Page 2 of 4
Re: Yamaha AV Receiver Plugin
Posted: Friday 18 August 2017 17:57
by ohnsorge
Hi, when i install a plugin after few hours Domoticz show error:
2017-08-18 17:20:56.782 Domoticz V3.8153 (c)2012-2017 GizMoCuz
2017-08-18 17:20:56.783 Build Hash: 494fff7, Date: 2017-07-30 12:19:41
2017-08-18 17:20:56.783 Startup Path: /home/pi/domoticz/
2017-08-18 17:20:56.830 Sunrise: 05:42:00 SunSet:20:10:00
2017-08-18 17:20:56.830 EventSystem: reset all events...
2017-08-18 17:20:56.993 PluginSystem: Started, Python version '3.4.2'.
2017-08-18 17:20:56.994 Using 1-Wire support (OWFS)...
2017-08-18 17:20:57.009 Active notification Subsystems: (0/12)
2017-08-18 17:20:57.018 WebServer(HTTP) started on address: 0.0.0.0 with port 8080
2017-08-18 17:20:57.042 Error: WebServer(SSL) startup failed on address 0.0.0.0 with port: 443: bind: Permission denied
2017-08-18 17:20:57.042 Error: WebServer(SSL) check privileges for opening ports below 1024
2017-08-18 17:20:57.043 Proxymanager started.
2017-08-18 17:20:57.046 Starting shared server on: 0.0.0.0:6144
2017-08-18 17:20:57.046 TCPServer: shared server started...
2017-08-18 17:20:57.047 RxQueue: queue worker started...
2017-08-18 17:20:59.059 Wunderground: Worker started...
2017-08-18 17:20:59.060 EventSystem: reset all events...
2017-08-18 17:20:59.062 EventSystem: reset all device statuses...
2017-08-18 17:20:59.334 PluginSystem: Entering work loop.
2017-08-18 17:20:59.551 (Yamaha RXV) Initialized version 1.0.0, author 'thomasvillagers'
Naruszenie ochrony pamięci
Have you meet something like this?
Sorry for my english :)
Posted: Thursday 24 August 2017 20:02
by EJanus
I've been trying for hours to get this to work, but no success. I hope you can take some time to help me out.
The plugin made by thomasvillagers works really well! But now I want to use zone2 as well. So I took the code that jimtrout87 wrote and tried to put it in the latest update of thomasvillagers plugin.py (because the code that jimtrout87 posted earlier, doesn't work anymore).
What I've been trying to do is this:
 # Basic Python Plugin
# Author: thomas-villagers
<plugin key="YamahaPlug" name="Yamaha AV Receiver" author="thomasvillagers" version="1.0.0" wikilink="http://www.domoticz.com/wiki/plugins/plugin.html" externallink="https://yamaha.com/products/audio_visual/av_receivers_amps/">
    <params>
     <param field="Address" label="IP Address" width="200px" required="true" default="192.168.1.10"/>
     <param field="Port" label="Port" width="50px" required="true" default="50000"/>
     <param field="Mode6" label="Debug" width="75px">
       <options>
          <option label="True" value="Debug"/>
          <option label="False" value="Normal"  default="true" />
       </options>
     </param>
    </params>
</plugin>
import Domoticz
import base64
class BasePlugin:
    enabled = False
    isConnected = True
    outstandingPings = 0
    nextConnect = 0
    commandArray = ["@MAIN:VOL=?", "@MAIN:INP=?", "@MAIN:MUTE=?", "@MAIN:SOUNDPRG=?", "@MAIN:SCENE=?", "@MAIN:PWR=?","@ZONE2:VOL=?", "@ZONE2:INP=?", "@MAIN:ZONE2=?", "@ZONE2:SOUNDPRG=?", "@ZONE2:SCENE=?", "@ZONE2:PWR=?"]
