Samsung TV control in Domoticz
ptijo
Re: Samsung TV control in Domoticz
Post by ptijo »
i have try :
/usr/local/iSamsungTV/bin$ ./iSamsungTV C 192.168.1.10 -KEY KEY_MUTE
-sh: ./iSamsungTV: cannot execute binary file: Exec format error
and with root
-ash: /usr/local/iSamsungTV/bin$: No such file or directory
jumbotroll
Post by jumbotroll »
@ptijo
I am using this without any problem, on DS712+, but maybe my build not working on your NAS.
If my packages not work I'm going to delete them from my server.
Edit: packages deleted!
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Rodio
Post by Rodio »
tontze wrote:
Correct sudo usage :
sudo /usr/local/iSamsungTV/bin/iSamsungTV E 192.168.1.36 -KEY KEY_POWEROFF
Still the same error:
root@HA:~# sudo /usr/local/iSamsungTV/bin/iSamsungTV E 192.168.1.36 -KEY KEY_POWEROFF
/usr/local/iSamsungTV/bin/iSamsungTV: /usr/local/iSamsungTV/bin/iSamsungTV: cannot execute binary file
I tried:
Delete and reinstall package.
Install it on my 916 (running latest stable version)
Install it on my 916 running Domoticz V3.6749
Tried the C, D, F TV setting.
All give the same error
ptijo
Post by ptijo »
jumbotroll wrote:@ptijo
I see that there are lot of issue with version of NAS
uname r :2.6.32.12
'm sorry, but I'm resigning myself.
thanks
tontze
Domoticz version: Beta Ch
Post by tontze »
I tried:
Not the same error, last time it didnt find sudo since wrong path was provided to it. go to
and try
./iSamsungTV
or
sudo ./iSamsungTV
If it cannot be xecuted, you have wrong architecture for the binary or perhaps permission problem ? You can try giving more execution permissions
chmod a+x /usr/local/iSamsungTV/bin/iSamsungTV
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Rodio
Post by Rodio »
Hi Tontze,
Thx for the replies.
did the chmod a+x thing
root@HA:/usr/local/iSamsungTV/bin# iSamsungTV
-ash: /bin/iSamsungTV: cannot execute binary file: Exec format error
root@HA:/usr/local/iSamsungTV/bin# iSamsungTV E 192.168.1.36 -KEY KEY_POWERON
root@HA:/usr/local/iSamsungTV/bin# sudo iSamsungTV
/bin/iSamsungTV: /bin/iSamsungTV: cannot execute binary file
root@HA:/usr/local/iSamsungTV/bin# sudo ./iSamsungTV
./iSamsungTV: ./iSamsungTV: cannot execute binary file
R
tontze
Post by tontze »
Check that your binary file matches with your systems architecture, is it ARM and your system is X86 or vice versa :) Or is it 32bit program and your system is 64bit, or vice versa.
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Rodio
Post by Rodio »
No idea how to check for which architecture the binary file is.
I've downloaded it form the site of Jumbotroll, but he's deleted them (they're not there anymore).
I'm gonna stop for now with this 'project'.
Thx for the help Tontze, really appreciate it :D
bueno79
Domoticz version: 4.9700
Post by bueno79 »
your problem is : this file is NOT compile for your architecture. type :
file iSamsungTV
you will see the infos (you need file command of course). So I get the same issue and fix it with a 214play.
- I install a linux ubuntuu.
- I install the CORRECT tool chain from here on the ubuntuu (https://sourceforge.net/projects/dsgpl/ ... edomCookie)
- I set some variables to compile on th ubuntuu (lines below are not for 214play, just example)
export CFLAGS="-I/usr/local/arm-none-linux-gnueabi/include"
export LDFLAGS="-L/usr/local/arm-none-linux-gnueabi/lib"
export RANLIB=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ranlib
export LD=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-ld
export CC=/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc
export LD_LIBRARY_PATH=/usr/local/arm-none-linux-gnueabi/lib
export ARCH=arm
- then compile the samsungTV code (I clone the project on the ubuntuu with git first) with the gcc (the path is in the variable CC you set before)
- move my new iSAmsungTV on my NAS
it woooorks !!!
you can find all info in french here : http://benjamin-balet.info/multimedia/s ... -synology/
you can fin d info on google with "cross compilation synology"
regards
Bueno
stavast
Post by stavast »
perwei wrote:Just a comment regarding newer Samsung TVs like model K. Seems iSamsungTV isn't working on those models.
On the other hand, Wake-on-LAN does work and brings the TV from sleeping and un-pingable to live and pingable.
Cheers,
Per
As a proud owner of a Samsung Series K I really wanted to integrate remote control into Domoticz and i finally found a way!
