Domoboard - Bug reports
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
jaccov
Re: Domoboard - Bug reports
pi@Domoticz:~/domoboard/bin $ sudo /home/pi/domoboard/bin/python /home/pi/domoboard/server.py -d -c /home/pi/domoboard/home.conf
Error occured during loading imports for the plugin afvalwijzer: No module named BeautifulSoup. Install it with 'easy_install BeautifulSoup' or 'pip install BeautifulSoup'
squandor
- Domoticz version: 3.5837
Ok so could you try the following. Run /home/pi/domoboard/bin/python than after that try: import BeautifulSoup
jaccov
pi@Domoticz:~/domoboard/bin $ /home/pi/domoboard/bin/python
Python 2.7.9 (default, Sep 17 2016, 20:26:04)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
File "<stdin>", line 1, in <module>
ImportError: No module named BeautifulSoup
squandor
Ow I see it already you where still using the pip of the os could you try the following command sudo /home/pi/domoboard/bin/pip install BeautifulSoup --upgrade
jaccov
Yes it is running now but.....
when I open a browser I get
IOError
IOError: [Errno 2] No such file or directory: 'VERSION.md'
Traceback (most recent call last)
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 2000, in __call__
return self.wsgi_app(environ, start_response)
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1991, in wsgi_app
response = self.make_response(self.handle_exception(e))
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1567, in handle_exception
reraise(exc_type, exc_value, tb)
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1988, in wsgi_app
response = self.full_dispatch_request()
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1641, in full_dispatch_request
rv = self.handle_user_exception(e)
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1544, in handle_user_exception
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1639, in full_dispatch_request
rv = self.dispatch_request()
File "/home/pi/domoboard/lib/python2.7/site-packages/flask/app.py", line 1625, in dispatch_request
return self.view_functions[rule.endpoint](**req.view_args)
File "/home/pi/domoboard/lib/python2.7/site-packages/flaskext/auth/auth.py", line 186, in decorator
return func(*args, **kwargs)
File "/home/pi/domoboard/server.py", line 55, in generatePage
version = webconfig.getVersion(),
File "/home/pi/domoboard/modules/webconfig.py", line 23, in getVersion
f = open('VERSION.md', 'r')
squandor
Hmm strange what you could try is remove in the plugins folder afvalwijzer.py in template remove afvalwijzer and in docs remove the readmy from afvalwijzer and try to start domoboard again en try to install it again
jaccov
Removed it all but the result is the same
squandor
Even if you didn't try to install afvalwijzer?
jaccov
I removed it, didn't install it again.
Browser says the same IOError.
squandor
hmm could you see if there is an VERSION.md in you domoboard folder?jaccov wrote:I removed it, didn't install it again.
jaccov
Yes it is there.
jaccov
Well it is very strange, I restart the raspberry a couple of times.
And now it is working....
but after reboot again, still IOerror
squandor
Hmm what you could try is remove the version.md and create it again with the values from the github
jaccov
when I start it in home/pi/domoboard/ it is working perfect
when i start it in home/pi/ then I get the IOerror
squandor
Strange we will look into that but now it will start normally right?
jaccov
Yes it is., thanks for the support
