Page 2 of 18
Re: Help with Yeelight Bulb
Posted: Monday 12 September 2016 18:27
by Derik
corbin wrote:
Derik wrote: Only i do not understand the ssdp protocol? Working with putty?
Or how do i send the request.
some one understand this..?
Are you able to run a command like this?
printf '{"id":1,"method":"toggle","params":[]}\r\n' > /dev/tcp/192.168.0.2/55443
change 192.168.0.2 to the IP address of your bulb. Also check that you have developer mode enabled on the bulb. The quotes may need escaping, I'd check myself but don't have a Linux install handy.
Corbin...
If you planed a hardware plugin... [ love that option..xxxx]
Only i do not understand the methode..
In my browser?
in putty?
Or in a linux [ and then? ]
Sorry for my dombo questions
Posted: Monday 12 September 2016 23:18
by TwoEasy
I found another temporary way to control the bulbs. Not the most effective or smoothest way to do it but it works..
I have a old Android tablet that I use as a on the wall dashboard, always connected to a charger and always at home, connected to wifi. I have tasker installed. So I made a virtual switch in domoticz that sends a on/off message via pushbullet that my Android tablet listen for and then runs the wanted command on the wanted bulb.
Like I said, dirty, not local but It works for now I think. (not actully tested yet)
Posted: Tuesday 13 September 2016 6:35
by farhanito
I you want local, i think this tasker plugin will work better
https://play.google.com/store/apps/deta ... .httpevent
Posted: Tuesday 13 September 2016 12:00
by corbin
Derik wrote: Corbin...
In my browser?
in putty?
try this from Linux command line (terminal)
echo -ne '{"id":1,"method":"toggle","params":[]}\r\n' | nc -w1 192.168.5.19 55443
Posted: Friday 30 September 2016 12:46
by corbin
Any Windows Domoticz users want to test my Yeelight code?
Posted: Monday 03 October 2016 1:06
by corbin
Posted: Sunday 09 October 2016 10:00
by TwoEasy
Oh amazing Corbin! Really awesome! Unfortunately I use Raspberry pi so I cannot test it, I can happily test it if possible on pi
Posted: Sunday 09 October 2016 11:06
by Derik
Looks there are people that have supported the yeelight in windows domoticz....
Posted: Sunday 09 October 2016 11:10
by TwoEasy
  • u
Derik wrote:Looks there are people that have supported the yeelight in windows domoticz....
Yeah, as you can see two posts up it is Corbin who created this.
Posted: Sunday 09 October 2016 11:18
by Derik
TwoEasy wrote:
  • u
O real? :D :D :D
Will try a linux version... [ have bulb]
Only i do not understand the way i should use:
Posted: Sunday 09 October 2016 17:42
by Derik
Did install the last Windows Beta, on my NUC
No Yeelight?
Posted: Monday 10 October 2016 7:48
by corbin
Derik wrote:Did install the last Windows Beta, on my NUC
No Yeelight?
Derik, try this link - compiled for Windows. https://1drv.ms/f/s!AiVyh7yRnMKPgT1s4nzWDgJX7UaO
The code on github probably isn't working right now - I am rewriting it to work in Linux.
Posted: Monday 10 October 2016 18:50
by Derik
No Yeelight?
Did install this version on my pc.
Ad the yeelight..
Only see no thing happend?
While my light is on and visible in my lan.
What do i need to do more?
Posted: Monday 10 October 2016 20:45
by corbin
Have you enabled development mode on your Yeelight?
Posted: Monday 10 October 2016 20:54
by Derik
corbin wrote:Have you enabled development mode on your Yeelight?
mmm
I do only have the bulb and a android app?
Is that ok?
Where can i find this mode?
Posted: Monday 10 October 2016 20:58
by corbin
Use the main Yeelight app, link on top right to settings
Posted: Monday 10 October 2016 21:07
by corbin
Yes the Android app is what I use, but the link to developer mode is only there in the main Yeelight app, it isn't in shortcuts to individual lights.
Posted: Monday 10 October 2016 21:22
by Derik
Got him :-)
Only have a other problem..
My X64 [ windows] nuc is not working as a slave for my master.. [ endium problem or something ]
Why not in Beta Windows?
Posted: Monday 10 October 2016 21:29
by corbin
Derik wrote:Got him :-)
Awesome!
With Windows not working as a slave, yeah is to do with big/little endian - not going to work.
But, I almost have the Linux version working...
Posted: Monday 10 October 2016 21:42
by Derik
corbin wrote:With Windows not working as a slave, yeah is to do with big/little endian - not going to work.
What is that for problem endian... [ when i run Domoticz on X86 is that better? ]
When you have linux let me now i test...[ when i have time ]
Are all Yeelights working?
Like the strips and the small bulbs?
http://www.ebay.com/itm/Original-Xiaomi ... SwHoFXs-G7
Great JOB!!!
