Page 2 of 2
Re: Aeotec ZW100 MultiSensor 6 - motion sensor not working
Posted: Friday 24 March 2017 14:49
by RB87
Updated to beta, nothing changed except burglar status is not 3 but 0x03 now, also the following error in log:
2017-03-24 14:40:51.497 PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
Posted: Monday 27 March 2017 22:12
by tequila
This error has nothing to do with the issue.
Posted: Tuesday 28 March 2017 15:04
by RB87
I've opened a ticket at Aeotec giving all the details and this topic. I hope they have a solution for this. Keep this topic posted..
Posted: Tuesday 28 March 2017 18:02
by RB87
I started the whole system again, and suddenly the motion sensor worked for one time. Hereby the log. Sensor is: MS-Motion, i received a pushover notification when it turned off again. Didnt turn on afterwards though :(
Below also the startup log. The burglar event is now 0x00, but doesnt change to the motion state.
2017-03-28 17:39:38.059 Incoming connection from: 192.168.0.4
2017-03-28 17:40:23.049 Sunrise: 07:23:00 SunSet:20:04:00
2017-03-28 17:40:23.049 EventSystem: reset all events...
2017-03-28 17:40:23.107 Proxymanager started.
2017-03-28 17:40:23.122 Active notification Subsystems: (0/12)
2017-03-28 17:40:32.919 Active notification Subsystems: (0/12)
2017-03-28 17:40:52.516 (ZStick) Light/Switch (MS-Motion)
2017-03-28 17:40:52.520 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:40:52.521 (ZStick) UV (UV)
2017-03-28 17:40:52.522 (ZStick) Lux (Unknown)
2017-03-28 17:40:52.523 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:40:52.525 (ZStick) Light/Switch (Alarm Level)
2017-03-28 17:40:52.527 (ZStick) Light/Switch (Alarm Type)
2017-03-28 17:40:52.529 (ZStick) Light/Switch (Burglar)
2017-03-28 17:40:53.763 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:40:54.158 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:40:55.510 (ZStick) Lux (Unknown)
2017-03-28 17:40:55.610 (ZStick) UV (UV)
2017-03-28 17:41:02.579 OpenZWave: Received timeout notification from HomeID: 4149631228, NodeID: 3 (0x03)
2017-03-28 17:41:05.566 (ZStick) Lux (Unknown)
2017-03-28 17:41:06.206 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:41:07.697 (ZStick) Light/Switch (Alarm Type)
2017-03-28 17:41:07.699 (ZStick) Light/Switch (Alarm Level)
2017-03-28 17:41:07.702 (ZStick) General/Alarm (Alarm Type: Burglar 7 (0x07))
2017-03-28 17:41:07.703 (ZStick) Light/Switch (Burglar)
2017-03-28 17:41:09.342 (ZStick) UV (UV)
2017-03-28 17:41:10.441 (ZStick) Light/Switch (MS-Motion)
2017-03-28 17:41:58.842 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:41:59.239 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:42:00.078 (ZStick) Lux (Unknown)
2017-03-28 17:42:00.178 (ZStick) UV (UV)
2017-03-28 17:42:02.898 Notification sent (pushover) => Success
2017-03-28 17:42:02.912 Active notification Subsystems: (0/12)
2017-03-28 17:42:13.317 Active notification Subsystems: pushover (1/12)
2017-03-28 17:43:00.379 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:43:00.775 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:43:01.615 (ZStick) Lux (Unknown)
2017-03-28 17:43:01.715 (ZStick) UV (UV)
2017-03-28 17:43:10.720 Notification sent (pushover) => Success
2017-03-28 17:43:10.295 (ZStick) Light/Switch (MS-Motion)
2017-03-28 17:43:10.723 (ZStick) Light/Switch (Alarm Type)
2017-03-28 17:43:10.725 (ZStick) Light/Switch (Alarm Level)
2017-03-28 17:43:10.727 (ZStick) General/Alarm (Alarm Type: Burglar 7 (0x07))
2017-03-28 17:43:10.728 (ZStick) Light/Switch (Burglar)
2017-03-28 17:44:01.915 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:44:02.312 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:44:03.151 (ZStick) Lux (Unknown)