    commandIndex = 0
    def __init__(self):
        #self.var = 123
        return
    def onStart(self):
        if Parameters["Mode6"] == "Debug":
           Domoticz.Debugging(1)
        Domoticz.Debug("onStart called")
        if (len(Devices) == 0):
            Domoticz.Device(Name="Status",  Unit=1, Type=17,  Switchtype=17).Create()
            Domoticz.Device(Name="Volume",  Unit=2, Type=244, Subtype=73, Switchtype=7,  Image=8).Create()
            LevelActions= "LevelActions:"+stringToBase64("||||")+";"
            LevelNames= "LevelNames:"+stringToBase64("Off|Scene1|Scene2|Scene3|Scene4|Other")+";"
            Other= "LevelOffHidden:ZmFsc2U=;SelectorStyle:MA==" # true is "dHJ1ZQ==", 1 is "MQ=="
            Options=LevelActions+LevelNames+Other
            Domoticz.Device(Name="Source", Unit=3, TypeName="Selector Switch", Options=Options).Create()
            Domoticz.Device(Name="Zone 2 Status",  Unit=4, Type=17,  Switchtype=17).Create()
            Domoticz.Device(Name="Zone 2 Volume",  Unit=5, Type=244, Subtype=73, Switchtype=7,  Image=8).Create()
            LevelActions= "LevelActions:"+stringToBase64("|||")+";"
            LevelNames= "LevelNames:"+stringToBase64("Off|Main Sync|Input1|Other")+";"
            Domoticz.Device(Name="Zone 2 Source", Unit=6, TypeName="Selector Switch", Options=Options).Create()
        self.connection = Domoticz.Connection(Name="Yamaha connection", Transport="TCP/IP", Protocol="Line", Address=Parameters["Address"], Port=Parameters["Port"])
        self.connection.Connect()
        Domoticz.Heartbeat(20)
    def onStop(self):
        Domoticz.Log("onStop called")
    def onConnect(self, Connection, Status, Description):
        Domoticz.Debug("onConnect called. Status: " + str(Status))
        if (Status == 0):
          self.isConnected = True
#         UpdateDevice(1,1,"")
          self.onHeartbeat()
        else:
          self.isConnected = False
    def onMessage(self, Connection, Data, Status, Extra):
        Domoticz.Debug("onMessage called")
        self.outstandingPings = self.outstandingPings - 1
        strData = Data.decode("utf-8", "ignore")
        arrData = strData.split('=')
        for x in arrData:
            Domoticz.Debug(x)
        if (arrData[0] == "@MAIN:VOL"):
            vol = float(arrData[1])
            sliderValue = int(vol*5/4 + 100)
			if (Devices[1].sValue == "On"):
                UpdateDevice(2,2,str(sliderValue))
        elif (arrData[0] == "@MAIN:INP"):
            s = arrData[1]
                if (s == "HDMI1"):
                    UpdateDevice(3,2,str(10))
                elif (s == "HDMI2"):
                    UpdateDevice(3,2,str(20))
                elif (s == "AUDIO1"):
                    UpdateDevice(3,2,str(30))
                elif (s == "TUNER"):
                    UpdateDevice(3,2,str(40))
                else:
                    UpdateDevice(3,2,str(50))
        elif (arrData[0] == "@MAIN:PWR"):
            p = arrData[1]
            Domoticz.Log(p)
            if (p == "On"):
                UpdateDevice(1,1,"On")
            elif (p == "Standby"):
                UpdateDevice(1,0,"Standby")
                UpdateDevice(2,0,Devices[2].sValue)
                UpdateDevice(3,0,Devices[3].sValue)
        elif (arrData[0] == "@ZONE2:VOL"):
            if (Devices[4].sValue == "On"):
                UpdateDevice(5,2,str(sliderValue))
        elif (arrData[0] == "@ZONE2:INP"):
            s = arrData[1]
                if (s == "Main Zone Sync"):
                    UpdateDevice(6,2,str(10))
                    UpdateDevice(6,2,str(20))
                else:
                    UpdateDevice(6,2,str(30))
        elif (arrData[0] == "@ZONE2:PWR"):
            p = arrData[1]
            Domoticz.Log(p)
            if (p == "On"):
                UpdateDevice(4,1,"On")
                UpdateDevice(4,0,"Standby")
                UpdateDevice(5,0,Devices[5].sValue)
                UpdateDevice(6,0,Devices[6].sValue)
    def onCommand(self, Unit, Command, Level, Hue):
        Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
