Page 2 of 184
Re: New Dashboard Design
Posted: Thursday 09 March 2017 23:24
by EdwinK
Works great. Now to do some editing, as I don't need all of the layout. (No need for radio/tv and the downloads section, and make it so that some other info is visible. But keep up the good work. I love it.
Posted: Thursday 09 March 2017 23:33
by robgeerts
If you leave the variables empty for the IP of nzbget and Horizon in CONFIG.JS, it will hide those blocks
Posted: Thursday 09 March 2017 23:55
by Skippiemanz
I assume you run you're setup on a synology nas?
Unforunetly from a Rpi the Horizonbox script doesnt work with
var _HOST_ZIGGO_HORIZON = 'http://192.168.165.2/test/switch_horizon.php';
Posted: Friday 10 March 2017 8:12
by robgeerts
Do you have PHP installed on your rpi?
If yes, check the IP-address inside switch_horizon.php, it has to point to the right IP-address of Horizon.
You can find this with the windows-program 'Advanced IP Scanner'.
Posted: Friday 10 March 2017 9:04
by EdwinK
robgeerts wrote:If you leave the variables empty for the IP of nzbget and Horizon in CONFIG.JS, it will hide those blocks
That is great
Posted: Friday 10 March 2017 10:07
by EdwinK
So far I've got this (part of it fallen off, because of the size of the screen).
Instead of how it is now,I would like the Toon Scenes and Hue scenes to be a dropdown menu.
The HUE sliders don't seem to work as it should be, I believe. I can slide them higher or lower, but after turning off, and then on again, it remains on the last used level.
Don't need the radio and the radar part, so if it would be possible to move some other stuff there (dont know how), it would be nice.
Is it possible to see the counters of the meters (ie electricity and gas). Using Toon here.
edit: Removed the radio and radar part. Prefer to listen to the radio on my Mediacenter.
Posted: Friday 10 March 2017 10:41
by Awst6000
I tried, but the Horizon block still appears.
The 'Verkeer' header still shows up also.
Posted: Friday 10 March 2017 10:48
by robgeerts
If have changed this in the lastest version..
Could you check this? NOTE: BACKUP YOUR CONFIG.JS!
I dont understand this...
So you can handle the brightness but the problem is when switching back on, it remains on the last used level? Isn't that normal?
I've read you've already managed to remove these, for other members interested in removeing/adding buttons, take a look at CONFIG.JS
In your screenshot I see the energy and gas usage?
Isn't this coming from Toon already?
Posted: Friday 10 March 2017 10:50
by robgeerts
Awst6000 wrote:robgeerts wrote:If you leave the variables empty for the IP of nzbget and Horizon in CONFIG.JS, it will hide those blocks
Works over here, could you test with the latest version, backup your CONFIG.JS
Posted: Friday 10 March 2017 10:56
by Awst6000
It looks like this is/was hardcoded in the index.html, but I'll download the latest version.
Posted: Friday 10 March 2017 11:13
by EdwinK
This works
The sliders keep moving back to the last position, even if I dragged them to another posisition. Could be something I did wrong in Domoticz though.
I was hoping to also see the counters (meterstanden T1 en T2 en gas).
Posted: Friday 10 March 2017 11:22
by EdwinK
I just decided to drop the sliders (at least for now). I can just set some scenes in Hue Scenes and use those instead.
Posted: Friday 10 March 2017 14:46
by deennoo
Real a great job !
Do you plan to made user choose their language ?
I got some device temp/hum who are shown as switch (all of them)
Posted: Friday 10 March 2017 19:00
by remb0
can you share your background please? it's very nice!
l00pz wrote:And what if you have multiple "Temp" Switches
For no it looks like its using some random Temp Switch that I have, so if this Switch could be configured that would be cool. The Temperature Switches that you're using is also from Toon I presume? I tried adding my HoneyWell EvoTouch to it, but unfortunately it's not possible to control the Temperature with the Dashboard.
As for the Screenshot, this is my current Dashboard.
Posted: Friday 10 March 2017 19:02
by robgeerts
You can find it in Gitlab
I've found it via Google 'android fade background'
Verstuurd vanaf mijn SM-G930F met Tapatalk
Posted: Friday 10 March 2017 20:27
by remb0
thanks rob! i found also others :
http://www.lanlinglaurel.com/blur-wallpaper.html
why you don't theme u p with the guys of domoboard? combine the best of both?
your graphics there settings / framework?
Posted: Friday 10 March 2017 20:40
by madpatrick
Great Tool !!
i've setup as described and the information from Toon is loading, but not all settings a correct.
Can i change this somewhere ?
Posted: Friday 10 March 2017 21:43
by pvm
+1
You've both did some excellent development. Merging them would give a lot of functions an good looks
Posted: Saturday 11 March 2017 12:44
by robgeerts
Thanks for the other wallpapers!
Well, in theory I could use this theme for Domoboard but I don't have the time to do this.
I just created this dashboard for myself in the first place because had some hours available, but still wanted to share this with you guys.
Be my guest to copy this design, or use elements from my source for Domoboard
In main.js, change this line:
if(data.result[r]['Type']=='Temp'){
to
if(data.result[r]['Type']=='Temp' && data.result[r]['HardwareType']=='Toon Thermostat'){
Posted: Saturday 11 March 2017 19:49
by madpatrick
Rob,
This wirked for the roomtemperature, but at "verlichting" de server infomation is not good.
It looks like a switch, but must show the temperature or cpu usage. In Domoticz it is showing correct.
I hope you can help with this.
