Page 2 of 5
Re: Gearoticz | Gear S3 and S2 Tizen implementation awaiting validation
Posted: Friday 19 May 2017 8:31
by ehallq
Bad news, they rejected the app since they wasn't able to test it, I need to provide a test account. Only thing is, I did, and I gave them a test account. I will make a video for them as they probably have trouble understanding what this is. I guess we need to wait a bit more, sorry
EDIT:
Video sent, and I pointed towards my test notes which they clearly didnt read last time... :/
Looks like it will take another week
Posted: Friday 19 May 2017 14:07
by JoXeTe
I can not find the application from the Samsung Gear application portal ... is there any problem ?. I'm looking for "Gearoticz" ....
Posted: Friday 19 May 2017 15:30
by ehallq
JoXeTe wrote:I can not find the application from the Samsung Gear application portal ... is there any problem ?. I'm looking for "Gearoticz" ....
App is not out yet, I am waiting for validation. Samsung rejected the application this morning since they didnt understand what the app did. I have resubmitted it with a video showing them how to do it.
Posted: Tuesday 23 May 2017 10:25
by ehallq
App is released
Link in first post!
Please report bugs and/or suggestions here
Posted: Tuesday 23 May 2017 13:37
by JoXeTe
For the first version € 0.92 !!! I find it very expensive .....
It is true that it is a great contribution, but, of there is to pay ....
Posted: Tuesday 23 May 2017 21:41
by pwhooftman
just installed the app on my S3, entered the credentials, all my switches show up fine but they do not switch if i press them...
Posted: Tuesday 23 May 2017 21:59
by pwhooftman
suggestions:
- switches should have a 1 sec press & hold to prevent switching when scrolling
- when i switched a certain switch and use the back key 1 or two times, every now and then the screen shows "Settings" header in blue, then the name of the last switch, and then "Settings" as a white button. Other times, only the Settings button is showing. The gui is inconsistent when using the back key
- the state of the switches is not shown (all are off), and switching does not work
- this app would benefit or using favourites or shortcuts to limit the switch list to most used.
- other categories (energy etc) most welcome!
EDIT: app just lost all entered server info, switches still showing but not functioning....
Posted: Wednesday 24 May 2017 8:16
by ehallq
pwhooftman wrote:just installed the app on my S3, entered the credentials, all my switches show up fine but they do not switch if i press them...
What you see there is the part in settings where you add your switches. These switches will appear on the first screen if you step back from settings.
pwhooftman wrote:suggestions:
- No, this wont happen since you are supposed to scroll with the bezel. I know that bezel-scrolling doesnt work in settings/switches, but you are only supposed to add what switches you want to use there. In the meny where you actually turn on and off switches, scrolling with bezel works. I dont want a delay because that makes everything go so slow. Thats one of the reasons I dont like the Android Wear implementation. But it needs this kind of setup since not all watches have bezels/scrolling wheels.
- You probably have been mixing up the settings/switches menu with the first start menu. Settings is a white button which leads you to the settings menu where you can add and remove switches from the first screen. The blue settings text is a title
- Again you are in the wrong menu
- This is what the app currently have, you select what favorite switches/scenes you have and add them
- Noted, could be added later together with temperature
About the server info, its not gone, its saved on the device, however the menu is just empty since there is no need to show it any more.
I will make some sort of guide, see first post
Posted: Wednesday 24 May 2017 21:39
by pwhooftman
a, that explains a lot, all working now. ++
Posted: Friday 26 May 2017 11:35
by BluesBro
There really should be a watchface to complement Domoticz ont the Gear. I'm no good in programming it my self, but I surly would pay for one!
Posted: Monday 29 May 2017 8:55
by ehallq
BluesBro wrote:There really should be a watchface to complement Domoticz ont the Gear. I'm no good in programming it my self, but I surly would pay for one!
Ok, what should the watchface do to complement Domoticz?
Posted: Monday 29 May 2017 21:05
by zicht
Love the app --> Great work, works like a charm and intuitive once it is setup !
I had a good laugh about the comment someone made in the store
Posted: Sunday 18 June 2017 10:45
by DieterKoblenz
Great app! Could you also implement the selector list switch?
Posted: Thursday 03 August 2017 0:07
by ehallq
An update is out! This adds temperatures to the list, and also darken the background to pitch black instead of the greyish color. It also fixes the bug where for example 60% dim would set to 59%
Posted: Tuesday 29 August 2017 8:48
by Henrik
Love this app. Works great on my S3 Classic.
However there is one small thing, I would like to address. I'm using a "Push On Button" for my garage door, which by definition should always be off.
However on the Gear it always shows as On, so I have to press the button twice to activate it. Once for turning it off, which does nothing, and then again for turning it on.
I don't know if its a bug in Domoticz, but I have also made this post:
http://domoticz.com/forum/viewtopic.php?f=6&t=19145
Maybe you could look at the "Data" field too?
Posted: Wednesday 20 September 2017 0:10
by tinytomos
I really findthe app great, after i have selected swiched can i then decide which switch is at the top of the list??
Like the change order of appearance
Thanks for the app
Posted: Tuesday 26 September 2017 14:12
by ehallq
Henrik wrote: Tuesday 29 August 2017 8:48
Really nice to hear, thanks!
I see, I havent tought about that case, so I will need to fix it. Not sure when I will make a update, have alot of work todo with my actual job, but I will find some time. What you could do is a ordinary switch that have a 1 sec off delay and with lua/blocky triggers the garage door when being turned on.
tinytomos wrote: Wednesday 20 September 2017 0:10
Thanks for the app
Thanks foor the feedback!
The current way to change the order is to remove your selected switches and and select the switches in the order you want them. However Scenes/groups will always be at the top,this is because on the watch you are more likely to trigger a bunch of lights with a single click rather than using multiple buttons.
Posted: Thursday 28 September 2017 17:14
by chatainsim
Since the last update, app stop working on my Gear S2.
I add my server but then I'm not able to add temp device or switch or anything else.
Is there a way to get logs ?
Posted: Wednesday 18 October 2017 17:37
by dynammo
I bought the app, i see my switchs and temp switchs, i selected what i want, return to home of app, but ... Action on them don't work.
Temp switch indicate "Temperature". Switch tap : the gear S3 buzz but nothing work.
I'm alone to have a problem ?
Domoticz app on my phone works fine.
Gear S3 / Domoticz Version: 3.8590
Any help will be appreciated
Many thanks.
Posted: Monday 30 October 2017 20:20
by jeanbart
When will this be available for Gear Sport (SM-R600NZKAPHN)?
Edit:
Just noticed this morning it got fixed!
