https://github.com/domoticz/domoticz/issues/693
Lua and Kodi
rickwilleme
- Domoticz version: 3.6792
Re: Lua and Kodi
Just did. Hope they're able to find the root cause of this issue
Raspberry Pi ~ Fibaro Dimmer (Z-Wave) ~ Several KAKU switches and dimmers (433 MHz) ~ Amazon Echo ~ Somfy RTS ~ Sony TV ~ Kodi/XBMC ~ Essent E-Thermostaat (ICY) ~ Cresta thermostat ~ Wundermap Weather ~ Smoke detectors
- Dnpwwo
Re: Lua and Kodi
I don't believe this is a problem with the Kodi plugin but more a feature of the way events are handled within Domoticz itself
From memory, when a new event is submitted for a device it overrides events already in the queue under most circumstances. I believe this is prevent unexpected results if multiple events were sent to a device in rapid succession. At the end of the day, Domoticz is designed to handle simple devices like switches so sending streams of commands does not make sense.
That said, there are work arounds as shown here:
By specifically delaying the second command both are executed as the log shows:
Have a play with it but it seemed to me that delays of less than 3 seconds were ignored so maybe you can activate the plugin then schedule the pause.
Good luck
-- loop through all the changed devices
for deviceName,deviceValue in pairs(devicechanged) do
print ("Device based event fired on '"..deviceName.."', value '"..tostring(deviceValue).."'");
if (deviceName=='Test Trigger') then
commandArray[1] = { ['Lounge Kodi'] = 'Pause' }
commandArray[2] = { ['Lounge Kodi'] = 'Set Volume 50 AFTER 3' }
return commandArrayCode: Select all
2016-06-12 18:05:23.419 Kodi: (Lounge Kodi) Sent command: 'Input.ExecuteAction pause'.
2016-06-12 18:05:23.903 LUA: Device based event fired on 'Lounge Kodi', value 'Unknown'
2016-06-12 18:05:23.419 (Kodi Servers) Lighting 2 (Lounge Kodi)
2016-06-12 18:05:26.913 Kodi: (Lounge Kodi) Sent command: 'Set Volume'.
2016-06-12 18:05:26.915 Kodi: (Lounge Kodi) Volume changed to 50.00000, Muted: false.
2016-06-12 18:05:26.973 Kodi: (Lounge Kodi) Volume set to 50.
2016-06-12 18:05:27.137 LUA: Device based event fired on 'Lounge Kodi', value 'Unknown'
2016-06-12 18:05:26.913 (Kodi Servers) Lighting 2 (Lounge Kodi)
Good luck
dannybloe
Re: Lua and Kodi
I agree that for commands that change the actual state of the device this is the best way to go. However, this fails with the 'execute script' command. That is a different beast and you should be able to just send a dozen of those and all of them should be executed. It's like the openURL command or sendNotification (with whatever syntax that is). They have to be queued and executed one by one. So yeah, for pause and play it doesn't make sense to have them execute all, just the last one.
- Plaagje
- Domoticz version: Latest
Re: Lua and Kodi
I tried to play around with kodi and lua scripts and would like to pause my Kodi only when kodi is playing video's.
But i can only get to print the On and Off statuses and not Video Audio Photo or Paused...
I have 2 Kodi's (Kodi Livingroom, Kodi Bedroom)
This is my script:
The only status i see is:
I can see the status on the dummy switch changing to Video
--EDIT--
when the status changes this show up in the log:
Anyone an idea or workaround?
This is my script:
-- loop through all the devices and find the Kodi Mediaplayers
for deviceName in pairs(otherdevices) do
Name = tostring(deviceName)
name = deviceName:sub(1,4)
if (name=='Kodi') then
print (deviceName..":"..otherdevices[deviceName]);
if (devicechanged['Doorbell_Switch'] == 'On' and otherdevices[deviceName] == 'Video') then
commandArray[deviceName] = 'Pause'
2017-04-01 17:15:03.275 LUA: Kodi Livingroom:On
2017-04-01 17:15:03.275 LUA: Kodi Bedroom:On
--EDIT--
