I have the same problem in stable version 3.6334: LUA scripts running fine, Blockly events not triggered anymore.
Restarting the Raspberry Pi on which Domoticz runs does NOT fix the issue.
I have recently added an RfxTrx433E to my Domoticz and I see that others (simon_rb) have also done RfxTrx433E related changes before getting this bug. Could it somehow be cause by RfxTrx433E? disabling the RfxTrx433E in Domoticz and even restarting the Raspberry Pi after it does NOT solve the problem.
Events not working after update to 3.5837
- BazsoDombiAndras
- Domoticz version: v4.10717
- BazsoDombiAndras
Re: Events not working after update to 3.5837
Updated to the latest beta: 3.6478.
The problem still exists.
chatainsim
- Domoticz version: v4.11307
I have the same problem with 3.6478.BazsoDombiAndras wrote:Updated to the latest beta: 3.6478.
I'm not using a RPI. Only a server with Ubuntu.
- Siewert308SW
- Domoticz version: Stable
No problems here on the latest beta on a Pi3.BazsoDombiAndras wrote:I have the same problem in stable version 3.6334: LUA scripts running fine, Blockly events not triggered anymore.
But seems blocky is down if Lua is working.
Otherwise i would check on which usb port the rfx is running and what domoticz runs.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
- DS923+ Docker
chatainsim
I've restarted my server and it's working fine now.chatainsim wrote:I have the same problem with 3.6478.BazsoDombiAndras wrote:Updated to the latest beta: 3.6478.
harolds
I had to run the 'updaterelease' script to fix this problem. After that I used 'updatebeta' but it looked like I was still on the beta after running 'updaterelease'. Now I see message from my LUA scripts again. So looks like that fixed it.
