Page 2 of 4
Re: Ikea "TRÅDFRI" smart lights series uses ZigBee Light Link (ZLL)
Posted: Monday 03 April 2017 15:38
by Hedda
FYI, some developers in the Home Assistant community have started analyzing the traffic between the Ikea Trådfri app (on Android/iOS) and the Ikea Trådfri Gateway:
https://community.home-assistant.io/t/i ... ee/14788/8
So far they have determened that application looks to communicate over UDP with Ikea Trådfri Gateway encrypted using DTLS v1.2 (Datagram Transport Layer Security).
Posted: Tuesday 04 April 2017 9:40
by Hedda
Someone now looks to have figured out how exactly Android/iOS communicates with the Ikea Trådfri Gateway - Turns out it communicates using OMA LwM2M (Lightweight machine-to-machine) security model for IoT device management based on CoAP (Constrained Application Protocol) encrypted with DTLS (Datagram Transport Layer Security) using the PSK (Pre-Shared Key) written on under the physicial Ikea Trådfri Gateway box.
https://bitsex.net/software/2017/coap-e ... a-tradfri/
https://bitsex.net/software/2017/ikea-t ... ee-lights/
This Norwegian guy as linked in two blog posts above have already figured out how monitor and send control commands to the Ikea Trådfri Gateway using standard CoAP to send and recieve commands to its end devices (using DTLS based encrypted communication to the Ikea Trådfri Gateway over network).
https://tools.ietf.org/html/rfc7252
Ikea Trådfri Android application appears to be using multicast (224.0.0.1) to find the Ikea Trådfri Gateway, and then communicates using encrypted CoAP (coaps). Also, it does not look like the Trådfri Gateway attempts to talk to the Internet (as the device looks to have has no outgoing connections). The default Ikea Trådfri Android app is fairly basic, where it currently only let you create schedules for turning on and off, and you can control lights and create zones, and control zones.
Looks like Ikea might have conformed with OMA LightweightM2M (LwM2M) Object IDs and Resource Registry ID as unique identifier
http://www.openmobilealliance.org/wp/OM ... istry.html
Examples:
5750 Application Type
5850 On/Off
5851 Dimmer
5706 Colour
IPSO (IP for Smart Objects) Smart Object Guidelines provide a common design pattern:
https://github.com/IPSO-Alliance/pub/bl ... /README.md
https://github.com/IPSO-Alliance/pub/tr ... er/reg/xml
IPSO provide common object model for interoperability of IoT Devices and Applications.
OMA LightweightM2M (LWM2M) standard:
http://openmobilealliance.org/iot/
http://openmobilealliance.org/iot/light ... m2m-lwm2m/
http://www.openmobilealliance.org/wp/Ov ... rview.html
http://www.openmobilealliance.org/tech/profiles/
https://github.com/OpenMobileAlliance/O ... opers/wiki
http://devtoolkit.openmobilealliance.or ... ck=Default
http://www.openmobilealliance.org/wp/comments.html
https://github.com/OpenMobileAlliance/O ... ers/issues
http://openmobilealliance.hs-sites.com/keep_updated
Intestingly is that CoAP (Constrained Application Protocol) is the protocol which the OCF (Open Connectivity Foundation) backed by most industry gians is promoting to become the standard for IoT. As reference in IoTivity and AllJoyn projects which guidelines one can suspect that Ikea have followed when they choose to go with standard CoAP in the Ikea Trådfri Gateway and its apps.
https://en.wikipedia.org/wiki/Constrain ... n_Protocol
OCF (Open Connectivity Foundation) which is lead by all the indistry giants recently made a merger between IoTivity and AllJoyn happen as lead by the Linux Foundation.
https://en.wikipedia.org/wiki/Open_Conn ... Foundation
CoAP (Constrained Application Protocol) is the protocol which the OCF (Open Connectivity Foundation) is promoting to become the standard for IoT.
