Page 2 of 2
Re: ACDB-6500BC doorbell
Posted: Saturday 15 February 2014 22:37
by Mavy
I am using this same doorbell and for me it worked without any issues. The only difference i can see is that i have ATI,AD and Hideki enabled.
@mbliek, i am pretty sure the 6500BC is an ARC devices because it has the Letter code selector.
Posted: Monday 17 February 2014 20:44
by Heisenberg
I tried again by pushing the doorbell and this is what I see in the ' Not Used' Devices section. But after I added the unit by giving it a name (Doorbell) and push the doorbell again, nothing happens.
Posted: Monday 17 February 2014 21:06
by b_weijenberg
The doorbell button transmits only an ON command.
You have the reset the state to OFF before you will see the ON command change.
Posted: Monday 17 February 2014 21:14
by Heisenberg
b_weijenberg wrote:The doorbell button transmits only an ON command.
Thnx for the quick reply. Could you tell me how to reset to OFF state? Do I need to reset the Doorbell receiver or something else?
Posted: Monday 17 February 2014 21:51
by mbliek
Heisenberg wrote:b_weijenberg wrote:The doorbell button transmits only an ON command.
No need for that, it doesn't show on/off in domoticz.
Did you add the doorbell as type doorbell?
Not just only the name.
Posted: Tuesday 18 February 2014 9:53
by Heisenberg
mbliek wrote:Heisenberg wrote:b_weijenberg wrote:The doorbell button transmits only an ON command.
Yes, I did. But still no recognition in Domiticz when I push the button. The doorbell does ring when front door button is pushed.
Posted: Tuesday 18 February 2014 10:03
by Mavy
What exactly are you trying to achieve? As said before the doorbell only send an on command, so you wont actually see anything change other then a new on record in the log.
Posted: Tuesday 18 February 2014 18:28
by Heisenberg
Mavy wrote:I am using this same doorbell and for me it worked without any issues. The only difference i can see is that i have ATI,AD and Hideki enabled.
Gents,
Today I sucessfully added this doorbell. It was indeed recognized by Domoticz as an ARC device. I suddenly was able to see the device after pushing doorbell button on front door. Thnx all!
Posted: Wednesday 19 February 2014 15:44
by mbliek
Glad it's working now
Posted: Sunday 04 October 2015 20:24
by sincze
Mavy wrote:What exactly are you trying to achieve? As said before the doorbell only send an on command, so you wont actually see anything change other then a new on record in the log.
In this case I would like to achieve
If (dark) & (doorbell is pressed (status = chime) then "switch on front door light"
after 1 minute switch off the light.
I thought if status of the doorbell would reset to "off" after 1 minute this could help me to switch the front light off.
The reset option is available with the motion sensor.
Posted: Friday 11 December 2015 21:03
by robingerritsen
Heisenberg wrote:Mavy wrote:I am using this same doorbell and for me it worked without any issues. The only difference i can see is that i have ATI,AD and Hideki enabled.
Gents,
I have exact the same problem! Can you tell me what you did?
i have enabled the ARC protocol, but it still wont work......
Posted: Thursday 21 September 2017 6:48
by Ariz
thnx, looking forward to read your installation steps.
gclub
