Page 2 of 5
Re: RFlink might support Mi-light and other protocols soon :)
Posted: Thursday 09 June 2016 16:42
by Stuntteam
Yes, fully..
Posted: Thursday 09 June 2016 19:59
by Larsja
What exactly is "2.4 Ghz, NRF24L01 with Milight wiring required"? What do i need to do with this?
http://www.ebay.com/itm/310651702557
Posted: Thursday 09 June 2016 20:31
by deennoo
You need to follow this wiring instruction :
http://www.nemcon.nl/blog2/wiring
This device works (got one), I use a 5v to 3.3v converter to power it from my méga + 10uf condo.
Actually rflink doesn't use the fully power of this device, maybe next time
Posted: Thursday 09 June 2016 21:21
by burton666
I don't understand, how do I pair/ control a mi-light bulb using only the domoticz gui? I have wired the nrf radio as the instructions .
Posted: Thursday 09 June 2016 21:31
by Stuntteam
Without remote control:
Go to:
http://www.nemcon.nl/blog2/faq
and scroll down to
"how to pair Milight bulbs without the original Milight remote control in Domoticz?"
If you have a remote control:
you can pair bulbs as usual.. make sure auto accept new devices is turned on for some time and press the ON button for the zone you want to use on the remote control..RFLink will detect the remote control signal and tell Domoticz about it.. it will then show up in your device list.
Posted: Friday 10 June 2016 6:05
by burton666
I only get "problems creating sensor" every time I try the commands.
Posted: Friday 10 June 2016 7:23
by deennoo
Please enable allow new device on your domoticz parameters
Which Domoticz version have you ?
Posted: Friday 10 June 2016 9:07
by burton666
I am using the latest beta of domoticz. I have checked the options to always allow all devices in the settings.
I have tried two different nrf radios and have checked the wireing several times.
Posted: Friday 10 June 2016 9:34
by Stuntteam
Check the hardware tab.. is firmware listed as version 42?
Posted: Friday 10 June 2016 9:38
by burton666
yes it is
Posted: Friday 10 June 2016 9:40
by burton666
And I have my mi-light just a 1m away from the RF-link gateway and I have unpaired the lamp in advance using the android app
Posted: Friday 10 June 2016 10:48
by Stuntteam
Range for sure is not an issue.
Check your PM..
Posted: Friday 10 June 2016 18:22
by Larsja
deennoo wrote:You need to follow this wiring instruction :
Ah, thanks
I have the RFLink shield from Nodo-Shop.nl so im guessing then its just plug and play, gotta see if i find some drawings.
Posted: Friday 10 June 2016 18:32
by deennoo
Milight wiring is different from the nodo shield.
Posted: Friday 10 June 2016 18:46
by Larsja
Blast!
Posted: Friday 10 June 2016 19:09
by Stuntteam
Also, make sure you enable miglight after flasing the firmware..
Posted: Friday 10 June 2016 20:00
by burton666
Where? in domoticz?
Re: RE: Re: RFlink might support Mi-light and other protocols soon :)
Posted: Friday 10 June 2016 20:28
by deennoo
burton666 wrote:Where? in domoticz?
On RFLink loader who come with the R42 fw
Posted: Friday 10 June 2016 20:46
by burton666
I tried flashing again using the loader from r42. I see the buttons to turn ON/OFF nodo + milight but they are greyed out before/during/ and after the flashing, I can't press anything other than "upload firmware"
Posted: Friday 10 June 2016 21:41
by deennoo
Enable serail on rflink loader (i promise you will not create a black hole by try to press some button by your own)