Posted: Wednesday 05 April 2017 13:15
by Hedda
Sound as Ikea have choosen to base their implementation on OMA (Open Mobile Alliance) and Eclipse recommended standard of those three logical components; CoAP, and DTLS layers of the LwM2M (Lightweight M2M) protocol stack.
Lightweight M2M (LWM2M) is a system standard in the Open Mobile Alliance. It includes DTLS, CoAP, Block, Observe, SenML and Resource Directory and weaves them into a device-server interface along with an Object structure."
http://openmobilealliance.org/data-mode ... of-things/
https://connect2.io/open-mobile-allianc ... oma-lwm2m/
http://openmobilealliance.org/constrain ... -protocol/
https://iot.eclipse.org/standards/
https://eclipse.org/community/eclipse_n ... ticle2.php
https://www.eclipsecon.org/na2014/sites ... %20(1).pdf
The Wakaama project (from Eclipse) covers the LWM2M Protocol, CoAP, and DTLS layers of the LwM2M protocol stack for all three logical components. Wakaama is not a library but files to be built with an application. The Eclipse Wakaama project provides a C portable framework for building LWM2M clients and/or servers. The source code of Wakaama is available from the project webpage. It is written in C and designed to be portable on POSIX compliant systems.
http://www.eclipse.org/wakaama/
You can also build the "dtls" branch of libcoap from:
https://github.com/obgm/libcoap/tree/dtls
And then enter examples and do stuff like:
echo '{ "3311" : [{ "5851" : 255 }] }' | ./coap-client -u "Client_identity" -k "YOUR_KEY" -v 10 -m put "coaps://192.169..0.3:5684/15001/65538" -f -
You can set the dimmer to something between 0-255.
You can also query all the available endpoints:
./coap-client -u "Client_identity" -k "YOUR_KEY" -v 10 -m get "coaps://192.168.0.3:5684/.well-known/core"
Posted: Thursday 06 April 2017 8:29
by Hedda
pautomate from the Home Assistant community put together a very simple implementation for his Raspberry Pi.
https://community.home-assistant.io/t/i ... n/14788/19
"Taking no credit of all the hard work others have put in and just put my code here if you want to play around":
First installed the libcoap-library as such:
apt-get install libtool
git clone --recursive
https://github.com/obgm/libcoap.git
cd libcoap
git checkout dtls
git submodule update --init --recursive
./autogen.sh
./configure --disable-documentation --disable-shared
make
sudo make install
pautomate put together a very simple Python-script that execute by running shell_commands:
https://github.com/ggravlingen/home-ass ... de/ikea.py
You then run the code by invoking:
python ikea.py "65537" "100" "Yellow"
Or, from within Home assistant as a shell command:
ikealight_off: '/usr/bin/python3 /home/homeassistant/.homeassistant/extraconfig/python_code/ikea.py "65537" "0" "Yellow"'
Posted: Thursday 06 April 2017 8:53
by Hedda
FYI, looks like ha-bridge issue 570 have become a collective point for links and notes about protocols used as well as some code implementations.
https://github.com/bwssytems/ha-bridge/issues/570
Communication between Android/iOS app and the Gateway deffinitly takes place via OMA Lightweight M2M (LwM2M) wrapped in CoAP with DTLS.
Libraries listed under
https://en.wikipedia.org/wiki/OMA_LWM2M#Implementations may be best approach instead of writing a new LwM2M library from scratch just for te Ikea Trådfri Gateway.
Such as:
Anjay - C implementation of the client-side OMA LwM2M protocol have very good documentation:
https://avsystem.github.io/Anjay-doc/
https://github.com/AVSystem/Anjay
FYI, Ikea is a customer of AVSystem who developed the LwM2M library Anjay (which is dual-licensed, bot as free and open source software and under a commercial license).
https://www.avsystem.com/news/avsystem- ... ts-lwm2m1/
https://www.avsystem.com/products/anjay/
https://avsystem.github.io/Anjay-doc/Co ... pport.html
While they don't say so outright one could suspect that Ikea uses commercially licensed Anjay and/or AVSystem Coiote for the Ikea Trådfri Gateway and its apps.
