Page 2 of 3
Re: Domoboard - Configuration issues
Posted: Sunday 05 March 2017 12:43
by Snowtiger
squandor wrote:Snowtiger wrote:It is not possible to get 2 variables in one chart in Domoticz, and so in Domoboard?
Actually bar chart and donut charts does support multiple devices
Good to know, had not thought about those
Posted: Sunday 05 March 2017 14:58
by squandor
Snowtiger wrote:squandor wrote:Snowtiger wrote:It is not possible to get 2 variables in one chart in Domoticz, and so in Domoboard?
No problem and wez3 has created an bug in github so we will try to fix the line charts so that it is possible to have multiple devices in the chart
Posted: Sunday 05 March 2017 16:12
by Snowtiger
good news (y)
Posted: Tuesday 14 March 2017 22:18
by Trigun
Hi Guys,
Is it common that when adding total usage table, it doesn't add up correctly?
mine shows 3.400 + 0.400 = 7.200
thanks in advance!
Posted: Wednesday 15 March 2017 8:45
by squandor
Trigun wrote:Hi Guys,
thanks in advance!
i actually don't know, we only parse the value's out of domoticz instead of calculating them so maybe the calculation depends on something in domoticz.
Posted: Friday 17 March 2017 21:28
by Trigun
Hi Guys,
I've fiddling around with Domoboard for a while and it's great but during the time i ran into a few issues.
* Power_usage charts are not adding up correctly(If I use them seperately it's working fine though but adding two different devices is not working correctly)
* i cannot seem to get two of the same graphs showing the powerusage of 2 different devices
reason for this is that I would like to use Domoboard as a dashboard to show the status/usage of different devices in my network.
the is the setup for 1 room I would like to use:
[werkkamer]
[[display_components]]
components = line_charts, bar_charts, power_usage, domoticz_smart_charts
[[top_tiles]]
[[switches]]
Lamp Zolder = 6,switch
[[line_charts]]
Temperatuur zolder = 36,month,temp
[[domoticz_smart_charts]]
Total Usage Zolderlamp = 15,month,usage
Totaal overloop lamp = 4,month,usage
[[power_usage]]
Usage Overlooplamp = 4, month,usage
Usage Zolderlamp = 15, month,usage
Hopefully I am doing something wrong and someone is able to point me in the right direction.
Thanks in advance
Posted: Saturday 18 March 2017 11:46
by squandor
[werkkamer]
[[top_tiles]]
[[switches]]
[[line_charts]]
[[power_usage]]
Thanks in advance
Well I know why it's not working but you're not going to be happy about it.
We use the charts functions from domoticz but they used globals for the charts which means that you can't use the same graph types on the same page like 2 times month.
We don't know how to fix that at the moment because the code of domoticz is quite large
Posted: Saturday 18 March 2017 16:53
by Trigun
squandor wrote:Trigun wrote:Hi Guys,
[werkkamer]
[[top_tiles]]
[[switches]]
[[line_charts]]
[[power_usage]]
Thanks in advance
hmm thats a shame, is there a possible workaround perhaps?
Posted: Saturday 18 March 2017 17:56
by squandor
Trigun wrote:squandor wrote:Trigun wrote:Hi Guys,
[werkkamer]
[[top_tiles]]
[[switches]]
[[line_charts]]
[[power_usage]]
Thanks in advance
Maybe use 1 smart chart and one normal chart
Or 1 month and another year type. We are looking to combine devices in one chart so you will have the same principle.
Posted: Saturday 18 March 2017 18:20
by Trigun
Ok, that sounds promising.
perhaps extracting the data from the domoticz database will work?
Looking forward to the updated version, thanks again for all your help!
Posted: Saturday 18 March 2017 20:26
by EdwinK
squandor wrote:
That's the right notation. But if I trie to use you're zip code on
http://mijnafvalwijzer.nl it doesn't give an result so afvalwijzer doesnt support you're zip code
Strange, when i checked (and double checked), my postcode (zip code) was recognized on mijnafvalwijzer.nl, 3161LH, 27 but it also gives an unknown zip-code
Posted: Sunday 19 March 2017 13:45
by EdwinK
Earlier today I wrote that I've got things working, but... guess Murphy's law decided to kick in.
root@DiskStation:/var/packages/domoboard# python server.py -c domo.conf
File "server.py", line 149, in <module>
unsanitizedConfig = configobj.ConfigObj(configfile)
File "build/bdist.linux-armv5tel/egg/configobj.py", line 1229, in __init__
File "build/bdist.linux-armv5tel/egg/configobj.py", line 1318, in _load
configobj.NestingError: Cannot compute the section depth at line 76.
Had made a change into domo.conf, but since that didn't work, removed it and put the old config file back.
(Edit) - Just to try something, I made a new test.conf file and when starting that, it all worked again. Retrying my 'old' domo.conf and it failed again with the above error.
Posted: Sunday 19 March 2017 13:59
by jjnj
Is anyone else having issues with the RSS reader?
I see the ''block'' with the title but there is no content.
components = news
[[news]]
rssfeed = http://feeds.nos.nl/nosnieuwsalgemeen
Posted: Sunday 19 March 2017 22:21
by Snowtiger
jjnj wrote:Is anyone else having issues with the RSS reader?
components = news
[[news]]
This NOS feeds is serviced by FeedBurner and therefore not available in this way - I tried
http://www.nu.nl/rss/Algemeen and it works
Posted: Monday 20 March 2017 11:25
by squandor
Snowtiger wrote:jjnj wrote:Is anyone else having issues with the RSS reader?
components = news
[[news]]
thats a shame indeed.
Posted: Monday 20 March 2017 11:26
by squandor
EdKo66 wrote:Earlier today I wrote that I've got things working, but... guess Murphy's law decided to kick in.
hmm i didn't always liked Murphy's law
it seems that there is something in you're domo.conf which crashes the server. maybe forgot an bracket or something?
Posted: Monday 20 March 2017 12:53
by EdwinK
I guess so. But.. I copied it one on one to the new file and it worked. Computers are sometimes stupid thigns
Posted: Monday 20 March 2017 12:55
by squandor
EdKo66 wrote:I guess so. But.. I copied it one on one to the new file and it worked. Computers are sometimes stupid thigns
haha that sure is.
Posted: Monday 20 March 2017 13:09
by jjnj
components = news
[[news]]
Indeed, thank you!
Posted: Friday 21 April 2017 17:45
by AleSpero
Hello! I recently discovered this tool, and it's really great! Thank you for your hard work
I got some questions:
- Can i add data from 2 different devices in a line chart? I've seen in the general discussion topic that someone had both temperature and humidity in the same chart, i tried to replicate that (using a Lux sensor instead of humidity)
-Speaking of the Lux sensor, i can't seem to display its data in a line chart (i tried Domoticz smart chart too)
Is it supported? I tried something like
But it's showing an "usage" graph with no data in it.
Thank you!
