juankar wrote:Very interesting Project and pehap a solution for the problema of automatic lights/PIR sensors.
I've read this can detect sense of movement, so it could detect if a person go into or out from a room, so we could know how many persons are in the room and so keeps light on or heater or.... Am I right?
presence detection is a quite trending topic, and people counting is even more. i believe there are various approaches
there are some led sensors that can detect if some light beam is broken and eventaully if you have a couple, you can judge which was the direction.. i do not know how reliable this could be implemented.
One thing that is for sure is measuring CO2. I've been experimenting with this as part of my other project and what i can confirm is that in a *closed* room, the co2 does increase with a rate that depends on the number of people inside. if it does not decrease too much or falls down - this means the door/window is open.
and it rises pretty fast.. i believe in 5 min timeframe, the increase would be enough to judge that you have to turn on and off the heating.
of course it is not too perfect - but - when it falls down - it means either people are gone or too many windows are open - in both cases you do not need to heat
and adding a PIR will tell you if the room is empty or occupied. but not how much people are there
if you already have some windows sensors - perhaps you can corrrelate everything
