TOON died within Domoticz
Plantje
Re: TOON died within Domoticz
I hope a solution for windows will come as well!
jjnj
Did you guys installed the latest update yes or no?
Sent from my LG-F800L using Tapatalk
darkrain
Yes I did install the latest beta (3.5769) for Raspberry Pi
- HansieNL
Yesss... I got the P1 values back.
I did restart my Toon and Router.
2016-10-15 15:41:16.112 Error: ToonThermostat: Error getting current state!
2016-10-15 15:51:29.156 Error: ToonThermostat: Error getting current state!
2016-10-15 16:01:42.893 Error: ToonThermostat: Error getting current state!
2016-10-15 16:11:57.241 Error: ToonThermostat: Error getting current state!
Looks like getting P1 info is limited to once in 10 minutes.
Blah blah blah
darkrain
Nice! I only got the P1 for electricity back after restarting my devices. It looks to me that the connections at the back-end (between the different servers Eneco is using) are not yet completely synchronized.HansieNL wrote:Yesss... I got the P1 values back.
- gizmocuz
http://www.domoticz.com/downloads/Plantje wrote:I hope a solution for windows will come as well!
Slinkos
- Domoticz version: 3.4834
What worked for me is (after updating domoticz to the latest beta, 5769) updating my login and password onder de Toon Hardware. I also read that a lot of users had to restart their Toon. But since I got it all working again, my Toon is very unstable again, also the Toon app doesn't work. I don't know if it's a coincidence or not.
Plantje
Thanks! mAiden also pointed me to the bèta on a different forum. I guess it's the bèta that I need, right?gizmocuz wrote:http://www.domoticz.com/downloads/Plantje wrote:I hope a solution for windows will come as well!
Can I just install the bèta and can I keep my settings? Or will I need to setup my complete Domoticz again?
I read that polling will now be done per 5 minutes instead of every 30 seconds. But values in the MySQL database are already stored per 5 minutes, right?
I'm not sure if it's a problem on my end, but I only seem to get the P1-information (power and gas). No temperature, solar or setpoint. Although controlling the setpoint does work.
Version 5770
Edit: After setting a setpoint I get all data again, apparently. Strange behaviour.
Version 5770
darkrain
I recognize this behavior somewhat. My system is getting P1 values and setting states is working.anandus wrote:I'm not sure if it's a problem on my end, but I only seem to get the P1-information (power and gas). No temperature, solar or setpoint. Although controlling the setpoint does work.
Version 5770
But the room temperature and setpoint are not updating as often as they should...
P1 updates are received every 5 minutes like you would expect, but the temperature only seems to come in sometimes.
At the moment it's not predictable if the temperature and setpoint will come in...
Plantje
Read this on the Wiki:
I assume that also goes for the beta, right?Update[edit]
To install a new version/update just run the new setup file.
DO NOT UNINSTALL, this will delete everything! (Unless you want so...)
Slinkos
YesPlantje wrote:Read this on the Wiki:I assume that also goes for the beta, right?Update[edit]
Plantje
Thanks! That seems to be the trick indeed; on Windows as well. I installed the beta yesterday, but until this morning I still saw all sensors red. I learned with Z-Wave, networking etc to be somewhat patient, so I didn't rush, but this fixed the last issue!anandus wrote: Edit: After setting a setpoint I get all data again, apparently. Strange behaviour.
bertbigb
Hi just a question.lukev wrote:Jumbotroll just updated his packages, so installed the latest Beta on my synology. Right away I saw some new devices: current temp, setpoint, heating on, tapwater on, preheat on. After a few minutes also the gas and electric p1-meters were visible. So everything seems ok for the moment. Hope it will stay this way
What Synology are you using?
I have a Synology 1515+ and as far as I can see there the version is domoticz_avoton-6.0_3.0.5763-7.spk is available, but that one doesn't contain the update to get my Toon working with Domoticz again.
At what repository you have found it? I used http://www.jadahl.com/domoticz_beta_6/i ... llist=true
Just wondering and hoping Jumbotroll will also update that package soon.
I also want to thank Jumbotroll for his good work for the Synology group. I suggest everyone makes him a donation to let him continue his good work.
Best regards Bert
Synology DS1517+ - DSM 6.2
bertbigb
Just to let you all know - Jumbotroll just updated all the Synology Packagesbertbigb wrote:Hi just a question.lukev wrote:Jumbotroll just updated his packages, so installed the latest Beta on my synology. Right away I saw some new devices: current temp, setpoint, heating on, tapwater on, preheat on. After a few minutes also the gas and electric p1-meters were visible. So everything seems ok for the moment. Hope it will stay this way
Best regards Bert
Slinkos
My Toon is still far from stable. Doesn't work well within Domoticz, also doesn't work well with the official Toon app.
- HansieNL
My Toon app values are different from the thermostat.
Some status of my Hue lights are also not correct.
Looks like synchronisation with the app is not o.k. at this moment.
I had to restart my router to get values in Domoticz.
Blah blah blah
bertbigb
Also bad luck over here. I updated the software yesterday. It updated all the devices once and then the whole night it retrieved only the value of P1 meter (electricity). 2016-10-18 09:44:59.766 (Toon Thermostaat) P1 Smart Meter (Toon Energy)
But no gas, no setpoint. So not much use for Domoticz at this stage.
I stopped domoticz, toon and the router. Then i started up the router, toon and domoticz but still no response.
I'm wondering if anyone has Domoticz in combination with Toon working again or is everyone still suffering?
In the past it was working so great
Best regards Bert
Plantje
No luck here either. Worked for a while and then it stopped again!
This sucks, Eneco! Not willing to create a Windows app and now blocking users that have found a way around that!
S4nd3r
- Domoticz version: 3.5877
Support Eneco states this:
Wat werkt er nog niet
Om het risico op overbelasting zoveel mogelijk te beperken hebben we twee functies nog niet weer geactiveerd:
Domoticz: Domoticz gebruikers hebben continue een verbinding met ons service center (een mobiele app maar ongeveer één minuut) en geven daarom een relatief zeer grote belasting op onze servers. Om te voorkomen dat mobiele app gebruikers geen toegang krijgen vanwege deze kleine groep hebben we voorlopig de toegang voor jullie nog geblokkeerd.
Vergelijk functie: De vergelijk functie veroorzaakt bij ons een grote belasting op onze DNS servers. Omdat we verwachten dat klanten het functioneren van de mobiel app belangrijker vinden dan resultaten van de vergelijk functie, hebben we deze voor dit weekend uitgeschakeld. We verwachten begin deze week weer te kunnen activeren.
