Python Plugin: Wan IP Checker
emme
Domoticz version: latest
Re: Plugin - Wan IP Checker
Post by emme »
:oops: :oops:
looks like I have something wrong....
2017-02-23 22:11:00.414 Error: www_wanIP hardware (52) thread seems to have ended unexpectedly
here is the full log:
2017-02-23 22:13:00.643 (www_wanIP) Plugin is stopping.
2017-02-23 22:13:01.094 (www_wanIP) Exiting work loop...
2017-02-23 22:13:01.094 (www_wanIP) Stopped.
2017-02-23 22:13:01.447 (www_wanIP) Initialized version 1.0.0, author 'ycahome'
2017-02-23 22:13:01.448 (www_wanIP) Debug log level set to: 'true'.
2017-02-23 22:13:01.448 (www_wanIP) 'Version':'1.0.0'
2017-02-23 22:13:01.448 (www_wanIP) 'HomeFolder':'/home/pi/domoticz/plugins/WAN-IP-CHECKER/'
2017-02-23 22:13:01.449 (www_wanIP) 'HardwareID':'52'
2017-02-23 22:13:01.449 (www_wanIP) 'Address':'https://4.ifcfg.me/ip'
2017-02-23 22:13:01.449 (www_wanIP) 'Mode1':'3600'
2017-02-23 22:13:01.449 (www_wanIP) 'Name':'www_wanIP'
2017-02-23 22:13:01.449 (www_wanIP) 'Port':'0'
2017-02-23 22:13:01.449 (www_wanIP) 'Author':'ycahome'
2017-02-23 22:13:01.449 (www_wanIP) 'Mode6':'Debug'
2017-02-23 22:13:01.449 (www_wanIP) 'Key':'WAN-IP-CHECKER'
2017-02-23 22:13:01.449 (www_wanIP) Device count: 1
2017-02-23 22:13:01.449 (www_wanIP) Device: 1 - ID: 901, Name: 'www_wanIP - WAN IP 1', nValue: 1, sValue: 'xxxxxxx'
2017-02-23 22:13:01.449 (www_wanIP) Device ID: '901'
2017-02-23 22:13:01.449 (www_wanIP) Device Name: 'www_wanIP - WAN IP 1'
2017-02-23 22:13:01.449 (www_wanIP) Device nValue: 1
2017-02-23 22:13:01.449 (www_wanIP) Device sValue: 'xxxxxx'
2017-02-23 22:13:02.351 (www_wanIP) WAN IP retrieved:xxxxxxx
2017-02-23 22:13:02.351 (www_wanIP) Previous WAN IP:xxxxxxx
2017-02-23 22:13:02.351 (www_wanIP) WAN IP the same. Skipping
2017-02-23 22:13:02.402 (www_wanIP) Heartbeat interval set to: 3600.
2017-02-23 22:13:10.965 (www_wanIP) Calling message handler 'onHeartbeat'.
2017-02-23 22:13:10.965 (www_wanIP) onHeartbeat called
2017-02-23 22:13:11.932 (www_wanIP) WAN IP retrieved:xxxxxxxx
2017-02-23 22:13:11.932 (www_wanIP) Previous WAN IP:xxxxxxx
2017-02-23 22:13:11.932 (www_wanIP) WAN IP the same. Skipping
2017-02-23 22:14:30.456 Error: www_wanIP hardware (52) thread seems to have ended unexpectedly
"We always done this way"
ycahome
Domoticz version: lat Beta
Post by ycahome »
JimmyH1969 wrote:Not working on Windows. Domoticz restarts every 10 seconds. Nothing in log, but thats hard to see if the system is no longer responding.
Did you ever tested with another plugin?
Do you have python proper installed?
ycahome
Post by ycahome »
emme wrote::oops: :oops:
Try to set interval to 60. Seems that there is a bug on domoticz with bigher intervals
BarryT
Domoticz version: 2024.3
Post by BarryT »
Yup, latest domoticz version, latest jessie lite and just installed python3dev, now everything works.