2017-03-28 17:44:03.252 (ZStick) UV (UV)
2017-03-28 17:45:03.453 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:45:03.849 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:45:04.688 (ZStick) Lux (Unknown)
2017-03-28 17:45:04.789 (ZStick) UV (UV)
2017-03-28 17:46:04.989 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:46:05.384 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:46:06.225 (ZStick) Lux (Unknown)
2017-03-28 17:46:06.325 (ZStick) UV (UV)
2017-03-28 17:47:06.525 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:47:06.921 (ZStick) Temp + Humidity (TempHum)
2017-03-28 17:47:07.759 (ZStick) Lux (Unknown)
2017-03-28 17:47:07.861 (ZStick) UV (UV)
Startup log:
2017-03-24 14:50:37.508 Domoticz V3.7118 (c)2012-2017 GizMoCuz
2017-03-24 14:50:37.508 Build Hash: 345f92c, Date: 2017-03-24 09:50:58
2017-03-24 14:50:37.509 Startup Path: /home/pi/domoticz/
2017-03-24 14:50:37.690 PluginSystem: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
2017-03-24 14:50:37.734 WebServer(HTTP) started on address: :: with port 80
2017-03-24 14:50:37.743 Proxymanager started.
2017-03-24 14:50:37.745 RxQueue: queue worker started...
2017-03-24 14:50:37.746 TCPServer: shared server started...
2017-03-24 14:50:39.746 EventSystem: reset all events...
2017-03-24 14:50:39.752 EventSystem: reset all device statuses...
2017-03-24 14:50:39.753 EventSystem: Started
2017-03-24 14:50:40.246 OpenZWave: Starting...
2017-03-24 14:50:40.259 OpenZWave: Version: 1.4-2435-gc61d20d-dirty
2017-03-24 14:50:40.260 OpenZWave: using config in: /home/pi/domoticz/Config/
2017-03-24 14:50:40.483 OpenZWave: Driver Ready
2017-03-28 17:38:55.095 OpenZWave: Received timeout notification from HomeID: 4149631228, NodeID: 3 (0x03)
2017-03-28 17:39:05.123 OpenZWave: Received timeout notification from HomeID: 4149631228, NodeID: 3 (0x03)
2017-03-28 17:39:09.239 OpenZWave: All Nodes queried (Some Dead)
2017-03-28 17:39:09.240 OpenZWave: Received Node Dead notification from HomeID: 4149631228, NodeID: 3 (0x03)
2017-03-28 17:39:15.130 OpenZWave: Received timeout notification from HomeID: 4149631228, NodeID: 3 (0x03)
Posted: Tuesday 28 March 2017 20:12
by gizmocuz
Is your controller still in group 1, because on the previous page it seems you removed it.
I don't think Aeotec can help you with this issue here...
The motion sensor is triggered via the burglar alarm sensor (new sensor type), it will change it's value, i won't recommend using the 'switch'
make an blockly action to check against this alarm sensors value
There is also a discussion on github about this
Posted: Wednesday 29 March 2017 11:42
by RB87
Yeah i noticed, but then the burglar sensor must change from 0x03 (motion) to 0x00 (idle state) and to 0x07 (vibration) if i pick it up? It never changes back to state 0x00 and/or 0x03 (not registrering motion).
About the groups. I canceled that action, just needed the screenshot. Controller is still in group 1.
Aeotec replied on the ticket, they advice me to downgrade to a lower version (i did a firmware upgrade from 1.07 to 1.07 just in case something was wrong there). Now ill try version 1.06 (downgrade). If this doesnt working they advice me to exchange it under warranty.
Re: [SOLVED] Aeotec ZW100 MultiSensor 6 - motion sensor not working
Posted: Saturday 01 April 2017 16:45
by RB87
The issue has been resolved by exchanging the sensor for a new one. This one reacts as described on the motion sensor and burglar state.
Thank you all for your assistance, because of this Aeotec concluded quickly it was a faulthy sensor.
Kind regards