        if (self.isConnected == False):
            return
        if (Unit == 1):
            if (Command == "Off"):
                UpdateDevice(1,0,Devices[1].sValue) # TODO remove
                self.connection.Send("@MAIN:PWR=Standby\r\n")
            elif (Command == "On"):
               self.connection.Send("@MAIN:PWR=On\r\n")
        elif (Unit == 2):
            if (Command == "Set Level"):
                volume = int(Level)*4/5 - 80
                volumeToSend = round(2*volume)/2
                self.connection.Send("@MAIN:VOL="+str(volumeToSend)+"\r\n")
        elif (Unit == 3):
            input = str(int(int(Level)/10))
            self.connection.Send("@MAIN:SCENE=Scene " + input + "\r\n")
        elif (Unit == 4):
                UpdateDevice(4,0,Devices[1].sValue) # TODO remove
                self.connection.Send("@ZONE2:PWR=Standby\r\n")
                self.connection.Send("@ZONE2:PWR=On\r\n")
        elif (Unit == 5):
                self.connection.Send("@ZONE2:VOL="+str(volumeToSend)+"\r\n")
        elif (Unit == 6):
            if (input == "1"):
                self.connection.Send("@ZONE2:INP=Main Zone Sync" + "\r\n")
            elif (input == "2"):
                self.connection.Send("@ZONE2:INP=AUDIO1" + "\r\n")
    def onNotification(self, Data):
        Domoticz.Debug("onNotification: " + str(Data))
    def onDisconnect(self, Connection):
        Domoticz.Debug("onDisconnect called")
 #       UpdateDevice(1,0,"")
 #       UpdateDevice(2,0,Devices[2].sValue)
 #       UpdateDevice(3,0,Devices[3].sValue)
    def onHeartbeat(self):
        Domoticz.Debug("onHeartbeat called. Connected: " + str(self.isConnected))
        if (self.isConnected == True):
            if (self.outstandingPings > 6):
                Domoticz.Debug("Missed more than 6 pings - disconnect")
                self.connection.Disconnect()  # obsolete
                self.nextConnect = 0
            else:
                self.connection.Send(self.commandArray[self.commandIndex] + "\r\n")
                self.commandIndex = (self.commandIndex + 1 ) % len(self.commandArray)
                self.outstandingPings = self.outstandingPings + 1
        else:
            self.outstandingPings = 0
            self.nextConnect = self.nextConnect - 1
            if (self.nextConnect <= 0):
                self.nextConnect = 3
                self.connection.Connect()  # obsolete
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onConnect(Connection, Status, Description):
    global _plugin
    _plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data, Status, Extra):
    global _plugin
    _plugin.onMessage(Connection, Data, Status, Extra)
def onCommand(Unit, Command, Level, Hue):
    global _plugin
    _plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Data):
    global _plugin
    _plugin.onNotification(Data)
def onDisconnect(Connection):
    global _plugin
    _plugin.onDisconnect(Connection)
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
def UpdateDevice(Unit, nValue, sValue):
    # Make sure that the Domoticz device still exists (they can be deleted) before updating it
    if (Unit in Devices):
        if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue):
            Devices[Unit].Update(nValue, str(sValue))
            Domoticz.Log("Update "+str(nValue)+":'"+str(sValue)+"' ("+Devices[Unit].Name+")")
    return
    # Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
    Domoticz.Debug("Device count: " + str(len(Devices)))
    for x in Devices:
        Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
        Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
    return
def stringToBase64(s):
    return base64.b64encode(s.encode('utf-8')).decode("utf-8")
def base64ToString(b):
    return base64.b64decode(b).decode('utf-8')
It doesn't work. When I add hardware in Domoticz it seems to work after selecting this plugin, but when i go to the Devices nothing shows up. Domoticz log tells me that there is an error in line 80, but I don't understand how I should fix this.
Line 80: if (Devices[1].sValue == "On"):
Please help me out.