It has something to do with the Python.
emme
Post by emme »
uhm... looks like on beta 7441 something has changed in the plugin framework :(
I got this in the log.. and of course the IP doesn't change:
2017-05-08 16:27:41.464 Error: (plug_WanIP) 'onHeartbeat' failed 'ssl.SSLError':'failed to allocate SSL context'.
2017-05-08 16:27:41.464 Error: (plug_WanIP) ----> Line 101 in /home/pi/domoticz/plugins/WanIP/plugin.py, function onHeartbeat
2017-05-08 16:27:41.464 Error: (plug_WanIP) ----> Line 72 in /home/pi/domoticz/plugins/WanIP/plugin.py, function onHeartbeat
2017-05-08 16:27:41.464 Error: (plug_WanIP) ----> Line 153 in /usr/lib/python3.4/urllib/request.py, function urlopen
2017-05-08 16:27:41.464 Error: (plug_WanIP) ----> Line 455 in /usr/lib/python3.4/urllib/request.py, function open
2017-05-08 16:27:41.464 Error: (plug_WanIP) ----> Line 473 in /usr/lib/python3.4/urllib/request.py, function _open
2017-05-08 16:27:41.465 Error: (plug_WanIP) ----> Line 433 in /usr/lib/python3.4/urllib/request.py, function _call_chain
2017-05-08 16:27:41.465 Error: (plug_WanIP) ----> Line 1217 in /usr/lib/python3.4/urllib/request.py, function https_open
2017-05-08 16:27:41.465 Error: (plug_WanIP) ----> Line 1144 in /usr/lib/python3.4/urllib/request.py, function do_open
2017-05-08 16:27:41.465 Error: (plug_WanIP) ----> Line 1206 in /usr/lib/python3.4/http/client.py, function __init__
2017-05-08 16:27:41.465 Error: (plug_WanIP) ----> Line 459 in /usr/lib/python3.4/ssl.py, function _create_stdlib_context
2017-05-08 16:27:41.465 Error: (plug_WanIP) ----> Line 348 in /usr/lib/python3.4/ssl.py, function __new__
BarryT
Post by BarryT »
emme wrote:uhm... looks like on beta 7441 something has changed in the plugin framework :(
ycahome wrote:Do you have "python3-dev" installed?
Is your internet working correctly?
I have seen that errors before when my internet was down..
Otherwise, try to check your python version in domoticz, when its giving a error try to update Python>
"sudo apt-get install python3-dev"
Let us know ;)
emme
Post by emme »
..internet with some problems :P
vodafone statin was faulty :P :P
thanks
ciao
M
BarryT
Post by BarryT »
emme wrote:..internet with some problems :P
thanks
ciao
M
Now we talking :)
DennisD
Post by DennisD »
BarryT,
Did you figure out what the problem was with python? I 2 get the same errors you had
2017-05-14 17:18:03.228 Error: (IP Checker) 'onHeartbeat' failed 'URLError'.
2017-05-14 17:18:03.228 Error: (IP Checker) ----> Line 102 in /home/pi/domoticz/plugins/wan-ip-checker/plugin.py, function onHeartbeat
2017-05-14 17:18:03.228 Error: (IP Checker) ----> Line 73 in /home/pi/domoticz/plugins/wan-ip-checker/plugin.py, function onHeartbeat
2017-05-14 17:18:03.228 Error: (IP Checker) ----> Line 153 in /usr/lib/python3.4/urllib/request.py, function urlopen
2017-05-14 17:18:03.228 Error: (IP Checker) ----> Line 455 in /usr/lib/python3.4/urllib/request.py, function open
2017-05-14 17:18:03.228 Error: (IP Checker) ----> Line 473 in /usr/lib/python3.4/urllib/request.py, function _open
2017-05-14 17:18:03.228 Error: (IP Checker) ----> Line 433 in /usr/lib/python3.4/urllib/request.py, function _call_chain
2017-05-14 17:18:03.228 Error: (IP Checker) ----> Line 1217 in /usr/lib/python3.4/urllib/request.py, function https_open
2017-05-14 17:18:03.228 Error: (IP Checker) ----> Line 1180 in /usr/lib/python3.4/urllib/request.py, function do_open
Already tried to reinstall python 3.4 and tried lots of stuff python related to fix the issue, without any result
BarryT
Post by BarryT »
DennisD wrote:BarryT,
DennisD
Post by DennisD »
Nope, had that already so that is installed.
