Zwave Control Panel Now Showing 3 Unknown Devices
Domosapiens
Domoticz version: V3.5981
Re: Zwave Control Panel Now Showing 3 Unknown Devices
Post by Domosapiens »
Happy to see you are on track again.
In a static network there is no need for a nightly Heal Network.
You can do it now and then by hand (menu: Node management).
If Automatic Backup is Enabled they are running at the same moment at 04:00.
I think that's a less happy combination. (04:03 would be a more robust choice)
from nodes out in the garden and outbuildings
If you have isolated windows (HR glass in dutch) there is a tiny metal frame inside.
That frame is open for short-wave emissions (sun light) and reflecting long wave emissions (the low temperature in your house)
For Z-Wave, with waves of 34 cm your window is just a metal sheet and very difficult to pass (90% attenuation).
You brick wall is even easier.
Read more here: https://www.domotiga.nl/attachments/dow ... -small.pdf
Via the metal sheet you get wave interference: the direct path to your stick and a reflection via the window.
If you have bad luck, those waves are extinguish each other. With good luck they amplify each other:
Play around in an area of 17 cm (half the wave) to find an optimal transmit/receiver point.
gcoupe
Domoticz version: v4.10717
Post by gcoupe »
Things are not improving much. I'm still getting nodes randomly set to being dead. If I restart Domoticz completely, then sometimes the nodes become alive again, and sometimes not.
Something is definitely wrong here, and I'm not convinced that it is being caused by poor Zwave reception. As I've said earlier in the thread, everything was rock-solid until recently. All that's been done is that I've upgraded to the latest "stable" version, and added three new nodes. Is there some way to regress to the earlier stable version from March 2016?