AVSystem Coiote it is a complete end-to-end solution for empowering IoT applications, which I understand relies on Anjay too.
https://www.avsystem.com/products/coiote/
Again, also see the official LwM2M and the CoAP (Constrained Application Protocol) documentation from IETF here:
Today the Ikea Trådfri Gateway only uses a small subset of the OMA Lightweight M2M (LwM2M) protocol, but who knows, it is likley that Ikea will extend the use of LwM2M in future firmware updates for Ikea Trådfri Gateway, either for enhancements or new features.
Re: Ikea "TRÅDFRI" Gateway and smart lights series for ZigBee Light Link (ZLL) lighting
Posted: Thursday 06 April 2017 9:23
by tontze
Seems to be stores in Finland too
Posted: Friday 07 April 2017 12:40
by Ericv
Now also for sale in Holland.
Posted: Friday 07 April 2017 15:35
by deennoo
End of April for France
Posted: Friday 07 April 2017 20:45
by Ericv
Lights are not recognised by my Hue bridge.
Posted: Monday 10 April 2017 9:30
by Hedda
Home-Assistant developers looks to be making great stides with their initial development of Ikea Trådfri Gateway hub support:
https://community.home-assistant.io/t/i ... tion/14788
And again so are Homebridge and ha-developers:
https://github.com/stenehall/homebridge-ikea
Ericv wrote:Lights are not recognised by my Hue bridge.
@Ericv, that is known; Philips have on-purpose removed any accidental compatibility they had in their previous firmware. You can not expect that Philips (or Ikea) will ever activly work to make their hubs compatible with each other endpoint devices. If their endpoint devices just happen to work with each others hubs then it will only be a happy chance due to both of them being ZigBee based. Philips (or Ikea) have no intention of on-purpose making their hubs working with other manufacturers lightbulbs, that would just mean supporting endpoint devices that they they are not getting paid for, which is crazy to do for a commercial company unless you are specifically selling a hub/gateway that is specifically meant to work with third-party endpoint devices, such as Samsung SmartThings Hub, Vera, or Wink Hub.
Posted: Monday 10 April 2017 20:42
by Ericv
I did not really expect it to work. Just wanted to let you know that i tried; with no success obviously
It would be nice to have a Domoticz plugin.
I tried to do a portscan on the Trådfri hub. Again no success, no ports found.
Posted: Tuesday 11 April 2017 9:00
by Hedda
Home Assistant developers ( ggravlingen / pautomate, balloob & turbokongen ) looks to be making great progress with their collaberation on a Python class to communicate with the Ikea Trådfri Gateway, and also extracted that code from the platform into a standalone Python library
https://github.com/ggravlingen/python-openikeatradfri
More discussion on that in the Home Assistant Community forum
https://community.home-assistant.io/t/i ... ion/14788/
Posted: Tuesday 11 April 2017 9:08
by Hedda
Ericv wrote:I tried to do a portscan on the Trådfri hub. Again no success, no ports found.
You shouldn't on any TCP port, it only listens to two UDP ports, read this security analysis of Ikea Trådfri Gateway:
https://mjg59.dreamwidth.org/47803.html
Again also read all the collected information here (which among many other things includes that information too):
Posted: Wednesday 12 April 2017 8:22
by Hedda
Posted: Tuesday 18 April 2017 10:14
by Hedda
Jaime Jiménez (from the company Ericsson) who is an active member of the IPSO Alliance’s working group, especially the Semantic WG that published the IPSO Smart Object Guidelines, posted this great teardown of the Ikea Trådfri implementation:
http://jaimejim.github.io/tradfri/
He also shared a couple of links to related articles he posted earlier:
http://jaimejim.github.io/lwm2m-yang/
http://jaimejim.github.io/coap-functionality-lwm2m/
Also checkout the IoTSI Workshop as a reference:
https://www.iab.org/activities/workshops/iotsi/
Interestingly enough Michael Koster (who is the main author of these IPSO Objects) posted a comment to Jaime's post staying: "Great move on IKEA's part here. Too bad we hadn't published the IPSO lighting objects yet. Maybe we can talk them into registering the new identifiers with OMNA.".