BarryT
Post by BarryT »
DennisD wrote:Nope, had that already so that is installed.
Cache cleaned?
Rebooted?
Symlinks of python correct?
DennisD
Post by DennisD »
Cache is clean, rebooted multiple times after fresh install (python 3.4). Just need to check the symlinks again
BarryT
Post by BarryT »
DennisD wrote:Cache is clean, rebooted multiple times after fresh install (python 3.4). Just need to check the symlinks again
What does your startup log of domoticz says?
Is python started or does it gives you an error?
DennisD
Post by DennisD »
The weird thing about the the startup is that i seem to miss the log entry PluginSystem: Started, Python version '3.4.2
Hardware Monitor: Started
2017-05-14 21:24:33.498  ToonThermostat: Worker started...
2017-05-14 21:24:33.498  Wunderground: Worker started...
2017-05-14 21:24:33.499  DarkSky: Started...
2017-05-14 21:24:33.500  Pinger: Started
2017-05-14 21:24:33.501  Philips Hue: Worker started...
2017-05-14 21:24:33.501  XiaomiGateway: will listen on 9898 for hardware id 36
2017-05-14 21:24:33.512  XiaomiGateway: Worker started...
2017-05-14 21:24:33.513  EventSystem: reset all events...
2017-05-14 21:24:33.520  EventSystem: reset all device statuses...
2017-05-14 21:24:33.540  XiaomiGateway: Could not detect local IP address: resolve: Host not found (authoritative)
2017-05-14 21:24:33.540  Error: XiaomiGateway: system
2017-05-14 21:24:33.541  XiaomiGateway: stopped
2017-05-14 21:24:33.552  EventSystem: Started
2017-05-14 21:24:33.700  RFLink: Using serial port: /dev/ttyACM0
2017-05-14 21:24:33.770  PluginSystem: Entering work loop.
2017-05-14 21:24:34.001  OpenZWave: using config in: /home/pi/domoticz/Config/
2017-05-14 21:24:34.056  OpenZWave: Starting...
2017-05-14 21:24:34.056  OpenZWave: Version: 1.4-2501-g5af6780-dirty
2017-05-14 21:24:34.275  OpenZWave: Driver Ready
2017-05-14 21:24:34.289  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2017-05-14 21:24:34.289  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2017-05-14 21:24:34.290  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Luminance, Instance: 3
2017-05-14 21:24:34.290  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR MULTILEVEL, Label: Seismic Intensity, Instance: 25
2017-05-14 21:24:34.290  OpenZWave: Value_Added: Unhandled Label: Seismic Intensity, Unit:
2017-05-14 21:24:34.291  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Alarm Type, Instance: 1
2017-05-14 21:24:34.291  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Alarm Level, Instance: 1
2017-05-14 21:24:34.292  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: SourceNodeId, Instance: 1
2017-05-14 21:24:34.292  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: ALARM, Label: Burglar, Instance: 1
2017-05-14 21:24:34.293  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2017-05-14 21:24:34.293  OpenZWave: Value_Added: Node: 8 (0x08), CommandClass: SENSOR ALARM, Label: General, Instance: 1
2017-05-14 21:24:34.295  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-14 21:24:34.295  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-05-14 21:24:34.296  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-05-14 21:24:34.296  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-05-14 21:24:34.296  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-05-14 21:24:34.296  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Up, Instance: 1
2017-05-14 21:24:34.296  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: SWITCH MULTILEVEL, Label: Down, Instance: 1
