EdwinK
Re: New Dashboard Design
Post by EdwinK »
Works great. Now to do some editing, as I don't need all of the layout. (No need for radio/tv and the downloads section, and make it so that some other info is visible. But keep up the good work. I love it.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
If you leave the variables empty for the IP of nzbget and Horizon in CONFIG.JS, it will hide those blocks ;)
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
I assume you run you're setup on a synology nas?
Unforunetly from a Rpi the Horizonbox script doesnt work with
var _HOST_ZIGGO_HORIZON	  	= 'http://192.168.165.2/test/switch_horizon.php';
robgeerts
Post by robgeerts »
Do you have PHP installed on your rpi?
If yes, check the IP-address inside switch_horizon.php, it has to point to the right IP-address of Horizon.
You can find this with the windows-program 'Advanced IP Scanner'.
EdwinK
Post by EdwinK »
robgeerts wrote:If you leave the variables empty for the IP of nzbget and Horizon in CONFIG.JS, it will hide those blocks ;)
That is great :)
EdwinK
Post by EdwinK »
So far I've got this (part of it fallen off, because of the size of the screen).
Instead of how it is now,I would like the Toon Scenes and Hue scenes to be a dropdown menu.
The HUE sliders don't seem to work as it should be, I believe. I can slide them higher or lower, but after turning off, and then on again, it remains on the last used level.
Don't need the radio and the radar part, so if it would be possible to move some other stuff there (dont know how), it would be nice.
Is it possible to see the counters of the meters (ie electricity and gas). Using Toon here.
edit: Removed the radio and radar part. Prefer to listen to the radio on my Mediacenter.
Awst6000
Post by Awst6000 »
I tried, but the Horizon block still appears.
The 'Verkeer' header still shows up also.
robgeerts
Post by robgeerts »
EdKo66 wrote: Instead of how it is now,I would like the Toon Scenes and Hue scenes to be a dropdown menu.
If have changed this in the lastest version..
Could you check this? NOTE: BACKUP YOUR CONFIG.JS!
EdKo66 wrote: The HUE sliders don't seem to work as it should be, I believe. I can slide them higher or lower, but after turning off, and then on again, it remains on the last used level.
I dont understand this...
So you can handle the brightness but the problem is when switching back on, it remains on the last used level? Isn't that normal?
EdKo66 wrote: Don't need the radio and the radar part, so if it would be possible to move some other stuff there (dont know how), it would be nice.
I've read you've already managed to remove these, for other members interested in removeing/adding buttons, take a look at CONFIG.JS
EdKo66 wrote: Is it possible to see the counters of the meters (ie electricity and gas). Using Toon here.
In your screenshot I see the energy and gas usage?
Isn't this coming from Toon already?
robgeerts
Post by robgeerts »
Works over here, could you test with the latest version, backup your CONFIG.JS
Awst6000
Post by Awst6000 »
It looks like this is/was hardcoded in the index.html, but I'll download the latest version.
EdwinK
Post by EdwinK »
This works :)
The sliders keep moving back to the last position, even if I dragged them to another posisition. Could be something I did wrong in Domoticz though.
I was hoping to also see the counters (meterstanden T1 en T2 en gas).
EdwinK
Post by EdwinK »
I just decided to drop the sliders (at least for now). I can just set some scenes in Hue Scenes and use those instead. :)
deennoo
Post by deennoo »
Real a great job !
Do you plan to made user choose their language ?
I got some device temp/hum who are shown as switch (all of them)
http://domo-attitude.fr
remb0
Post by remb0 »
can you share your background please? it's very nice!
l00pz wrote:And what if you have multiple "Temp" Switches :D For no it looks like its using some random Temp Switch that I have, so if this Switch could be configured that would be cool. The Temperature Switches that you're using is also from Toon I presume? I tried adding my HoneyWell EvoTouch to it, but unfortunately it's not possible to control the Temperature with the Dashboard.
As for the Screenshot, this is my current Dashboard.
robgeerts
Post by robgeerts »
You can find it in Gitlab ;) I've found it via Google 'android fade background'
Verstuurd vanaf mijn SM-G930F met Tapatalk
remb0
Post by remb0 »
thanks rob! i found also others :http://www.lanlinglaurel.com/blur-wallpaper.html
why you don't theme u p with the guys of domoboard? combine the best of both?
your graphics there settings / framework?
madpatrick
Domoticz version: 2025.1
Post by madpatrick »
Great Tool !!
i've setup as described and the information from Toon is loading, but not all settings a correct.
Can i change this somewhere ?
-= HP server GEN11 =- OZW -=- Toon2 (rooted) -=- Domoticz v2025.1 -=- Dashticz v3.14b on Tab8" =-
pvm
Domoticz version: 4.10538
Post by pvm »
remb0 wrote:thanks rob! i found also others :http://www.lanlinglaurel.com/blur-wallpaper.html
+1
You've both did some excellent development. Merging them would give a lot of functions an good looks
robgeerts
Post by robgeerts »
Thanks for the other wallpapers!
Well, in theory I could use this theme for Domoboard but I don't have the time to do this.
I just created this dashboard for myself in the first place because had some hours available, but still wanted to share this with you guys.
Be my guest to copy this design, or use elements from my source for Domoboard ;)
madpatrick wrote: i've setup as described and the information from Toon is loading, but not all settings a correct.
In main.js, change this line:
if(data.result[r]['Type']=='Temp'){
to
if(data.result[r]['Type']=='Temp' && data.result[r]['HardwareType']=='Toon Thermostat'){
madpatrick
Rob,
This wirked for the roomtemperature, but at "verlichting" de server infomation is not good.
It looks like a switch, but must show the temperature or cpu usage. In Domoticz it is showing correct.
I hope you can help with this.
Locked
