Page 2 of 3
Re: Ticz - Another Domoticz app for Windows 10 / UWP
Posted: Thursday 26 May 2016 8:06
by Derik
hansworst wrote:
Derik wrote:mmm
More pressure to use wan and lan settings... :?:
Camera cost a lot of Data!!!
Assuming you live in the Netherlands, which your profile states ;
- You pay for your phone's data over 3G/4G for any data
Yes that is correct ]
- You don't pay if your phone is connected to WiFi / local LAN and accessing resources either internally or externally [ yes ]
As long as your phone is connected to local WiFi / LAN it really doesn't matter if you access your local Domoticz server via local IP address 192.168.x.x or external 83.83.242.xx . If you can prove to me that you get charged for that, I will apologize in front of the entire forum, and then tell you to search for another ISP :lol: :lol:
I now that the cost of lan is free...
In the Netherlands all the providers have data restrictions....
And when you have the option to look to a cam, there is streaming data....[ with cost a lot of data ]
And whit a small payment to the isp you will have a great problem
And i hope that you now what the risks are when you use free wifi over the world.
With a open port in your home network...
Posted: Thursday 26 May 2016 12:37
by Kouseri
Kouseri wrote:Thanks @hansworst from this great Windows 10 app. Based on my testing today, it seems to be working very well.
I found a missing fire alarm icon and filled an issue to the Github.
Thanks for fixing this one!
niki_lauda wrote:2. the refreshing pop up bar is very usefull but may by a smaller indicator is less intrusive.
I agree that the refreshing pop up bar is a pretty intrusive. I'm not sure does it add any value to end user to show refreshing pop up bar every time when refreshing works as it should... It definately adds value when refreshing encounters an issue/error during the refreshing process. So what about showing the refreshing pop up bar only when issue/error is encountered?
What about adding a possibility to modify user variables directly from the Ticz? I live in Finland and we're using electric engine heaters in cars when it's cold. I do have a switch which is controlled by the Domoticz via lua scripts (script_time_carheaterswitch.lua & script_device_carheaterswitchcompanion.lua). Time when leaving from home is set by the user variables (single event and recurring events are supported) and the scipts calculate when the heater should be turned on depending on outside temperature. It easy for me to modify the user variables via web interface of the Domoticz but it's not easy for my wife... :D
So having a possibility to modify (selected) user variables via the Ticz would make modifying "leaving times" much easier.
Posted: Monday 30 May 2016 15:10
by hansworst
niki_lauda wrote: What about adding a possibility to modify user variables directly from the Ticz? I live in Finland and we're using electric engine heaters in cars when it's cold. I do have a switch which is controlled by the Domoticz via lua scripts (script_time_carheaterswitch.lua & script_device_carheaterswitchcompanion.lua). Time when leaving from home is set by the user variables (single event and recurring events are supported) and the scipts calculate when the heater should be turned on depending on outside temperature. It easy for me to modify the user variables via web interface of the Domoticz but it's not easy for my wife... :D
I'll have a look if I can find a nice mechanism to implement this. Doesn't seem to be so hard to do, It just needs a nice interface :)
Posted: Monday 30 May 2016 15:27
by hansworst
v1.9.0.0 should be released in the store by now :
Major changes :
  • Added : Camera Support. Within the Menu, you'll see a Webcam Icon in the bottom icon-bar. Clicking the icon currently opens up a listview of your webcams, with a single frame captured. You can enable/disable auto refresh and set the refreshrate between 100ms and 2000ms. Be careful of your battery consumption when using high refresh rates :). Pressing ESC, or Back button closes the list and disables the refresh of any camera's that were running. If you see the Ticz Logo, instead of your cam's contents, it means that no frame could be loaded for that cam. You can test if Domoticz is able to capture a single frame by going to :
    http(s)://<DOMOTICZ_IP>:<DOMOTICZ_PORT>/camsnapshot.jpg?idx=<CAMIDX>&t=<RANDOM_NUMBER>
    Note : CAMIDX is the IDX of the webcam, not of the device it is linked to.
    If it gives you back a JPG to download, it should work with Ticz, anything else it returns and Ticz won't be able to use it either :)
  • Added : Logitech / Squeezebox Remote Control + LMS Icon : Your LMS Player will show a second icond of a remote when in Wide View. Clicking the remote gives you a remote with basic functionality to control your LMS Player. Hitting ESC of Back button closes the remote. KODI Remote control will be implemented too... :)
  • Disabled : Text Marquee for Media Players. The implementation of letting the text scroll was sort of a hack and caused strange app crashes in some views. I've temporarily disabled it.
  • Lots of underwater changes to improve performance, and hopefully resolved some bugs here and there
Posted: Thursday 02 June 2016 9:50
by hansworst
v1.9.2.0 is currently being pushed to the Store
  • Support for Variables is added. You will find an icon like 'Aa' next to the Camera icon in the Menu, which will show your list of variables and their current value. You can update them with a new value, and a response will be given if the change was succesful or not. The LastUpdate Time will also be updated, so you can verify the change was succesful !
  • The variable type cannot be changed (i.e. change Integer to String). This should be done through Domoticz
  • Backup to OneDrive : I've enabled the option to backup Ticz settings to OneDrive. When you have Backup running under WP, this would mean that if you reset your phone or reinstall Ticz, it downloads the Settings from OneDrive, and you keep your configuration. I initially hesitated to enable this option, but I've not encountered or heard people talking about corrupted configs, rendering Ticz unusable :)
Let me know what you think !