SamsungCTL makes it possible to control the Samsung Series K (and probably all the other series as well). At this moment i can control the TV via the command interface, so we are only a small step away from the full integration which will allow us to control the TV via Domoticz.
Installation
1. Install python3-pip:
pi@domoticz:~ $ sudo apt-get install python3-pip
2. Install SamsungCTL:
pi@domoticz:~ $ sudo pip3 install samsungctl
3. Install websocket-client (this python module is needed for the 2016+ Samsung models):
pi@domoticz:~ $ sudo pip3 install websocket-client
4. Make sure your TV is on, run the following command from the cli (Change xxx.xxx.xxx.xxx with the IP address of your TV):
pi@domoticz:~ $ samsungctl --host xxx.xxx.xxx.xxx --method websocket KEY_MUTE
5. Depending on the setting of your TV, the TV will ask you if you want to allow the external control from the device from which you just send the mute key
6. Allow the external control with your TV Remote and voila! remote control should be working now and the volume of your TV should be muted.
Extra information:
1. To unmute your tv use
pi@domoticz:~ $ samsungctl --host xxx.xxx.xxx.xxx --method websocket KEY_VOLUP
KEY_UNMUTE would be the logical unmute option, but I didn't see that in the key list ;)
2. The extra option
--method websocket
should only be needed for the 2016+ models.
Links
SamsungCTL GitHub: https://github.com/Ape/samsungctl
Key Codes: https://github.com/Ape/samsungctl#key-codes
Good luck!
mlamie
Domoticz version: 3.5877
Post by mlamie »
stavast wrote: Good luck!
I have seen there is a new Samsung TV page in the Domoticz wiki based on samsungctl. You can try that as well I expect.
https://www.domoticz.com/wiki/Plugins/SamsungTV.html
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
Westcott
Post by Westcott »
When I try it from the command line, I get -
File "/usr/local/bin/samsungctl", line 9, in <module>
load_entry_point('samsungctl==0.6.0', 'console_scripts', 'samsungctl')()
File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 93, in main
config = _read_config()
File "/usr/local/lib/python2.7/dist-packages/samsungctl/__main__.py", line 37, in _read_config
except FileNotFoundError:
NameError: global name 'FileNotFoundError' is not defined
My guess is that the config file is missing...
stavast
Post by stavast »
O Wow, I have been searching for two weeks! what a coincidence and a luck. Thank god the plugin is from the 27th of March, I was very sure I search in every corner of the Domoticz forum and wiki. I felt a bit of a fool for missing such a big elephant :lol: Thanks for mentioning it mlamie!
stavast
Post by stavast »
Westcott wrote:When I try it from the command line, I get -
You need to have Python Version 3 to be able to run samsungctl. based upon this "File "/usr/local/lib/python2.7/" i get the feeling you installed it under Python Version 2 with the use of pip instead of pip3
Westcott
Post by Westcott »
Thanks, Stavast!
The Wiki needs to be updated with some 3's.
I REALLY don't like version-specific installs.
Now I'm getting the dreaded -
/usr/local/bin/python3.5: error while loading shared libraries: libpython3.5.so.1.0: cannot open shared object file: No such file or directory
Python3 runs OK -
Python3 -i
Python 3.5.2 (default, Dec 14 2016, 15:53:15)
echo $LD_LIBRARY_PATH
/usr/local/lib
And libpython3.5.so.1.0 is in /usr/local/lib
Haven't been able to Google a solution yet.
ptijo
Post by ptijo »
#bueno79
Could you give me the gcc command
i try but i have the same error (format exec error)
bueno79 wrote:Hi,
file iSamsungTV
export ARCH=arm
it woooorks !!!
regards
Bueno
bueno79
Post by bueno79 »
@ptijo
just imagine your processor is an arm. you get the tool chain and your path is the default one. And you have the source from iSamnsungTV in your home. So you should type something like this :
/usr/local/arm-none-linux-gnueabi/bin/arm-none-linux-gnueabi-gcc /home/bueno/iSamsungTV/iSamsungTV.c
woodtrix
Post by woodtrix »
If you have a precompiled binary of iSamsungTV, other then osx or raspberry pi, post a link, I will add them to the github page...
tontze
Post by tontze »
Finally made a button to control my TV in domoticz, but seems its not working well ..
2017-04-18 17:31:47.268 Error: Error executing script command (/usr/local/bin/iSamsungTV). returned: 512
This is what im getting to log in domoticz, from command line its working well .. ?
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
bueno79
Post by bueno79 »
woodtrix wrote:If you have a precompiled binary of iSamsungTV, other then osx or raspberry pi, post a link, I will add them to the github page...
ok I will extract my version.