He referenses another that good framework written by Michael Koster (the main author of the data models and IPSO Objects that Ikea Trådfri uses):
https://github.com/connectIOT/iottoolkit/
Posted: Sunday 23 April 2017 10:30
by Schuko80
Hi there, yesterday I give the the ikea lamps a try and I can say, it works really fine with domoticz.
I'm able to switch them on/off and make a dim - colour changing from warm to cold white doesn't work at the moment, i'm not sure, witch command I have to use
I think working on the ikea Gateway is a good idea, but for me i think it is better to work with a real Zigbee Gateway, so I can control all Zigbee Items and not only Ikea ones.
To get it work, I use Raspbee on a Raspberry Pi (intern Version - you can get a USB Version, too) - the Software use the Philips Hue Rest API, so you can connect Domotics by the Philips Hue Plug in.
I think maybe some of you are interested in this
This was my first post here and I'm sorry for my bad English, it's a long time ago I have to write it down
Posted: Sunday 23 April 2017 11:19
by tontze
Schuko80 wrote:Hi there, yesterday I give the the ikea lamps a try and I can say, it works really fine with domoticz.
Definitely interested on this !
Posted: Monday 24 April 2017 9:00
by Hedda
I think maybe some of you are interested in this.
So kind of like BWS Systems HA-Bridge (Home Automation Bridge) but talking directly to ZigBee devices with a ZigBee USB dongle or serial (GPIO) adapter ? HA-Bridge also offer the Philips Hue Rest API:
I'm diffinitly interested in this regardless. Ikea is not the only company that offer cheap ZigBee devices; Xiaomi is another
https://www.domoticz.com/forum/viewtopi ... 17&t=11520
I also posted a thread about it here:
https://www.domoticz.com/forum/viewtopi ... 9&p=123809
And someone else posted this:
https://www.domoticz.com/forum/viewtopi ... 0&p=128357
Problem as a I understand it with being compatible with ZigBee devices from different vendors is that most ZigBee devices do not follow the exact same standard, and currently there is no common library like there is for Z-Wave, as there we have OpenZWave
https://github.com/openzwave/
I guess what we need then a project that offer a "OpenZigBee" library that would be an open source and free library that talks to ZigBee devices from different vendors via a dongle and the ZigBee serial API?
Posted: Tuesday 25 April 2017 20:35
by Schuko80
Ok, i See you Post... you want this:
*Specifically I would like one that supports ZigBee Home Automation, ZigBee Light Link, ZigBee Smart Energy, as well as ZigBee PRO*
Take a look here, the instruction Book is english and zigbee pro works too
https://www.dresden-elektronik.de/funkt ... ibilitaet/
Yesterday i try the ikea clear bulb 950lm e27. This was a bit tricky, when i Open the network, the bulb has to switch on and off by Power switch - about. 3 to 4 Times. Don't Know the Problem, but after that it works fine, too.
The ha bridge i süße for alexa - the raspbee Software is called deconz.
Posted: Tuesday 25 April 2017 20:56
by moroen
A general ZigBee gateway would definitely be nice, but in the meantime, it's quite easy to get support for the Ikea Trådløs gateway from domotics, using a python module created by ggravlingen as part of the home-assistant project, available here:
https://github.com/ggravlingen/pytradfri
I bought the "starter kit" a couple of days ago, consisting of the gateway, a remote and two bulbs and had the bulbs controllable from domoticz with less effort than I'd imagined. The main caveat is adding the bulbs to the gateway, for that I needed the iOS app, but once added, on/off, dim-level and white-color temperature works using ggravlingens module and a python-script called from on and off-actions of virtual switches.
https://github.com/moroen/ikea-tradfri
Guess creating a module for the python plugins system currently under development is the next logical step...
M