Posted: Friday 01 September 2017 16:56
by EJanus
jimtrout87 wrote: Monday 06 March 2017 10:36 Ok so i tried this myself and managed to get the scenes working if anyone is interested...
Hi Jim,
As you can read in my last post, your code doesn't work anymore. I tried to fix it by combining your code with the newest plugin of thomas, but I failed (becourse I have no programming skills). Can you help me out? I really would like to be able to use zone2 etc. like you posted before.
Posted: Wednesday 06 September 2017 17:28
by EJanus
I Think I solved it. Right now I'm testing if and how everything works. Will report back later.
Posted: Friday 15 September 2017 22:00
by Remicade
Hi, on my rx-v677 it is sort of running. I o not use any additional scripts, only the plugin.
Volume works. Selector works. But when I power off the amp Domoticz still says the it is on.
How to get the Yamaha logos is my other question.
Thanks Paul
by Remicade
Hi, on my rx-v677 it is sort of running. I do not use any additional scripts, only the plugin.
Volume works. Selector works. But when I power off the amp Domoticz still says that it is on.
Thanks Paul
Posted: Friday 15 September 2017 23:26
by Goldwing1973
2017-09-15 23:23:26.617 Error: (Yamaha Reciever Woonkamer) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
Thats what i'm getting with my Yamaha RX-V477, it would be nice to get it working.
Posted: Saturday 16 September 2017 14:15
by Remicade
After a restart, (Domoticz hangs some times, I have to copy the auto restart and monitoring script) in my log I find this...
2017-09-16 14:12:51.793 Error: (Yamaha) 'onMessage' failed 'ValueError':'invalid literal for int() with base 10: 'y''.
2017-09-16 14:12:51.793 Error: (Yamaha) ----> Line 159 in /home/pi/domoticz/plugins/Yamaha/plugin.py, function onMessage
2017-09-16 14:12:51.793 Error: (Yamaha) ----> Line 85 in /home/pi/domoticz/plugins/Yamaha/plugin.py, function onMessage
What could this be?
Thanks Paul
Posted: Sunday 17 September 2017 17:30
by Remicade
Could this be an answer to my earlier question:
The error is "invalid literal for int() with base 10:". This just means that the argument that you passed to int doesn't look like a number. In other words it's either empty, or has a character in it other than a digit.
This can be reproduced in a python shell.
>>> int("x")
ValueError: invalid literal for int() with base 10: 'x'
But change int into what?
Thanks Paul
Posted: Friday 29 September 2017 22:27
by Damnet
Goldwing1973 wrote: Friday 15 September 2017 23:26 2017-09-15 23:23:26.617 Error: (Yamaha Reciever Woonkamer) 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
Agree im getting the same errors fyi. 'onMessage' failed 'TypeError':'onMessage() missing 2 required positional arguments: 'Status' and 'Extra''.
HTR4065 receiver with Domoticz Version: 3.8209 on RPi.
Posted: Saturday 07 October 2017 15:01
by thomasvillagers
Hi!
fixed.
hm, cannot confirm this one ...
In addition, I refactored a few things and added a new device for controlling your AV inputs.
You can rename the input names in the two selector switches and you can delete unused ones. But you MUST keep them in order. That means, you can delete the unused inputs HDMI7, HDMI6 etc. but you CAN'T delete i. e. HDMI1 and keep the others.
You can find the updated version on Github. Hope "most" of the bugs are fixed (there are still plenty, sorry ...).
Icon images attached!
- thomas
Posted: Thursday 02 November 2017 23:09
by zicht
Hi Thomas !
Thanks man, works like a charm.
