I've gone and made some simple mods to the code for the AVR-X2300W and now each zone turns on/off when the relevant selector switch is used. The 'main' power switch turns both on/off. I also modified the list of inputs to match those for the AVR and have attached the code for those interested.
# Denon & Marantz AVR plugin
# Author: Dnpwwo, 2016 - 2017, Artemgy 2017
# Mode3 ("Sources") needs to have '|' delimited names of sources that the Denon knows about.
# The Selector can be changed afterwards to any text and the plugin will still map to the actual Denon name.
# Modified by rjblake for Denon AVR-X2300W. Only powers on the Main Zone or Zone2 when a single zone is selected. Main Power turns both Zone on/off
# Also changed names of the inputs to match those for the AVR
<plugin key="DenonMarantz" version="2.5.5" name="Denon / Marantz AVR Amplifier" author="dnpwwo/artemgy" wikilink="" externallink="http://www.denon.co.uk/uk">
<description>
Denon & Marantz AVR plugin.<br/><br/>
"Sources" need to have '|' delimited names of sources that the Denon knows about from the technical manual.<br/>
The Sources Selector(s) can be changed after initial creation to any text and the plugin will still map to the actual Denon name.<br/><br/>
Devices will be created in the Devices Tab only and will need to be manually made active.
</description>
<params>
<param field="Address" label="IP Address" width="200px" required="true" default="127.0.0.1"/>
<param field="Port" label="Port" width="30px" required="true" default="23"/>
<param field="Mode2" label="Startup Delay" width="50px" required="true">
<options>
<option label="2" value="2"/>
<option label="3" value="3"/>
<option label="4" value="4" default="true" />
<option label="5" value="5"/>
<option label="6" value="6"/>
<option label="7" value="7"/>
<option label="10" value="10"/>
</options>
</param>
# Changed for Denon AVR-X2300W
<param field="Mode3" label="Sources" width="550px" required="true" default="Off|SAT/CBL|DVD|BD|GAME|AUX1|MPLAY|TV|AUX2|TUNER|USB/IPOD|CD|BT|IRP|FVP"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
</options>
</param>
</params>
</plugin>
import Domoticz
import base64
import datetime
class BasePlugin:
isConnected = False
nextConnect = 3
oustandingPings = 0
powerOn = False
mainOn = False
mainSource = 0
mainVolume1 = 0
zone2On = False
zone2Source = 0
zone2Volume = 0
zone3On = False
zone3Source = 0
zone3Volume = 0
ignoreMessages = "|SS|SV|SD|MS|PS|CV|SY|TP|"
selectorMap = {}
pollingDict = {"PW":"ZM?\r", "ZM":"SI?\r", "SI":"MV?\r", "MV":"MU?\r", "MU":"PW?\r" }
lastMessage = ""
lastHeartbeat = datetime.datetime.now()
SourceOptions = {}
def onStart(self):
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
self.SourceOptions = {'LevelActions': '|'*Parameters["Mode3"].count('|'),
'LevelNames': Parameters["Mode3"],
'LevelOffHidden': 'false',
'SelectorStyle': '1'}
if (len(Devices) == 0):
Domoticz.Device(Name="Power", Unit=1, TypeName="Switch", Image=5).Create()
Domoticz.Device(Name="Main Zone", Unit=2, TypeName="Selector Switch", Switchtype=18, Image=5, Options=self.SourceOptions).Create()
Domoticz.Device(Name="Main Volume", Unit=3, Type=244, Subtype=73, Switchtype=7, Image=8).Create()
else:
if (2 in Devices and (len(Devices[2].sValue) > 0)):
self.mainSource = int(Devices[2].sValue)
