Page 2 of 3
Re: IR Sensor on Raspberry Pi 3
Posted: Tuesday 14 March 2017 23:45
by Harlov
Nautilus wrote:Harlov wrote:I think I have got it working with savings in /etc/triggerhappy/triggers.d/ but when I need to type in Domoticz
EV_KEY KEY_PLAYPAUSE 1 curl -s "http: // url: port / json.htm? Type = Command & param = Switch light & idx = IDXofNEOplug & switchcmd = On"
I get the error message in Domoticz saying Invalid ON Action!
Of course I have changed the IP ich idx
I would first verify it ( = http: // url: port / json.htm? Type = Command & param = Switch light & idx = IDXofNEOplug & switchcmd = On) works in the browser. I think it's case sensitive so the string you have there will not work like that but I'm not sure if you just wrote something there and have the correct format in the .conf file (there are also some extra spaces on your example but perhaps those are because of some copy/paste issue?
It could also be security (disable authentication on local network), protected switch or something like that. Check the correct json syntax here:
https://www.domoticz.com/wiki/Domoticz_ ... Fswitch_on
edit: I see you edited the post but the syntax is still wrong. Should be something like:
http://192.168.0.???:8080/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On
note the added "&switchcmd
Here is the correct comands i type in it is perhaps wrong
http://192.168.0.???:8080/json.htm?type ... t&idx=1=On"
aha okej
I wrote that you showed and got 401 Unauthorized
Posted: Wednesday 15 March 2017 0:03
by Harlov
Nautilus wrote:Harlov wrote:...but when I need to type in Domoticz...
This I don't quite get. You should not be typing anything in Domoticz (not sure though if I understand the sentence correctly
Also, why are you trying to link both On and Off to same ir command?
Wrong of me, I'm tired so that's probably why I can not think right
may try more tomorrow and see if I can get it to work, I get hope
Thank you for your help is appreciated
Posted: Wednesday 15 March 2017 0:08
by Nautilus
Don't worry, you are close
For the "unauthorized", either disable authentication in local network (Domoticz settings -> System -> Local networks) or if you use basic authentication this should also work:
Posted: Wednesday 15 March 2017 18:26
by Harlov
I turned off Authentication: and added the Local Networks IP number 192.168.0.* And then it works as it should when I test in the browser
But it does work not when I press on the remote control
it may have to do with triggerhappy, I do not know.
"status" : "OK",
"title" : "SwitchLight"
Posted: Wednesday 15 March 2017 19:24
by Nautilus
Well, you can keep the authentication on, just keep the bypass for local network the you've set it up now. If you have opened the Domoticz port to outside network (and forwarded the IP) then anyone can access it...
Harlov wrote:But it does work not when I press on the remote control
I trust you reloaded Triggerhapppy after modifying the .conf file? If not, please do and test again. Also, are you 100% sure the remote's keypress is interpreted as "EV_KEY KEY_PLAYPAUSE"? It was what you saw when running the "dump" command?
Posted: Wednesday 15 March 2017 19:39
by Harlov
I did a reload of TriggerHappy but nothing happens when I press any buttons
EV_KEY KEY_PLAYPAUSE 1 curl -s "http://192.168.0.148:8080/json.htm?type=command¶m=switchlight&idx=1=On"
EV_KEY KEY_PLAYPAUSE 1 /dev/input/event0
# KEY_PLAYPAUSE 1 command
EV_KEY KEY_PLAYPAUSE 0 /dev/input/event0
# KEY_PLAYPAUSE 0 command
but nothing happens
Posted: Wednesday 15 March 2017 19:42
by Harlov
but nothing happens
Is it because I use the Logitech Harmony 650 remote makes it not work
Posted: Wednesday 15 March 2017 19:52
by Nautilus
No, I think it is the "key name" that is wrong. Let me give you an example. When I turn on the "dump" and press a certain key I get:
EV_KEY KEY_LEFTCTRL 1 /dev/input/event1
# KEY_LEFTCTRL 1 command
EV_KEY KEY_LEFTSHIFT 1 /dev/input/event1
# KEY_LEFTCTRL+KEY_LEFTSHIFT 1 command
EV_KEY KEY_2 1 /dev/input/event1
# KEY_LEFTCTRL+KEY_LEFTSHIFT+KEY_2 1 command
EV_KEY KEY_2 2 /dev/input/event1
# KEY_LEFTCTRL+KEY_LEFTSHIFT+KEY_2 2 command
EV_KEY KEY_LEFTCTRL 0 /dev/input/event1
# KEY_2+KEY_LEFTSHIFT+KEY_LEFTCTRL 0 command
EV_KEY KEY_LEFTSHIFT 0 /dev/input/event1
# KEY_2+KEY_LEFTSHIFT 0 command
EV_KEY KEY_2 0 /dev/input/event1
# KEY_2 0 command
So the dump outputs all of the above. From all these, the correct line in my .conf file is just:
KEY_2+KEY_LEFTSHIFT+KEY_LEFTCTRL 1 curl -s "http://url:port/json.htm?type=command¶m=switchlight&idx=356&switchcmd=On"
So I'd drop the EV_KEY away at least and try with just:
Remember to reload...