Adjusted the code a bit for all input on my v773 (HDMI1-5 AV1-6 AUDIO1-2, NET, USB, V-AUX)
    <params>
     <param field="Address" label="IP Address" width="200px" required="true" default="127.0.0.1"/>
       <options>
       </options>
     </param>
    </params>
</plugin>
import Domoticz
import base64
class BasePlugin:
    enabled = False
    isConnected = True
    nextConnect = 0
    commandArray = ["@MAIN:VOL=?", "@MAIN:INP=?", "@MAIN:MUTE=?", "@MAIN:SOUNDPRG=?"]
    commandIndex = 0
    def __init__(self):
        #self.var = 123
        return
    def onStart(self):
        if 1 not in Devices:
            Domoticz.Debug("Create Status Device")
            Domoticz.Device(Name="Status",  Unit=1, Type=17,  Switchtype=17, Used=1).Create()
        if 2 not in Devices:
            Domoticz.Debug("Create Volume Device")
            Domoticz.Device(Name="Volume",  Unit=2, Type=244, Subtype=73, Switchtype=7,  Image=8, Used=1).Create()
        if 3 not in Devices:
            Domoticz.Debug("Create HDMI Device")
            Options = { "LevelActions" : "|||||||",
                        "LevelNames"   : "Off|HDMI1|HDMI2|HDMI3|HDMI4|HDMI5",
                        "LevelOffHidden" : "true",
                        "SelectorStyle" : "0"
            Domoticz.Device(Name="Source", Unit=3, TypeName="Selector Switch", Switchtype=18, Options=Options, Used=1).Create()
        if 4 not in Devices:
            Domoticz.Debug("Create AV Device")
            Options = { "LevelActions" : "||||||",
                        "LevelNames"   : "Off|AV1|AV2|AV3|AV4|AV5|AV6",
            Domoticz.Device(Name="AV Source", Unit=4, TypeName="Selector Switch", Switchtype=18, Options=Options, Used=1).Create()
        if 5 not in Devices:
            Domoticz.Debug("Create AUDIO Device")
                        "LevelNames"   : "Off|AUDIO 1|AUDIO 2|NET|USB|V-AUX",
            Domoticz.Device(Name="AUDIO Source", Unit=5, TypeName="Selector Switch", Switchtype=18, Options=Options, Used=1).Create()
    def onStop(self):
        if (Status == 0):
          self.onHeartbeat()
        else:
    def onMessage(self, Connection, Data):
        for x in arrData:
            Domoticz.Debug(x)
            UpdateDevice(2, Devices[2].nValue, str(sliderValue))
        elif (arrData[0] == "@MAIN:MUTE"):
            if (arrData[1] == "Off"):
                UpdateDevice(2, 2, Devices[2].sValue)
            elif (arrData[1] == "On"):
                UpdateDevice(2, 0, Devices[2].sValue)
            s = arrData[1]
            if (s.startswith("HDMI")) or (s.startswith("AV")) or  (s.startswith("AUDIO")) :
              inp = int(s[-1:])
            if (s.startswith("HDMI")):
              UpdateDevice(3,2,str(inp*10))
              UpdateDevice(4,2,"0")
              UpdateDevice(5,2,"0")
            elif (s.startswith("AV")):
              UpdateDevice(4,2,str(inp*10))
              UpdateDevice(3,2,"0")
            elif (s.startswith("AUDIO")):
              UpdateDevice(5,2,str(inp*10))
            elif (s.startswith("NET")):
              UpdateDevice(5,2,str(30))
            elif (s.startswith("USB")):
              UpdateDevice(5,2,str(40))
            elif (s.startswith("V-AUX")):
              UpdateDevice(5,2,str(50))
        elif (arrData[0] == "@MAIN:SOUNDPRG"):
            UpdateDevice(1,1, arrData[1])
            return
        if (Unit == 1):
        elif (Unit == 2):
            elif (Command == "Off"):
                self.connection.Send("@MAIN:MUTE=On\r\n")
                self.connection.Send("@MAIN:MUTE=Off\r\n")
        elif (Unit == 3):
            self.connection.Send("@MAIN:INP=HDMI" + input + "\r\n")
        elif (Unit == 4):
            self.connection.Send("@MAIN:INP=AV" + input + "\r\n")
        elif (Unit == 5):
            if (input == "1" or input == "2"):
             self.connection.Send("@MAIN:INP=AUDIO" + input + "\r\n")
            elif (input == "3"):
             self.connection.Send("@MAIN:INP=NET RADIO" + "\r\n")
            elif (input == "4"):
             self.connection.Send("@MAIN:INP=USB" + "\r\n")
            elif (input == "5"):
             self.connection.Send("@MAIN:INP=V-AUX" + "\r\n")
        UpdateDevice(4,0,Devices[4].sValue)
            else:
        else:
global _plugin
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
    global _plugin
def onMessage(Connection, Data):
    global _plugin
    _plugin.onMessage(Connection, Data)
    global _plugin
    global _plugin
    global _plugin
def onHeartbeat():
    global _plugin
    return
    for x in Devices:
    return
As i am not a coder at all I am sure my code is not the most beautifull thing, but it works for me at the moment.