Posted: Saturday 04 June 2016 9:10
by hansworst
v1.9.3.0 is currently available in the Store
  • Fix Device Icon/Button not to increase in size when Device is in Large View
  • Implemented KODI Remote Control
  • Fixed password prompt for protected devices to be potentially located underneath soft keyb
  • Added stats for camera's to indicate bandwidth consumption when streaming
Posted: Sunday 05 June 2016 13:28
by Kouseri
hansworst wrote:v1.9.2.0 is currently being pushed to the Store
Great work again and a thanks lot about adding user variables to the app! :D
One comment regarding to the usability of the Domoticz Variables list though. Could it be possible modify layout of the list so the name of the user variables are fully visible in portrait view? Now value box hides the names if the name of the user variable is too long.
User variables list
User variables list
In landscape view the name of the user variables are fully visible but Update button is hidden by Windows keys.
User variables in landscape view
By the way is it currently possible to see a version number of the app from the app itself? If not maybe it could make sense to add it for example to About Ticz... page?
Posted: Monday 06 June 2016 10:25
by hansworst
v2.0.1.0 is currently being pushed to the Store
  • Fixed : Variables : Name of the variable now spans the entire control
  • Fixed : Variables : Modified screen layout to take into consideration devices with on-screen software buttons
  • Fixed : About : Version number was already present, but may have fallen off the screen for devices with on-screen software buttons. Same fix as Variables
  • Feature : Screensaver added : In Settings/General you'll find a toggleswitch to enable/disable a screensaver for Ticz, which kicks in after x amount of seconds of idle time. This feature is only really useful if you use Ticz on a device that acts as a 'Control Panel' that is running Ticz 24/7. I'm currently finalizing my setup of a control panel with a RPi2 running Windows 10 IoT, and a screensaver modus can be useful for that.
Edit : MS tells me it can take a couple of days for this release to appear in the Store..so please be patient :)
V2.0.1.0 is in the Store :)
Posted: Monday 06 June 2016 20:59
by Derik
app getting greater....
Nice!!!!
My wish is still active :lol: :x
Posted: Saturday 23 July 2016 9:05
by modular
Hi first of all i really love the app! I only have one question.
When i put in my local (raspberry)IP and my Phone is connected to my wifi it all works flawless :D, but if put in my public ip is does not work when i'm at home connected to my home wifi. How can i make sure i do not have to change the ip when i come of leave my home?
Posted: Saturday 23 July 2016 10:38
by toreandre
Kouseri wrote: In landscape view the name of the user variables are fully visible but Update button is hidden by Windows keys.
IF the problem still is there you can hide the windows buttons by swiping from the buttom and up.
Posted: Saturday 23 July 2016 11:50
by Herman-H
I see a small difference with blinds between Domoticz and Ticz. Ticz didn't show the status of the blinds, named WC-Raam.
Posted: Monday 25 July 2016 16:30
by modular
Hi i can't edit my radiator settings. It works perfect on my laptop with the web interface of domoticz, but with twix i see it and it displays the right tempature(set in the web interface). But when i try to click on it to edit the tempature it does nothing.
https://www.robbshop.nl/danfoss-thermostaat-kraan-lc13
Posted: Monday 25 July 2016 22:02
by modular
I noticed a maby 'bug' my Fibaro Motion Sensor reports now 26,8, but the main screen of twix shows 27,1. The weird thing is when i open ' show device details' it shows the correct tempature under data. Is this a bug or is my configuration messed up?
Posted: Tuesday 26 July 2016 14:07
by hansworst
Herman-H wrote:I see a small difference with blinds between Domoticz and Ticz. Ticz didn't show the status of the blinds, named WC-Raam.
Hi Herman, in order for being able to have blinds show up as within Domoticz itself, you'll have to long-tap or right-click the device and select "Wide" view. You can do this when the room is in Dashboard or Resize View (Settings--> Room Configuration)
Posted: Tuesday 26 July 2016 14:09
by hansworst
Thanks for the tip. I hoped I'd solved the issue related to the Windows Soft buttons masking part of the "Update" button, but apparently it isn't yet. I'll have another go at it ! (I don't have a phone with soft-buttons so little hard to check :(
Posted: Tuesday 26 July 2016 14:11
by hansworst
modular wrote:Hi first of all i really love the app! I only have one question.
But does it work when you connect to your public IP from remote/4g ? I've heard such an issue before, but am unable to replicate it. I can only imagine it to be related somehow with NAT/Firewall/Guest WiFi settings on the router :(
Posted: Tuesday 26 July 2016 14:16
by hansworst
modular wrote:Hi i can't edit my radiator settings. It works perfect on my laptop with the web interface of domoticz, but with twix i see it and it displays the right tempature(set in the web interface). But when i try to click on it to edit the tempature it does nothing.
I only own a thermostat (Toon) that I can test, and am not sure how a radiator would popup (is it a Setpoint device ?). If it's a Setpoint device, it should allow to set the temperature when the device is in Wide View (In Resize or Dashboard View, you can right-click/long tap the device and select Wide).
If this doesn't work, please raise an issue on github, including the JSON details of your device : /json.htm?type=devices&rid=<IDX>
Posted: Tuesday 26 July 2016 14:49
by hansworst
ps to all : I assume everybody is running the latest 2.0.2 version which was released a few days ago. Includes a few bugfixes for Blinds Open/Close buttons not working properly and cams are shown more fullscreen than before. If not on the latest version, please update :)
Posted: Tuesday 26 July 2016 21:58
by niki_lauda
hansworst wrote:ps to all : I assume everybody is running the latest 2.0.2 version which was released a few days ago. Includes a few bugfixes for Blinds Open/Close buttons not working properly and cams are shown more fullscreen than before. If not on the latest version, please update :)
Check.
