Page 2 of 3
Re: interceptWH2600 - WH2600 Weather Station Interceptor
Posted: Saturday 11 November 2017 11:57
by Doudy
I'm still here.
I tried to start interceptWH2600.py via the interceptWH2600.sh script.
The script works but interceptWH2600.py does not start.
pi@RASPBERRYPI-182:~/interceptWH2600 $ sudo /etc/init.d/interceptWH2600.sh start
[ ok ] Starting interceptWH2600.sh (via systemctl): interceptWH2600.service.
pi@RASPBERRYPI-182:~/interceptWH2600 $ /etc/init.d/interceptWH2600.sh status
● interceptWH2600.service - LSB: Intercept weather data from your WH2600 Weather Station
Loaded: loaded (/etc/init.d/interceptWH2600.sh)
Active: active (exited) since sam 2017-11-11 11:37:47 CET; 4s ago
Process: 11875 ExecStop=/etc/init.d/interceptWH2600.sh stop (code=exited, status=0/SUCCESS)
Process: 11961 ExecStart=/etc/init.d/interceptWH2600.sh start (code=exited, status=0/SUCCESS)
I followed the wiki procedure
sudo cp /home/pi/interceptWH2600/interceptWH2600.sh /etc/init.d
sudo chmod 0755 /etc/init.d/interceptWH2600.sh
sudo systemctl daemon-reload
start-stop-daemon line :
start-stop-daemon --start --background --pidfile $PIDFILE --make-pidfile --name $daemon_NAME --quiet --chuid $DAEMONUSER --startas $DAEMON
The script .sh
#!/bin/sh
### BEGIN INIT INFO
# Provides: interceptWH2600
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Intercept weather data from your WH2600 Weather Station
# Description: Intercept weather data from your WH2600 Weather Station
### END INIT INFO
# Change the next 3 lines to suit where you install your script and what you want to call it
DIR=/home/pi/interceptWH2600
DAEMON=$DIR/interceptWH2600.py
DAEMON_NAME=interceptWH2600
DAEMON_OPTS=""
LOG=/home/pi/interceptWH2600/interceptWH2600.log
PATH=$PATH:/sbin:/bin:/usr/sbin:/usr/bin
. /lib/lsb/init-functions
# This next line determines what user the script runs as.
# Root generally not recommended but necessary if you are using the Raspberry Pi GPIO from Python.
DAEMON_USER=pi
# The process ID of the script when it runs is stored here:
PIDFILE=/var/run/$DAEMON_NAME.pid
do_start () {
log_daemon_msg "Starting system $DAEMON_NAME daemon"
start-stop-daemon --start --background --pidfile $PIDFILE --make-pidfile --name $daemon_NAME --quiet --chuid $DAEMONUSER --startas $DAEMON -- $DAEMON_OPTS
$DAEMON_OPTS
log_end_msg $?
do_stop () {
log_daemon_msg "Stopping system $DAEMON_NAME daemon"
start-stop-daemon --stop --pidfile $PIDFILE --retry 10
log_end_msg $?
case "$1" in
start|stop)
#do_${1}
stop)
do_stop
#do_${1}
restart|reload|force-reload)
do_stop
do_start
status)
status_of_proc "$DAEMON_NAME" "$DAEMON" && exit 0 || exit $?
echo "Usage: /etc/init.d/$DAEMON_NAME {start|stop|restart|status}"
exit 1
esac
exit 0
An idea ?
Posted: Saturday 11 November 2017 12:18
by BakSeeDaa
Doudy wrote: Monday 06 November 2017 17:21
It's a way of seeing things.
I would prefer live variations.
That can easily be done by modifying the script to suit your needs.
Posted: Saturday 11 November 2017 12:26
by BakSeeDaa
Doudy wrote: Saturday 11 November 2017 11:57
I'm still here.
The script .sh
#!/bin/sh
### BEGIN INIT INFO
### END INIT INFO
DAEMON_OPTS=""
DAEMON_USER=pi
do_start () {
$DAEMON_OPTS
log_end_msg $?
do_stop () {
log_end_msg $?
case "$1" in
start|stop)
#do_${1}
stop)
do_stop
#do_${1}
do_stop
do_start
status)
exit 1
esac
exit 0
An idea ?
