New module - BleBox
mastadook
- Domoticz version: 2022.1
Re: New module - BleBox
maybe it´s damaged? or something else.
I have tried the config in BleBox and Domoticz one after one, nothing helped.
Just the Arrow Buttons changed the direction, not the Percentage Bar
________________________________________________________________________
global chief of permanent lightning and strike detonator
fantom
Maybe this is bug in domoticz, and switch "normal" works identically as "inverted"
mastadook
I do the cabeling all new now, so up is up in Hardware Switch
Up is Up when using the Webpage of the BleBox.
Pointing in blebox to the last 20% of the Blinds (nearly closed, it´s workinf fine and is nearly closed.
Pointing to 0% (Open) in Domoticz it stops in the middle and remains half open, if I choose 80% it´s nearly closed.
Yes, Calibaration is deleted and new autocalibrated.
Is there a File or a Config where the translation can be changed?
I see when coosing %Percentages it will be translated to some steps 1-12 or something.
I hoped I can replace this Fibare Shutters, cause they making Ghostswitching with the BleBox Shutters,
but with this Problems not possible to set correct Percentages, this will also not be a Solution for me
fantom
You may check what domoticz send to shutterBox (desiredPos) and actually position (currentPos) on
https://technical.blebox.eu/shutterBoxA ... utterState
Domoticz send 0 and 100 ? Or not ?
mastadook
So, i double and triple checked everything.
Shut down in Real and in the App, Domoticz set to Inverted, Percentage Bar Wrong, Icons correct Shut down in Real and in the App, Domoticz set to Normal, Percentage Bar correct, Icons and Text Wrong Shut down in Real and in the App, Domoticz set to back to inverted, Percentage Bar wrong Icons correct Text ? this is, what the Get from my shutter box replied:
Thank you for your Help
Edit:
If I send
http://192.168.1.23/s/p/80 then I got this reply:
in Domoticz the Percentage Bar say, no matter if I switch to Normal or Inverted - 20%
and i real it is 60% closed...
So the real Thing seems to Work more or less, but the Percentage Bar in Domoticz making Problems and did not fit the Icons and the Text
When sending 80% from Domoticz (NOT Inverted) it says:
{"shutter":{"state":4,"currentPos":{"position":0,"tilt":-1},"desiredPos":{"position":0,"tilt":-1},"favPos":{"position":50,"tilt":50},"controlType":1,"calibrationParameters":{"isCalibrated":1,"maxMoveTimeUpMs":23082,"maxMoveTimeDownMs":22417,"maxTiltTimeUpMs":1100,"maxTiltTimeDownMs":1100}}}Edit:
If I send
{"shutter":{"state":0,"currentPos":{"position":0,"tilt":-1},"desiredPos":{"position":80,"tilt":-1},"favPos":{"position":50,"tilt":50}}}and i real it is 60% closed...
{"shutter":{"state":2,"currentPos":{"position":19,"tilt":-1},"desiredPos":{"position":19,"tilt":-1},"favPos":{"position":50,"tilt":50},"controlType":1,"calibrationParameters":{"isCalibrated":1,"maxMoveTimeUpMs":23082,"maxMoveTimeDownMs":22417,"maxTiltTimeUpMs":1100,"maxTiltTimeDownMs":1100}}}________________________________________________________________________
mastadook
No more Ideas?
Is there a place with Config Files for BleBox Devices?
Maybe I can play around and change there the Translation from % to what is going to be send to the Box?
Or any other Ideas?
Or any other Ideas?
fantom
I think, that this is problem in domoticz with this control.
I installed one shutterBox a few days ago. I will try check where is problem.
gmacioso
- Domoticz version: BETA
After update to 2021.01 BleBOX module crashes Domoticz
pablo75
Hello
New betarelase (13196) solve crashes due to blebox module but all blebox devises doesn't work anymore.
In log file:
2021-04-18 21:33:48.590 Error: BLEBOXY: Invalid json received!
In Hardware section all devices with unknown status. When you try to use device you received Error: BLEBOXX: unknown device (192.168.X.X)
any idea?
regards
Pablo
In log file:
any idea?
regards
Pablo
pablo75
Strange symptom after V2021.1 build 13196 deploy. All Blebox hardware in line IP Adreess at the end of line have special character (attached screen).
