Page 2 of 2
Re: Aeotec Home Energy Meter Gen 5
Posted: Sunday 12 May 2019 16:33
by McJohn
We use a "simple" HEM 1 with 1 fase.
But I think you are right.
See picture below from the manual.
Posted: Monday 13 May 2019 0:07
by Nautilus
Thanks - saw the same on online documentation, but wanted to make sure that I've really understood it correctly. Too bad, makes the purchase much less intriguing for a non-electrician (it's 75€+ for even a 5 minute visit of an electrician). Does anyone know any similar devices with 3-phase measurement and a possibility to detect the direction (import/export)?
Posted: Saturday 07 September 2019 20:49
by McJohn
There is a bug in Domotics for this Aeotec Home Energy Meter Gen 5:
When the power if off (no 230V anymore, also for the HEM!) it keeps displaying the last HEM update: ~230V, even if there is no power anymore...
We want to make a Blocky or LUA trigger when the power is available again (or gone) but that's impossible with this bad information.
Posted: Sunday 27 October 2019 15:27
by JuanUil
Maybe a stupid question but where can I find the manufactuer_specific.xml file.
I can not find it on my pi
Posted: Monday 28 October 2019 20:08
by JuanUil
Done everything mentioned in this thread but I don't get it working.
Could somebody post the settings of all parameters for the HEM?
Thnx in advance
Jan
Posted: Monday 28 October 2019 20:29
by JuanUil
And an upload of the manufactuer-SPECIFIC.xml file would also help
Posted: Thursday 31 October 2019 18:44
by JuanUil
So tried everything without result.
meter is not reporting every 5 seconds and also the readings look redicules.
in nighttime I have a negative usage.
Anay help?
Posted: Sunday 03 November 2019 14:14
by JuanUil
nobody?
Posted: Tuesday 05 November 2019 21:31
by drogert
I got my home energy Gen 5 (one clamp) fitted and its reporting!
Only one thing is not working as espected. It can report the Voltage and Amps but without stetting the device to polling it just wont update the values
WITH polling it does update BUT. i get a timeout error in domotica
2019-11-05 21:30:21.041 Status: OpenZWave: Received timeout notification from HomeID: 4118417576, NodeID: 2 (0x02)
I dont mind this as its working, but it shouldnt be the right way i guess...
Anyone knows what i can do about this?
UPDATE
So by changing the group output settings to:
Group 1 reports to : 15
Group 2 reports to: 0
Group 3 reports to: 0
You can calculate what the HEM reports with this Excel sheet:
https://aeotec.freshdesk.com/helpdesk/a ... 6039852024
fixed the "polling" issue. It now reports all 4 values every 5 secs
Posted: Wednesday 06 November 2019 21:36
by drogert
So ive been measuring it for one day now and found out: when checking the logs it says I did a total of 18KW in 24hrs. When i calculate this from the actual meter its around 13Kwh. When I look at the Device itself in the Node screen it has a total of 12Kwh. Which is closer to what its actually shown by the meter. Does anyone know why this is so different?
Update
When waking up this moring the Kwh log went from 18Kwh to -4Kwh...
Surely this must be a bug in domoticz?
Posted: Wednesday 13 November 2019 23:06
by quasarius
How did you fix the polling? Or rather, fix so it reports every 5 seconds? Even with correct node settings I only get updates every 90 seconds in Domoticz.
Posted: Friday 22 November 2019 13:58
by drogert
quasarius wrote: Wednesday 13 November 2019 23:06
Well, using the excel sheet you can fill in what the HEM5 needs to report to group 1
in this case its 15
then below the these settings you can set the interval for group 1 at 5 secs
Posted: Sunday 24 November 2019 10:20
by quasarius
drogert wrote: Friday 22 November 2019 13:58
in this case its 15
I know, my issue is that the OZW control panel does show updates every 5 seconds, but whatever I do I can't get Domoticz to update the device values more often than every 90 seconds. Which means it doesn't trigger any events more often than every 90 seconds either.
Posted: Saturday 27 November 2021 16:57
by dagger38
Darn.... can't even get the hem to include into domoticz???
How do you do that!