Hello!
I can't say because I don't see any error messages.
Try running the following from the command line:
/home/pi/interceptWH2600/interceptWH2600.py -v -d
Does it generate any error messages?
Posted: Saturday 11 November 2017 13:27
by Doudy
The messages is :
-bash: /home/pi/interceptWH2600/interceptWH2600.py : /usr/bin/^M : mauvais interpréteur: Aucun fichier ou dossier de ce type
in english :
wrong interpreter: No file or file of this type
Posted: Saturday 11 November 2017 15:52
by Doudy
BakSeeDaa wrote: Saturday 11 November 2017 12:18
Ok but how?
I am very very beginner ...
Posted: Sunday 12 November 2017 10:12
by BakSeeDaa
Doudy wrote: Saturday 11 November 2017 13:27
The messages is :
in english :
I assume that you have followed the
installation instruction carefully and while doing that didn't receive any error messages
Do you have python installed?
Check version with
If you don't have python installed, you must install it.
Check that the file /home/pi/interceptWH2600/interceptWH2600.py exists.
ls -la /home/pi/interceptWH2600/interceptWH2600.py
When python is installed and the /home/pi/interceptWH2600/interceptWH2600.py file exists, please try this command:
/usr/bin/python /home/pi/interceptWH2600/interceptWH2600.py -v -d
Posted: Sunday 12 November 2017 10:24
by BakSeeDaa
Doudy wrote: Saturday 11 November 2017 15:52
Ok but how?
I can't see how a very momentary wind direction is useful for Home Automation. Here, the wind direction will change from one second to another. Swinging in any direction +- 90 degrees is not uncommon. The script normally takes care using a function to calculate the wind vector from time series of wind
speeds and directions.
Anyway if you'd like to change it, edit the configuration file and set "windDirSmoothenizer" to false.
Posted: Sunday 12 November 2017 11:29
by Doudy
BakSeeDaa wrote: Sunday 12 November 2017 10:12
pi@RASPBERRYPI-182:~/interceptWH2600 $ /usr/bin/python -V
Python 2.7.9
Check version with
Installed
pi@RASPBERRYPI-182:~/interceptWH2600 $ ls -la /home/pi/interceptWH2600/interceptWH2600.py
-rwxrwxrwx 1 pi pi 22858 nov 12 10:59 /home/pi/interceptWH2600/interceptWH2600.py
pi@RASPBERRYPI-182:~/interceptWH2600 $ /usr/bin/python /home/pi/interceptWH2600/interceptWH2600.py -v -d
Debug is on
WH2600 Interceptor 1.0.3 listening for PWS on port 8084. Running on TTY console...
Received data for station ID : IATH46
windchillf 41.4
rainin 0.0
dailyrainin 0.32
monthlyrainin 1.12
solarradiation 82.77
realtime 1
windspeedmph 4.7
baromin 29.48
rtfreq 12
lowbatt 0
windgustmph 4.92
tempf 44.1
indoorhumidity 49
winddir 254
dewptf 40.5
PASSWORD te5f9tza
ID IATH46
dateutc 2017-11-12 11:25:19
softwaretype WH2600 Interceptor V. 1.0.3
yearlyrainin 5.46
UV 1
humidity 87
action updateraw
weeklyrainin 0.77
indoortempf 70.2
Latest wind speed reading: 254
'windDirSmoothenizer' is active. Resultant of the last 4 wind direction readings (Reported to WU) : 254
array [254, 254, 254, 254]
Checking if Domoticz devices needs to be updated...