Not possible to delete them and if I tried add device once again this special character is added to IP address at the end automatically.
Still blebox devices doesn't work. Log errors:
2021-04-19 09:27:30.857 Error: BLEBOXY: Invalid json received!
2021-04-19 09:27:39.300 Error: BLEBOXY: unknown device (192.168.11.6)
pablo
pablo
pablo75
Is there anyone who has migrated to V2021.1 and has a properly functioning Blebox?
thanks for the info.
Pablo
Pablo
BartekKo
I have a problem with adding BB modules to Domoticz V2021.1. Last two years everything was working properly but as usuall something went wrong fored me to install new Raspbian and Domoticz.
Now each attempt (manual or auto) causes crash of domoticz and system need to be reloaded.
Any idea why?
Any idea why?
fantom
I'm coming back after a few years to improve this module
I'll see what I can do.
fantom
So feel free to download the version at least
Version: 2024.4 (build 15998)
Strongly rebuilt BleBox support. There should be no duplicates, the controls should work, signal strength should be displayed, etc.
ps. I recomended remove all BleBox devices and add they again.
- Domoticz version: 2026.3
I dont know if history data of the old devices would be stored because then I would propose another way of implementing:fantom wrote: Wednesday 22 May 2024 7:33
- Disable (not delete!) BleBox in Domoticz (menu Setup - hardware)
- Create new BleBox gateway in Domoticz
- New devices are created in BleBox and visible in menu Setup- Devices
- If you want to keep the history logging of the old devices then you need to replace the old device with the new one if identical devices are created. Use the replace function in Edit device, see wiki Replace Devices Devices that were replaced will get the old name and old IDX, no need to change scripts.
NOTE: Alternatively, you can also change the type of the old disabled BleBox hardware to "Dummy" and re-enable it, then replace each dummy device with equivalent Zwave JS UI discovered device.
- Now you can delete the old BleBox gateway in Domoticz (menu Setup - hardware). All related old devices that not were replaced will be deleted.
homeJLB
- Domoticz version: 2024.7
because there are some warnings from this code in the AppVeyor Build,
This is because the function 'm_sql.InsertDevice' return a 'uint64_t'
and the idx is declared as 'int'
what is best accepted;
or
kind regards
conversion from 'uint64_t' to 'int', possible loss of dataand the idx is declared as 'int'
int idx = (int)m_sql.InsertDevice(m_HwdID, 0, id, 1, deviceType.rfxType, deviceType.subType, deviceType.switchType, 0, "Unavailable", deviceName, signalQuality, 255, 0);
_log.Debug(DEBUG_HARDWARE, "BleBox: new device Id: '%d'", idx);
m_sql.safe_query("UPDATE DeviceStatus SET StrParam1='%d', StrParam2='%q' WHERE (ID==%d)", deviceTypeID, IPAddress.c_str(), idx);
idx = m_sql.InsertDevice(m_HwdID, 0, id, 2, pTypeGeneralSwitch, sTypeAC, STYPE_PushOn, 0, "Unavailable", deviceName, signalQuality, 255, 0);
idx = m_sql.InsertDevice(m_HwdID, 0, id, 3, pTypeGeneralSwitch, sTypeAC, STYPE_PushOn, 0, "Unavailable", deviceName, signalQuality, 255, 0);
}Code: Select all
int idx = (int)m_sql.InsertDevice(........Code: Select all
int idx = static_cast<int>(m_sql.InsertDevice(........-
fantom
I see that this has been corrected
https://github.com/domoticz/domoticz/co ... a66fe71faa
homeJLB
No it is not corrected;
GizMoCuz has put in; Bad coding! Return = uint64_t, please change!
it must be for example;
uint64_t idx = m_sql.InsertDevice(m_HwdID, 0, id, 1, deviceType.rfxType, deviceType.subType, deviceType.switchType, 0, "Unavailable", deviceName, signalQuality, 255, 0);
_log.Debug(DEBUG_HARDWARE, "BleBox: new device Id: '%" PRIu64 "'", idx);
m_sql.safe_query("UPDATE DeviceStatus SET StrParam1='%d', StrParam2='%q' WHERE (ID==%" PRIu64 ")", deviceTypeID, IPAddress.c_str(), idx);
