Re: Python buienradar (is it going to rain) script
Posted: Tuesday 23 January 2018 12:25
Hmm, thats the same and this
dpkg-query -l 'libpython*'Open source Home Automation System
https://forum.domoticz.com/
dpkg-query -l 'libpython*'digdug3 wrote: Tuesday 23 January 2018 12:25 Hmm, thats the same and thisCode: Select all
domoticz@domo-server:~ $ dpkg-query -l 'libpython*'
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii libpython-all-d 2.7.13-2 armhf package depending on all supported P
ii libpython-dev:a 2.7.13-2 armhf header files and a static library fo
ii libpython-stdli 2.7.13-2 armhf interactive high-level object-orient
ii libpython2.7:ar 2.7.13-2+deb armhf Shared Python runtime library (versi
ii libpython2.7-de 2.7.13-2+deb armhf Header files and a static library fo
ii libpython2.7-mi 2.7.13-2+deb armhf Minimal subset of the Python languag
ii libpython2.7-st 2.7.13-2+deb armhf Interactive high-level object-orient
ii libpython3-dev: 3.5.3-1 armhf header files and a static library fo
ii libpython3-stdl 3.5.3-1 armhf interactive high-level object-orient
ii libpython3.4:ar 3.4.4-3 armhf Shared Python runtime library (versi
ii libpython3.4-mi 3.4.4-3 armhf Minimal subset of the Python languag
ii libpython3.4-st 3.4.4-3 armhf Interactive high-level object-orient
ii libpython3.5:ar 3.5.3-1 armhf Shared Python runtime library (versi
ii libpython3.5-de 3.5.3-1 armhf Header files and a static library fo
ii libpython3.5-mi 3.5.3-1 armhf Minimal subset of the Python languag
ii libpython3.5-st 3.5.3-1 armhf Interactive high-level object-orient
ls -l /usr/lib/python*/ssl.pyForgot about this post, but this is what I havedigdug3 wrote: Tuesday 23 January 2018 16:58 Lot more than I have, but at least the same...
What about the module itself? In my stretch installation they are inCode: Select all
-rw-r--r-- 1 root root 37805 Nov 24 18:33 /usr/lib/python2.7/ssl.py
-rw-r--r-- 1 root root 34392 Apr 24 2016 /usr/lib/python3.4/ssl.py
-rw-r--r-- 1 root root 42352 Jan 19 2017 /usr/lib/python3.5/ssl.py
cd /usr/local/lib/python3.5
domoticz@domo-server:/usr/local/lib/python3.5 $ ls
LICENSE.txt base64.py curses gzip.py mimetypes.py pty.py sre_compile.py trace.py
__future__.py bdb.py datetime.py hashlib.py modulefinder.py py_compile.py sre_constants.py traceback.py
__phello__.foo.py binhex.py dbm heapq.py multiprocessing pyclbr.py sre_parse.py tracemalloc.py
__pycache__ bisect.py decimal.py hmac.py netrc.py pydoc.py ssl.py tty.py
_bootlocale.py bz2.py difflib.py html nntplib.py pydoc_data stat.py turtle.py
_collections_abc.py cProfile.py dis.py http ntpath.py queue.py statistics.py turtledemo
_compat_pickle.py calendar.py dist-packages idlelib nturl2path.py quopri.py string.py types.py
_compression.py cgi.py distutils imaplib.py numbers.py random.py stringprep.py typing.py
_dummy_thread.py cgitb.py doctest.py imghdr.py opcode.py re.py struct.py unittest
_markupbase.py chunk.py dummy_threading.py imp.py operator.py reprlib.py subprocess.py urllib
_osx_support.py cmd.py email importlib optparse.py rlcompleter.py sunau.py uu.py
_pydecimal.py code.py encodings inspect.py os.py runpy.py symbol.py uuid.py
_pyio.py codecs.py ensurepip io.py pathlib.py sched.py symtable.py venv
_sitebuiltins.py codeop.py enum.py ipaddress.py pdb.py selectors.py sysconfig.py warnings.py
_strptime.py collections filecmp.py json pickle.py shelve.py tabnanny.py wave.py
_sysconfigdata.py colorsys.py fileinput.py keyword.py pickletools.py shlex.py tarfile.py weakref.py
_threading_local.py compileall.py fnmatch.py lib-dynload pipes.py shutil.py telnetlib.py webbrowser.py
_weakrefset.py concurrent formatter.py lib2to3 pkgutil.py signal.py tempfile.py wsgiref
abc.py config-3.5m fractions.py linecache.py plat-linux site-packages test xdrlib.py
aifc.py configparser.py ftplib.py locale.py platform.py site.py textwrap.py xml
antigravity.py contextlib.py functools.py logging plistlib.py smtpd.py this.py xmlrpc
argparse.py copy.py genericpath.py lzma.py poplib.py smtplib.py threading.py zipapp.py
ast.py copyreg.py getopt.py macpath.py posixpath.py sndhdr.py timeit.py zipfile.py
asynchat.py crypt.py getpass.py macurl2path.py pprint.py socket.py tkinter
asyncio csv.py gettext.py mailbox.py profile.py socketserver.py token.py
asyncore.py ctypes glob.py mailcap.py pstats.py sqlite3 tokenize.pyCode: Select all
python3 -c "import sys; print('\n'.join(sys.path))"Code: Select all
/usr/lib/python35.zip
/usr/lib/python3.5
/usr/lib/python3.5/plat-arm-linux-gnueabihf
/usr/lib/python3.5/lib-dynload
/usr/local/lib/python3.5/dist-packages
/usr/lib/python3/dist-packages
/usr/local/lib/python35.zip
/usr/local/lib/python3.5/plat-arm-linux-gnueabihf
/usr/local/lib/python3.5/lib-dynload
/usr/local/lib/python3.5/site-packages
import sys
import datetime
import time
import os
...Code: Select all