2017-05-14 21:24:34.296  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: METER, Label: Energy, Instance: 1
2017-05-14 21:24:34.297  OpenZWave: Value_Added: Node: 9 (0x09), CommandClass: METER, Label: Power, Instance: 1
2017-05-14 21:24:34.299  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH BINARY, Label: Switch, Instance: 1
2017-05-14 21:24:34.299  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Step Size, Instance: 1
2017-05-14 21:24:34.299  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Inc, Instance: 1
2017-05-14 21:24:34.299  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Dec, Instance: 1
2017-05-14 21:24:34.300  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Level, Instance: 1
2017-05-14 21:24:34.300  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Up, Instance: 1
2017-05-14 21:24:34.300  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: SWITCH MULTILEVEL, Label: Down, Instance: 1
2017-05-14 21:24:34.300  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Energy, Instance: 1
2017-05-14 21:24:34.301  OpenZWave: Value_Added: Node: 10 (0x0a), CommandClass: METER, Label: Power, Instance: 1
2017-05-14 21:24:34.405  Incoming connection from: 192.168.1.27
2017-05-14 21:24:34.617  RFLink: 20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R46;
2017-05-14 21:24:34.617  RFLink: Controller Initialized!...
2017-05-14 21:24:34.692  RFLink: 20;01;MiLight=ON;
2017-05-14 21:24:34.693  RFLink: 20;02;VER=1.1;REV=46;BUILD=0c;
2017-05-14 21:24:34.693  RFLink Detected, Version: 1.1 Revision: 46 Build: 0
2017-05-14 21:24:34.815  (IP Checker) Initialized version 1.0.0, author 'ycahome'
DennisD
Post by DennisD »
Just did a fresh install of my rpi3 but still have the same issue, i do however have the log entry PluginSystem: Started, Python version '3.4.2 which at first i didn't. Running the latest beta (3.479)
EDIT: Replaced the url to https://api.ipify.org/ , now no more errors!
assenzuid
Post by assenzuid »
Domoticz Bèta 3.7602 has some issues with the Python framework.
viewtopic.php?f=6&t=17778
poudenes
Domoticz version: 3.8993
Post by poudenes »
Works GREAT !!!!!
Only thing: You can not use it on a Slave Domoticz and read the info on the Master Domoticz. The Device is not shown in list of "not used"devices on the Master Domoticz.
Maybe thats it thing to look at. Rest briljant plugin. Now i can check if my VPN is on !!
andi216
Domoticz version: 3.7243
Post by andi216 »
Hello
How can I send a notification to the Telegram if it changes wan ip?
(A simple method ... I'm not a programmer)
poudenes
Post by poudenes »
Now i get this error as well:
Error: (Domoticz IP) ----> Line 101 in /home/pi/domoticz/plugins/wan-ip-checker/plugin.py, function onHeartbeat
Error: (Domoticz IP) ----> Line 72 in /home/pi/domoticz/plugins/wan-ip-checker/plugin.py, function onHeartbeat
Error: (Domoticz IP) ----> Line 153 in /usr/lib/python3.4/urllib/request.py, function urlopen
Error: (Domoticz IP) ----> Line 461 in /usr/lib/python3.4/urllib/request.py, function open
Error: (Domoticz IP) ----> Line 571 in /usr/lib/python3.4/urllib/request.py, function http_response
Error: (Domoticz IP) ----> Line 499 in /usr/lib/python3.4/urllib/request.py, function error
Error: (Domoticz IP) ----> Line 433 in /usr/lib/python3.4/urllib/request.py, function _call_chain
Error: (Domoticz IP) ----> Line 579 in /usr/lib/python3.4/urllib/request.py, function http_error_default
Have the python3 dev installed already