self.mainOn = (Devices[2].nValue != 0)
if (3 in Devices and (len(Devices[3].sValue) > 0)):
self.mainVolume1 = int(Devices[3].sValue) if (Devices[3].nValue != 0) else int(Devices[3].sValue)*-1
if (4 in Devices and (len(Devices[4].sValue) > 0)):
self.zone2Source = int(Devices[4].sValue)
self.zone2On = (Devices[4].nValue != 0)
if (5 in Devices and (len(Devices[5].sValue) > 0)):
self.zone2Volume = int(Devices[5].sValue) if (Devices[5].nValue != 0) else int(Devices[5].sValue)*-1
if (6 in Devices and (len(Devices[6].sValue) > 0)):
self.zone3Source = int(Devices[6].sValue)
self.zone3On = (Devices[6].nValue != 0)
if (7 in Devices and (len(Devices[7].sValue) > 0)):
self.zone3Volume = int(Devices[7].sValue) if (Devices[7].nValue != 0) else int(Devices[7].sValue)*-1
if (1 in Devices):
self.powerOn = (self.mainOn or self.zone2On or self.zone3On)
DumpConfigToLog()
dictValue=0
for item in Parameters["Mode3"].split('|'):
self.selectorMap[dictValue] = item
dictValue = dictValue + 10
Domoticz.Transport("TCP/IP", Parameters["Address"], Parameters["Port"])
Domoticz.Protocol("Line")
Domoticz.Connect()
return
def onConnect(self, Status, Description):
if (Status == 0):
self.isConnected = True
Domoticz.Log("Connected successfully to: "+Parameters["Address"]+":"+Parameters["Port"])
Domoticz.Send('PW?\r')
Domoticz.Send('ZM?\r', Delay=1)
Domoticz.Send('Z2?\r', Delay=2)
Domoticz.Send('Z3?\r', Delay=3)
else:
self.isConnected = False
self.powerOn = False
Domoticz.Log("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Port"])
Domoticz.Debug("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Port"]+" with error: "+Description)
self.SyncDevices()
return
def onMessage(self, Data, Status, Extra):
self.oustandingPings = self.oustandingPings - 1
strData = Data.decode("utf-8", "ignore")
Domoticz.Debug("onMessage called with Data: '"+str(strData)+"'")
strData = strData.strip()
action = strData[0:2]
detail = strData[2:]
if (action in self.pollingDict): self.lastMessage = action
if (action == "PW"): # Power Status
if (detail == "STANDBY"):
elif (detail == "ON"):
self.powerOn = True
else: Domoticz.Debug("Unknown: Action "+action+", Detail '"+detail+"' ignored.")
elif (action == "ZM"): # Main Zone on/off
self.mainOn = True
elif (detail == "OFF"):
self.mainOn = False
elif (action == "SI"): # Main Zone Source Input
for key, value in self.selectorMap.items():
if (detail == value): self.mainSource = key
elif (action == "MV"): # Master Volume
if (detail.isdigit()):
if (abs(self.mainVolume1) != int(detail[0:2])): self.mainVolume1 = int(detail[0:2])
elif (detail[0:3] == "MAX"): Domoticz.Debug("Unknown: Action "+action+", Detail '"+detail+"' ignored.")
else: Domoticz.Log("Unknown: Action "+action+", Detail '"+detail+"' ignored.")
elif (action == "MU"): # Overall Mute
if (detail == "ON"): self.mainVolume1 = abs(self.mainVolume1)*-1
elif (detail == "OFF"): self.mainVolume1 = abs(self.mainVolume1)
elif (action == "Z2"): # Zone 2
# Zone 2 response, make sure we have Zone 2 devices in Domoticz and they are polled
if (4 not in Devices):
LevelActions = '|'*Parameters["Mode3"].count('|')
Domoticz.Device(Name="Zone 2", Unit=4, TypeName="Selector Switch", Switchtype=18, Image=5, Options=self.SourceOptions).Create()
Domoticz.Log("Zone 2 responded, devices added.")