import sys
sys.path.append('/usr/lib/python3.5')
import datetime
import time
import os
...Code: Select all
import sys
import datetime
import time
import os
...Code: Select all
File "buienradar.py", line 25, in <module>
import ssl
File "/usr/local/lib/python3.5/ssl.py", line 98, in <module>
import _ssl # if we can't import it, let the error propagate
ImportError: No module named '_ssl'
pi@raspberrypi:~/domoticz/scripts $ ./buienradar.py
/usr/bin/env: ‘python3\r’: No such file or directory
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# Title: buienradar.py
# Date: 25-10-2016/08-03-2018
# Info: Checks buienradar.nl if it is going to rain and reports back to domoticz
# Version : 0.6
# 0.1 Initial release
# 0.2 Added silent mode
# 0.3 Add password
# Use direct connection to domoticz to get values
# 0.4 Add SSL and fix server(s)
# 0.5 Updated to Python 3
# Bug fix when current status was 0
# 0.6 Updated buienradar url
import sys
import datetime
import time
import os
import subprocess
import json
import base64
import ssl
import urllib.request
# Settings for the domoticz server
domoticzserver = "https://127.0.0.1:8080"
domoticzusername = "admin"
domoticzpassword = "password"
domoticzpasscode = "passcode"
domoticzcheckssl = False
# If enabled. The script will log to the file _.log
# Logging to file only happens after the check for other instances, before that it only prints to screen.
log_to_file = False
lat = "xx.xx"
lon = "x.xx"
BuienradarUrl = "https://gpsgadget.buienradar.nl/data/raintext/?lat=" + lat + "&lon=" + lon
BuienradarCheckSSL = False
Duration = 25
RainExpectedIDX = "513"
# Check silent mode for cron
silentmode = False
if (len(sys.argv)) > 1:
if (str(sys.argv[1]) == "silent"):
silentmode = True
# DO NOT CHANGE BEYOND THIS LINE
lastsuccess=datetime.datetime.now()
base64string = base64.encodestring(('%s:%s' % (domoticzusername,domoticzpassword)).encode()).decode().replace('\n', '')
def log(message):
if silentmode == False:
print(message)
if log_to_file == True:
logfile = open(sys.argv[0] + '.log', "a")
logfile.write(message + "\n")
logfile.close()
def domoticzrequest(url):
request = urllib.request.Request(url)
request.add_header("Authorization", "Basic %s" % base64string)
if (domoticzcheckssl == False):
response = urllib.request.urlopen(request, context=ssl._create_unverified_context())
else:
response = urllib.request.urlopen(request)
return response.read()
def domoticzstatus(getIDX):
domoticzurl = domoticzserver + '/json.htm?type=devices&rid=' + getIDX
json_object = json.loads(domoticzrequest(domoticzurl).decode('utf-8'))
status = ''
# Search the device in JSON list
if json_object["status"] == "OK":
status = json_object["result"][0]["Data"]
else:
log (datetime.datetime.now().strftime("%H:%M:%S") + " - Error: Could not find device idx " + getIDX + " in Domoticz response.")
return status
log (datetime.datetime.now().strftime("%H:%M:%S") + " - Script buienradar.py started.")
# Get current starttime and endtime
now = datetime.datetime.now().strftime("%H:%M")
hour, min = now.split(":")
starttime = (int(hour)*60) + int(min)
endtime = starttime + Duration
total_rain_predictions = 0
total_rain_values = 0
# Get buienradar data
request = urllib.request.Request(BuienradarUrl)
if (BuienradarCheckSSL == False):
else:
html = response.read() # read the data
# 000|hh:mm where 000 is mm of rain expected (000 -> no rain, 255 -> heavy rain)
for line in html.splitlines():
#print("rain: " + data[0] + " time:" + data[1])
data = line.decode('utf-8').split("|")
mhour, mmin = data[1].split(":")
calc_time = (int(mhour)*60) + int(mmin)
if ((calc_time >= starttime) and (calc_time <= endtime)):
total_rain_predictions = total_rain_predictions + float(data[0])
total_rain_values = total_rain_values + 1
response.close() # close the connection
# Calculate result
result = "0.00"
if (total_rain_values > 0):
rain_0_100 = (total_rain_predictions/total_rain_values)*0.392156862745098 # convert 000/255 data to procent (100/255)
result = format(rain_0_100, '.2f')
currentstatus = format(int(''.join(filter(str.isdigit, domoticzstatus(RainExpectedIDX)))), '.2f')
if (result != currentstatus): # Status has changed --> notify domoticz
log (datetime.datetime.now().strftime("%H:%M:%S") + " - Current status: " + currentstatus + " / result: " + result)
domoticzrequest(domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + RainExpectedIDX + "&nvalue=0&svalue=" + result + "&passcode=" + domoticzpasscode)
else:
if (hour == 12 and min < 10): # Send some data to prevent a red bar --> notify domoticz
log (datetime.datetime.now().strftime("%H:%M:%S") + " - Current status: " + currentstatus + " / updating")
domoticzrequest(domoticzserver + "/json.htm?type=command¶m=udevice&idx=" + RainExpectedIDX + "&nvalue=0&svalue=0.00&passcode=" + domoticzpasscode)