Updating the Domoticz Indoor Temp + Humidity device to 21.2 ; 49
Updating the Domoticz Outdoor Temp + Humidity device to 6.7 ; 87
Updating the Domoticz Barometer device to 998.0
Updating the Domoticz UV device to 1
Updating the Domoticz Solar Radiation device to 82
{'windchillf': 41.4, 'rainin': 0.0, 'winddir_avg10m': 254, 'windspdmph_avg2m': 4.7, 'windgustmph_2m': 4.92, 'dailyrainin': 0.32, 'monthlyrainin': 1.12, 'solarradiation': 82.77, 'realtime': 1, 'windspeedmph': 4.7, 'baromin': 29.48, 'rtfreq': 12, 'winddir_avg2m': 254, 'lowbatt': 0, 'windgustmph': 4.92, 'tempf': 44.1, 'indoorhumidity': 49, 'windspdmph_avg10m': 4.7, 'winddir': 254, 'dewptf': 40.5, 'PASSWORD': 'xxxxxx', 'ID': 'IATH46', 'dateutc': '2017-11-12 11:25:19', 'softwaretype': 'WH2600 Interceptor V. 1.0.3', 'windgustmph_10m': 4.92, 'yearlyrainin': 5.46, 'UV': 1, 'humidity': 87, 'action': 'updateraw', 'weeklyrainin': 0.77, 'indoortempf': 70.2}
success
https://rtupdate.wunderground.com/weath ... tempf=70.2
windchillf 41.4
rainin 0.0
dailyrainin 0.32
monthlyrainin 1.12
realtime 1
windspeedmph 4.7
baromin 29.49
rtfreq 12
lowbatt 0
windgustmph 4.92
tempf 44.1
indoorhumidity 49
winddir 254
dewptf 40.5
PASSWORD te5f9tza
ID IATH46
dateutc 2017-11-12 11:25:28
yearlyrainin 5.46
UV 1
humidity 87
action updateraw
weeklyrainin 0.77
indoortempf 70.2
Past 2 minutes resultant wind direction: 254
Past 10 minutes resultant wind direction: 254
Past 2 minutes average wind speed: 2.1
Past 10 minutes average wind speed: 2.1
Past 2 minutes maximum wind gust speed: 2.2
Past 10 minutes maximum wind gust speed: 2.2
[254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254, 254]
[2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1, 2.1]
[2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2, 2.2]
success
^C^C received, shutting down the web server
Posted: Sunday 12 November 2017 11:33
by Doudy
BakSeeDaa wrote: Sunday 12 November 2017 10:24
It is rather the speed in live that I want to display!
Posted: Sunday 12 November 2017 11:43
by Doudy
hello,
a small note
there is
it is necessary
Latest wind direction reading: 254
Posted: Sunday 12 November 2017 11:45
by BakSeeDaa
Doudy wrote: Sunday 12 November 2017 11:43
hello,
a small note
there is
it is necessary
Thanks. I will correct that.
Posted: Wednesday 15 November 2017 8:50
by Doudy
I do not see any change when displaying.
I would like to arrive at the same thing as on the WU website.
Posted: Wednesday 15 November 2017 9:17
by BakSeeDaa
Doudy wrote: Wednesday 15 November 2017 8:50
I don't know what's on display at the WU underground web site. You can have a look at the
PWS Upload Protocol to get an idea about what data is getting sent.
If you'd like to update your Domoticz device with instantaneous wind data, locate the following code and remove all occurances of the text '_avg10m', so that winddir_avg10m becomes winddir etc. Make sure your substitution only affects the code shown below.
# Updating the 'Wind' device. No need to check the current value, it's likely to be different anyway
elif domoDevice['categoryName'] == 'Wind' and domoDevice['domoticzSensorType'] == 86:
# First build the data string
dataString = str(jsonQs['winddir_avg10m'])
dataString += ';' + str(degToCompass(jsonQs['winddir_avg10m']))
dataString += ';' + str(round(ms(jsonQs['windspdmph_avg10m']) * 10 , 0))
dataString += ';' + str(round(ms(jsonQs['windgustmph_10m']) * 10 , 0))
dataString += ';' + str(round(temp_c(jsonQs['tempf']), 1))
dataString += ';' + str(round(wind_chill(temp_c(jsonQs['tempf']), jsonQs['windspdmph_avg10m']), 1))
if isDebug: print 'Wind data string: ', dataString # E.g. '4;N;30.0;44.0;-6.6;-14.3'
if isVerbose: print 'Updating the Domoticz Wind device to', dataString
payload = dict([('type', 'command'), ('param', 'udevice'), ('idx', domoDevice['domoticzIdx']), \
('nvalue', 0), ('svalue', dataString)])
r = domoticzAPI(payload)
You never answered me before when I asked you, I'm so curious to know how instantaneous wind data can be used for home automation. I mean, one second the wind comes from south with a speed of 3 m/s. Maybe 10 seconds after that the wind comes from west but 0.1 m/s and maybe another 10 seconds followed by wind from north east at the speed of 3 m/s. For me, that's all random data that says nothing really.