if (5 not in Devices):
Domoticz.Device(Name="Volume 2", Unit=5, Type=244, Subtype=73, Switchtype=7, Image=8).Create()
if ("Z2" not in self.pollingDict):
self.pollingDict = {"PW":"ZM?\r", "ZM":"SI?\r", "SI":"MV?\r", "MV":"MU?\r", "MU":"Z2?\r", "Z2":"PW?\r" }
self.zone2On = True
self.zone2On = False
elif (detail == "MUON"):
self.zone2Volume = abs(self.zone2Volume)*-1
elif (detail == "MUOFF"):
elif (detail.isdigit()):
if (abs(self.zone2Volume) != int(detail[0:2])): self.zone2Volume = int(detail[0:2])
else:
if (detail == value): self.zone2Source = key
elif (action == "Z3"): # Zone 3
# Zone 3 response, make sure we have Zone 3 devices in Domoticz and they are polled
if (6 not in Devices):
Domoticz.Device(Name="Zone 3", Unit=6, TypeName="Selector Switch", Switchtype=18, Image=5, Options=self.SourceOptions).Create()
Domoticz.Log("Zone 3 responded, devices added.")
if (7 not in Devices):
Domoticz.Device(Name="Volume 3", Unit=7, Type=244, Subtype=73, Switchtype=7, Image=8).Create()
if ("Z3" not in self.pollingDict):
self.pollingDict = {"PW":"ZM?\r", "ZM":"SI?\r", "SI":"MV?\r", "MV":"MU?\r", "MU":"Z2?\r", "Z2":"Z3?\r", "Z3":"PW?\r" }
self.zone3On = True
self.zone3On = False
self.zone3Volume = abs(self.zone3Volume)*-1
if (abs(self.zone3Volume) != int(detail[0:2])): self.zone3Volume = int(detail[0:2])
else:
if (detail == value): self.zone3Source = key
else:
if (self.ignoreMessages.find(action) < 0):
Domoticz.Debug("Unknown message '"+action+"' ignored.")
self.SyncDevices()
return
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Log("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
Command = Command.strip()
action, sep, params = Command.partition(' ')
action = action.capitalize()
params = params.capitalize()
delay = 0
if (self.powerOn == False):
delay = int(Parameters["Mode2"])
else:
# Amp will ignore commands if it is responding to a heartbeat so delay send
lastHeartbeatDelta = (datetime.datetime.now()-self.lastHeartbeat).total_seconds()
if (lastHeartbeatDelta < 0.5):
delay = 1
Domoticz.Log("Last heartbeat was "+str(lastHeartbeatDelta)+" seconds ago, delaying command send.")
if (Unit == 1): # Main power switch
if (action == "On"):
Domoticz.Send(Message='ZMON\r')
Domoticz.Send(Message='Z2ON\r')
elif (action == "Off"):
Domoticz.Send(Message='ZMOFF\r', Delay=delay)
Domoticz.Send(Message='Z2OFF\r', Delay=delay)
# Main Zone devices
elif (Unit == 2): # Main selector
elif (action == "Set"):
if (self.powerOn == False): Domoticz.Send(Message='ZMON\r')
Domoticz.Send(Message='SI'+self.selectorMap[Level]+'\r', Delay=delay)
elif (Unit == 3): # Main Volume control
Domoticz.Send(Message='MUOFF\r', Delay=delay)
Domoticz.Send(Message='MV'+str(Level)+'\r', Delay=delay)
Domoticz.Send(Message='MUON\r', Delay=delay)
# Zone 2 devices
elif (Unit == 4): # Zone 2 selector
Domoticz.Send(Message='Z2ON\r', Delay=delay)
if (self.zone2On == False):
delay += 1
Domoticz.Send(Message='Z2'+self.selectorMap[Level]+'\r', Delay=delay)
delay += 1
Domoticz.Send(Message='Z2?\r', Delay=delay)
elif (Unit == 5): # Zone 2 Volume control
# if (self.powerOn == False): Domoticz.Send(Message='PWON\r')
delay += 1
Domoticz.Send(Message='Z2MUOFF\r', Delay=delay)
Domoticz.Send(Message='Z2'+str(Level)+'\r', Delay=delay)
Domoticz.Send(Message='Z2MUON\r', Delay=delay)
# Zone 3 devices
elif (Unit == 6): # Zone 3 selector
Domoticz.Send(Message='Z3ON\r', Delay=delay)
if (self.zone3On == False):
delay += 1
Domoticz.Send(Message='Z3'+self.selectorMap[Level]+'\r', Delay=delay)
delay += 1
Domoticz.Send(Message='Z3?\r', Delay=delay)
Domoticz.Send(Message='Z3OFF\r', Delay=delay)
elif (Unit == 7): # Zone 3 Volume control
delay += 1
Domoticz.Send(Message='Z3MUOFF\r', Delay=delay)
Domoticz.Send(Message='Z3'+str(Level)+'\r', Delay=delay)
Domoticz.Send(Message='Z3MUON\r', Delay=delay)
return
def onDisconnect(self):
Domoticz.Log("Denon device has disconnected.")
