Kerui D026
EdddieN
Domoticz version: 4.9700
Re: Kerui D026
Post by EdddieN »
I'm testing this one too, I have it recognised with RFXcom as Lighting4 sensor. However Domoticz shows them always as ON, but I can see on the logs that both, open and closed are received as:
(RFX433) Lighting 4 (Unknown)
I have RFXtrx433E version with fw Type2/1017
Are you able to get it working as open closed?
11101101 - www.machinon.com
denman091
Domoticz version: 3.8153
Re: Kerui D026
Post by denman091 »
Hi Guys,
I'm a new domoticz user. I have a RFXCom433e with Ext2/1020 firmware.
I want a door sensor witch i can add as a single security device. Open and Closed. I read that de Kerui D026 is supported in version 1012 by rfxcom but witch one i should by?
https://www.aliexpress.com/item/433MHz- ... 40451.html?
Or:
https://www.aliexpress.com/item/D026-Wi ... 30002.html?
Or are these 2 identical?
iLLiac4
Re: Kerui D026
Post by iLLiac4 »
I was testing D026 sensor with RFXTfx433E (1020) and if i enable only lightning4 protocol it receives open, close and temper signal but no battery status.
If i enable also x10 and lightning 4 protocol all three (open, close, temper) are sended as one signal, which is kind of not usefull.
31. 08. 2017 08:16:34
Packettype    = Security1
subtype       = X10 security
Sequence nbr  = 1
id1-3         = 110D00 decimal:1117440
status        = Alarm + Tamper
battery level = OK
Signal level  = 8  -56dBm
Is this a normal behaviour?
b_weijenberg
Re: Kerui D026
Post by b_weijenberg »
Is the tamper switch closed?
What is received with X10 disabled?
RFX-433, RFX-433EMC, RFX-868
iLLiac4
Re: Kerui D026
Post by iLLiac4 »
Hmm. Is seems that it is domotics bug. As it lists as only one status. Will investigate further.
Status in rfx is:
31. 08. 2017 09:00:57
31. 08. 2017 09:00:58
Sequence nbr = 0
status = Normal
battery level = OK
31. 08. 2017 09:01:01
Sequence nbr = 1
status = Alarm
battery level = OK
31. 08. 2017 09:01:03
Sequence nbr = 2
battery level = OK
Shyam
Re: Kerui D026
Post by Shyam »
I've just got one of these. After playing around and updating my RFXtrx433 firmware, I'm able to add 3 new Lighting4 devices (open, closed and tamper). How can I get the battery status? I read on here that if I enable X10, I should see just a security sensor, but I'm not....
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
Accenta Gen4 Security System Integration
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Blog: http://www.shyambhundia.com
b_weijenberg
Re: Kerui D026
Kerui D026 sensors reported as X10 security sensors is supported by the RFXtrx433E using Ext2 firmware.
See also chapter 2.2.2. in the RFXtrx User Guide.
Shyam
Re: Kerui D026
Post by Shyam »
b_weijenberg wrote: Tuesday 22 May 2018 11:38 Kerui D026 sensors reported as X10 security sensors is supported by the RFXtrx433E using Ext2 firmware.
Right that make sense! Cheers
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
Shyam
Re: Kerui D026
Post by Shyam »
I've bought one of these sensors to test, but I've noticed an issue. If the door is opened and shut quickly (5-10secs) I only get the open signal and not the closed. Any one else experienced this?
Cheers
Shyam
Raspberry Pi B+
Rfxcomm rfxtrx433
LigthwaveRF
Byron Door Bell
HomeEasy PIR
Nest Thermostat
Geofencing
Pushover
harolds
Re: Kerui D026
Post by harolds »
The close signal is not received of processed correctly most of the time.