Posted: Wednesday 15 March 2017 20:10
by Harlov
# KEY_2 0 command
Tried to switch to without EV_KEY but nothing happens. I also did reload twice but nothing works, your code looks after all begin the same way as my codes so then you might wonder what is wrong
Posted: Wednesday 15 March 2017 22:28
by Nautilus
Hmm, strange indeed. Only couple of things left to try I think.
EDIT:Maybe just a typo in your post above, but after posting this I noticed the command below is still faulty, it is missing the &switchcmd part, i.e. should be: curl -s "
http://192.168.0.148:8080/json.htm?type ... ]switchcmd[/b]=On"
1. From command line run the curl command and see if it goes through as expected. I mean:
Note! Copy/paste it from the .conf file so that you use the exact same format. If this triggers the desired action in Domoticz, then this part certainly works.
2. Choose another IR command and this time use the full keyboard in Flirc and associate the IR command to some simple key combination. E.g. what I used in my example CTRL+ALT+2. Now that you are not using a normal keyboard key it might cause some issues.
If 1. fails, then we need to try to fix that before moving to 2. Post any error messages you might get here...
Posted: Wednesday 15 March 2017 23:02
by Harlov
Nautilus wrote:Hmm, strange indeed. Only couple of things left to try I think.
I changed the conf file and made a reload and this is the result
What this how you meant
pi@raspberrypi:~ $ curl -s http://192.168.0.148:8080/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On
[1] 858
[2] 859
[3] 860
pi@raspberrypi:~ $ {
"status" : "ERR"
^C
[1] Done curl -s http://192.168.0.148:8080/json.htm?type=command
[2]- Done param=switchlight
[3]+ Done idx=1
pi@raspberrypi:~ $
Posted: Wednesday 15 March 2017 23:06
by Nautilus
You are missing quotes around the url ->
"http://192.168.0.148:8080/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On"
Posted: Wednesday 15 March 2017 23:17
by Harlov
Nautilus wrote:You are missing quotes around the url ->
then i got this
pi@raspberrypi:~ $ curl -s "http://192.168.0.148:8080/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On"
pi@raspberrypi:~ $
in the browser
"status" : "OK",
Posted: Wednesday 15 March 2017 23:23
by Nautilus
Take away -s (s = silent) and you should see some output. In any case, you can check from Domoticz log (switch log) if it fired.
Posted: Wednesday 15 March 2017 23:31
by Harlov
Nautilus wrote:Take away -s (s = silent) and you should see some output. In any case, you can check from Domoticz log (switch log) if it fired.
Log file Domoticz
2017-03-15 23:27:03.632 OpenZWave: Domoticz has send a Switch command! NodeID: 4 (0x04)
2017-03-15 23:27:03.632 (Controller) Light/Switch (Wall Plug)
2017-03-15 23:27:03.685 (Controller) Light/Switch (Wall Plug)
2017-03-15 23:27:03.703 (Controller) Light/Switch (Wall Plug)
2017-03-15 23:27:11.472 Incoming connection from: 192.168.0.106
And this
pi@raspberrypi:~ $ curl "http://192.168.0.148:8080/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On"
"status" : "OK",
Posted: Wednesday 15 March 2017 23:33
by Nautilus
Ok, curl is finally working. Did you already try it in the .conf file in the correct format?
Posted: Wednesday 15 March 2017 23:46
by Harlov
Nautilus wrote:Ok, curl is finally working. Did you already try it in the .conf file in the correct format?
I have saved this in the conf file and make reload
so it seems EV_KEY_KEY_PLAYPAUSE do not want to work
it might be something wrong with the infrared usb?
EV_KEY_KEY_PLAYPAUSE 1 curl "http://192.168.0.148:8080/json.htm?type=command¶m=switchlight&idx=1&switchcmd=On"
Posted: Thursday 16 March 2017 0:00
by Nautilus
Harlov wrote:Nautilus wrote:Ok, curl is finally working. Did you already try it in the .conf file in the correct format?
As discussed, I'm pretty sure it needs to be:
But if this does not work, then go for point number
2. from the earlier post and try with a standard key (combination)...
Posted: Thursday 16 March 2017 19:35
by Harlov
Nautilus wrote:Harlov wrote:Nautilus wrote:Ok, curl is finally working. Did you already try it in the .conf file in the correct format?
I've got it working now, I had to put a @ after KEY_PLAYPAUSE@ . I also had to modify the configuration files in it's default setup, the daemon is run as user nobody and i have Changing the user to pi, and then restart and it worked
KEY_PLAYPAUSE@ 1 curl "http://192.168.0.148:8080/json.htm?type=command¶m=switchlight&idx=1&switchcmd=Off"
Posted: Thursday 16 March 2017 19:42
by Nautilus
Good to hear! Was a bit of a struggle but you pulled it through...