return
def onHeartbeat(self):
if (self.isConnected == True):
if (self.oustandingPings > 5):
Domoticz.Disconnect()
self.nextConnect = 0
else:
Domoticz.Send(self.pollingDict[self.lastMessage])
Domoticz.Debug("onHeartbeat: self.lastMessage "+self.lastMessage+", Sending '"+self.pollingDict[self.lastMessage][0:2]+"'.")
self.oustandingPings = self.oustandingPings + 1
else:
# if not connected try and reconnected every 3 heartbeats
self.oustandingPings = 0
self.nextConnect = self.nextConnect - 1
if (self.nextConnect <= 0):
self.nextConnect = 3
Domoticz.Connect()
self.lastHeartbeat = datetime.datetime.now()
return
def SyncDevices(self):
UpdateDevice(1, 0, "Off")
UpdateDevice(2, 0, "0")
UpdateDevice(3, 0, str(abs(self.mainVolume1)))
UpdateDevice(4, 0, "0")
UpdateDevice(5, 0, str(abs(self.zone2Volume)))
UpdateDevice(6, 0, "0")
UpdateDevice(7, 0, str(abs(self.zone3Volume)))
else:
UpdateDevice(1, 1, "On")
UpdateDevice(2, self.mainSource if self.mainOn else 0, str(self.mainSource if self.mainOn else 0))
if (self.mainVolume1 <= 0 or self.mainOn == False): UpdateDevice(3, 0, str(abs(self.mainVolume1)))
else: UpdateDevice(3, 2, str(self.mainVolume1))
UpdateDevice(4, self.zone2Source if self.zone2On else 0, str(self.zone2Source if self.zone2On else 0))
if (self.zone2Volume <= 0 or self.zone2On == False): UpdateDevice(5, 0, str(abs(self.zone2Volume)))
else: UpdateDevice(5, 2, str(self.zone2Volume))
UpdateDevice(6, self.zone3Source if self.zone3On else 0, str(self.zone3Source if self.zone3On else 0))
if (self.zone3Volume <= 0 or self.zone3On == False): UpdateDevice(7, 0, str(abs(self.zone3Volume)))
else: UpdateDevice(7, 2, str(self.zone3Volume))
return
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onConnect(Status, Description):
global _plugin
_plugin.onConnect(Status, Description)
def onMessage(Data, Status, Extra):
global _plugin
_plugin.onMessage(Data, Status, Extra)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onDisconnect():
global _plugin
_plugin.onDisconnect()
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
def UpdateDevice(Unit, nValue, sValue):
# Make sure that the Domoticz device still exists (they can be deleted) before updating it
if (Unit in Devices):
if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue):
Devices[Unit].Update(nValue, str(sValue))
Domoticz.Log("Update "+str(nValue)+":'"+str(sValue)+"' ("+Devices[Unit].Name+")")
return
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Internal ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("External ID: '" + str(Devices[x].DeviceID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
def stringToBase64(s):
return base64.b64encode(s.encode('utf-8')).decode("utf-8")
def base64ToString(b):
return base64.b64decode(b).decode('utf-8')