Good luck!
Posted: Wednesday 15 November 2017 11:28
by Doudy
Thank you for your help, I will test your suggestion.
BakSeeDaa wrote: Wednesday 15 November 2017 9:17
Good luck!
For now I do not really use it to integrate Domoticz.
It's just to see the wind speed and its live direction. Like on the Wunderground website.
Posted: Thursday 16 November 2017 9:18
by Doudy
It works properly.
Display at the same speed as wunderground, even a little before.
I also modified:
windspdmph_avg10m => windspeedmph
windgustmph_10m => windgustmph
UPDATE_INTERV = 1 # Expected Weather Station report Interval in seconds
UPDATE_DOMO_INTERV = 1 # Weather Station report Interval that Domoticz will by updated by
Code :
dataString = str(jsonQs['winddir'])
dataString += ';' + str(degToCompass(jsonQs['winddir']))
dataString += ';' + str(round(ms(jsonQs['windspeedmph']) * 10 , 0))
dataString += ';' + str(round(ms(jsonQs['windgustmph']) * 10 , 0))
dataString += ';' + str(round(wind_chill(temp_c(jsonQs['tempf']), jsonQs['windspeedmph']), 1))
Posted: Tuesday 21 November 2017 9:03
by Doudy
I'm still here.
About my post from 11/11/2017.
When i start the service manualy :
I have the following message :
pi@RASPBERRYPI-182:~/interceptWH2600 $ sudo sh interceptWH2600.sh start
[ ok ] Starting system interceptWH2600 daemon:.
But, interceptWH2600.py don't working
I have no update at wunderground and domoticz
But, when i strat following :
sudo python /home/pi/interceptWH2600/interceptWH2600.py
Updates are working normally !
WU message :
Current Conditions Station reported 6 seconds ago
an idea
Posted: Tuesday 21 November 2017 9:15
by BakSeeDaa
Doudy wrote: Tuesday 21 November 2017 9:03
You mentioned the following in an earlier post
Doudy wrote: Saturday 04 November 2017 9:36
Remark
in wiki there is
sudo update-rc.d /etc/init.d/interceptWH2600.sh defaults
il is
sudo update-rc.d interceptWH2600.sh defaults
That seems to be correct and the Wiki has been updated. Strange that no one else noticed that. Thanks for letting me know.
I will investigate further.
Posted: Tuesday 21 November 2017 9:52
by BakSeeDaa
First please run the following command
and let me know the results:
Then please run the following commands:
sudo chmod 755 /home/pi/interceptWH2600/interceptWH2600.py
Then run this and let me know the results:
Posted: Tuesday 21 November 2017 11:43
by Doudy
Here is the result :
pi@RASPBERRYPI-182:~ $ ls -la /home/pi/interceptWH2600/interceptWH2600.py
-rwxrwxrwx 1 pi pi 21073 nov 16 09:10 /home/pi/interceptWH2600/interceptWH2600.py
pi@RASPBERRYPI-182:~ $ sudo chmod 755 /home/pi/interceptWH2600/interceptWH2600.py
-rwxr-xr-x 1 pi pi 21073 nov 16 09:10 /home/pi/interceptWH2600/interceptWH2600.py
pi@RASPBERRYPI-182:~ $ sudo /etc/init.d/interceptWH2600.sh start
pi@RASPBERRYPI-182:~ $ pgrep -x "interceptWH2600"
pgrep ==> Display nothing
Thanks for your help
Posted: Tuesday 21 November 2017 12:33
by BakSeeDaa
Doudy wrote: Tuesday 21 November 2017 11:43
Hmm... there seems to be ^M characters in the python script. But how did they get there in such case?
Might it be so that you have altered the python script file using a MSDOS/Windows editor? That will destroy the script file.
Download a new python script file by doing an
upgrade.
After that do not open the file again with a MSDOS/Windows editor. And if You do that accidentally, don't save the file.
