ByronSX PIR
simonrg
Domoticz version: 3.8807
Re: ByronSX PIR
Post by simonrg »
@windriverski thanks, sorry should have checked post more carefully.
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
for i, v in pairs(otherdevices) do
   tc = tostring(i)
   v = i:sub(1,3)
   if (v == 'PIR') then
      difference = timedifference(otherdevices_lastupdate[tc])
      if (difference > 239 and difference < 320) then
         tempdiff = tostring(difference)
         c = i:sub(5)
         tempmessage = c.." Light Off - at least 240 secs up - actually - " .. tempdiff .. "seconds"
         print(tempmessage)
         commandArray[c] = 'Off'
Simon
simonrg
Re: ByronSX PIR
Post by simonrg »
Domoticz and a bit of LUA script have turned these Siemens wireless PIRs into the ultimate smart PIRs (tm) :lol: that work with the LightwaveRF system
The Siemens wireless PIRs only send an on signal (detectd) but no off signal, so I had to write a couple of scripts to make them function more like normal PIRs and actually turn things on and then off after a set length of time - see previous posts.
I liked the idea of having a single script that interacted with all the PIRs such that I could add more PIRs without adding any extra script. So by associating each PIR with a Domoticz motion sensor called "PIR roomx" it would turn on lightswitch "roomx". Initially this meant that each PIR and light switch did exactly the same thing, so I settled on turning things on all the day for a set length of time. However, having posted the script here and on the LightwaveRFcommunity.org.uk forum, then other people suggested why couldn't they control groups or only control at certain times.
So I have now extended the scripts to create the ultimate smart PIR (tm) :lol:
Each of the motion sensors in Domoticz follow this name convention:
PIRxyzSwitchName or PIRxyzGroupName
x speicifies when the PIR controls - a=all day, n=nighttime, d=daytime, 1=custom timer 1 set to 22:00 to 07:30
y specifies what the PIR is controlling - r = room (single Domoticz) switch and g = group
z specifies how long the ligth will stay on for in minutes, so z =5 turns the switch or the group on for 5 minutes, or u = don't turn off ever
So to use and install just place the two scripts in ~/domoticz/scripts/lua, then create your correctly named PIRs and you will have the ultimate smart PIR (tm) :lol: system.
script_device_pirs.lua
-- ~/domoticz/scripts/lua/script_device_pirs.lua
-- Each of the motion sensors in Domoticz follow this name convention:
-- PIRxyzSwitchName or PIRxyzGroupName
-- x speicifies when the PIR controls - a=all day, n=nighttime, d=daytime, 1=custom timer 1 set to 22:00 to 07:30
-- y specifies what the PIR is controlling - r = room (single Domoticz) switch and g = group
-- z specifies how long the ligth will stay on for in minutes, so z =5 turns the switch or the group on for 5 minutes, or u = don't turn off ever
-- N.B. be carefully as currently there is little error checking so wrongly named PIRs in Domoticz may cause an error
-- N.B. one wrongly named PIR may stop the script, check log for any issues
function timetest(opertime)
   if opertime == "a" then
      return true
   if opertime == "n" then
      if timeofday['Nighttime'] then
         return true
         return false
   if opertime == "d" then
      if timeofday['Daytime'] then
         return true
         return false
   if opertime == "1" then
      time = os.date("*t")
      if ((time.hour <= 7) and (time.min <= 30)) or (time.hour >= 22) then
         return true
         return false
   return false
tc=next(devicechanged)
v=tostring(tc)
if (v:sub(1,3) == 'PIR') then
   if timetest(v:sub(4,4)) then
      c=v:sub(7)
      if v:sub(5,5) == "g" then
         c="Group:"..c
      commandArray[c] = 'On'
      tmess = c..' On - time 0'
      print(tmess)
script_time_pirs.lua
   t1 = os.time()
   return difference
   tc = tostring(i)
   v = i:sub(1,3)
      onmode = i:sub(6,6)
      if onmode ~= "u" then
         timeon = (tonumber(onmode) * 60) - 1
         if (difference > timeon and difference < (timeon + 60)) then
            c = i:sub(7)
            if i:sub(5,5) == "g" then
               c="Group:"..c
            tempmessage = c.." Light Off - after at least " .. (timeon+1) .. "secs up - actually - " .. tempdiff .. "seconds"
            print(tempmessage)
So please enjoy the ultimate smart PIR (tm) :lol: system
CopyCatz
Developer
Re: ByronSX PIR
Post by CopyCatz »
Nice work Simon!