Sorry if i used some dirty code to get the functionality.
note : Now looking into zone 2 input selection and volume, but i am stuck on the selection of zone 2 :shock:
Posted: Monday 06 November 2017 8:05
by zicht
All credits to Thomas !
MAIN ON/OFF Volume&Mute (HDMI1-5 AV1-6 AUDIO1-2, NET, USB, V-AUX)
ZONE2 ON/OFF Volume&Mute (Audio1-2,Net,USB)
    <params>
       <options>
       </options>
     </param>
    </params>
</plugin>
import Domoticz
import base64
class BasePlugin:
    enabled = False
    isConnected = True
    nextConnect = 0
    commandArray = ["@MAIN:SOUNDPRG=?", "@MAIN:PWR=?", "@MAIN:VOL=?", "@MAIN:INP=?", "@MAIN:MUTE=?", "@ZONE2:PWR=?", "@ZONE2:VOL=?", "@ZONE2:MUTE=?", "@ZONE2:INP=?"]
	#commandArray = ["@MAIN:VOL=?", "@MAIN:INP=?", "@MAIN:MUTE=?", "@MAIN:SOUNDPRG=?"]
    commandIndex = 0
    def __init__(self):
        #self.var = 123
        return
    def onStart(self):
        if 6 not in Devices:
            Domoticz.Debug("Create Status Z2 Device")
            Domoticz.Device(Name="Status Zone2",  Unit=6, Type=17,  Switchtype=17, Used=1).Create()
        if 7 not in Devices:
            Domoticz.Debug("Create Volume Zone 2 Device")
            Domoticz.Device(Name="Volume Zone2",  Unit=7, Type=244, Subtype=73, Switchtype=7,  Image=8, Used=1).Create()
        if 8 not in Devices:
            Domoticz.Debug("Create AUDIO Z2 Device")
                        "LevelNames"   : "Off|AUDIO 1|AUDIO 2|NET|USB",
            Domoticz.Device(Name="AUDIO Source Zone2", Unit=8, TypeName="Selector Switch", Switchtype=18, Options=Options, Used=1).Create()
    def onStop(self):
        if (Status == 0):
          self.onHeartbeat()
        else:
        for x in arrData:
            Domoticz.Debug(x)
            s = arrData[1]
              inp = int(s[-1:])
            if (arrData[1] != "On"):
                UpdateDevice(1, 2, "Off")
            #elif (arrData[1] == "Standby"):
                #UpdateDevice(6, 2, "Off")
            #elif (arrData[1] == "On"):
                #UpdateDevice(1, 2, "On")
            UpdateDevice(7, Devices[7].nValue, str(sliderValue))
        elif (arrData[0] == "@ZONE2:MUTE"):
                UpdateDevice(7, 2, Devices[7].sValue)
                UpdateDevice(7, 0, Devices[7].sValue)
            s = arrData[1]
              inp = int(s[-1:])
              UpdateDevice(8,2,str(inp*10))
              UpdateDevice(8,2,str(30))
              UpdateDevice(8,2,str(40))
                UpdateDevice(6, 0, "Off")
                UpdateDevice(6, 2, "On")
            return
        if (Unit == 1):
        elif (Unit == 2):
        elif (Unit == 3):
        elif (Unit == 4):
        elif (Unit == 5):
        if (Unit == 6):
                UpdateDevice(6,0,Devices[6].sValue) # TODO remove
        elif (Unit == 7):
                self.connection.Send("@ZONE2:MUTE=On\r\n")
                self.connection.Send("@ZONE2:MUTE=Off\r\n")
        elif (Unit == 8):
             self.connection.Send("@ZONE2:INP=AUDIO" + input + "\r\n")
             self.connection.Send("@ZONE2:INP=NET RADIO" + "\r\n")
             self.connection.Send("@ZONE2:INP=USB" + "\r\n")
             self.connection.Send("@ZONE2:INP=V-AUX" + "\r\n")
        UpdateDevice(7,0,Devices[7].sValue)
        UpdateDevice(8,0,Devices[8].sValue)
            else:
        else:
global _plugin
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
    global _plugin
    global _plugin
    global _plugin
    global _plugin
    global _plugin
def onHeartbeat():
    global _plugin
    return
    for x in Devices:
    return
The only thing i am not getting the way it should, is the ON/OFF on the status device :
-On Off action works but the status of the receiver is not 100% clear. --> it appears in the text in the sensor it self
-On Off action works but in some condiftions you need to click a couple of time to cyclus on/off on the device duo to the above.
