Page 2 of 10
Re: ESP8266 Air quality sensor
Posted: Sunday 29 October 2017 14:39
by jvdz
I am running an Wemos D1 + MH-Z19b since a few months now with a modified version of ESPEASY I made as described here:
https://gathering.tweakers.net/forum/li ... 9#52624079
This Wemos also has 2 LUX sensors, a DHT22 Sensor for Temp&Humidity and a BMP180 Barometer (Presure).
All these devices are directly updated via the build in options of this modified ESPEASY version by a URL call.
The devices are all setup in Dummy hardware which you first need to create yourself and then use the IDX in the ESPEASY definition for the device:
- Knipsel.PNG (40.11 KiB) Viewed 11464 times
The graph created by the MH-Z19b/CO-20 looks like this:
- Knipselb.PNG (246.72 KiB) Viewed 11464 times
The thread I linked is a good place to find some information about the usage of this setup.
Jos
Posted: Sunday 29 October 2017 15:23
by LouiS22
Topcase1 wrote: Sunday 29 October 2017 14:23
Because I'm new here I say Hello to everyone,
The air quality sensor made of an ESP8266 and an MH-Z19 is true to me.
What I understand is that you can use and pair this combination of stand alone with Wi-Fi to my Raspberrypi on which Domoticz stands?
Now I saw the print of a CO2 chart, and I want that too.
But on the same print, I see hardware as the Volcraft co-20 in Domoticz.
Can anyone explain how this is? Is it that if you download the software by itself, if you have Volcraft in Domoticz?
Thanks in advance,
Topcase1
You have to create a dummy sensor in Domoticz, then create a CO2 virtual sensor within. Note its IDX, that's what you have to feed from ESP8266 (for example Espeasy).
Posted: Sunday 29 October 2017 18:33
by Topcase1
Jos en LouiS22, Thanks!
Topcase1
Posted: Friday 03 November 2017 16:27
by nixalsschrott
It sounds very interesting and is also very close to what I am searching for.
Since your link does not contain english or german description it would be very helpful, if you could provide a little howto with component list and steps to set up the hard- and firmware.
Kind regards
matty
Posted: Friday 03 November 2017 17:27
by jvdz
Hi Matty,
No problem. We can do that here so others can also benefit from it... and maybe later convert that into a Wiki page once we have nailed down the appropriate process.
So lets start simple and work our way into the details depending on how far you are already.
Components used:
- Wemos D1 mini - https://wiki.wemos.cc/products:d1:d1_mini
- MH-Z19(b) (Either A or B version will work. I have a B version)
- ESPEasy - Latest Mega version will work but won't update via HTTP JSON with the standard settings. My version does work with JSON. So the below only works with my GIT version at this moment.
Assembling
Connect the following:
MH-Z19 Tx → Wemos pin D5
MH-Z19 Rx → Wemos pin D6
MH-Z19 gnd → Wemos gnd pin
MH-Z19 vin → Wemos 5V pin (Only for MHZ19B, else 3.3V if I remember correctly!)
Loading ESPEASY
Either I can provide the bin to load or you can build it yourself by setting up the following:
Source code development
Load the Bin file either from Atom or the load process describe
here.
Add Airquality device to Domoticz:
Goto the Domoticz webpage and select: Setup/Hardware.
Add A dummy Sensor:
- air0a.PNG (57.06 KiB) Viewed 11408 times
- air0b.PNG (11.07 KiB) Viewed 11408 times
Make a note of the created device IDX found in in Setup/Devices
- air0c.PNG (52.83 KiB) Viewed 11408 times
Continue Next post (can only attach 3 images each post)
by jvdz
Configuring ESPEasy:
Goto the webpage of the Wemos/ESPEasy unit and do de basic configuration as described
in this page.
Define the Domoticz server under the controllers Tab:
- AIR1.PNG (30.02 KiB) Viewed 11407 times
and fill in the appropriate information to connect to your Domoticz server.
Define the Device is the Devices tab:
- air2.PNG (49.95 KiB) Viewed 11407 times
.. and fil in the field as shown and use the Found IDX of the domoticz device in the "Send to controller IDX field.
You should be in business after you saved this.
Under the Tools/LOG option in ESPEASY you find information about the steps ESPEASY does and when it receives information.
This is the log I have and you see also the MHZ19 in there:
- air3.PNG (64.13 KiB) Viewed 11407 times
Shoot when you have questions.
Jos
Posted: Monday 06 November 2017 9:31
by nixalsschrott
Dear Jos,
really fast reply - thanks a lot.
I need some time to proceed since I am going to order the parts from China, delivery will need approximitely at least 2 weeks.
Regarding the component list you also mentioned DHT22 and GY-68 BMP180 before. Do these sensors also work within this project (connect to same PCB)? Then I would add this parts to my order.
Kind regards
matty
Posted: Monday 06 November 2017 9:59
by jvdz
Yes they do. I've also made some changes in my port of the ESPEASY software to support direct update of the of the dummy BMP180 sensor in Domoticz using the standard HTTP config with IDX.
