Suggestion: Z-Wave device management improvements
Ricard1
Re: Suggestion: Z-Wave device management improvements
Also, when "clicking" to removing a Z-Wave Node for some reason it would be great if a list of the specific Node associated devices/endpoints was shown in a window, with "select" checkbox to each entry as an option to delete some or all associates.
As it is now if you forget to remove device entries at the Node removal you tend to end up with a lot of trash in the device list.
morten6883
mischa
- Domoticz version: 3.8872
I think one of the reasons why the devices are not automatically deleted as well is that you lose saved (historical) sensor data.Ricard1 wrote:Also, when "clicking" to removing a Z-Wave Node for some reason it would be great if a list of the specific Node associated devices/endpoints was shown in a window, with "select" checkbox to each entry as an option to delete some or all associates.
A better option is to export sensor data, before you delete them.
Also mentioned in this post: viewtopic.php?f=31&t=12442#p93512
Pi 2 - Pi 1 - Razzbery 2.0 - Fibaro FGD-211 - Fibaro FGD-212 - Fibaro FGRGBWM-441 (RGBW Module) - Fibaro FGBS321 (Universal Switch) - FGWPF-102 - TBK Home TZ67-G - Synology DS1515+ - Esp Easy (with wemos D1 mini)
Ricard1
Yes migrating to new devices is an important function, but that one is not best handled as is in Domoticz. i.e. having old and new switches in a device table you can not move to the new and retain all old switch associations, like if used in Blockly it will loose the connection to functions and you have to manually correct it, if not fixed by later betas?