-Off is displayed as pause, but switches to on while the receiver remains off (due to status update)
I have no idea how to solve this.
- is it possible to retieve the device status in python plugin ? (If i use device.svalue i get errors :S) --> The goal is to stop the commands issued by @MAIN:SOUNDPRG what currently overwrites the status of on/off
- How to put a Kodi like device off and on ?
Any hints tips to solve this last issue are welcome.
Posted: Thursday 16 November 2017 5:53
by mooninite
Hello, all.
I have fixed the issue with the switch appearing "on" when the receiver is "off". I have made a pull request with the thomas-villagers github repo and you guys can adapt the patch to your version of Domoticz.
https://github.com/thomas-villagers/dom ... aha/pull/2
Posted: Friday 17 November 2017 10:28
by thomasvillagers
ah cool! :-) I'll check out your changes later and pull them in if they work ... :-)
- thomas
Posted: Thursday 30 November 2017 20:46
by schulpr
Does anyone has an idea why I get these error messages?
"2017-11-30 19:42:40.856 Error: (Yamaha) Transport is not connected, write directive to 'Yamaha connection' ignored"
I'm on the most recent beta.
Best regards, Rob
Posted: Wednesday 20 December 2017 10:39
by woody4165
Thanks to Thomas for this plugin and to zicht for some mods.
Just removed from zitch plugin everything related to Zone2 and it's working fine with my RX-V479.
Do you think it's possible to select Spotify or BT as source?
Merry Xmas to all of you and thanks again!!!
Posted: Monday 01 January 2018 15:48
by getdown
Hi All,
I try to use the plugin but in my log i have an error (see the attached file).
Do you know what's the problem ?
happy new year to all !
Posted: Monday 01 January 2018 15:59
by sion
HI,
Firstly; Great plugin!
After a day of trying to get this to work - only to realise i had been trying to get it to work ( on windows ) with 64 bit python, i uninstalled that, and instaleld the 32 bit version and all all worked straight away.
SO, everything seems to work well, and got the volume working with alexa which is nice, but my log is filling up with the same message a above:
im getting the following every minuet:
2018-01-01 14:57:19.331 PluginSystem: Starting I/O service thread.
2018-01-01 14:57:19.436 Error: (lounge AV) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2018-01-01 14:57:19.441 Error: (lounge AV) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2018-01-01 14:57:39.420 Error: (lounge AV) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2018-01-01 14:57:39.426 Error: (lounge AV) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2018-01-01 14:57:39.429 Error: (lounge AV) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'.
2018-01-01 14:57:39.431 Error: (lounge AV) 'onMessage' failed 'TypeError':'onMessage() takes 2 positional arguments but 4 were given'
did anyone find a fix for this?
CHeers,
Sion.
Posted: Monday 01 January 2018 16:28
by sion
Spoke too soon ;)
After aboit 30 mins it crashed Domoticz .
It’s now crashing domoticz as soon as it loads.
Using windows 10.
Latest stable build.
Latest python 32bit.
I also tried this with the latest beta, but it crashed as soon as I adjusted volume.
How do I go about disabeling it if I can’t get domoticz to load?