Jos
Posted: Monday 06 November 2017 10:39
by LouiS22
jvdz wrote: Friday 03 November 2017 17:27
[*]ESPEasy - Latest Mega version will work but won't update via HTTP JSON with the standard settings.
Actually it works, you have to define a rule, then it's ok. Of course your solution is much more elegant
One question though: have you noticed any "not stable reading" error messages? I have it from time to time.
Posted: Monday 06 November 2017 13:39
by jvdz
LouiS22 wrote: Monday 06 November 2017 10:39
Correct, hence my comment that it doesn't work with the standard settings for IDX and Domoticz host.
That won't happen on my setup as I have a mh-z19b version, which doesn't supply the S value, so that is set to 0.
That actually was the reason I made my own version of ESPEASY, since the standard version at the time would always come back with that warning and others had the same issue with the b variant.
Jos
Posted: Monday 06 November 2017 14:30
by LouiS22
jvdz wrote: Monday 06 November 2017 13:39
Jos
Never noticed there's a B variant (mine is without B - and that's also producing the error message).
Posted: Monday 06 November 2017 17:19
by jvdz
You can check the value of S when you check the ESPEASY values for the device.
Anything below 64 is considered "unstable" in the ESPEASY software for the A version, and will trigger this message.
TD-er made several changes lately for the standard version of ESPEASY in which this piece of code does the checking for S. It nicely explains the usage of it with the also included delay filter option:
if (s > 0 && s < 64 && filterValue != PLUGIN_049_FILTER_OFF) {
// Not the "B" version of the sensor, S value is used.
// S==0 => "B" version, else "A" version
// The S value is an indication of the stability of the reading.
// S == 64 represents a stable reading and any lower value indicates (unusual) fast change.
// Now we increase the delay filter for low values of S and increase response time when the
// value is more stable.
// This will make the reading useful in more turbulent environments,
// where the sensor would report more rapid change of measured values.
difference = difference * s;
difference /= 64;
log += F("Compensate Unstable ");
filterApplied = true;
This code is executed when the delay filter is off and is the old behavior:
case PLUGIN_049_FILTER_OFF: {
if (s != 0 && s != 64) {
log += F("Skip Unstable ");
return false;
filterApplied = false;
break;
I am not using this version so have no real experience with it, but can only say that the B version I have seems to be pretty stable in its readings.
Jos
Posted: Tuesday 07 November 2017 10:17
by LouiS22
jvdz wrote: Monday 06 November 2017 17:19
difference /= 64;
return false;
break;
Jos
Thanks, I did a custom build from github yesterday evening with the latest modifications - will see how it performs. There's indeed new options to customize ZH19 behaviour - even for the "old" version.
Posted: Tuesday 07 November 2017 12:50
by Igrek
Hello!
This plug-in gives out three values, the dummy Sensor Co2 does not accept such.
Which Domoticz sensor did you use?
Posted: Tuesday 07 November 2017 13:14
by LouiS22
Igrek wrote: Tuesday 07 November 2017 12:50
Hello!
Dummy CO2, but I'm using it with a rule created within ESPEasy (http push into Domoticz). Let me know if you need it. BTW I only use the PPM value.
Posted: Tuesday 07 November 2017 13:42
by Igrek
LouiS22 wrote: Tuesday 07 November 2017 13:14
Dummy CO2, but I'm using it with a rule created within ESPEasy (JSON and push the value into Domoticz). Let me know if you need it. BTW I only use the PPM value.
Yes, I also need only PPM value!
Now I receive the text and run parse the LUA script.
Sure that there is a way easier...
I need it!
Ta!
Posted: Tuesday 07 November 2017 18:07
by jvdz
Just enable the Rules in ESPEasy and add this rule:
Where:
<MHZ19> = Devicename of the MHZ19 unit in ESPEASY
<DomoticsIP> = IP address of your domoticz server
<port> = port used by your domoticz server
<IDX> = The IDX of the device in Domoticz
on <MHZ19>#PPM do
SendToHTTP,<DomoticsIP>,<port>,/json.htm?type=command¶m=udevice&idx=<IDX>&nvalue=[MHZ19#PPM]
endon
The rule will be started each time an new value arrives and prerform the url.
Jos
Posted: Tuesday 07 November 2017 18:24
by LouiS22
jvdz wrote: Tuesday 07 November 2017 18:07
Where:
on <MHZ19>#PPM do
endon
Jos
Indeed, with the below correction: udevice goes first, then type!
on CO2TEST#PPM do
SendToHTTP 192.168.0.19,8080,/json.htm?param=udevice&type=command&idx=2894&nvalue=[CO2TEST#PPM]
endon
(my device name is CO2TEST, you can replace it with the one you like)
Posted: Tuesday 07 November 2017 18:45
by jvdz
Pretty sure it worked that way before I changed my ESPEASY version, which is to be expected.
Posted: Tuesday 07 November 2017 18:51
by Thelion
I'm following this topic and I'm about to order the components, but I noticed there is a 0-2000PPM and a 0-5000PPM version of the MH-Z19B
I really hope the air quality never gets in the 5000PPM range, but more range is better, right?