markk
Re: ByronSX PIR
Post by markk »
Pure genius. Thanks very much Simon.
markk
Re: ByronSX PIR
Post by markk »
Hi Simon
Is there a simple amendment that can be made to the first script which would start the timer but not actually turn the light on? I ask because my family don't tend to have a problem switching lights on when they enter a room, only turning them off when they leave it :). Without the on command I could have the off command working all day at set times after last movement without turning lights on during the day as well.
Mark
simonrg
Re: ByronSX PIR
Post by simonrg »
Hi Mark,
Yes, I think it will almost do it already, if you set the custom timer 1 then it will only turn on between 22:00 & 07:30, but I think it will turn off anyway as it is the PIR which starts the timer not the light. Give it a try and see, set PIR name to use custom timer 1, walk in the room the light won't turn on unless between the correct times, but if you then switch on the light and leave the room, the light will switch off after set time.
I could explicitly add this to script, but for the time being it should work anyway.
Simon
markk
Re: ByronSX PIR
Post by markk »
Hi @simonrg
I have finally got your script working fantastically and have realised where I was going wrong. I was setting the time off time to 15 minutes but it wasn’t working. I finally tried it at 9 minutes and it worked so it appears the time off time can only be from 1-9. It won’t work with any two digit number. I would love to be able to set my lights to stay on for a bit longer than 9 minutes before they plunge us into darkness. One final amendment to your already ultimate script would be the icing on the cake for me
Derik
Re: ByronSX PIR
Post by Derik »
Is this sensor to buy in Holland?
Or a clone?
simonrg
Re: ByronSX PIR
Post by simonrg »
@markk I had kept x y z as single characters to make the script simpler and potentially quicker. However there is no reason why these have to correspond directly to minutes. z could be used as an index to look up in a table, then any character could be used or just change the calculation. So, a quick fix is just to change the single line in the script_time_pirs.lua script where the length of timeto stay on is calculated.
Current version the value of z (onmode) is multiplied by 60 seconds:
Either to get double the time, i.e. 2, 4, 6, 8, 12, 14, 16, 18 minutes on
timeon = (tonumber(onmode) * 120) - 1
Or to square z to get, 1, 4, 9, 16, 25, 36, 49, 64, 89 minutes on
timeon = (60 * tonumber(onmode) ^ 2) - 1
markk
Re: ByronSX PIR
Post by markk »
Oh yes, that's just perfect. Thanks v much Simon
markk
Re: ByronSX PIR
Post by markk »
Just to add that if, like me, any of you have a Wickes or Response SA range wirefree alarm system installed, the door contacts and PIRs in this range work exactly the same as the byron SX PIRs and therefore perfectly with @simonrg's scripts.
Since I had these in almost every room anyway I now have automatic on/off lights in them now too :D
Mathiasw
Re: ByronSX PIR
Post by Mathiasw »
Simon, I don't quite understand the line of code:
Wouldn't that mean that "timezone" 1 is 2200 to midnight, and the first half hour of every hour from midnight to 0730?
simonrg
Re: ByronSX PIR
Post by simonrg »
@Mathiasw thanks for pointing this out, it doesn't make sense because it's not supposed to be that way, :oops: it is a bug, if you look at the line in context:
         return true
         return false
Basically, the clause will only return true if the hour is less than or equal to 7 and the minutes are less than or equal to 30, so 6:35 would result in false.
So it should be:
      if (((time.hour * 60) + time.min) <= ((7 * 60) + 30)) or (time.hour >= 22) then
         return true
         return false
Now if hours * 60 + minutes < 7 * 60 + 30 then it will return true correctly, i.e. any time between 10pm and 7:31am.
I should really write a function then it would be easy to set up any custom times.
Here's the function:
function customtest(nowhours, nowmins, starthours, startmins, endhours, endmins)
   nowmins = nowmins + (nowhours * 60)
   startmins = startmins + (starthours * 60)
   endmins = endmins + (endhours * 60)
--   print(nowmins..":"..startmins..":"..endmins)
   if (startmins > endmins) then
--    spans midnight
      if ((nowmins >= startmins) or (nowmins <= endmins)) then
         return true
         return false
--    doesn't span midnight
      if ((nowmins >= startmins) and (nowmins <= endmins)) then
         return true
         return false
This purely returns true or false depending on whether within operation time or not. It also copes with times that span midnight or times that don't.
So the current state of the script_device_pirs.lua is:
--    spans midnight
         return true
         return false
         return true
         return false
      return true
         return true
         return false
         return true
         return false
      return customtest(time.hour, time.min, 22, 0, 7, 30)
   return false
v=tostring(tc)
      c=v:sub(7)
         c="Group:"..c
      print(tmess)
I am a bit concerned that this script is now becoming a bit long and as such may start to impact Domoticz's performance, but LUA seems fairly efficient so should be ok. I guess the best thing is only to implement this version if you want to use custom timers. In which case you can just add extra ones with:
   if opertime == "2" then
      return customtest(time.hour, time.min, 0, 0, 5, 30)
   if opertime == "3" then
      return customtest(time.hour, time.min, 9, 1, 17,59)
ONce again, thanks for the pointing out my error :D .
Mathiasw
Re: ByronSX PIR
Post by Mathiasw »
I've been programming for 40 years and I was sure the code was wrong, but being new to the community it seemed politer to say "I think the may be an issue with the code"!
I solve the time comparison problem by converting the time into an integer (hours*100)+minutes, then it becomes a simple comparison between eg.
CompositeTime > 0630 and CompositeTime < 2215
.. For example.
Stokie21
Re: ByronSX PIR
Post by Stokie21 »
Hi Again Simon, sorry not had anytime online over the last couple of weeks
I am still having trouble setting this up, due to me not knowing anything about code
i entered the scripts
Made a group called Birds and added a few switches to test
I called the PIR, PIR1gzBirds i am guessing thats where I set up the 1 for custom timer, the G for Group, and the Z for 5 mins???
but can not get this to work, its just giving an error which is
Error: Mon Feb 10 21:09:38 2014 scripts\lua\script_time_pirs.lua:31: attempt to perform arithmetic on a nil value
I know it might be a simple error for a coder, but i know nothing about code so it might aswel be in german!
Can you point me in the correct direction to get this thing going?
markk
Re: ByronSX PIR
Post by markk »
Stokie21 wrote:Hi Again Simon, sorry not had anytime online over the last couple of weeks
You are nearly there. You need to enter the actual amount of minutes you want the light to stay on for between 1and 5 not "z"
Try that.
simonrg
Re: ByronSX PIR
Post by simonrg »
@Stokie21, as @Markk says, it looks like the only thing wrong is that rather than z you need to replace this to specify the time - PIR1g5Birds rather than PIR1gzBirds, as 5 will mean the lights will not turn off for at least 5 minutes. I would also try with PIRag5Birds first so that you can see its working without worrying about it only working at certain times, and then when that works change the name to PIR1g5Birds. Hope that now works ok. Simon
Stokie21
Re: ByronSX PIR
Post by Stokie21 »
Agh i see, missed the last jump!!
working just fine now on the test, so have set it to custom time so if anyone goes in my bird shed after 10pm the house lights up :)
Thanks for all the help
nigels0
Domoticz version: 3.8153
Re: ByronSX PIR
Post by nigels0 »
Fantastic work. Extremely easy to add PIRs now.
commodore white
Re: ByronSX PIR
Post by commodore white »
simonrg wrote:I don't think it is appropriate for Domoticz to make a special case for the ByronSX PIRs
I sort of agree. However, if you register the device as of type "motion sensor" it's not unreasonable to expect domoticz to do "motions sensor" things - this includes turning the darn thing off if an off signal isn't received in a period you define. As it is, my new house is going to have 8 motion detection that all show "on". Not very wife friendly.
