PlayBlub (Bluetooth Bulb) Python Plugin - Beta tester Wanted
deennoo
Re: PlayBlub (Bluetooth Bulb) Python Plugin - Beta tester Wanted
If you have some Time and knowledge you can search which Handle are use to drive color and effect
I can give you à Small how to, that easy to do but long.
http://domo-attitude.fr
poudenes
- Domoticz version: 3.8993
I have some knowledge to do some tests, my biggest issue i can't program
. So if you tell me how to do it, then i will test it.
deennoo
ok i think that we just need to have some value, i send you mp for this
- Mediacj
I managed to get them working without your great software with the gatttool, but I had to change the address for handle color from 0x0016(in your plugin.py) to 00x0019 in gattool to let it work. So there seems a shift of 3.zaraki673 wrote:Hi Mediacj,
have you this issue on every heartbeat ? or just one time ?
i think it's just an init error in my code, i will see that ASAP
Domoticz: 3.7243
Python: Python 2.7.9 (python -V)
but also Python 3.4.2 (python3 -V)
Bulb: Playbulb Candle
Firmware: BTL300_v6
zaraki673
I just update RGBW plugin with this informations, thank's
https://github.com/zaraki673/MiPow-Play ... /plugin.py
can you try ?
can you try ?
- Mediacj
Thanks! I also changed the address in plugin.py but that didn't help for the connection errors, this is what I get now with your new version:zaraki673 wrote:I just update RGBW plugin with this informations, thank's
can you try ?
2017-04-14 22:55:03.615 (Playbulb) Initialized version 1.0.1, author 'zaraki673'
2017-04-14 22:55:03.616 (Playbulb) Debug log level set to: 'true'.
2017-04-14 22:55:03.618 (Playbulb) Error connecting device - is it up ?
2017-04-14 22:55:03.618 (Playbulb) 'Mode3':'0'
2017-04-14 22:55:03.618 (Playbulb) 'Mode1':'8'
2017-04-14 22:55:03.618 (Playbulb) 'Name':'Playbulb'
2017-04-14 22:55:03.618 (Playbulb) 'Mode6':'Debug'
2017-04-14 22:55:03.618 (Playbulb) 'Mode2':'0'
2017-04-14 22:55:03.618 (Playbulb) 'HomeFolder':'/home/jan/domoticz/plugins/mipow/'
2017-04-14 22:55:03.618 (Playbulb) 'Address':'ED:C6:4B:11:AC:E6'
2017-04-14 22:55:03.618 (Playbulb) 'Port':'0'
2017-04-14 22:55:03.618 (Playbulb) 'HardwareID':'27'
2017-04-14 22:55:03.618 (Playbulb) 'Key':'MiPow'
2017-04-14 22:55:03.618 (Playbulb) 'Author':'zaraki673'
2017-04-14 22:55:03.618 (Playbulb) 'Version':'1.0.1'
2017-04-14 22:55:03.618 (Playbulb) Device count: 8
2017-04-14 22:52:52.671 (Playbulb) Calling message handler 'onHeartbeat'.
2017-04-14 22:52:52.671 (Playbulb) Error getting status
2017-04-14 22:52:52.674 (Playbulb) Error connecting device - is it up ?-
zaraki673
the plugin can't connect to your candle when you see this message, so you should :
- check hci you have configure, (hci0, hci1 or hci2) you can check device available when running hcitool dev
- check mac address
- check if your candle is on
- check nothing other is connect (don't know if some playbulb can have multiple connection at the same time)
- check mac address
- Mediacj
Thx for your respond but I have done that alreadyzaraki673 wrote:the plugin can't connect to your candle when you see this message, so you should :
- check mac address
It is hci0 I have the correct mac address and it is on, under gatttool it works with these parameters. And I switch it off and on and disconnect the bluetooth connection before I go back to Domoticz.
But it works under Rasp Zero W now, only thing is when I switch the playbulb effect to off the candle is switched off, so I can't set it to no effect.
zaraki673
downoad it again, you will have btle error code in log now, then we will see where error is
- Mediacj
Done that! And now it works just recompiled bluez etc. because I got a exception error on it. To be more specific, this was the solution, it seems that there is a problem under Ubuntu with the compiling of Bluez:
One thing I had to remove a extra ':' in your source on line 572 (::) because it gave a error in the Domoticz log when starting.
Many thanks for your help!
cd "/usr/local/lib/python3.5/dist-packages/bluepy-1.0.5-py3.5.egg/bluepy/"
sudo makeOne thing I had to remove a extra ':' in your source on line 572 (::) because it gave a error in the Domoticz log when starting.
zaraki673
Thank's I remove itMediacj wrote:Done that! And now it works just reinstalled bluez etc. because I got a exception error on it.
poudenes
Using the latest plugin.py with my Sphere - Spot (fw:BTL203M_V1.6) work so nice!!!
Hope the development will go on so we get less switched and a color picker multi color switch like Philips Hue
zaraki673
Hi, sorry, i'm working on another plugin , i will try to update this one soon
poudenes
That would be great !!! Im open to test the plugin.
poudenes
Maybe to excited.. Any news or update for the PlayBlub plugin?
deennoo
dev is working on another plugin who need more time in developement (RFP1000 : USB key for 433 and 868 devices), surely he will came back to this soon, but he need to finish rfp1000 firstpoudenes wrote:Maybe to excited.. Any news or update for the PlayBlub plugin?
poudenes
Ok
i'll will wait
deennoo wrote: dev is working on another plugin who need more time in developement (RFP1000 : USB key for 433 and 868 devices), surely he will came back to this soon, but he need to finish rfp1000 first
poudenes
Hi There all,
Any idea when this plugin will updated? change all color switches into a color selector?
Also have 4 new bulbs "Smart" with FM BT_201 they work with settings of sphere/smart
deennoo
poudenes
2017-05-14 11:40:23.171 (Raam Links) Calling message handler 'onHeartbeat'.
2017-05-14 11:40:23.241 (Raam Links) Error getting status
2017-05-14 11:40:23.253 (Raam Links) Error connecting device - is it up ? (btle error code : 1)
I see this msg for all my MiPow Bulbs. They are working. Can do everything with it inside Domoticz. But get this error as well
But what can i do to solve this?
