Page 2 of 2
Re: Telegram Notification IF LAN IP CHANGED
Posted: Sunday 25 December 2016 23:35
by ropske
i have made a php file called version.php
<?php
phpinfo();
and this works, so php is working
Posted: Monday 26 December 2016 0:26
by ropske
my token is correctly and userid also, because when i enter this
https://api.telegram.org/123456789/send ... 9&text=wie ben jij
then i'm receiving this on my telegram bot
can someone show me maybe how to use this telegram.php ?
thanks
Posted: Monday 26 December 2016 1:49
by sincze
ropske wrote:will it also work with:
PHP Version
5.5.22
i have this one installed in my nas and if i want to run the telegram.php
i'm getting this error:
HTTP 500-fout
Dat is vreemd... deze pagina kan niet worden weergegeven door de website
seems something is wrong with your .php file, you might want to check the source vice php checker??
to see if you might have a typo.
http://phpcodechecker.com/
Posted: Monday 26 December 2016 10:38
by ropske
i just copied the code from you:
#!/usr/bin/php
<?php error_reporting(E_ALL);ini_set("display_errors","on");
$silent=true;$type=NULL;$to=NULL;
if(isset($_REQUEST['silent']))$silent=$_REQUEST['silent'];
if(isset($_REQUEST['text'])){$type='text';$content=$_REQUEST['text'];}
if(isset($_REQUEST['photo'])){$type='photo';$content=$_REQUEST['photo'];}
if(isset($_REQUEST['video'])){$type='video';$content=$_REQUEST['video'];$silent=true;}
if(isset($_REQUEST['to']))$to=$_REQUEST['to'];
if($to=='Wife')$telegramchatid=12345678;
elseif($to=='channel')$telegramchatid=-1234567890123;
else $telegramchatid=87654321;
if(!empty($argv[1])&&!empty($argv[2])){$type=$argv[1];$content=$argv[2];}
if(!empty($argv[1])&&$argv[1]=="snapshot") {$type='photo';$content = "/run/pikrellcam/mjpeg.jpg";$silent=true;}
if(isset($type)&&isset($content)){
    $bot_url="https://api.telegram.org/bot123592115:A2EZ-xCRhO-RBf2qICiJs8q2A_2YIr1irxI/";
    if($type=="text"){$url=$bot_url."sendMessage?chat_id=".$telegramchatid;$post_fields=array('chat_id'=>$telegramchatid,'text'=>$content,'disable_notification'=>$silent);}
    elseif($type=="photo"){$url=$bot_url."sendPhoto?chat_id=".$telegramchatid;$post_fields=array('chat_id'=>$telegramchatid,'photo'=>new CURLFile(realpath($content)),'disable_notification'=>true);}
    elseif($type=="video"){$url=$bot_url."sendVideo?chat_id=".$telegramchatid;$post_fields=array('chat_id'=>$telegramchatid,'video'=>new CURLFile(realpath($content)),'disable_notification'=>true);}
    $ch=curl_init();curl_setopt($ch,CURLOPT_HTTPHEADER,array("Content-Type:multipart/form-data"));curl_setopt($ch,CURLOPT_URL,$url);curl_setopt($ch,CURLOPT_RETURNTRANSFER,1);curl_setopt($ch,CURLOPT_POSTFIELDS,$post_fields);
    for($x=1;$x<=100;$x++){
        $result=json_decode(curl_exec($ch),true);
        if($result['ok']===true)break;
        sleep($x*3);
but when i enter this in http://phpcodechecker.com/ i'm getting indeed some errors.
PHP Syntax Check: Parse error: syntax error, unexpected '$telegramchatid' (T_VARIABLE) in your code on line 10
else $telegramchatid=123456789;
PHP Syntax Check: Errors parsing your code
when i change to this:
else ($telegramchatid=123456789);
it's ok, but then the next error comes...
Posted: Monday 26 December 2016 11:05
by sincze
ropske wrote:i just copied the code from you:
A well I had to modify that code a bit as well to have it work without any problems on my setup. This is my telegram.php. Credits ofcourse go to the original writer :D
#!/usr/bin/php
<?php
error_reporting(E_ALL);ini_set("display_errors", "on");
$silent=false;$type='';
if(isset($_REQUEST['silent'])) $silent = $_REQUEST['silent'];
if(isset($_REQUEST['text'])) {$type='text';$content = $_REQUEST['text'];}
if(isset($_REQUEST['photo'])) {$type='photo';$content = $_REQUEST['photo'];}
if(isset($_REQUEST['video'])) {$type='video';$content = $_REQUEST['video'];$silent=true;}
if(!empty($argv[1])&&!empty($argv[2])) {$type=$argv[1];$content = $argv[2];}
//if(!empty($argv[1])&&$argv[1]=="snapshot") {$type='photo';$content = "/var/tmp/snapshot1.jpg";$silent=true;}
echo '<pre>REQUEST=';print_r($_REQUEST);echo '</pre>';
if(isset($type)&&isset($content)) {
	echo 'Type = '.$type.'<br/>Content = '.$content.'<br/>';
	$telegrambot='123456789:AA_______________________________poQ';
	$telegramchatid=-1111222233334;
	$bot_url    = "https://api.telegram.org/bot$telegrambot/";
	if($type=="text") {
		$url        = $bot_url . "sendMessage?chat_id=" . $telegramchatid ;
		$post_fields = array('chat_id'   => $telegramchatid,
			'text'     => $content,
			'disable_notification' => $silent
	else if($type=="photo") {
		$url        = $bot_url . "sendPhoto?chat_id=" . $telegramchatid ;
			'photo'     => new CURLFile(realpath($content)),
			'disable_notification' => true
	else if($type=="video") {
		$url        = $bot_url . "sendVideo?chat_id=" . $telegramchatid ;
			'video'     => new CURLFile(realpath($content)),
	//echo 'URL = '.$url.'<br/>';
	//echo '<pre>post_fields=';print_r($post_fields);echo '</pre>';
		$ch = curl_init();
		curl_setopt($ch, CURLOPT_HTTPHEADER, array(
		curl_setopt($ch, CURLOPT_URL, $url);
		curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
		curl_setopt($ch, CURLOPT_POSTFIELDS, $post_fields);
		$output = json_decode(curl_exec($ch),true);
	//echo '<pre>Output=';print_r($output);echo '</pre>';
The problem I had was with line
Had to comment that out of the way. This code will compile without errors on PHP Code Checker.
Posted: Monday 26 December 2016 11:13
by ropske
Posted: Monday 26 December 2016 11:25
by ropske
because it's still not working :(
Posted: Monday 26 December 2016 12:09
by sincze
ropske wrote:because it's still not working :(
assuming you configured your webserver correctly (mine is running on default port 80 not 5000) the command would be:
http://192.168.2.10/php/telegram.php?text=Reboot_MQX
as you can see my telegram.php is not located in the root of the www directory of the webserver, but in sub directory called php.
good luck. you now have all the pieces :D
Posted: Monday 26 December 2016 12:27
by ropske
i cannot change my port :(
i have a zyxell nas 540
maybe it is something at my nas-server i need to setup.
i better bought a synology it seems
Posted: Monday 26 December 2016 12:31
by sincze
ropske wrote:i cannot change my port :(
I don't use synology for this.
Any webserver will do. APACHE / NGINX.
Posted: Monday 26 December 2016 18:14
by ropske
lol, seems this 'section' on my nas is not supporting php
need to check how to activate it on published sites
