EDIT: Fixed
EDIT: Fixed
Blah blah blah
robgeerts
- Domoticz version: 3.7067
Fixed in beta!
- htilburgs
Confirmed! And the new var trashnames / colors work nice!!robgeerts wrote:Fixed in beta!
Hardware:
Blueone
Please test in latest beta!robgeerts wrote:Blueone wrote:There appear to be a new bug with the thermostat function. Every 5 seconds (the refresh time) there is a class added to the thermostat setpoint. When you increase or decrease the setpoint the action is done for every added class, zo if you have the dashboard open for a couple of minutes the classed several dozens of classes are added to the setpoint, and it is going to change the setpoint for every class and one click will change the setpoint with 10 degrees for example:
Sorry, not working yet, I know have one setpoint with loads of classes which increases with every refresh and one setpoint without a thermostat**** class. The up and down aren't working at all.
I also verified the code I added in the addthermostat function in main.js but that isn't causing the issue.
robgeerts
Could you try once in another browser?
Blueone
My mistake, I had some code in custom.js which was interfering. Both setpoint don't have a thermostat class at all at the moment, so changing the setpoint doesn't work but the multiple classes are gone.
robgeerts
Those classes arent used anymore
Blueone
Oke clear, but the increase and decrease doenst work at the moment
, so there is still a small bug somewhere.
maninblack30
on the latest master I have a selector switch, if I operate any other switch once, the drop-down for the selector doesn't stay open long enough for me to select, tried chrome and IE. it works fine if it's the first switch i use after a reload, but as soon as I operate anything else it breaks again.
Ta,
Ta,
mikeoo
Updated to latest beta and cleared the cache.
I use some door sensors with Xiaomi Mi Smart Home Gateway 2.
Added them to Dashticz and try to use some other icons instead of the default ones because i want to use the doorsensor as a windowssensor.
For the test i use this in config.js
But it keeps the default doorsensor icon .
When i do the same for a dummy switch it is working fine.
blocks[1980] = {}
blocks[1980]['icon'] = 'fa-window-close';
blocks[1980]['title'] = 'Voordeur';
blocks[1980]['show_lastupdate'] = true;When i do the same for a dummy switch it is working fine.
qwerk
hi,
since today I get
a java error main.js/v=54 line:417
It is not the lat beta also before that.
Is it my installation, or is dashticz?
since today I get
- HansieNL
I'm not sure of this works in your case... maybe you can try? Add following code to custom.js. Change to your own icon.mikeoo wrote:Updated to latest beta and cleared the cache.
But it keeps the default doorsensor icon .Code: Select all
blocks[1980] = {} blocks[1980]['icon'] = 'fa-window-close'; blocks[1980]['title'] = 'Voordeur'; blocks[1980]['show_lastupdate'] = true;
function getBlock_1980(device,idx){
$('.block_'+idx).attr('onclick','switchDevice(this)');
var html='';
html+='<div class="col-xs-4 col-icon">';
if(device['Status']=='Closed') html+='<img src="img/your_icon_closed.png" class="off icon" />';
else html+='<img src="img/your_icon_open.png" class="on icon" />';
html+='</div>';
html+='<div class="col-xs-8 col-data">';
html+='<strong class="title">'+device['Name']+'</strong><br />';
if(device['Status']=='Off') html+='<span class="state">Closed</span>';
else html+='<span class="state">Open</span>';
if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
html+='</div>';
return html;
Blah blah blah
robgeerts
Try latest beta..qwerk wrote:hi,
since today I get
Do you still have the issue in this version?
qwerk
had it a few tmes with at least two dashticz versionsrobgeerts wrote:Try latest beta..qwerk wrote:hi,
since today I get
moved to latest beta and other webserver.
did not have it anymore
mikeoo
Nice, code is working fine.HansieNL wrote:I'm not sure of this works in your case... maybe you can try? Add following code to custom.js. Change to your own icon.mikeoo wrote:Updated to latest beta and cleared the cache.
function getBlock_1980(device,idx){ $('.block_'+idx).attr('onclick','switchDevice(this)'); var html=''; html+='<div class="col-xs-4 col-icon">'; if(device['Status']=='Closed') html+='<img src="img/your_icon_closed.png" class="off icon" />'; else html+='<img src="img/your_icon_open.png" class="on icon" />'; html+='</div>'; html+='<div class="col-xs-8 col-data">'; html+='<strong class="title">'+device['Name']+'</strong><br />'; if(device['Status']=='Off') html+='<span class="state">Closed</span>'; else html+='<span class="state">Open</span>'; if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>'; html+='</div>'; return html; }
Only problem when you need to use it for more sensors you get a lot of extra code in custom.js for every sensor.
Why does it works for most sensor when you change the icon in CONFIG.js but not for this type of sensor.
Blueone
Oke, i found the bug in this piece of code:Blueone wrote:Oke clear, but the increase and decrease doenst work at the moment, so there is still a small bug somewhere.
[/code]
if(typeof(addedThermostat[idx])=='undefined'){
addThermostatFunctions('.block_'+idx+'_2');
addedThermostat[idx] = true;
[/code]
The ‘_2’ is hardcoded while not every setpoint block contains the _2, for example, mine setpoint block class is simply Block_628, so the clickevent isn’t added to the block.
BTW: The thermostatfunctions are also added to the temperature blocks at the moment, not really an issue but it isn’t nessecary
robgeerts
Thanks for finding the bug, will fix this asap!
robgeerts
Could you test latest beta?Blueone wrote:Oke, i found the bug in this piece of code:Blueone wrote:Oke clear, but the increase and decrease doenst work at the moment, so there is still a small bug somewhere.
[/code]
[/code]
robgeerts
Should be fixed in latest beta!mikeoo wrote:Updated to latest beta and cleared the cache.
- htilburgs
@robgeerts, I'm using the index2 / custom_2 option right now. Works great, but....
Can it be that the custom.css doesn't work that's in this directory? Or did I miss something?
Hardware:
